04-OSPFV3-MIB | 182.84 KB |
ospfv3NssaTranslatorStatusChange
ospfv3NbrRestartHelperStatusChange
ospfv3VirtNbrRestartHelperStatusChange
OSPFV3-MIB
About this MIB
Use this MIB to obtain OSPFv3 information.
MIB file name
rfc5643-ospfv3.mib
Notifications
ospfv3VirtIfStateChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.191.0.1 |
Virtual interface state changes. |
Informational |
Warning |
ON |
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.1
Informational
Warning
ON
A notification sent when the state of a virtual interface changes to Point-to-Point or changes from Point-to-Point to another state. To reduce unnecessary notifications caused by virtual interface up events, no virtual interface state change notification will be sent within 2 times the dead interval since the virtual interface state changes to a value other than DOWN.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-state-change command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.191.1.1.1 (ospfv3RouterId) |
Unique identifier of a router in an AS. |
No |
Ospfv3RouterIdTC |
Unsigned32 (1..'FFFFFFFF'h) |
1.3.6.1.2.1.191.1.8.1.9 (ospfv3VirtIfState) |
Virtual interface state. |
No |
INTEGER |
down(1), pointToPoint(4) |
Recommended action
No action is required.
ospfv3NbrStateChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.2 |
Neighbor state changes. |
Informational |
Warning |
ON |
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.2
Informational
Warning
ON
For DR and BDR, this notification is sent when the state of a neighbor changes to FULL or changes from FULL to another state. For DRother, this notification is sent when the state of a neighbor changes to 2-way or changes from 2-way to another state.
To reduce unnecessary notifications caused by interface up events, no neighbor state change notification will be sent within 2 times the dead interval since the interface state changes to a value other than DOWN.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 neighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 neighbor-state-change command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.9.1.8 (ospfv3NbrState) |
Neighbor state. |
No |
INTEGER |
down(1), attempt(2), init(3), twoWay(4), exchangeStart(5), exchange(6), loading(7), full(8) |
Recommended action
Check whether the interface state has changed.
ospfv3VirtNbrStateChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.3 |
Virtual neighbor state changes. |
Informational |
Warning |
ON |
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.3
Informational
Warning
ON
A notification sent when the state of a virtual neighbor changes to FULL or changes from FULL to another state. To reduce unnecessary notifications caused by virtual interface up events, no virtual neighbor state change notification will be sent within 2 times the dead interval since the virtual interface state changes to a value other than DOWN.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtneighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtneighbor-state-change command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.11.1.8 (ospfv3VirtNbrState) |
Virtual neighbor state. |
No |
INTEGER |
Recommended action
ospfv3IfConfigError
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.4 |
Interface configuration error. |
Informational |
Warning |
ON |
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.4
Informational
Warning
ON
A notification sent when a non-virtual interface receives a packet from another router with mismatched configuration.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-cfg-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-cfg-error command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.7.1.12 (ospfv3IfState) |
Interface state. |
No |
INTEGER |
down(1), loopback(2), waiting(3), pointToPoint(4), designatedRouter(5), backupDesignatedRouter(6), otherDesignatedRouter(7), standby(8) |
1.3.6.1.2.1.191.1.14.3 (ospfv3PacketSrc) |
IPv6 packet that cannot be identified by a neighbor. |
No |
InetAddressIPv6 |
OCTET STRING (16) |
1.3.6.1.2.1.191.1.14.1 (ospfv3ConfigErrorType) |
OSPFv3 configuration error type. |
No |
INTEGER |
badVersion(1), areaMismatch(2), unknownNbmaNbr(3), unknownVirtualNbr(4), helloIntervalMismatch(5), deadIntervalMismatch(6), optionMismatch(7), mtuMismatch(8), duplicateRouterId(9), noError(10) |
1.3.6.1.2.1.191.1.14.2 (ospfv3PacketType) |
OSPFv3 data packet type. |
No |
INTEGER |
hello(1), dbDescript(2), lsReq(3), lsUpdate(4), lsAck(5), nullPacket(6) |
Recommended action
Verify that the parameters configured on the interface are consistent with parameters in the hello packets.
ospfv3VirtIfConfigError
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.5 |
Virtual interface configuration error. |
Error |
Warning |
ON |
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.5
Error
Warning
ON
A notification sent when a virtual interface receives a packet from another router with mismatched configuration.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-cfg-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-cfg-error command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Ospfv3RouterIdTC |
No |
INTEGER |
No |
INTEGER |
No |
INTEGER |
Recommended action
ospfv3IfRxBadPacket
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.6 |
A non-virtual interface receives an error packet. |
Error |
Warning |
ON |
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.6
Error
Warning
ON
A notification sent when a non-virtual interface receives an OSPFv3 packet that cannot be parsed.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-bad-pkt command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-bad-pkt command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Ospfv3RouterIdTC |
Interface state. |
No |
INTEGER |
IPv6 packet that cannot be identified by the neighbor. |
No |
InetAddressIPv6 |
OCTET STRING (16) |
No |
INTEGER |
Recommended action
ospfv3VirtIfRxBadPacket
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.7 |
A virtual interface receives an error packet. |
Informational |
Warning |
ON |
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.7
Informational
Warning
ON
A notification sent when a virtual interface receives an OSPFv3 packet that cannot be parsed.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-bad-pkt command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-bad-pkt command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Ospfv3RouterIdTC |
No |
INTEGER |
No |
INTEGER |
Recommended action
ospfv3IfStateChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.10 |
Interface state changes. |
Error |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when the state of a non-virtual interface changes from DR to Down or changes to the Point-to-Point, DR, BDR, or Drother state.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-state-change command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Ospfv3RouterIdTC |
Interface state. |
No |
INTEGER |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.11 |
A router's ability to translate type-7 LSAs into type-5 LSAs changes. |
Error |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when a router's ability to translate type-7 LSAs into type-5 LSAs changes.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 nssatranslator-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 nssatranslator-status-change command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.2.1.12 (ospfv3AreaNssaTranslatorState) |
Method for the NSSA ABR to become capable of translating Type-7 LSAs into Type-5 LSAs. |
No |
INTEGER |
enabled(1), elected(2), disabled(3) |
Recommended action
ospfv3RestartStatusChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.12 |
GR restarter state changes. |
Error |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when the GR restarter state changes.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 grrestarter-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 grrestarter-status-change command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.1.18 (ospfv3RestartStatus) |
GR restarter state. |
No |
INTEGER |
notRestarting(1), plannedRestart(2), unplannedRestart(3) |
1.3.6.1.2.1.191.1.1.16 (ospfv3RestartInterval) |
GR timeout interval. |
No |
Ospfv3UpToRefreshIntervalTC |
Unsigned32 (40..1800) |
1.3.6.1.2.1.191.1.1.20 (ospfv3RestartExitReason) |
Reason why the device exited GR restarter state. |
No |
INTEGER |
none(1), inProgress(2), completed(3), timedOut(4), topologyChanged(5) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.13 |
The GR helper state of a neighbor changes. |
Error |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when a neighbor enters or exits GR helper state.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 grhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 grhelper-status-change command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.9.1.13 (ospfv3NbrRestartHelperStatus) |
GR helper state of the neighbor. |
No |
INTEGER |
notHelping(1), helping(2) |
1.3.6.1.2.1.191.1.9.1.14 (ospfv3NbrRestartHelperAge) |
GR helper aging timer. |
No |
Unsigned32 (1..1800) |
1.3.6.1.2.1.191.1.9.1.15 (ospfv3NbrRestartHelperExitReason) |
Reason why the neighbor exited GR helper state. |
No |
INTEGER |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.14 |
The GR helper state of a virtual neighbor changes. |
Error |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when a virtual neighbor enters or exits GR helper state.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtgrhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtgrhelper-status-change command.
Object
OID (object name) |
Index |
Type |
Value range |
No |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.11.1.13 (ospfv3VirtNbrRestartHelperStatus) |
GR helper state of the virtual neighbor. |
No |
INTEGER |
1.3.6.1.2.1.191.1.11.1.14 (ospfv3VirtNbrRestartHelperAge) |
Remaining time of the GR interval when the router is acting as a GR helper for the virtual neighbor. |
No |
1.3.6.1.2.1.191.1.11.1.15 (ospfv3VirtNbrRestartHelperExitReason) |
Reason why the virtual neighbor exited GR helper state. |
No |
INTEGER |
Recommended action
