17-Network Management and Monitoring
HomeSupportReference GuidesMIB CompanionH3C S5590-EI S5130S-G FS5500-EI FS5500V2-EI S6530X Switch Series MIB Reference-6W10117-Network Management and Monitoring
03-HH3C-NTP-MIB
03-HH3C-NTP-MIB 102.63 KB
HH3C-NTP-MIB
About this MIB
Use this MIB to configure NTP of the device.
MIB file name
hh3c-ntp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3cNTP(22)
Scalar objects
hh3cNTPSysLeap
Object (OID)
Access
Value range
Implementation
hh3cNTPSysLeap (1.3.6.1.4.1.25506.8.22.1.1.1)
read-only
INTEGER
noWarning(0), addSecond(1), subtractSecond(2), alarm(3)
Two-bit system leap indicator.
As per the MIB.
hh3cNTPSysStratum
Object (OID)
Access
Value range
Implementation
hh3cNTPSysStratum (1.3.6.1.4.1.25506.8.22.1.1.2)
read-only
Integer32
Integer32 (1..16)
Stratum level of the local system clock.
As per the MIB.
hh3cNTPSysPrecision
Object (OID)
Access
Value range
Implementation
hh3cNTPSysPrecision (1.3.6.1.4.1.25506.8.22.1.1.3)
read-only
Integer32
Integer32 (-20..20)
Accuracy of the system clock.
As per the MIB.
hh3cNTPSysRootdelay
Object (OID)
Access
Value range
Implementation
hh3cNTPSysRootdelay (1.3.6.1.4.1.25506.8.22.1.1.4)
read-only
OCTET STRING
OCTET STRING (1..128)
Round-trip delay from the local device to the primary reference source at the root of the synchronization subnet.
As per the MIB.
hh3cNTPSysRootdispersion
Object (OID)
Access
Value range
Implementation
hh3cNTPSysRootdispersion (1.3.6.1.4.1.25506.8.22.1.1.5)
read-only
OCTET STRING
Maximum error of the system clock relative to the primary reference source at the root of the synchronization subnet.
As per the MIB.
hh3cNTPSysRefid
Object (OID)
Access
Value range
Implementation
hh3cNTPSysRefid (1.3.6.1.4.1.25506.8.22.1.1.6)
read-only
OCTET STRING
Reference clock ID of the local clock.
As per the MIB.
hh3cNTPSysReftime
Object (OID)
Access
Value range
Implementation
hh3cNTPSysReftime (1.3.6.1.4.1.25506.8.22.1.1.7)
read-only
OCTET STRING
Timestamp of the local system clock updated most recently.
As per the MIB.
hh3cNTPSysPoll
Object (OID)
Access
Value range
Implementation
hh3cNTPSysPoll (1.3.6.1.4.1.25506.8.22.1.1.8)
read-only
Integer32
Integer32 (-20..20)
System polling interval.
As per the MIB.
hh3cNTPSysPeer
Object (OID)
Access
Value range
Implementation
hh3cNTPSysPeer (1.3.6.1.4.1.25506.8.22.1.1.9)
read-only
Integer32
Integer32 (0..2147483647)
Reference synchronization source specified by the system.
This object is replaced by hh3cNTPSysSrcPeer.
hh3cNTPSysState
Object (OID)
Access
Value range
Implementation
hh3cNTPSysState (1.3.6.1.4.1.25506.8.22.1.1.10)
read-only
INTEGER
noUpdateClock(0), getfreqInfo(1), clockBySet(2), clockBySetAndNoFreq(3), clockBySyns(4), findError(5)
Status of the local clock.
An integer indicates the status of the local clock. Currently, clockBySet(2) is not supported.
hh3cNTPSysOffset
Object (OID)
Access
Value range
Implementation
hh3cNTPSysOffset (1.3.6.1.4.1.25506.8.22.1.1.11)
read-only
OCTET STRING
Offset of the local clock updated most recently.
As per the MIB.
hh3cNTPSysDrift
Object (OID)
Access
Value range
Implementation
hh3cNTPSysDrift (1.3.6.1.4.1.25506.8.22.1.1.12)
read-only
OCTET STRING
Pre-made clock frequency.
As per the MIB.
hh3cNTPSysCompliance
Object (OID)
Access
Value range
Implementation
hh3cNTPSysCompliance (1.3.6.1.4.1.25506.8.22.1.1.13)
read-only
OCTET STRING
System error.
As per the MIB.
hh3cNTPSysClock
Object (OID)
Access
Value range
Implementation
hh3cNTPSysClock (1.3.6.1.4.1.25506.8.22.1.1.14)
read-only
OCTET STRING
System local time.
As per the MIB.
hh3cNTPSysStabil
Object (OID)
Access
Value range
Implementation
hh3cNTPSysStabil (1.3.6.1.4.1.25506.8.22.1.1.15)
read-only
OCTET STRING
Clock frequency stability.
As per the MIB.
hh3cNTPSysAuthenticate
Object (OID)
Access
Value range
Implementation
hh3cNTPSysAuthenticate (1.3.6.1.4.1.25506.8.22.1.1.16)
read-write
INTEGER
noAuthenticate(0), authenticate(1)
An integer indicates that the system supports authentication.
As per the MIB.
hh3cNTPSysPollSec
Object (OID)
Access
Value range
Implementation
hh3cNTPSysPollSec
(1.3.6.1.4.1.25506.8.22.1.1.17)
read-only
Integer32
Integer32 (2..1048576)
System polling interval, in seconds.
As per the MIB.
hh3cNTPSysClockSec
Object (OID)
Access
Value range
Implementation
hh3cNTPSysClockSec
(1.3.6.1.4.1.25506.8.22.1.1.18)
read-only
Integer32
Standard MIB values.
System local time, in seconds.
As per the MIB.
hh3cNTPServerIP
Object (OID)
Access
Value range
Implementation
hh3cNTPServerIP
(1.3.6.1.4.1.25506.8.22.1.1.19)
read-write
IpAddress
OCTET STRING (4)
IP address of the NTP server.
As per the MIB.
hh3cNTPSysSrcPeer
Object (OID)
Access
Value range
Implementation
hh3cNTPSysSrcPeer (1.3.6.1.4.1.25506.8.22.1.1.20)
read-only
Unsigned32
As per the MIB.
Tabular objects
hh3cNTPPeerTable
About this table
This table provides information about the peers associated with the local NTP server.
Support for operations
Create
Edit/Modify
Delete
Read
Supported. The hh3cNTPPeerRowStatus column supports only value createAndGo.
Not supported
Supported
Supported
Columns
The table indexes are hh3cNTPPeerRemAdr and hh3cNTPPeerHMode.
Object (OID)
Access
Value range
Implementation
hh3cNTPPeerConfig (1.3.6.1.4.1.25506.8.22.2.1.1.1.1)
read-only
TruthValue
true(1),
false(2)
A bit indicates the establishment of the association. If a peer is unreachable, the bit is not recoverable.
As per the MIB.
hh3cNTPPeerAuthenable (1.3.6.1.4.1.25506.8.22.2.1.1.1.2)
read-only
TruthValue
true(1),
false(2)
A bit indicates that the peer system supports authentication.
As per the MIB.
hh3cNTPPeerAuthentic (1.3.6.1.4.1.25506.8.22.2.1.1.1.3)
read-only
TruthValue
true(1),
false(2)
A bit indicates that the authentic message passes authentication.
As per the MIB.
hh3cNTPPeerRemAdr (1.3.6.1.4.1.25506.8.22.2.1.1.1.4)
not-accessible
IpAddress
OCTET STRING (4)
IP address of the peer. Set the object when creating a new association.
As per the MIB.
hh3cNTPPeerRemPort (1.3.6.1.4.1.25506.8.22.2.1.1.1.5)
read-only
Integer32
Integer32 (1..65535)
The UDP port number on which the peer receives NTP messages.
As per the MIB.
hh3cNTPPeerLocAdr (1.3.6.1.4.1.25506.8.22.2.1.1.1.6)
read-only
IpAddress
OCTET STRING (4)
IP address of the local host.
As per the MIB.
hh3cNTPPeerLocPort (1.3.6.1.4.1.25506.8.22.2.1.1.1.7)
read-only
Integer32
The UDP port number on which the local host receives NTP messages.
As per the MIB.
hh3cNTPPeerLeap (1.3.6.1.4.1.25506.8.22.2.1.1.1.8)
read-only
INTEGER
Second leap indicator of the peer.
As per the MIB.
hh3cNTPPeerHMode (1.3.6.1.4.1.25506.8.22.2.1.1.1.9)
not-accessible
INTEGER
unspecified (0), symmetricActive (1), symmetricPassive (2), client (3), server(4), broadcast (5), reservedControl (6), reservedPrivate (7), broadcastclient (8), multicastclient (9)
Host association mode.
As per the MIB.
hh3cNTPPeerStratum (1.3.6.1.4.1.25506.8.22.2.1.1.1.10)
read-only
Integer32
Integer32 (0..255)
Stratum level of the peer, indicating the clock accuracy.
As per the MIB.
hh3cNTPPeerPPoll (1.3.6.1.4.1.25506.8.22.2.1.1.1.11)
read-only
Integer32
Integer32 (-20..20)
The interval at which the peer polls the local host.
As per the MIB.
hh3cNTPPeerHPoll (1.3.6.1.4.1.25506.8.22.2.1.1.1.12)
read-only
Integer32
Integer32 (-20..20)
The interval at which the local host polls the peer.
As per the MIB.
hh3cNTPPeerPrecision (1.3.6.1.4.1.25506.8.22.2.1.1.1.13)
read-only
Integer32
Integer32 (-20..20)
Precision of the peer clock.
As per the MIB.
hh3cNTPPeerRootDelay (1.3.6.1.4.1.25506.8.22.2.1.1.1.14)
read-only
OCTET STRING
Round-trip delay from the peer clock to the local clock.
As per the MIB.
hh3cNTPPeerRootDispersion (1.3.6.1.4.1.25506.8.22.2.1.1.1.15)
read-only
OCTET STRING
Clock time difference between the peer clock and the time source.
As per the MIB.
hh3cNTPPeerRefId (1.3.6.1.4.1.25506.8.22.2.1.1.1.16)
read-only
OCTET STRING
Reference source ID of the peer clock.
As per the MIB.
hh3cNTPPeerRefTime (1.3.6.1.4.1.25506.8.22.2.1.1.1.17)
read-only
OCTET STRING
Timestamp of the peer clock.
As per the MIB.
hh3cNTPPeerOrg (1.3.6.1.4.1.25506.8.22.2.1.1.1.18)
read-only
OCTET STRING
Local clock timestamp in the NTP message sent most recently.
As per the MIB.
hh3cNTPPeerRec (1.3.6.1.4.1.25506.8.22.2.1.1.1.19)
read-only
OCTET STRING
Local timestamp in the NTP message received most recently from the peer.
As per the MIB.
hh3cNTPPeerXmt (1.3.6.1.4.1.25506.8.22.2.1.1.1.20)
read-only
OCTET STRING
Local time after the sending of a NTP message.
As per the MIB.
hh3cNTPPeerReach (1.3.6.1.4.1.25506.8.22.2.1.1.1.21)
read-only
Integer32
Reachability count. A peer is unreachable if the object value is 0.
As per the MIB.
hh3cNTPPeerValid (1.3.6.1.4.1.25506.8.22.2.1.1.1.22)
read-only
Integer32
Integer32 (0..255)
Valid sampling data.
As per the MIB.
hh3cNTPPeerTimer (1.3.6.1.4.1.25506.8.22.2.1.1.1.23)
read-only
Integer32
The interval of transmitted NTP messages from the host to the peer.
As per the MIB.
hh3cNTPPeerDelay (1.3.6.1.4.1.25506.8.22.2.1.1.1.24)
read-only
OCTET STRING
Delay of messages from the host to the peer.
As per the MIB.
hh3cNTPPeerOffset (1.3.6.1.4.1.25506.8.22.2.1.1.1.25)
read-only
OCTET STRING
Offset of the peer relative to the local clock.
As per the MIB.
hh3cNTPPeerJitter (1.3.6.1.4.1.25506.8.22.2.1.1.1.26)
read-only
OCTET STRING
Sampling data flag.
As per the MIB.
hh3cNTPPeerDispersion (1.3.6.1.4.1.25506.8.22.2.1.1.1.27)
read-only
OCTET STRING
Maximum error of the peer relative to the local clock.
As per the MIB.
hh3cNTPPeerKeyId (1.3.6.1.4.1.25506.8.22.2.1.1.1.28)
read-only
Unsigned32
Authentication key ID in NTP messages.
As per the MIB.
hh3cNTPPeerFiltDelay (1.3.6.1.4.1.25506.8.22.2.1.1.1.29)
read-only
OCTET STRING
Round-trip delay of the peer relative to the local clock.
As per the MIB.
hh3cNTPPeerFiltOffset (1.3.6.1.4.1.25506.8.22.2.1.1.1.30)
read-only
OCTET STRING
As per the MIB.
hh3cNTPPeerFiltError (1.3.6.1.4.1.25506.8.22.2.1.1.1.31)
read-only
OCTET STRING
As per the MIB.
hh3cNTPPeerPMode (1.3.6.1.4.1.25506.8.22.2.1.1.1.32)
read-only
INTEGER
Association mode of the peer.
As per the MIB.
hh3cNTPPeerReceived (1.3.6.1.4.1.25506.8.22.2.1.1.1.33)
read-only
INTEGER(0..4294967295)
Number of received NTP messages.
As per the MIB.
hh3cNTPPeerSent (1.3.6.1.4.1.25506.8.22.2.1.1.1.34)
read-only
Number of sent NTP messages.
As per the MIB.
hh3cNTPPeerFlash (1.3.6.1.4.1.25506.8.22.2.1.1.1.35)
read-only
Hh3cAlarmStatus
BITS{
recvRepeatMsg(0),
recvremanMsg(1),
unSynMsg(2),
dispBeyond(3),
unauthenticate(4), unSynClock(5), straBeyond(6), rootDispBeyond(7), noAuthen(8),
refuOperate(9) }
Message test flag.
As per the MIB.
hh3cNTPPeerRowStatus (1.3.6.1.4.1.25506.8.22.2.1.1.1.36)
read-create
RowStatus
Supports only values active, createAndGo, and destroy.
Row status.
Supports only values active, createAndGo, and destroy. If the value broadcast, broadcastclient, or multicastclient is used for hh3cNTPPeerHMode, this object supports only the read operation.
