- H3C WSG1812X-PWR Wireless Integrated Services Gateway Installation Guide-5W104
- 01-Preparing for installation
- 02-Installing the device
- 03-Log in to the device
- 04-Hardware management and maintenance
- 05-Troubleshooting
- 06-Appendix A Chassis views and technical specifications
- 07-Appendix B LEDs
- 08-Appendix C Optional transceiver modules
| 06-Appendix A Chassis views and technical specifications | 124.62 KB |
1 Appendix A Chassis views and technical specifications
Chassis views
(1) Reset button (RESET) |
(2) USB port |
(3) Console port |
(4) 100/1000BASE-T autosensing Ethernet ports WAN 1 and WAN 2 |
(5) 100/1000BASE-T-PoE+ autosensing Ethernet ports LAN 3 to LAN 14 |
(6) 10GBASE-R-SFP+ ports |
Figure1-2 Rear view
(1) Grounding screw |
(2) AC-input power receptacle |
Technical specifications
Table1-1 Technical specifications
Item |
Specification |
Console port |
One, 9600 bps (default) to 115200 bps |
USB port |
USB 2.0, used for data transfer |
GE port |
· 2 × 100/1000BASE-T autosensing Ethernet copper ports · 12 × 100/1000BASE-T-PoE+ autosensing Ethernet copper ports: Downlink interfaces of the device that can provide PoE+ power. Each can provide a maximum PoE+ power of 30 W. |
SFP+ port |
2 × 10GBASE-R-SFP+ ports |
· To restore the device to factory settings, press and hold the button for more than 5 seconds. · To reset the device, press and hold the button for more than 15 ms. |
Memory |
2GB DDR4 |
Storage media |
4GB eMMC memory |
Dimensions (H × W × D) (excluding the rubber feet and mounting brackets) |
43.6 × 440 × 220 mm (1.72 × 17.32 × 8.66 in) |
AC power supply |
Rated voltage range: 100 to 240 VAC @ 50/60 Hz |
System power consumption |
11.8W to 173 W (including 150W PoE output) |
Weight |
2.9 kg (6.39 lb) |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Operating humidity |
5% RH to 95% RH |
