06-Layer 3 - IP Routing
HomeSupportSwitchesS12500R SeriesDiagnose & MaintainAlarms ReferencesH3C S12500R Switch Router Series Alarms References(R52xx)-6W10006-Layer 3 - IP Routing
02-ISIS-MIB
02-ISIS-MIB 250.52 KB
ISIS-MIB
About this MIB
ISIS-MIB is a standard MIB implemented based on RFC4444. Use this MIB to define MIB variables on managed devices according to associated IS-IS configuration at the CLI.
MIB file name
rfc4444-isis.mib
Notifications
isisDatabaseOverload
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.138.0.1
LSDB overload state changes.
Informational
Warning
ON
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.1
Informational
Warning
ON
A notification sent when the system enters or exits the overload status. The number of times for generating and clearing the notifications is recorded in isisSysStatLSPDbaseOloads.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis lsdboverload-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable isis lsdboverload-state-change command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.138.1.10.1.1 (isisNotificationSysLevelIndex)
IS level index.
No
IsisLevel
level1(1), level2(2), level1and2(3)
1.3.6.1.2.1.138.1.2.1.1.4 (isisSysLevelState)
Overload state of the IS level.
No
IsisLevelState
off (1), on (2), waiting (3), overloaded(4)
Recommended action
No action is required.
isisManualAddressDrops
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.2
This notification is generated for invalid area addresses.
Error
Warning
ON
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.2
Error
Warning
ON
A notification sent when an assigned address is ignored during route calculation. The value of the isisNotificationAreaAddress variable represents the ignored area address.
The number of times for generating the notifications is recorded in isisSysStatManAddrDropFromAreas.
The agent must throttle the generation of consecutive isisManualAddressDrops notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis manual-address-drop command.
OFF
CLI: Use the undo snmp-agent trap enable isis manual-address-drop command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.138.1.10.1.15 (isisNotificationAreaAddress)
Manually configured area addresses that have been dropped.
No
IsisOSINSAddress
OCTET STRING (0..20)
Recommended action
To resolve the issue:
1.Reduce the number of invalid or unused area addresses.
2.If the issue persists, contact H3C Support.
isisCorruptedLSPDetected
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.3
LSP errors.
Informational
Warning
ON
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.3
LSP errors.
Informational
Warning
ON
A notification sent when an LSP stored in the memory is damaged. The number of times for generating the notifications is recorded in isisSysCorrLSPs.
The system forwards the LSP ID. Although the ID is defined by the system, an error might error on the ID.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis lsp-corrupt command.
OFF
CLI: Use the undo snmp-agent trap enable isis lsp-corrupt command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
1.3.6.1.2.1.138.1.10.1.3 (isisPduLspId)
String that uniquely identifies a link state PDU.
No
IsisLinkStatePDUID
OCTET STRING (8)
Recommended action
isisAttemptToExceedMaxSequence
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.4
Attempts to exceed the maximum LSP sequence number
Informational
Warning
ON
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.4
Informational
Warning
ON
When an LSP sequence number flip occurs, the system clears and then waits for regeneration of this notification. This notification provides a description on the event. The event does not frequently occur, and the system sends a notification every time the event occurs.
The first six bytes of the LSP ID contain the system ID, and the remaining two bytes contain valid information.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis max-seq-exceeded command.
OFF
CLI: Use the undo snmp-agent trap enable isis max-seq-exceeded command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
No
IsisLinkStatePDUID
OCTET STRING (8)
Recommended action
isisIDLenMismatch
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.5
System ID length mismatches.
Error
Warning
ON
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.5
Error
Warning
ON
A notification sent when we receive a PDU with a different value for the system ID length. This notification includes the index of the link that received the PDU and the header of the packet, which may help a network manager identify the source of the confusion.
The agent must throttle the generation of consecutive isisIDLenMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis id-length-mismatch command.
OFF
CLI: Use the undo snmp-agent trap enable isis id-length-mismatch command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
1.3.6.1.2.1.138.1.10.1.5 (isisPduFieldLen)
System ID length in the received PDU.
No
IsisUnsigned8TC
Unsigned32 (0..255)
1.3.6.1.2.1.138.1.10.1.2 (isisNotificationCircIfIndex)
Interface index.
No
Unsigned32
Unsigned32(1..2147483647)
1.3.6.1.2.1.138.1.10.1.4 (isisPduFragment)
First 64 bytes in the PDU that triggers the notification.
No
IsisPDUHeader
OCTET STRING (0..64)
Recommended action
isisMaxAreaAddressesMismatch
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.6
Maximum area address mismatches.
Error
Warning
ON
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.6
Error
Warning
ON
A notification sent when we receive a PDU with a different value for the isisMaxAreaAddressesMismatch. This notification includes the header of the packet, which may help a network manager identify the source of the confusion.
The agent must throttle the generation of consecutive isisMaxAreaAddressesMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis maxarea-mismatch command.
OFF
CLI: Use the undo snmp-agent trap enable isis maxarea-mismatch command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
1.3.6.1.2.1.138.1.10.1.6 (isisPduMaxAreaAddress)
Maximum address in the received PDU.
No
IsisUnsigned8TC
Unsigned32 (0..255)
Interface index.
No
Unsigned32
No
IsisPDUHeader
Recommended action
isisOwnLSPPurge
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.7
Attempts to remove the local LSP.
Informational
Warning
ON
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.7
Informational
Warning
ON
A notification sent when we receive a PDU with the local system ID and a lifetime value of 0. This notification includes the link index and router ID, which may help a network manager identify the source of the confusion.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis own-lsp-purge command.
OFF
CLI: Use the undo snmp-agent trap enable isis own-lsp-purge command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
Interface index.
No
Unsigned32
No
IsisLinkStatePDUID
OCTET STRING (8)
Recommended action
isisSequenceNumberSkip
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.8
LSP sequence number duplications.
Informational
Warning
ON
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.8
Informational
Warning
ON
When we receive a PDU with the local system ID and different content, the system might redeploy the LSP by using a greater sequence number. A notification is sent when the sequence number increases by a value greater than 1. When two ISs has the same system ID, a large number of such notifications will be generated.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis skip-sequence-number command.
OFF
CLI: Use the undo snmp-agent trap enable isis skip-sequence-number command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
Interface index.
No
Unsigned32
No
IsisLinkStatePDUID
OCTET STRING (8)
Recommended action
isisAuthenticationTypeFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.9
Authentication type errors.
Error
Warning
ON
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.9
Error
Warning
ON
A notification sent when we receive a PDU with an error authentication type field. This notification includes the header of the packet, which may help a network manager identify the source of the confusion.
The agent must throttle the generation of consecutive isisAuthenticationTypeFailure notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis authentication-type command.
OFF
CLI: Use the undo snmp-agent trap enable isis authentication-type command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
Interface index.
No
Unsigned32
No
IsisPDUHeader
Recommended action
1.Modify configuration on the two ends so that they have matching authentication type.
isisAuthenticationFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.10
Authentication failures.
Error
Warning
ON
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when we receive a PDU with incorrect authentication information field. This notification includes the header of the packet, which may help a network manager identify the source of the confusion.
The agent must throttle the generation of consecutive isisAuthenticationFailure notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis authentication command.
OFF
CLI: Use the undo snmp-agent trap enable isis authentication command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
Interface index.
No
Unsigned32
No
IsisPDUHeader
Recommended action
1.Modify configuration on the two ends so that they have matching authentication information.
isisVersionSkew
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.11
Hello packet version mismatches.
Error
Warning
ON
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when we receive a hello packet from an IS running a different protocol version. This notification includes the header of the packet, which may help a network manager identify the source of the confusion.
The agent must throttle the generation of consecutive isisVersionSkew notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis version-skew command.
OFF
CLI: Use the undo snmp-agent trap enable isis version-skew command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
Interface index.
No
Unsigned32
1.3.6.1.2.1.138.1.10.1.7 (isisPduProtocolVersion)
Protocol version in the received PDU.
No
IsisUnsigned8TC
Unsigned32 (0..255)
No
IsisPDUHeader
Recommended action
isisAreaMismatch
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.12
Area address mismatches.
Error
Warning
ON
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when we receive a hello packet from an IS containing no matching area addresses. This notification includes the header of the packet, which may help a network manager identify the source of the confusion.
The agent must throttle the generation of consecutive isisAreaMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis area-mismatch command.
OFF
CLI: Use the undo snmp-agent trap enable isis area-mismatch command.
Object
OID (object name)
Index
Value range
Interface index.
No
Unsigned32
No
IsisPDUHeader
Recommended action
1.Modify configuration on the two ends so that they have at least one matching area address.
isisRejectedAdjacency
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.13
Adjacency creation failures.
Error
Warning
ON
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when we receive a hello packet from an IS but no adjacency has been established with it.
The agent must throttle the generation of consecutive isisRejectedAdjacency notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis rejected-adjacency command.
OFF
CLI: Use the undo snmp-agent trap enable isis rejected-adjacency command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
Interface index.
No
Unsigned32
No
IsisPDUHeader
Recommended action
1.Verify that the two ends have matching area addresses.
2.Verify that the two ends have matching IS levels.
3.Verify that the two ends have matching authentication types.
4.Verify that the two ends have matching authentication information.
5.If the issue persists, contact H3C Support.
isisLSPTooLargeToPropagate
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.14
Propagation failures caused by oversized LSPs.
Error
Warning
ON
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when an LSP larger than the dataLinkBlockSize value of the link is propagated.
The agent must throttle the generation of consecutive isisLSPTooLargeToPropagate notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis lsp-size-exceeded command.
OFF
CLI: Use the undo snmp-agent trap enable isis lsp-size-exceeded command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
Interface index.
No
Unsigned32
1.3.6.1.2.1.138.1.10.1.8 (isisPduLspSize)
Size of the LSP that is too large to be forwarded.
No
Unsigned32
No
IsisLinkStatePDUID
OCTET STRING (8)
Recommended action
1.Increase the interface MTU.
2.Reduce the LSP size.
isisOrigLSPBuffSizeMismatch
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.15
Buffer size mismatches of IS-IS packets.
Error
Warning
ON
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when we receive an LSP (Level-1 or Level-2) that is larger than the local isisSysLevelOrigLSPBuffSize value or has a Buffer Size value not matching the local isisSysLevelOrigLSPBuffSize value. If any value of the Buffer Size or LSP size exceeds the local setting, both values are rejected.
The agent must throttle the generation of consecutive isisOrigLSPBuffSizeMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis buffsize-mismatch command.
OFF
CLI: Use the undo snmp-agent trap enable isis buffsize-mismatch command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
Interface index.
No
Unsigned32
No
IsisLinkStatePDUID
OCTET STRING (8)
1.3.6.1.2.1.138.1.10.1.9 (isisPduOriginatingBufferSize)
Peer isisSysOrigLSPBuffSize value in the TLV.
No
IsisUnsigned16TC
Unsigned32 (0..16000)
1.3.6.1.2.1.138.1.10.1.10 (isisPduBufferSize)
Maximum received LSP size.
No
IsisUnsigned16TC
Recommended action
1.Reduce the length of LSPs generated by the neighbor.
2.Increase the LSP receive buffer size on the local end.
isisProtocolsSupportedMismatch
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.16
Supported-protocol mismatches.
Error
Warning
ON
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when a nonpseudonode LSP fragment 0 is received but no supported protocol is available. The reason for the notification might be that the system has not generated this field or no common elements are available. This notification includes the list of supported protocols. If the system does not support the TLV or the TLV is empty, the supported protocol list will be empty.
The agent must throttle the generation of consecutive isisProtocolsSupportedMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis protocol-support command.
OFF
CLI: Use the undo snmp-agent trap enable isis protocol-support command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
Interface index.
No
Unsigned32
1.3.6.1.2.1.138.1.10.1.11 (isisPduProtocolsSupported)
Protocol list supported by the neighbor.
No
OCTET STRING
OCTET STRING (0..255)
No
IsisLinkStatePDUID
OCTET STRING (8)
No
IsisPDUHeader
Recommended action
1.Verify the protocol support.
isisAdjacencyChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.17
IS-IS adjacency status changes.
Error
Warning
ON
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when an adjacency enters or exits up state. The first six bytes of the isisPduLspId variable represents the system ID of the neighbor. The isisAdjState variable represents the most recent adjacency state.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis adjacency-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable isis adjacency-state-change command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
Interface index.
No
Unsigned32
No
IsisLinkStatePDUID
OCTET STRING (8)
1.3.6.1.2.1.138.1.10.1.12 (isisAdjState)
Adjacency state.
No
INTEGER
down (1), initializing (2), up (3), failed(4)
1.3.6.1.2.1.31.1.1.1.1 (ifName)
Interface name
No
DisplayString
OCTET STRING(0..255)
Recommended action
1.Verify that the neighbor state is normal.
isisLSPErrorDetected
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.18
LSP packet parse failures.
Error
Warning
ON
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when an LSP with parse failure is received. isisCircIfIndex records the index of the link that received the PDU. isisPduFragment records the starting bytes of the PDU. isisErrorOffset indicates the problem.
If the problem was caused by malformed TLV, isisErrorOffset indicates the starting bytes of the TLV, and isisErrorTLVType records the type of the error TLV.
If the problem was caused by LSP header error, isisErrorOffset indicates the suspicious bytes.
The number of the LSPs of this type is recorded in isisSysStatLSPErrors.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis lsp-parse-error command.
OFF
CLI: Use the undo snmp-agent trap enable isis lsp-parse-error command.
Object
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
No
IsisLinkStatePDUID
OCTET STRING (8)
Interface index.
No
Unsigned32
No
IsisPDUHeader
1.3.6.1.2.1.138.1.10.1.13 (isisErrorOffset)
Offset of the error TLV.
No
Unsigned32
Standard MIB values.
1.3.6.1.2.1.138.1.10.1.14 (isisErrorTLVType)
Type of the error TLV.
No
Unsigned32
Unsigned32(0..255)
Recommended action
