02-Device Management
HomeSupportSwitchesS12500R SeriesDiagnose & MaintainAlarms ReferencesH3C S12500R Switch Router Series Alarms References(R52xx)-6W10002-Device Management
01-HH3C-RES-MON-MIB
01-HH3C-RES-MON-MIB 146.36 KB
HH3C-RES-MON-MIB
About this MIB
Use this MIB to monitor and manage state changes of cards and hardware resources on the device and enable the device to send notifications.
MIB file name
hh3c-res-mon.mib
Notifications
hh3cResMonMinorNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.169.3.0.1
Minor resource depletion alarm occurred
Error
Minor
1.3.6.1.4.1.25506.2.169.3.0.2 (hh3cResMonMinorRecoverNotification)
ON
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
Error
Minor
1.3.6.1.4.1.25506.2.169.3.0.2(hh3cResMonMinorRecoverNotification)
ON
This notification is generated when the amount of the free resource decreased to or below the hh3cResMonMinorThreshold.
System impact
Status control
The notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.169.2.1.1.1 (hh3cResMonChassisIndex)
Member ID of the device
Y
Unsigned32
Standard MIB values.
1.3.6.1.4.1.25506.2.169.2.1.1.2 (hh3cResMonSlotIndex)
Slot number
Y
Unsigned32
1.3.6.1.4.1.25506.2.169.2.1.1.3 (hh3cResMonCpuIndex)
CPU ID
Y
Unsigned32
1.3.6.1.4.1.25506.2.169.2.1.1.4 (hh3cResMonResourceName)
Resource name
Y
OCTET STRING
1.3.6.1.4.1.25506.2.169.2.1.1.5
 (hh3cResMonThresholdUnit)
Expression method for resource depletion thresholds
N
INTEGER
absolute(1),, percentage(2)
1.3.6.1.4.1.25506.2.169.2.1.1.6
 (hh3cResMonMinorThreshold)
Minor resource depletion threshold
N
Unsigned32
1.3.6.1.4.1.25506.2.169.2.1.1.7
 (hh3cResMonSevereThreshold)
Severe resource depletion threshold
N
Unsigned32
1.3.6.1.4.1.25506.2.169.2.2.1.1
 (hh3cResMonCurrent)
Amount of the used resource
N
Unsigned32
1.3.6.1.4.1.25506.2.169.2.2.1.2
 (hh3cResMonFree)
Amount of the free resource
N
Unsigned32
1.3.6.1.4.1.25506.2.169.2.2.1.3 (hh3cResMonTotal)
Total size of resource
N
Unsigned32
1.3.6.1.4.1.25506.2.169.3.1.1 (hh3cResMonAdditionalInfo)
Additional information
N
OCTET STRING
Recommended action
This issue has minor impact on the current services. To avoid more serious issues, take actions at an appropriate time or perform further observation.
Basic information
OID
Event
Severity
Default status
Minor resource depletion alarm cleared
Recovery
Warning
N/A (N/A)
ON
System impact
OID
Event
Severity
Default status
Recovery
Warning
N/A
ON
This notification is generated when the amount of the free resource increased to or above the hh3cResMonMinorThreshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Y
Unsigned32
Slot number
Y
Unsigned32
CPU ID
Y
Unsigned32
Resource name
Y
OCTET STRING
N
INTEGER
absolute(1), percentage(2)
N
Unsigned32
N
Unsigned32
 (hh3cResMonCurrent)
N
Unsigned32
 (hh3cResMonFree)
N
Unsigned32
N
Unsigned32
N
OCTET STRING
Recommended action
No action is required.
hh3cResMonSevereNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.169.3.0.3
Severe resource depletion alarm occurred
Error
Major
1.3.6.1.4.1.25506.2.169.3.0.4 (hh3cResMonSevereRecoverNotification)
ON
System impact
OID
Event
Severity
Default status
Error
Major
1.3.6.1.4.1.25506.2.169.3.0.4(hh3cResMonSevereRecoverNotification)
ON
This notification is generated when the amount of the free resource increased to or above the hh3cResMonSevereThreshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Y
Unsigned32
Slot number
Y
Unsigned32
CPU ID
Y
Unsigned32
Resource name
Y
OCTET STRING
N
INTEGER
N
Unsigned32
N
Unsigned32
 (hh3cResMonCurrent)
N
Unsigned32
 (hh3cResMonFree)
N
Unsigned32
N
Unsigned32
N
OCTET STRING
Recommended action
The issue has significant impact on current services. Immediate action is required.
Basic information
OID
Event
Severity
Default status
Severe resource depletion alarm cleared
Recovery
Warning
N/A (N/A)
ON
System impact
OID
Event
Severity
Default status
Recovery
Warning
N/A
ON
This notification is generated when the amount of the free resource is increased to or above hh3cResMonSevereThreshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Y
Unsigned32
Slot number
Y
Unsigned32
CPU ID
Y
Unsigned32
Resource name
Y
OCTET STRING
N
INTEGER
N
Unsigned32
N
Unsigned32
 (hh3cResMonCurrent)
N
Unsigned32
 (hh3cResMonFree)
N
Unsigned32
N
Unsigned32
N
OCTET STRING
Recommended action
hh3cResMonUsedUpNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.169.3.0.5
Resource used up alarm occurred
Error
Critical
1.3.6.1.4.1.25506.2.169.3.0.6 (hh3cResMonUsedUpRecoverNotification)
ON
System impact
OID
Event
Severity
Default status
Error
Critical
1.3.6.1.4.1.25506.2.169.3.0.6(hh3cResMonUsedUpRecoverNotification)
ON
This notification is generated when the resource is used up.
System impact
Status control
Object
OID (object name)
Index
Value range
Y
Unsigned32
Slot number
Y
Unsigned32
CPU ID
Y
Unsigned32
Resource name
Y
OCTET STRING
N
INTEGER
N
Unsigned32
N
Unsigned32
 (hh3cResMonCurrent)
N
Unsigned32
 (hh3cResMonFree)
N
Unsigned32
N
Unsigned32
N
OCTET STRING
Recommended action
The issue puts system assets and services at risk. Immediate action is required.
Basic information
OID
Event
Severity
Default status
Resource used up alarm cleared
Recovery
Warning
N/A (N/A)
ON
System impact
OID
Event
Severity
Default status
Recovery
Warning
N/A
ON
This notification is generated when the free resource increases from zero up.
System impact
Status control
Object
OID (object name)
Index
Value range
Y
Unsigned32
Slot number
Y
Unsigned32
CPU ID
Y
Unsigned32
Resource name
Y
OCTET STRING
N
INTEGER
N
Unsigned32
N
Unsigned32
 (hh3cResMonCurrent)
N
Unsigned32
 (hh3cResMonFree)
N
Unsigned32
N
Unsigned32
N
OCTET STRING
Recommended action
