05-Layer 3 - IP Services
HomeSupportSwitchesS12500R SeriesReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10105-Layer 3 - IP Services
14-HH3C-ARP-RATELIMIT-MIB
14-HH3C-ARP-RATELIMIT-MIB 38.88 KB
About this MIB
This MIB contains ARP rate limiting notifications.
MIB file name
hh3c-arp-ratelimit.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cARPRatelimit(110)
Notifications
hh3cARPRatelimitOverspeedTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.110.1.1.0.1
Rate of ARP packets delivered to the CPU on a device exceeded the threshold.
Informational
N/A
N/A
OFF
This notification is generated when the rate of ARP packets delivered to the CPU on a device exceeds the threshold.
Status control
ON
CLI: Use the snmp-agent trap enable arp rate-limit command.
OFF
CLI: Use the undo snmp-agent trap enable arp rate-limit command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.110.1.1.1.1 (hh3cARPRatelimitTrapVer)
Version of the trap.
No
Unsigned32
1
1.3.6.1.4.1.25506.2.110.1.1.1.2 (hh3cARPRatelimitTrapCount)
Alarm threshold that the ARP packet rate exceeded.
No
Unsigned32
Standard MIB values.
1.3.6.1.4.1.25506.2.110.1.1.1.3 (hh3cARPRatelimitTrapMsg)
Trap messages.
No
OCTET STRING
SIZE (1..254)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
