05-Layer 3 - IP Services
HomeSupportSwitchesS12500R SeriesReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10105-Layer 3 - IP Services
02-HH3C-DHCP-SNOOP2-MIB
02-HH3C-DHCP-SNOOP2-MIB 117.26 KB
About this MIB
DHCP snooping is a security feature for DHCP.
DHCP snooping provides the following security features:
·     Guarantees that DHCP clients obtain IP addresses from authorized DHCP servers.
·     Records IP-to-MAC bindings of DHCP clients (called DHCP snooping entries) for security purposes.
MIB file name
hh3c-dhcp-snoop2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDhcpSnoop2(124)
Scalar objects
hh3cDhcpSnoop2Enabled
Object (OID)
Access
Value range
Implementation
hh3cDhcpSnoop2Enabled (1.3.6.1.4.1.25506.2.124.1.1.1)
read-write
TruthValue
true(1),
false(2)
Enabling status of DHCP snooping.
As per the MIB.
hh3cDhcpSnoop2BindDbName
Object (OID)
Access
Value range
Implementation
hh3cDhcpSnoop2BindDbName (1.3.6.1.4.1.25506.2.124.1.1.2)
read-write
OCTET STRING
OCTET STRING (0..255)
Name of the file for saving DHCP snooping entries.
The name string cannot exceed the product-specific upper limit.
hh3cDhcpSnoop2BindRefreshIntvl
Object (OID)
Access
Value range
Implementation
hh3cDhcpSnoop2BindRefreshIntvl (1.3.6.1.4.1.25506.2.124.1.1.3)
read-write
Unsigned32
Unsigned32(60..864000)
DHCPv6 snooping entry refreshing interval.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cDhcpSnoop2BindRefresh (1.3.6.1.4.1.25506.2.124.1.1.4)
read-write
INTEGER
on(1)
Immediate saving of DHCP snooping entries.
As per the MIB.
hh3cDhcpSnoop2PktSentNum
Object (OID)
Access
Value range
Implementation
hh3cDhcpSnoop2PktSentNum (1.3.6.1.4.1.25506.2.124.1.2.1)
read-only
Counter64
INTEGER(0..18446744073709551615)
Number of packets forwarded by DHCP snooping.
As per the MIB.
hh3cDhcpSnoop2PktRcvNum
Object (OID)
Access
Value range
Implementation
hh3cDhcpSnoop2PktRcvNum (1.3.6.1.4.1.25506.2.124.1.2.2)
read-only
Counter64
Number of packets received by DHCP snooping.
As per the MIB.
hh3cDhcpSnoop2PktDropNum
Object (OID)
Access
Value range
Implementation
hh3cDhcpSnoop2PktDropNum (1.3.6.1.4.1.25506.2.124.1.2.3)
read-only
Counter64
Number of packets dropped by DHCP snooping.
As per the MIB.
Tabular objects
hh3cDhcpSnoop2BindTable
About this table
This table describes a DHCP snooping entry.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Supported
Supported
Columns
The table indexes are h3cDhcpSnoop2BindIpAddr, h3cDhcpSnoop2BindVlanId, and h3cDhcpSnoop2BindSecVlanId.
Object (OID)
Access
Value range
Implementation
hh3cDhcpSnoop2BindIpAddr (1.3.6.1.4.1.25506.2.124.2.1.1.1)
not-accessible
InetAddressIPv4
OCTET STRING (4)
IP address assigned to a DHCP client.
As per the MIB.
hh3cDhcpSnoop2BindVlanId (1.3.6.1.4.1.25506.2.124.2.1.1.2)
not-accessible
Unsigned32
Unsigned32(1..4094)
Outer VLAN tag of the DHCP packet.
As per the MIB.
hh3cDhcpSnoop2BindSecVlanId (1.3.6.1.4.1.25506.2.124.2.1.1.3)
not-accessible
Unsigned32
Unsigned32(1..4094|65535)
Inner VLAN tag of the DHCP packet.
As per the MIB.
hh3cDhcpSnoop2BindMacAddr (1.3.6.1.4.1.25506.2.124.2.1.1.4)
read-only
MacAddress
OCTET STRING (6)
MAC address of the DHCP client.
As per the MIB.
hh3cDhcpSnoop2BindLease (1.3.6.1.4.1.25506.2.124.2.1.1.5)
read-only
Unsigned32
Standard MIB values.
Remaining time of the lease for the DHCP client.
As per the MIB.
hh3cDhcpSnoop2BindPortIndex (1.3.6.1.4.1.25506.2.124.2.1.1.6)
read-only
InterfaceIndexOrZero
Integer32(0..2147483647)
Interface that connects to the DHCP client.
As per the MIB.
hh3cDhcpSnoop2BindRowStatus (1.3.6.1.4.1.25506.2.124.2.1.1.7)
read-create
RowStatus
Support only the destroy operation
Row status.
As per the MIB.
hh3cDhcpSnoop2IfConfigTable
About this table
This table describes the DHCP snooping configuration on interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifindex.
Object (OID)
Access
Value range
Implementation
hh3cDhcpSnoop2IfTrustStatus (1.3.6.1.4.1.25506.2.124.2.2.1.1)
read-write
INTEGER
untrusted(0),
trusted(1)
Enabling status of the DHCP snooping trusted interface.
As per the MIB.
hh3cDhcpSnoop2IfCheckMac (1.3.6.1.4.1.25506.2.124.2.2.1.2)
read-write
TruthValue
true(1),
false(2)
Enabling status of the MAC address check.
As per the MIB.
hh3cDhcpSnoop2IfCheckRequest (1.3.6.1.4.1.25506.2.124.2.2.1.3)
read-write
TruthValue
true(1),
false(2)
Enabling status of the DHCP-REQUEST check.
As per the MIB.
hh3cDhcpSnoop2IfRateLimit (1.3.6.1.4.1.25506.2.124.2.2.1.4)
read-write
Unsigned32
DHCP snooping packet rate limit on the interface.
As per the MIB.
hh3cDhcpSnoop2IfRecordBind (1.3.6.1.4.1.25506.2.124.2.2.1.5)
read-write
TruthValue
true(1),
false(2)
Recording DHCP snooping entries.
As per the MIB.
hh3cDhcpSnoop2IfMaxLearnNum (1.3.6.1.4.1.25506.2.124.2.2.1.6)
read-write
Unsigned32
Unsigned32(0..4294967295)
Maximum number of DHCP snooping entries that the interface (Layer 2 interface) can learn.
As per the MIB.
hh3cDhcpSnoop2IfOpt82Enable (1.3.6.1.4.1.25506.2.124.2.2.1.7)
read-write
TruthValue
true(1),
false(2)
Enabling status of Option 82 support
As per the MIB.
hh3cDhcpSnoop2IfOpt82Strategy (1.3.6.1.4.1.25506.2.124.2.2.1.8)
read-write
INTEGER
drop(1),
keep(2),
replace(3)
Option 82 strategy
As per the MIB.
hh3cDhcpSnoop2IfOpt82CIDMode (1.3.6.1.4.1.25506.2.124.2.2.1.9)
read-write
INTEGER
normal(1),
verbose(2),
userDefine(3)
Mode of the Circuit ID sub-option in Option 82.
As per the MIB.
hh3cDhcpSnoop2IfOpt82CIDNodeType (1.3.6.1.4.1.25506.2.124.2.2.1.10)
read-write
INTEGER
invalid(1),
mac(2),
sysname(3),
userDefine(4)
Format of the Circuit ID sub-option in verbose mode.
As per the MIB.
hh3cDhcpSnoop2IfOpt82CIDNodeStr (1.3.6.1.4.1.25506.2.124.2.2.1.11)
read-write
OCTET STRING
OCTET STRING (0..50)
User-defined string for the Circuit ID sub-option in verbose mode.
As per the MIB.
hh3cDhcpSnoop2IfOpt82CIDStr (1.3.6.1.4.1.25506.2.124.2.2.1.12)
read-write
OCTET STRING
OCTET STRING (0|3..63)
User-defined string for the Circuit ID sub-option in user-defined mode.
As per the MIB.
hh3cDhcpSnoop2IfOpt82CIDFormat (1.3.6.1.4.1.25506.2.124.2.2.1.13)
read-write
INTEGER
hex(1),
ascii(2),
undefine(3)
Padding format of the Circuit ID sub-option.
As per the MIB.
hh3cDhcpSnoop2IfOpt82RIDMode (1.3.6.1.4.1.25506.2.124.2.2.1.14)
read-write
INTEGER
normal(1),
sysname(2),
userDefine(3)
Mode of the Remote ID sub-option in Option 82.
As per the MIB.
hh3cDhcpSnoop2IfOpt82RIDStr (1.3.6.1.4.1.25506.2.124.2.2.1.15)
read-write
OCTET STRING
OCTET STRING (0..63)
User-defined string for the Remote ID sub-option in user-defined mode.
As per the MIB.
hh3cDhcpSnoop2IfOpt82RIDFormat (1.3.6.1.4.1.25506.2.124.2.2.1.16)
read-write
INTEGER
hex(1),
ascii(2)
Padding format of the Remote ID sub-option.
As per the MIB.
hh3cDhcpSnoop2IfVlanCIDTable
About this table
This table describes Option 82 Circuit ID sub-option configuration in VLANs.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are ifIndex and h3cDhcpSnoop2IfVlanCIDVlanIndex.
Object (OID)
Access
Value range
Implementation
hh3cDhcpSnoop2IfVlanCIDVlanIndex (1.3.6.1.4.1.25506.2.124.2.3.1.1)
not-accessible
Unsigned32
Unsigned32(1..4094)
VLAN ID.
As per the MIB.
hh3cDhcpSnoop2IfVlanCIDStr (1.3.6.1.4.1.25506.2.124.2.3.1.2)
read-create
OCTET STRING
OCTET STRING (3..63)
User-defined string for padding the Circuit ID sub-option.
As per the MIB.
hh3cDhcpSnoop2IfVlanCIDRowStatus (1.3.6.1.4.1.25506.2.124.2.3.1.3)
read-create
RowStatus
Active(1), createAndGo(4), destroy(6).
Row status.
As per the MIB.
hh3cDhcpSnoop2IfVlanRIDTable
About this table
This table describes Option 82 Remote ID sub-option configuration in VLANs.
Create
Edit/Modify
Delete
Read
Supported.
It must be bound to h3cDhcpSnoop2IfVlanRIDMode when you create an entry.
Supported.
It must be bound to h3cDhcpSnoop2IfVlanRIDMode when you modify an entry.
Supported
Supported
Columns
The table indexes are ifIndex and h3cDhcpSnoop2IfVlanRIDVlanIndex.
Object (OID)
Access
Value range
Implementation
hh3cDhcpSnoop2IfVlanRIDVlanIndex (1.3.6.1.4.1.25506.2.124.2.4.1.1)
not-accessible
Unsigned32
Unsigned32(1..4094)
VLAN ID.
As per the MIB.
hh3cDhcpSnoop2IfVlanRIDMode (1.3.6.1.4.1.25506.2.124.2.4.1.2)
read-create
INTEGER
sysname(1),
userDefine(2)
Padding mode of the Remote ID sub-option.
As per the MIB.
hh3cDhcpSnoop2IfVlanRIDStr (1.3.6.1.4.1.25506.2.124.2.4.1.3)
read-create
OCTET STRING
User-defined string for padding the Remote ID sub-option.
If the padding mode for the Remote ID sub-option is sysname(1), the value read from this object is 0.
hh3cDhcpSnoop2IfVlanRIDRowStatus (1.3.6.1.4.1.25506.2.124.2.4.1.4)
read-create
RowStatus
Row status.
As per the MIB.
