02-Device Management
HomeSupportSwitchesS12500R SeriesDiagnose & MaintainAlarms ReferencesH3C S12500R Switch Router Series Alarms References(R52xx)-6W10002-Device Management
03-SYSLOG-MSG-MIB
03-SYSLOG-MSG-MIB 71.89 KB
SYSLOG-MSG-MIB
About this MIB
Use this MIB to manage syslog messages as SNMP objects and enable and view syslog message notifications.
MIB file name
rfc5676-syslog-msg.mib
Notifications
syslogMsgNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.192.0.1
A syslog message generated
Informational
Warning
N/A (N/A)
OFF
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.192.0.1
Informational
Warning
N/A
OFF
This notification is generated when a new syslog message is received and the value of syslogMsgGenerateNotifications is true.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable syslog command.
MIB: Set syslogMsgEnableNotifications to true(1).
OFF
CLI: Use the undo snmp-agent trap enable syslog command.
MIB: Set syslogMsgEnableNotifications to false(2).
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.192.1.2.1.2 (syslogMsgFacility)
Facility of the syslog message.
N
SyslogFacility
kern(0), user(1), mail(2), daemon(3), auth(4), syslog(5), lpr(6), news(7), uucp(8), cron(9), authpriv(10), ftp(11), ntp(12), audit(13), console(14), cron2(15), local0(16), local1(17), local2(18), local3(19), local4(20), local5(21), local6(22), local7(23)
1.3.6.1.2.1.192.1.2.1.3 (syslogMsgSeverity)
Severity of the syslog message.
N
SyslogSeverity
emerg(0), alert(1), crit(2), err(3), warning(4), notice(5), info(6), debug(7)
1.3.6.1.2.1.192.1.2.1.4 (syslogMsgVersion)
Version of the syslog message.
N
Unsigned32
0..999
1.3.6.1.2.1.192.1.2.1.5 (syslogMsgTimeStamp)
Timestamp of the syslog message.
N
SyslogTimeStamp
OCTET STRING (SIZE (0|10|13))
1.3.6.1.2.1.192.1.2.1.6 (syslogMsgHostName)
Host name of the syslog message.
N
DisplayString
OCTET STRING (SIZE (0..255))
1.3.6.1.2.1.192.1.2.1.7 (syslogMsgAppName)
Application name of the syslog message.
N
DisplayString
OCTET STRING (SIZE (0..48))
1.3.6.1.2.1.192.1.2.1.8 (syslogMsgProcID)
Process ID of the syslog message.
N
DisplayString
OCTET STRING (SIZE (0..128))
1.3.6.1.2.1.192.1.2.1.9 (syslogMsgMsgID)
Message ID of the syslog message.
N
DisplayString
OCTET STRING (SIZE (0..32))
1.3.6.1.2.1.192.1.2.1.10 (syslogMsgSDParams)
Number of structured data element parameters carried in the syslog message.
N
Unsigned32
Standard MIB values.
1.3.6.1.2.1.192.1.2.1.11 (syslogMsgMsg)
Message part of the syslog message.
N
OCTET STRING
Recommended action
No action is required.
