17-Network Management and Monitoring
HomeSupportReference GuidesMIB CompanionH3C S5590-EI S5130S-G FS5500-EI FS5500V2-EI S6530X Switch Series MIB Reference-6W10117-Network Management and Monitoring
08-StationSW-MIB
08-StationSW-MIB 58.03 KB
StationSW-MIB
About this MIB
This MIB is a private MIB defined by the State Grid No. 1084 specification.
Use this MIB to enable the device to proactively send a notification to the network management station when a specific event occurs, such as MAC address change, command execution, and user login through Telnet or SSH, user logout, and password modification.
MIB file name
station-sw.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).nari(49763).stationSW(1)
Scalar objects
ucMacChange
Object (OID)
Access
Value range
Implementation
ucMacChange (1.3.6.1.4.1.49763.1.1.1)
accessible-for-notify
DisplayString
OCTET STRING (0..512)
MAC address change information.
As per the MIB.
Tabular objects
userTable
About this table
This table defines the variable bindings of the userTrap notification object.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table index is userIndex.
Object (OID)
Access
Value range
Implementation
userIndex (1.3.6.1.4.1.49763.1.1.2.1.1)
Integer32
Interger32
(1..2147483647)
Index of a user.
As per the MIB.
userName (1.3.6.1.4.1.49763.1.1.2.1.2)
DisplayString
OCTET STRING (0..64)
Name of the user.
As per the MIB.
userType (1.3.6.1.4.1.49763.1.1.2.1.3)
UserTypeEnum
http(1),
https(2),
snmp(3),
telnet(4),
ssh(5),
cli(6),
iec61850(7),
console(8)
Access method of the user.
Supports only values telnet(4), ssh(5), and console(8).
userStatus (1.3.6.1.4.1.49763.1.1.2.1.4)
UserStatusEnum
logIn(1),
logOut(2),
changePassword(3),
loginFail(4)
Status of the user.
As per the MIB.
userModified (1.3.6.1.4.1.49763.1.1.2.1.5)
DisplayString
Content modified by the user.
As per the MIB.
userIP
(1.3.6.1.4.1.49763.1.1.2.1.6)
DisplayString
IP address of the user.
As per the MIB.
userOperTable
About this table
This table defines the variable bindings of the userOperTrap notification object.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table index is userOperIndex.
Object (OID)
Access
Value range
Implementation
userOperIndex (1.3.6.1.4.1.49763.1.1.3.1.1)
Integer32
Interger32
(1..2147483647)
Index of a user operation.
As per the MIB.
userOperName (1.3.6.1.4.1.49763.1.1.3.1.2)
DisplayString
Name of the user operation.
As per the MIB.
userOperIP (1.3.6.1.4.1.49763.1.1.3.1.3)
DisplayString
As per the MIB.
userOperCommand (1.3.6.1.4.1.49763.1.1.3.1.4)
DisplayString
OCTET STRING (0..256)
Command executed by the user.
As per the MIB.
Notifications
The following information describes the notifications included in the StationSW-MIB module.
ucMacChangeTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.49763.1.2.1
MAC address change.
Informational
N/A
N/A
ON
This notification is generated when a MAC address is changed.
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.49763.1.1.1 (ucMacChange)
N/A
DisplayString
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
userTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.49763.1.2.2
User status change
Informational
N/A
N/A
ON
This notification is generated when a user logs in, logs out, or changes the password.
Status control
Objects
OID (object name)
Index
Value range
(userIndex)
Index of a user.
Yes
Integer32
Interger32
(1..2147483647)
(userName)
Name of the user.
No
DisplayString
(userType)
No
UserTypeEnum
http(1),
https(2),
snmp(3),
telnet(4),
ssh(5),
cli(6),
iec61850(7),
console(8)
(userStatus)
Status of the user.
No
UserStatusEnum
logIn(1),
logOut(2),
changePassword(3),
loginFail(4)
(userModified)
No
DisplayString
(userIP)
No
DisplayString
Recommended action
userOperTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.49763.1.2.3
Command execution by a user
Informational
N/A
N/A
ON
This notification is generated when a user executes a command at the CLI.
Status control
Objects
OID (object name)
Index
Value range
(userOperIndex)
Yes
Integer32
Interger32
(1..2147483647)
(userOperName)
No
DisplayString
(userOperIP)
No
DisplayString
(userOperCommand)
No
DisplayString
Recommended action
