| 03-Appendix B LEDs and ports | 130.25 KB |
1 Appendix B LEDs and ports
LEDs
Table 1-1 LED descriptions
LED status |
Off |
No power is present or the LED has been turned off. |
Yellow |
Steady on |
The AP is initializing, or an initialization exception has occurred. |
Flashing (twice per second) |
The Ethernet interfaces are down and no mesh links are established. |
Green |
Steady on |
The AP is in standby state and has connected to the Cloudnet platform, but does not have any associated clients. |
Flashing (once per second) |
The AP has connected to the Cloudnet platform and has associated clients. |
The AP is upgrading the image. |
Blue |
Steady on |
The AP is in standby state, but has not connected to the Cloudnet platform and does not have associated clients. |
The AP has not connected to the Cloudnet platform, but has associated clients. |
Ports
Figure 1-1 Ports on the AP
(1) 10/100/1000M Ethernet port |
(2) Power port |
(3) Grounding screw |
Table 1-2 Port descriptions
Port |
Standards and protocols |
GE1/PoE |
· IEEE802.3 · IEEE802.3ab · IEEE802.3i · IEEE802.3u · IEEE802.3af · IEEE802.3at |
10/100/1000M Ethernet copper port, which can receives PoE power. The port is represented by interface GE1/0/1 in the MAP file and gigabitethernet 1 for configuration on the AC. |
DC48V |
N/A |
Power port, used for receiving +48V power from a local power source. |
