16-Security Configuration Guide
HomeSupportWirelessWX3800X Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX3800X Series Access Controllers Configuration Guides(R1210P01)-6W10016-Security Configuration Guide
04-User profile configuration
04-User profile configuration 400.04 KB
Configuring user profiles
About user profiles
A user profile defines a set of parameters, such as a QoS policy, for a user or a class of users. A user profile can be reused when a user connected to the network on a different interface.
The user profile application allows flexible traffic policing on a per-user basis. Each time a user passes authentication (for example, portal authentication), the server sends the device the name of the user profile specified for the user. The device applies the parameters in the user profile to the user.
You can also apply a user profile to an interface to process all traffic on the interface.
User profiles are typically used in the following scenarios:
·     Resource allocation per user—Interface-based traffic policing limits the total amount of bandwidth available to a group of users. However, user-profile-based traffic policing can limit the amount of bandwidth available to a single user.
·     User access control—When a user passes authentication but the account is overdue, only the resources defined by the ACL permit rules in the free rules are accessible for this user.
Prerequisites for user profile
When a user profile works with authentication methods, you must configure authentication for the user profile. For information about supported authentication methods, see the configuration guides for the related authentication modules.
If a user profile is applied to an interface, no authentication settings are required.
Configuring a user profile
2.     Create a user profile and enter user profile view.
user-profile profile-name
3.     Configure the user profile. Choose the options to configure as needed:
¡     Apply an existing QoS policy to the user profile.
By default, no QoS policy is applied to a user profile.
¡     Configure a CAR policy for the user profile.
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
By default, no CAR policy is configured for a user profile.
¡     Configure a packet filter for the user profile.
packet-filter [ ipv6] { acl-number | name acl-name } { inbound | outbound }
By default, no packet filter is configured for a user profile.
For information about QoS policies and CAR policies, see QoS Configuration Guide.
Configuring session group profile
A session group profile is a particular type of user profile for a group of users. It implements QoS traffic control on a per-group basis. A user group can include multiple users and multiple services. For example, you can configure a session group profile to limit the total bandwidth for the user group in addition to configuring a user profile for each user.
After user profiles for user groups are deployed, the device identifies different user groups by sessions and associates each user group with a user profile.
2.     Create a session group profile and enter session group profile view.
user-profile profile-name type session-group
You can use the command to enter the view of an existing session group profile.
3.     Configure the session group profile. Choose the options to configure as needed:
¡     Configure a CAR policy for the session group profile.
By default, no CAR policy is configured for a session group profile.
For information about CAR policies, see QoS Configuration Guide.
Verifying and maintaining user profiles
To display configuration and online user information for the specified user profile or all user profiles, execute the following command in any view.
display user-profile [ session-group ] [ name profile-name ]
User profile configuration examples
Example: Configuring user profiles with RADIUS and MAC authentication
As shown in Figure 1, the AC is connected to the RADIUS server through a Layer 2 switch.
Configure the AC to meet the following requirements:
·     MAC authentication is used.
·     MAC-authenticated users access the wireless network through the specified AP.
Figure 1 Network diagram
Before configuring the AC, make sure:
·     The AC and the RADIUS server can reach each other.
·     An account with username 123 and password aaa_maca has been added on the RADIUS server.
1.     Configure a RADIUS scheme:
# Create a RADIUS scheme named imcc.
<AC> system-view
[AC] radius scheme imcc
# Specify the primary authentication server.
[AC-radius-imcc] primary authentication 10.18.1.88  1812
# Specify the primary accounting server.
[AC-radius-imcc] primary accounting 10.18.1.88  1813
# Set the authentication key to 123456789Test&! in plaintext form.
[AC-radius-imcc] key authentication simple 123456789Test&!
# Set the accounting key to 123456789Test&! in plaintext form.
[AC-radius-imcc] key accounting simple 123456789Test&!
# Exclude domain names from the usernames sent to the RADIUS server.
[AC-radius-imcc] user-name-format without-domain
[AC-radius-imcc] quit
2.     Configure AAA methods for an ISP domain:
# Create an ISP domain named imc.
[AC] domain imc
# Apply RADIUS scheme imcc to ISP domain imc for authentication, authorization, and accounting.
[AC-isp-imc] authentication lan-access radius-scheme imcc
[AC-isp-imc] authorization lan-access radius-scheme imcc
[AC-isp-imc] accounting lan-access radius-scheme imcc
[AC-isp-imc] quit
3.     Configure MAC authentication:
# Specify username 123 and password aaa_maca in plain text for the account shared by MAC authentication users.
[AC] mac-authentication user-name-format fixed account 123 password simple aaa_maca
# Configure SSID maca_imc for wireless service template maca_imc.
[AC] wlan service-template maca_imc
[AC-wlan-st-maca_imc] ssid maca_imc
# Set the authentication mode to MAC authentication.
[AC-wlan-st-maca_imc] client-security authentication-mode mac
# Specify the ISP domain imc for the service template.
[AC-wlan-st-maca_imc] mac-authentication domain imc
# Enable the service template.
[AC-wlan-st-maca_imc] service-template enable
[AC-wlan-st-maca_imc] quit
4.     Configure the manual AP ap1, and bind the service template to an AP radio:
# Create a manual AP named ap1, and specify the AP model and serial ID.
[AC] wlan ap ap1 model WA6320
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
# Configure channel 149 as the working channel for radio 1 of the AP, and enable radio 1.
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] channel 149
# Bind the service template maca_imc to radio 1.
[AC-wlan-ap-ap1-radio-1] service-template maca_imc
[AC-wlan-ap-ap1-radio-1] quit
[AC-wlan-ap-ap1] quit
5.     Configure a user profile:
# Create an AP group named macauth1, and add AP ap1 to the AP group.
[AC] wlan ap-group macauth1
[AC-wlan-ap-group-macauth1] ap ap1
[AC-wlan-ap-group-macauth1] quit
# Create a user profile named mac1, and specify AP group macauth1 as the permitted AP group for client access.
[AC] user-profile mac1
[AC-user-profile-mac1] wlan permit-ap-group macauth1
[AC-user-profile-mac1] quit
6.     Configure the RADIUS server on IMC 7.0:
In this example, the RADIUS server runs on IMC PLAT 7.2 and IMC EIA 7.2.
# Add the AC to IMC EIA as an access device.
a.     Log in to IMC, click the User tab, and select User Access Policy > Access Device Management > Access Device from the navigation tree.
b.     Click Add. Configure an access device as follows:
-     Set the shared key for secure RADIUS communication to 12345678.
-     Select the access device from the device list or manually add the access device (with the IP address 10.18.1.1).
-     Leave the default settings for other parameters and click OK.
Figure 2 Adding the AC as an access device
# Add an access policy.
a.     Click the User tab, and select User Access Policy > Access Policy from the navigation tree. Then, click Add to configure an access policy.
b.     Set the policy name to aaa_maca, and use default settings for other parameters.
Figure 3 Adding an access policy
# Add an access service.
a.     Click the User tab, and select User Access Policy > Access Service from the navigation tree.
Figure 4 Access Service page
a.     Click Add to configure an access service. Set the policy name to aaa_maca, and use default settings for other parameters.
Figure 5 Adding an access service
# Add an access user.
a.     Click the User tab, and select Access User from the navigation tree.
Figure 6 Access User page
a.     Click Add to configure an access user. Set the username and account name, and select MAC Authentication User.
Figure 7 Adding an access user
Figure 8 Adding an access policy
  • Become a Partner
  • Partner Resources
