00-Preface | 26.39 KB |
Preface
This documentation introduces the critical operations on IMC and its components that might cause personal safety risks, device failures, service interruptions, or anomalies.O&M personnel must understand potential risks before performing these operations to reduce the incidence of accidents.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
