- H3C WSG1812X-PWR Wireless Integrated Services Gateway Installation Guide-5W104
- 01-Preparing for installation
- 02-Installing the device
- 03-Log in to the device
- 04-Hardware management and maintenance
- 05-Troubleshooting
- 06-Appendix A Chassis views and technical specifications
- 07-Appendix B LEDs
- 08-Appendix C Optional transceiver modules
| 00-Preface | 99.18 KB |
Preface
This installation guide describes the installation procedures for the WSG1812X-PWR wireless integrated services gateway, including preparing for installation, installing the wireless integrated services gateway, and accessing the wireless integrated services gateway.
· Audience
Audience
· Network planners.
· Network administrators working with the WSG1812X-PWR wireless integrated services gateway.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
Your comments or suggestions would be highly appreciated.
