00-Preface | 100.95 KB |
Preface
H3C IE4320 Industrial Switch Series Hardware Information and Specifications describes the product models, technical specifications, removable components, ports, LEDs, and cooling system of the H3C IE4320 Industrial Switch Series.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S6116 Ultra-Low Latency switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
