05-Layer 3 - IP Services
HomeSupportSwitchesS12500R SeriesReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10105-Layer 3 - IP Services
07-HH3C-NAT-MIB
07-HH3C-NAT-MIB 45.53 KB
HH3C-NAT-MIB (Not ADE)
About this MIB
Use this MIB to obtain NAT information.
MIB file name
hh3c-nat.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cNat(18)
Tabular objects
hh3cNATStatVer2Table
About this table
This table obtains NAT statistics of version 2.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cNATStatChassis, hh3cNATStatSlot, and hh3cNATStatCPUID.
Object (OID)
Access
Value range
Implementation
hh3cNATStatChassis (1.3.6.1.4.1.25506.2.18.2.13.1.1)
not-accessible
Unsigned32
0..65534
Chassis number.
As per the MIB.
hh3cNATStatSlot (1.3.6.1.4.1.25506.2.18.2.13.1.2)
not-accessible
Unsigned32
0..65534
Slot number.
As per the MIB.
hh3cNATStatCPUID (1.3.6.1.4.1.25506.2.18.2.13.1.3)
not-accessible
Unsigned32
0..7
CPU number.
As per the MIB.
hh3cNATTotalNATSessionCount (1.3.6.1.4.1.25506.2.18.2.13.1.4)
read-only
Unsigned32
Standard MIB values.
Total number of NAT sessions.
As per the MIB.
hh3cNATEimTableCount (1.3.6.1.4.1.25506.2.18.2.13.1.5)
read-only
Unsigned32
Number of EIM entries.
As per the MIB.
hh3cNATInboundNoPATTableCount (1.3.6.1.4.1.25506.2.18.2.13.1.6)
read-only
Unsigned32
NO-PAT entries generated for the inbound NAT translation.
As per the MIB.
hh3cNATOutboundNoPATTableCount (1.3.6.1.4.1.25506.2.18.2.13.1.7)
read-only
Unsigned32
NO-PAT entries generated for the outbound NAT translation.
As per the MIB.
hh3cNATMaxDynamicPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.8)
read-only
Unsigned32
Number of NAT444 dynamic port blocks.
As per the MIB.
hh3cNATMaxStaticPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.9)
read-only
Unsigned32
Number of NAT444 static port blocks.
As per the MIB.
hh3cNATActiveDynamicPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.10)
read-only
Unsigned32
Number of active NAT444 dynamic port blocks.
As per the MIB.
hh3cNATActiveStaticPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.11)
read-only
Unsigned32
Number of active NAT444 static port blocks.
As per the MIB.
hh3cNatIPPoolGroupTable
About this table
Use this table to obtain NAT address group resources usage in a NAT instance.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cNatIPPoolName.
Object (OID)
Access
Value range
Implementation
hh3cNatIPPoolName (1.3.6.1.4.1.25506.2.18.2.19.1.1)
not-accessible
Unsigned32
OCTET STRING
Name of the NAT address pool.
As per the MIB.
hh3cNatIPPoolAddrUsage (1.3.6.1.4.1.25506.2.18.2.19.1.2)
read-only
IpAddress
Unsigned32
NAT address pool usage.
As per the MIB.
hh3cNatIPPoolTotalCount (1.3.6.1.4.1.25506.2.18.2.19.1.3)
read-only
Unsigned32
Unsigned32
Total number of IP addresses in the NAT address pool.
As per the MIB.
hh3cNatIPPoolUsedCount (1.3.6.1.4.1.25506.2.18.2.19.1.4)
read-only
Unsigned32
Unsigned32
Number of used IP addresses in the NAT address pool.
As per the MIB.
hh3cNatIPPoolUnusedCount
(1.3.6.1.4.1.25506.2.18.2.19.1.5)
read-only
OCTET STRING
Unsigned32
Number of unused IP addresses in the NAT address pool.
As per the MIB.
