08-HH3C-ND-TRAP-MIB | 41.56 KB |
HH3C-ND-TRAP-MIB
About this MIB
Use this MIB to obtain information about ND entry learning threshold and packet conflict related alarms.
MIB file name
hh3c-nd-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2). hh3cNDTrap(218)
Notifications
This section contains HH3C-ND-TRAP-MIB notifications.
hh3cNDTrapSlotThresholdResume
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.218.1.0.4 |
The number of ND entries on the current card dropped below the alarm threshold. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the number of dynamic ND entries on the card drops below the alarm threshold.
Status control
ON
CLI: Use the ipv6 nd entry-limit record enable command.
OFF
CLI: Use the undo ipv6 nd entry-limit record enable command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.218.1.1.1 (hh3cNDTrapEntryChassis) |
Chassis number. |
No |
Unsigned32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.218.1.1.2 (hh3cNDTrapEntrySlot) |
Slot number. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.1.1.4 (hh3cNDTrapEntryThreshold) |
Alarm threshold for the number of ND entries on the card. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.1.1.5 (hh3cNDTrapEntryDynamicNum) |
Number of dynamic ND entries. |
No |
Unsigned32 |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
