15-HH3C-ARP-TRAP-MIB | 41.45 KB |
HH3C-ARP-TRAP-MIB
About this MIB
Use this MIB to output notifications for the ARP module.
MIB file name
hh3c-arp-trap.mib
Root object
Notifications
hh3cARPTrapIPConflictAlarm
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.217.2.1.0.5 |
Local IP address conflicted. |
Informational |
Major |
1.3.6.1.4.1.25506.2.217.2.1.0.6(hh3cARPTrapMACIPConflictResume) |
OFF |
This notification is generated when the sender IP address in the ARP packet is the same as the IP address of the local device.
Status control
ON
CLI: Use the snmp-agent trap enable arp local-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable arp local-conflict command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.2.1.1.1 (hh3cARPTrapLocalConflictIf) |
Interface that received the ARP packet with a duplicate IP address. |
No |
OCTET STRING |
OCTET STRING (1..47) |
1.3.6.1.4.1.25506.2.217.2.1.1.3 (hh3cARPTrapLocalConflictIP) |
Sender IP address in the ARP packet. |
No |
IpAddress |
Standard MIB values. |
1.3.6.1.4.1.25506.2.217.2.1.1.5 (hh3cARPTrapLocalSrcMac) |
Sender MAC address in the ARP packet. |
No |
OCTET STRING |
OCTET STRING (1..15) |
1.3.6.1.4.1.25506.2.217.2.1.1.8 (hh3cARPTrapLocalPeVlan) |
Outer VLAN of the ARP packet. |
No |
INTEGER |
Integer32 (1..2147483647) |
1.3.6.1.4.1.25506.2.217.2.1.1.9 (hh3cARPTrapLocalCeVlan) |
Inner VLAN of the ARP packet. |
No |
INTEGER |
Recommended action
Check whether an ARP packet attack or a loop exists on the network.
