05-BGP4-MIB | 97.23 KB |
BGP4-MIB
About this MIB
This document contains MIB and Trap features compliant with RFC 4273.
MIB file name
rfc4273-bgp4.mib
Notifications
bgpEstablishedNotification
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.15.0.1 |
A peer enters established state. |
Recovery |
Warning |
ON |
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.15.0.1
Recovery
Warning
ON
A notification sent when BGP FSM enters established state.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp command or the snmp-agent trap enable bgp peer-established command.
OFF
CLI: Use the undo snmp-agent trap enable bgp command or the undo snmp-agent trap enable bgp peer-established command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.15.3.1.7 (bgpPeerRemoteAddr) |
Remote IP address of the peer connection. |
No |
IpAddress |
Standard MIB values. |
1.3.6.1.2.1.15.3.1.14 (bgpPeerLastError) |
Error code and subcode for the most recent peer connection error. |
No |
DisplayString |
OCTET STRING (2) |
1.3.6.1.2.1.15.3.1.2 (bgpPeerState) |
Peer connection state. |
No |
INTEGER |
idle(1), connect(2), active(3), opensent(4), openconfirm(5), established(6) |
Recommended action
No action is required.
bgpBackwardTransNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.15.0.2 |
A peer enters a lower numbered state. |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.15.0.2
Recovery
Warning
ON
A notification sent when BGP FSM enters a lower numbered state.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable bgp command or the snmp-agent trap enable bgp peer-backward-transition command.
OFF
CLI: Use the undo snmp-agent trap enable bgp command or the undo snmp-agent trap enable bgp peer-backward-transition command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
IpAddress |
OCTET STRING (4) |
No |
DisplayString |
OCTET STRING (2) |
No |
INTEGER |
Recommended action
To resolve the issue:
1.Verify that the notification is triggered by link state changes.
2.If the issue persists, contact H3C Support.
bgpEstablished
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.15.7.1 |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.15.7.1
Recovery
Warning
ON
【System impact】
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
No |
DisplayString |
OCTET STRING (2) |
No |
INTEGER |
Recommended action
bgpBackwardTransition
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.15.7.2 |
Error |
Warning |
ON |
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.15.7.2
Error
Warning
ON
【System impact】
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
No |
DisplayString |
OCTET STRING (2) |
No |
INTEGER |
Recommended action
To resolve this issue:
