06-HH3C-BGP-VPN-MIB | 202.56 KB |
hh3cBgpPeerRouteNumThresholdExceed
hh3cBgpPeerRouteNumThresholdCleard
hh3cBgpVrfRouteNumReachThreshold
hh3cBgpVrfRouteNumReachThresholdClear
hh3cBgpPeerAFRouteThresholdExceed
hh3cBgpPeerAFRouteThresholdClear
hh3cBgpVpnRpkiSessionRoaExceed
hh3cBgpVpnRpkiSessionRoaExceedClear
HH3C-BGP-VPN-MIB
About this MIB
This document contains route and packet information about peers in the address families supported by BGP (MBGP or MP-BGP).
MIB file name
hh3c-bgp-vpn.mib
Notifications
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.202.4.0.1 |
The number of routes received from a peer or peer group has exceeded the notification threshold. |
Recovery |
Warning |
ON |
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
This notification is generated when the number of routes received from a peer or peer group has reached or exceeded the notification threshold.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp or snmp-agent trap enable bgp peer-routenum-threshold-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable bgp or undo snmp-agent trap enable bgp peer-routenum-threshold-exceed command.
Object
OID (object name) |
Index |
Type |
Value range |
(1.3.6.1.4.1.25506.2.202.1.1.4.1.1 (hh3cBgpPeerConfigRouteLimitNum) |
Limit on the number of routes that can be received from a peer or peer group. |
No |
Unsigned32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.202.1.1.4.1.2 (hh3cBgpPeerConfigRouteLimitThreshold) |
Threshold value for the device to generate an alarm notification. The device generates an alarm notification when the ratio of the number of received routes to the limit on the number of received routes exceeds the threshold. |
No |
Unsigned32 |
Unsigned32{(0,100)} |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.202.4.0.2 |
The number of routes received from a peer or peer group has dropped below the notification threshold. |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
This notification is generated when the number of routes received from a peer or peer group has dropped below the notification threshold.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp or snmp-agent trap enable bgp peer-routenum-threshold-clear command.
OFF
CLI: Use the undo snmp-agent trap enable bgp or undo snmp-agent trap enable bgp peer-routenum-threshold-clear command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Unsigned32 |
No |
Unsigned32 |
Recommended action
hh3cBgpPeerRouteExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.202.4.0.3 |
The number of routes received from a peer or peer group has exceeded the limit. |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
This notification is generated when the number of routes received from a peer or peer group has exceeded the limit.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp or snmp-agent trap enable bgp peer-route-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable bgp or undo snmp-agent trap enable bgp peer-route-exceed command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Unsigned32 |
No |
Unsigned32 |
Recommended action
hh3cBgpPeerRouteExceedClear
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.202.4.0.4 |
The number of routes received from a peer or peer group has dropped below the limit. |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
This notification is generated when the number of routes received from a peer or peer group has dropped below the limit.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp or snmp-agent trap enable bgp peer-route-exceedclear command.
OFF
CLI: Use the undo snmp-agent trap enable bgp or undo snmp-agent trap enable bgp peer-route-exceedclear command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Unsigned32 |
No |
Unsigned32 |
Recommended action
hh3cBgpPeerEstablished
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.202.4.0.5 |
BGP FSM enters Established state |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
This notification is generated when BGP FSM enters Established state.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp or snmp-agent trap enable bgp peer-established command.
OFF
CLI: Use the undo snmp-agent trap enable bgp or undo snmp-agent trap enable bgp peer-established command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.202.1.1.2.1.8 (hh3cBgpPeerLastError) |
Error code and subcode for the most recent peer connection error. |
No |
DisplayString |
OCTET STRING (2) |
1.3.6.1.4.1.25506.2.202.1.1.2.1.4 (hh3cBgpPeerState) |
Peer state. |
No |
INTEGER |
idle(1), connect(2), active(3), opensent(4), openconfirm(5), established(6) |
Recommended action
hh3cBgpPeerBackwardTransition
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.202.4.0.6 |
BGP FSM changes from Established state to another state. |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
This notification is generated when BGP FSM changes from Established state to another state.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp or snmp-agent trap enable bgp peer-backward-transition command.
OFF
CLI: Use the undo snmp-agent trap enable bgp or undo snmp-agent trap enable peer-backward-transition command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
DisplayString |
OCTET STRING (2) |
Peer state. |
No |
INTEGER |
1.3.6.1.4.1.25506.2.202.1.1.2.1.9 (hh3cBgpPeerUnAvaiReason) |
Reason why the peer went down. |
No |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.202.4.0.7 |
The number of VPN routes in the BGP routing table has exceeded the limit. |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
This notification is generated when the number of VPN routes in the BGP routing table has exceeded the limit.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp or snmp-agent trap enable bgp vrfroutenum-reachthreshold command.
OFF
CLI: Use the undo snmp-agent trap enable bgp or undo snmp-agent trap enable bgp vrfroutenum-reachthreshold command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.202.1.2.1.1.1 (hh3cBgpVpnRouteType) |
Route type. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.202.1.2.1.1.2 (hh3cBgpVpnInstName) |
VPN instance name. |
No |
OCTET STRING |
0..31 |
1.3.6.1.4.1.25506.2.202.1.2.1.1.3 (hh3cBgpVpnAddressFamily) |
Address family. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.202.1.2.1.1.4 (hh3cBgpVpnCurrRouteNum) |
Number of VPN routes in the BGP routing table. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.202.1.2.1.1.5 (hh3cBgpVpnThresholdValue) |
Threshold value for the device to generate an alarm notification. The device generates an alarm notification when the ratio of the number of VPN routes to the maximum number of VPN routes exceeds the threshold. |
No |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.202.4.0.8 |
The number of VPN routes in the BGP routing table has dropped below the limit. |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
This notification is generated when the number of VPN routes in the BGP routing table has dropped below the limit.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp or snmp-agent trap enable bgp vrfroutenum-reachthreshold-clear command.
OFF
CLI: Use the undo snmp-agent trap enable bgp or undo snmp-agent trap enable bgp vrfroutenum-reachthreshold-clear command.
Object
OID (object name) |
Index |
Type |
Value range |
Route type. |
No |
Unsigned32 |
No |
OCTET STRING |
0..31 |
Address family. |
No |
Unsigned32 |
No |
Unsigned32 |
No |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.202.4.0.9 |
The number of routes received from a peer or peer group in an address family has exceeded the notification threshold. |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
This notification is generated when the number of routes received from a peer or peer group in an address family has exceeded the notification threshold.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp or snmp-agent trap enable bgp peer-addrfamily-routethreshold-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable bgp or undo snmp-agent trap enable bgp peer-addrfamily-routethreshold-exceed command.
Object
OID (object name) |
Index |
Type |
Value range |
Address family. |
No |
Unsigned32 |
No |
Unsigned32 |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.202.2.1.1.1.1 (hh3cBgpInstanceName) |
BGP process name. |
OCTET STRING |
{(1,31)} |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.202.4.0.10 |
The number of routes received from a peer or peer group in an address family has dropped below the notification threshold. |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
This notification is generated when the number of routes received from a peer or peer group in an address family has dropped below the notification threshold.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp or snmp-agent trap enable bgp peer-addrfamily-routethreshold-clear command.
OFF
CLI: Use the undo snmp-agent trap enable bgp or undo snmp-agent trap enable bgp peer-addrfamily-routethreshold-clear command.
Object
OID (object name) |
Index |
Type |
Value range |
Address family. |
No |
Unsigned32 |
No |
Unsigned32 |
No |
Unsigned32 |
BGP process name. |
OCTET STRING |
{(1,31)} |
Recommended action
hh3cBgpPeerAFRouteExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.202.4.0.11 |
The number of routes received from a peer or peer group in an address family has exceeded the limit. |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
This notification is generated when the number of routes received from a peer or peer group in an address family has exceeded the limit.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp or snmp-agent trap enable bgp peer-addrfamily-routeexceed command.
OFF
CLI: Use the undo snmp-agent trap enable bgp or undo snmp-agent trap enable bgp peer-addrfamily-routeexceed command.
Object
OID (object name) |
Index |
Type |
Value range |
Address family. |
No |
Unsigned32 |
No |
Unsigned32 |
BGP process name. |
OCTET STRING |
{(1,31)} |
Recommended action
hh3cBgpPeerAFRouteExceedClear
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.202.4.0.12 |
The number of routes received from a peer or peer group in an address family has dropped below the limit. |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
This notification is generated when the number of routes received from a peer or peer group in an address family has dropped below the limit.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp or snmp-agent trap enable bgp peer-addrfamily-routeexceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable bgp or undo snmp-agent trap enable bgp peer-addrfamily-routeexceed-clear command.
Object
OID (object name) |
Index |
Type |
Value range |
Address family. |
No |
Unsigned32 |
No |
Unsigned32 |
BGP process name. |
OCTET STRING |
{(1,31)} |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.202.3.2.0.1 |
The number of RPKI sessions has exceeded the limit. |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
This notification is generated when the number of RPKI sessions has exceeded the limit.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp or snmp-agent trap enable bgp peer-rpkisession-roaexceed command.
OFF
CLI: Use the undo snmp-agent trap enable bgp or undo snmp-agent trap enable bgp peer-rpkisession-roaexceed command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.202.3.1.4 (hh3cBgpVpnRpkiSessionRoaLimitNum) |
Limit on the number of RPKI sessions that can be established. |
No |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.202.3.2.0.2 (hh3cBgpVpnRpkiSessionRoaExceedClear) |
The number of RPKI sessions has dropped below the limit. |
Recovery |
Informational |
ON |
System impact
OID
Event
Severity
Default status
Recovery
Informational
ON
This notification is generated when the number of RPKI sessions has dropped below the limit.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp or snmp-agent trap enable bgp peer-rpkisession-roaexceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable bgp or undo snmp-agent trap enable bgp peer-rpkisession-roaexceed-clear command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Unsigned32 |
Recommended action
