H3C UAP672X Access Point Installation Guide-6W100
HomeSupportWirelessUAP672X Access PointInstall & UpgradeInstallation GuidesH3C UAP672X Access Point Installation Guide-6W100
02-Appendix A AP view and technical specifications
1 Appendix A  AP view and technical specifications
AP view
Figure1-1 AP view
Technical specifications
Table1-1 Technical specifications
Item
Specification
Protocol
IEEE802.11a/b/g/n/ac/ax
Dimensions (H × W × D)
250 × 101 × 110 mm (9.84 × 3.98 × 4.33 in)
Weight
1.07 kg (2.36 lb)
Antenna
Built-in omnidirectional antenna:
·     2.4 GHz: 3 dBi gain
·     5.1 GHz: 5 dBi gain
·     5.8 GHz: 5 dBi gain
System power consumption
14.4 W
