09-DISMAN-EVENT-MIB | 201.73 KB |
mteResourceSampleInstanceMaximum
mteResourceSampleInstancesHigh
mteResourceSampleInstanceLacks
DISMAN-EVENT-MIB
About this MIB
This MIB provides an automatic and distributed monitoring and management mechanism for MIB objects. By periodically monitoring MIB objects., the system automatically triggers the predefined notifications or set operations when the monitored objects meet the trigger conditions.
MIB file name
rfc2981-disman-event.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).dismanEventMIB(88)
Scalar objects
mteResourceSampleMinimum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteResourceSampleMinimum (1.3.6.1.2.1.88.1.1.1) |
read-write |
Integer32 |
Integer32 (1..2147483647) |
Minimum sampling interval allowed by the system. |
Default: 1. Each trigger sampling interval must be equal to or larger than the minimum sampling interval to lessen the impact of constant sampling. Modifying this node does not affect existing triggers. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteResourceSampleInstanceMaximum (1.3.6.1.2.1.88.1.1.2) |
read-write |
Unsigned32 |
Standard MIB values. |
Maximum number of object instances that can be concurrently sampled. |
A value of 0 indicates that no manual limit is specified. The limit is dynamic based on system operations and resources. Changing the maximum number of object instances that can be concurrently sampled does not affect the existing instances. If the maximum number of object instances that can be concurrently sampled is changed to a value smaller than the number of existing instances, the existing instances will continue to be sampled. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteResourceSampleInstances (1.3.6.1.2.1.88.1.1.3) |
read-only |
Gauge32 |
Number of current sampled instances. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteResourceSampleInstancesHigh (1.3.6.1.2.1.88.1.1.4) |
read-only |
Gauge32 |
Peak number of sampled instances. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteResourceSampleInstanceLacks (1.3.6.1.2.1.88.1.1.5) |
read-only |
Counter32 |
Number of sampling failures after the maximum number of sampled instances is reached. |
As per the MIB. |
mteTriggerFailures
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteTriggerFailures (1.3.6.1.2.1.88.1.2.1) |
read-only |
Counter32 |
Number of trigger test failures. |
As per the MIB. |
mteEventFailures
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteEventFailures (1.3.6.1.2.1.88.1.4.1) |
read-only |
Counter32 |
As per the MIB. |
mteHotTrigger
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteHotTrigger (1.3.6.1.2.1.88.2.1.1) |
accessible-for-notify |
SnmpAdminString |
OCTET STRING (0..255) |
Name of a trigger causing a notification. |
As per the MIB. |
mteHotTargetName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteHotTargetName (1.3.6.1.2.1.88.2.1.2) |
SnmpAdminString |
Remote target host name of a notification. |
As per the MIB. |
mteHotContextName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteHotContextName (1.3.6.1.2.1.88.2.1.3) |
SnmpAdminString |
Context name of a notification. |
As per the MIB. |
mteHotOID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteHotOID (1.3.6.1.2.1.88.2.1.4) |
OBJECT IDENTIFIER |
OID of the target object related to a notification. |
If the notification is triggered by mteTriggerFired, mteTriggerRising, mteTriggerFalling, or mteTriggerFailure, the OID is the OID of the monitored object. If the notification is triggered by mteEventSetFailure, the OID is the OID of the set object. |
mteHotValue
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteHotValue (1.3.6.1.2.1.88.2.1.5) |
Integer32 |
Value of the target object to match the trigger condition of a trigger. |
As per the MIB. |
mteFailedReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteFailedReason (1.3.6.1.2.1.88.2.1.5) |
FailureReason |
localResourceLack(-1), badDestination(-2), destinationUnreachable(-3), noResponse(-4), badType(-5), sampleOverrun(-6), noError(0), tooBig(1), noSuchName(2), badValue(3), readOnly(4), genErr(5), noAccess(6), wrongType(7), wrongLength(8), wrongEncoding(9), wrongValue(10), noCreation(11), inconsistentValue(12), resourceUnavailable(13), commitFailed(14), undoFailed(15), authorizationError(16), notWritable(17), inconsistentName(18) |
Trigger failure reason. |
As per the MIB. |
Tabular objects
mteTriggerTable
About this table
Use this table to configure or obtain information about triggers, including specifying monitored objects and setting the trigger test type, sampling interval, and sampling method.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
· To set the state of a row to createAndGo when creating the row, the objects in the row must meet the following requirements:
¡ The index of the row does not exist and an SNMPv3 user with name mteOwner exists. In addition, the privileges of the SNMPv3 user are equal to or less than the privileges of the current operator.
¡ The node type of monitored objects must be one of the following types: table, conceptual row, table column, simple leaf, or parent node of a leaf node.
¡ Set mteTriggerTargetTag to null.
¡ The value of mteTriggerFrequency must be equal to or greater than the value of mteResourceSampleMinimum.
¡ The mteTriggerObjectsOwner object must be an SNMPv3 user and the privileges of the SNMPv3 user are equal to or less than the privileges of the current operator.
¡ Do not set the mteTriggerEnabled node.
¡ Other nodes meet the MIB definitions.
· To set the state of a row to createAndWait when creating the row, the objects in the row must meet the following requirements:
¡ The node type of monitored objects must be one of the following types or the default type: table, conceptual row, table column, simple leaf, or parent node of a leaf node.
· If a row is in active state, you can perform the delete operation and cannot perform the edit/modify operation.
· To change the state of a row from notInService to active, the objects in the row must meet the following requirements:
¡ The mteTriggerObjectsOwner object must an SNMPv3 user and the privileges of the SNMPv3 user are equal to or less than the privileges of the current operator.
¡ Do not modify the mteTriggerEnabled object.
Columns
The table indexes are mteOwner and mteTriggerName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteOwner (1.3.6.1.2.1.88.1.2.2.1.1) |
not-accessible |
SnmpAdminString |
OCTET STRING (0..32) |
Level 1 index of the table. |
Supports only SNMPv3 users. You must configure the specified SNMPv3 user as the current operator. |
mteTriggerName (1.3.6.1.2.1.88.1.2.2.1.2) |
not-accessible |
SnmpAdminString |
OCTET STRING (1..32) |
Trigger name. Level 2 index of the table. |
As per the MIB. |
mteTriggerComment (1.3.6.1.2.1.88.1.2.2.1.3) |
read-create |
SnmpAdminString |
Trigger description. |
The first and last spaces in the string will be automatically removed. |
mteTriggerTest (1.3.6.1.2.1.88.1.2.2.1.4) |
read-create |
BITS |
BITS {existence(0), boolean(1), threshold(2)} |
As per the MIB. |
mteTriggerSampleType (1.3.6.1.2.1.88.1.2.2.1.5) |
read-create |
INTEGER |
absoluteValue(1), deltaValue(2) |
As per the MIB. |
mteTriggerValueID (1.3.6.1.2.1.88.1.2.2.1.6) |
read-create |
OBJECT IDENTIFIER |
OBJECT IDENTIFIER |
OID of the monitored object. |
Supports only table nodes, conceptual row nodes, table column nodes, simple leaf nodes, and parent nodes of leaf nodes. |
mteTriggerValueIDWildcard (1.3.6.1.2.1.88.1.2.2.1.7) |
read-create |
TruthValue |
true(1), false(2) |
Whether to enable wildcard search for objects. |
As per the MIB. |
mteTriggerTargetTag (1.3.6.1.2.1.88.1.2.2.1.8) |
read-create |
SnmpTagValue |
Remote tag for the monitored object. A length of 0 indicates the local system. This object supports only the local system. |
Supports only the read operation. |
mteTriggerContextName (1.3.6.1.2.1.88.1.2.2.1.9) |
read-create |
SnmpAdminString |
Name of the context for the OID of the monitored object. |
As per the MIB. |
mteTriggerContextNameWildcard (1.3.6.1.2.1.88.1.2.2.1.10) |
read-create |
TruthValue |
true(1), false(2) |
Whether to enable wildcard search for contexts. |
As per the MIB. |
mteTriggerFrequency (1.3.6.1.2.1.88.1.2.2.1.11) |
read-create |
Unsigned32 |
Unsigned32 (0..4294967295) |
Sampling interval. The value must be equal to or greater than the minimum sampling interval. |
The value of 0 is not supported. |
mteTriggerObjectsOwner (1.3.6.1.2.1.88.1.2.2.1.12) |
read-create |
SnmpAdminString |
Owner of the objects bound to the trigger. |
As per the MIB. |
mteTriggerObjects (1.3.6.1.2.1.88.1.2.2.1.13) |
read-create |
SnmpAdminString |
Objects bound to the trigger. |
As per the MIB. |
mteTriggerEnabled (1.3.6.1.2.1.88.1.2.2.1.14) |
read-create |
TruthValue |
true(1), false(2) |
Whether to enable the trigger When the value is false, the trigger is not sampled. |
Supports only the read operation. The read value for this object is true(1) if the state of the mteTriggerEntryStatus row is active. |
mteTriggerEntryStatus (1.3.6.1.2.1.88.1.2.2.1.15) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
mteTriggerExistenceTable
About this table
Use this table to configure or obtain information about existence trigger tests. It specifies the existence trigger test type, configures the type of the existence trigger test for the first sampling, and specifies the monitored objects and trigger event.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
To modify the object owner or event owner for a row, the follow requirements must be met:
· The new owner must be an existing SNMPv3 user.
· The privileges of the new owner must be equal to or lower than the privileges of the current operator.
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteTriggerExistenceTest (1.3.6.1.2.1.88.1.2.4.1.1) |
read-write |
BITS |
BITS {present(0), absent(1), changed(2)} |
Type of an existence trigger test. |
As per the MIB. |
mteTriggerExistenceStartup (1.3.6.1.2.1.88.1.2.4.1.2) |
read-write |
BITS |
BITS {present(0), absent(1)} |
Type of the existence trigger test for the first sampling. |
As per the MIB. |
mteTriggerExistenceObjectsOwner (1.3.6.1.2.1.88.1.2.4.1.3) |
read-write |
SnmpAdminString |
Owner of the existence trigger test objects. |
Supports only SNMPv3 users. The configuration is the same as the mteOwner object in the Trigger table. |
mteTriggerExistenceObjects (1.3.6.1.2.1.88.1.2.4.1.4) |
read-write |
SnmpAdminString |
Objects of the existence trigger test. |
As per the MIB. |
mteTriggerExistenceEventOwner (1.3.6.1.2.1.88.1.2.4.1.5) |
read-write |
SnmpAdminString |
Event owner. |
mteTriggerExistenceEvent (1.3.6.1.2.1.88.1.2.4.1.6) |
read-write |
SnmpAdminString |
Event name. |
As per the MIB. |
mteTriggerBooleanTable
About this table
Use this table to configure or obtain information about Boolean trigger tests. It specifies the Boolean trigger test type and the reference value, configures whether to enable the event for the first sampling, and specifies the monitored objects and trigger event.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteTriggerBooleanComparison (1.3.6.1.2.1.88.1.2.5.1.1) |
read-write |
INTEGER |
unequal(1), equal(2), less(3), lessOrEqual(4), greater(5), greaterOrEqual(6) |
Type of a Boolean trigger test. The comparison objects are mteTriggerValueID and mteTriggerBooleanValue. |
As per the MIB. |
mteTriggerBooleanValue (1.3.6.1.2.1.88.1.2.5.1.2) |
read-write |
Integer32 |
Integer32 (-2147483648..2147483647) |
Reference value for the Boolean trigger test. |
As per the MIB. |
mteTriggerBooleanStartup (1.3.6.1.2.1.88.1.2.5.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Whether the event is enabled for the first sampling. |
As per the MIB. |
mteTriggerBooleanObjectsOwner (1.3.6.1.2.1.88.1.2.5.1.4) |
read-write |
SnmpAdminString |
Owner of the Boolean trigger test objects. |
Supports only SNMPv3 users. The configuration must be the same as that of the mteOwner object. |
mteTriggerBooleanObjects (1.3.6.1.2.1.88.1.2.5.1.5) |
read-write |
SnmpAdminString |
Name of the Boolean trigger test objects. |
As per the MIB. |
mteTriggerBooleanEventOwner (1.3.6.1.2.1.88.1.2.5.1.6) |
read-write |
SnmpAdminString |
Owner of the Boolean event. |
mteTriggerBooleanEvent (1.3.6.1.2.1.88.1.2.5.1.7) |
read-write |
SnmpAdminString |
Name of the Boolean event. |
As per the MIB. |
mteTriggerThresholdTable
About this table
Use this table to configure or obtain information about threshold trigger tests. It specifies the threshold trigger test type for the first sampling, sets the absolute or delta rising or falling threshold, and configures the monitored objects and the trigger event.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
When you perform the edit/modify operation, follow these restrictions and guidelines:
· The rising threshold must be equal to or higher than the falling threshold.
· The delta rising threshold must be equal to or higher than the delta falling threshold.
· To modify the object owner or event owner for a row, the follow requirements must be met:
¡ The new owner must be an existing SNMPv3 user.
¡ The privileges of the new owner must be equal to or lower than the privileges of the current operator.
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteTriggerThresholdStartup (1.3.6.1.2.1.88.1.2.6.1.1) |
read-write |
INTEGER |
rising(1), falling(2), risingOrFalling(3) |
Threshold trigger test for the first sampling. |
As per the MIB. |
mteTriggerThresholdRising (1.3.6.1.2.1.88.1.2.6.1.2) |
read-write |
Integer32 |
Absolute rising threshold. |
As per the MIB. |
mteTriggerThresholdFalling (1.3.6.1.2.1.88.1.2.6.1.3) |
read-write |
Integer32 |
Absolute falling threshold. |
As per the MIB. |
mteTriggerThresholdDeltaRising (1.3.6.1.2.1.88.1.2.6.1.4) |
read-write |
Integer32 |
Delta rising threshold. |
As per the MIB. |
mteTriggerThresholdDeltaFalling (1.3.6.1.2.1.88.1.2.6.1.5) |
read-write |
Integer32 |
Delta falling threshold. |
As per the MIB. |
mteTriggerThresholdObjectsOwner (1.3.6.1.2.1.88.1.2.6.1.6) |
read-write |
SnmpAdminString |
Owner of the threshold test objects. |
Do not configure this object or configure the same settings for this object as the mteOwner object in the Trigger table. |
mteTriggerThresholdObjects (1.3.6.1.2.1.88.1.2.6.1.7) |
read-write |
SnmpAdminString |
Name of the threshold test objects. |
As per the MIB. |
mteTriggerThresholdRisingEventOwner (1.3.6.1.2.1.88.1.2.6.1.8) |
read-write |
SnmpAdminString |
Owner of the rising event. |
mteTriggerThresholdRisingEvent (1.3.6.1.2.1.88.1.2.6.1.9) |
read-write |
SnmpAdminString |
Name of the rising event. |
As per the MIB. |
mteTriggerThresholdFallingEventOwner (1.3.6.1.2.1.88.1.2.6.1.10) |
read-write |
SnmpAdminString |
Owner of the falling event. |
mteTriggerThresholdFallingEvent (1.3.6.1.2.1.88.1.2.6.1.11) |
read-write |
SnmpAdminString |
Name of the falling event. |
As per the MIB. |
mteTriggerThresholdDeltaRisingEventOwner (1.3.6.1.2.1.88.1.2.6.1.12) |
read-write |
SnmpAdminString |
Owner of the Delta rising event. |
mteTriggerThresholdDeltaRisingEvent (1.3.6.1.2.1.88.1.2.6.1.13) |
read-write |
SnmpAdminString |
Name of the Delta rising event. |
As per the MIB. |
mteTriggerThresholdDeltaFallingEventOwner (1.3.6.1.2.1.88.1.2.6.1.14) |
read-write |
SnmpAdminString |
Owner of the Delta falling event. |
mteTriggerThresholdDeltaFallingEvent (1.3.6.1.2.1.88.1.2.6.1.15) |
read-write |
SnmpAdminString |
Name of the Delta falling event. |
As per the MIB. |
mteObjectsTable
About this table
Use this table to configure or obtain monitored objects, including specifying the name of a monitored object and binding the OID of the object to a trigger.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
The state of a row can be set only to createAndGo. In addition, the following requirements must be met:
· The index of the row does not exist.
· The monitored OID nodes must be one of the following types: table, conceptual row, table column, simple leaf, and parent node of a leaf node.
Columns
The table indexes are mteOwner, mteObjectsName, and mteObjectsIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteObjectsName (1.3.6.1.2.1.88.1.3.1.1.1) |
not-accessible |
SnmpAdminString |
A locally-unique, administratively assigned name for a group of objects. Level 2 index. |
As per the MIB. |
mteObjectsIndex (1.3.6.1.2.1.88.1.3.1.1.2) |
not-accessible |
Unsigned32 |
Unsigned32 (1..2147483647) |
An arbitrary integer for the purpose of identifying individual objects within a mteObjectsName group. Level 3 index. |
As per the MIB. |
mteObjectsID (1.3.6.1.2.1.88.1.3.1.1.3) |
read-create |
OBJECT IDENTIFIER |
OBJECT IDENTIFIER |
OID of the objects. |
Supports one of the following node types: table, conceptual row, table column, simple leaf, and parent node of a leaf node. |
mteObjectsIDWildcard (1.3.6.1.2.1.88.1.3.1.1.4) |
read-create |
TruthValue |
true(1), false(2) |
Whether to enable wildcard matching. |
As per the MIB. |
mteObjectsEntryStatus (1.3.6.1.2.1.88.1.3.1.1.5) |
read-create |
RowStatus |
Row status. |
Supports only createAndGo, active, and destroy. |
mteEventTable
About this table
Use this table to configure or obtain information about events, including configuring the event name, event description, and event action type.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
¡ The index of the row does not exist.
¡ Set mteEventActions to set or notification, or both.
¡ Do not set mteEventEnabled.
¡ Do not set the mteEventEnabled node together with the row state.
· To change a row from notInService state to active, the objects in the row must meet the following requirements:
¡ Do not configure the mteEventEnabled node.
Columns
The table indexes are mteOwner and mteEventName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteEventName (1.3.6.1.2.1.88.1.4.2.1.1) |
not-accessible |
SnmpAdminString |
Event name. |
As per the MIB. |
mteEventComment (1.3.6.1.2.1.88.1.4.2.1.2) |
read-create |
SnmpAdminString |
Event description. |
The first and last spaces will be deleted automatically. |
mteEventActions (1.3.6.1.2.1.88.1.4.2.1.3) |
read-create |
BITS |
BITS { notification(0), set(1)} |
Event action type. |
As per the MIB. |
mteEventEnabled (1.3.6.1.2.1.88.1.4.2.1.4) |
read-create |
TruthValue |
true(1), false(2) |
Enabling status of the event. |
Supports only the read operation. When the value of mteEventEntryStatus is active, the return value of this object for the read operation is true(1). |
mteEventEntryStatus (1.3.6.1.2.1.88.1.4.2.1.5) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
mteEventNotificationTable
About this table
Use this table to configure or obtain information about notifications, including specifying the OID of a notification and binding objects to the notification.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
· The node of the object that inputs the notification is a trap node.
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteEventNotification (1.3.6.1.2.1.88.1.4.3.1.1) |
read-write |
OBJECT IDENTIFIER |
Notification OID. |
As per the MIB. |
mteEventNotificationObjectsOwner (1.3.6.1.2.1.88.1.4.3.1.2) |
read-write |
SnmpAdminString |
Owner of the objects bound to the notification. |
Do not configure this object or configure the same settings as the mteOwner object in the Event table. |
mteEventNotificationObjects (1.3.6.1.2.1.88.1.4.3.1.3) |
read-write |
SnmpAdminString |
Name of the objects bound to the notification. |
As per the MIB. |
mteEventSetTable
About this table
Use this MIB to configure or obtain information about set objects, including specifying an event for set objects and setting a value for the objects.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
The node type of a set object is from one of the following types: table, conceptual row, table column, simple leaf, and parent node of a leaf node.
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mteEventSetObject (1.3.6.1.2.1.88.1.4.4.1.1) |
read-write |
OBJECT IDENTIFIER |
OID of a set-action object. |
Supports only the following types of nodes: table, conceptual row, table column, simple leaf, and parent node of a leaf node. |
mteEventSetObjectWildcard (1.3.6.1.2.1.88.1.4.4.1.2) |
read-write |
TruthValue |
true(1), false(2) |
As per the MIB. |
mteEventSetValue (1.3.6.1.2.1.88.1.4.4.1.3) |
read-write |
Integer32 |
Value of the set-action object. |
As per the MIB. |
mteEventSetTargetTag (1.3.6.1.2.1.88.1.4.4.1.4) |
read-write |
SnmpTagValue |
Remote tag for the set-action object. |
Supports only the read operation. This object does not support the edit/modify operation. |
mteEventSetContextName (1.3.6.1.2.1.88.1.4.4.1.5) |
read-write |
SnmpAdminString |
Context for the set-action object. |
mteEventSetContextNameWildcard (1.3.6.1.2.1.88.1.4.4.1.6) |
read-write |
TruthValue |
true(1), |
As per the MIB. |
Notifications
The following information describes the notifications included in the DISMAN-EVENT-MIB module.
mteTriggerFired
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.88.2.0.1 |
A notification was triggered by a trigger test. |
Informational |
N/A |
N/A |
ON |
This notification is generated when a monitored object meets the trigger condition.
If an existence trigger test is configured, this notification is generated when the state of the monitored object changes from absent to present or from present to absent, or the value of the object changes.
If a Boolean trigger test is configured, this notification is generated if the comparison result for the value of the monitored object and the value of mteTriggerBooleanValue meets the trigger condition. If the comparison result changes from meeting the trigger condition to not meeting the trigger condition and then changing back to meeting the trigger condition, this notification is generated again. In other situations, this notification is not generated.
Status control
ON
CLI: Use the snmp-agent trap enable event-mib command.
OFF
CLI: Use the undo snmp-agent trap enable event-mib command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.88.2.1.1 (mteHotTrigger) |
Trigger name |
N |
SnmpAdminString |
1.3.6.1.2.1.88.2.1.2 (mteHotTargetName) |
Target host name. |
N |
SnmpAdminString |
1.3.6.1.2.1.88.2.1.3(mteHotContextName) |
Context name. |
N |
SnmpAdminString |
1.3.6.1.2.1.88.2.1.4(mteHotOID) |
Monitored object OID. |
N |
OBJECT IDENTIFIER |
1.3.6.1.2.1.88.2.1.5(mteHotValue) |
Value of the monitored object. |
N |
Integer32 |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
Configure an event to handle the notification.
mteTriggerRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.88.2.0.2 |
A rising alarm event was triggered. |
Informational |
N/A |
N/A |
ON |
If a threshold trigger test is configured and the value of mteTriggerThresholdStartup is rising or risingOrFaling, this notification is generated when the monitored object meets the trigger condition.
· The value of the monitored object is greater than or equal to the rising threshold, this notification is generated.
· The difference between the current sampled value and the previous sampled value is greater than or equal to the delta rising threshold, this notification is generated.
If the value of the monitored object crosses a threshold multiple times in succession, the managed device triggers an alarm event only for the first crossing. For example, if the value of a sampled object crosses the rising threshold multiple times before it crosses the falling threshold, only the first crossing triggers a rising alarm event.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Trigger name. |
N |
SnmpAdminString |
Target host name. |
N |
SnmpAdminString |
Context name. |
N |
SnmpAdminString |
N |
OBJECT IDENTIFIER |
N |
Integer32 |
Recommended action
mteTriggerFalling
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.88.2.0.3 |
A falling alarm event was triggered |
Informational |
N/A |
N/A |
ON |
If a threshold trigger test is configured and the value of mteTriggerThresholdStartup is falling or risingOrFaling, this notification is generated when the monitored object meets the trigger condition.
· If the value of the monitored object is smaller than or equal to the falling threshold, this notification is generated.
· If the difference between the current sampled value and the previous sampled value is smaller than or equal to the delta falling threshold, this notification is generated.
If the value of the monitored object crosses a threshold multiple times in succession, the managed device triggers an alarm event only for the first crossing. For example, if the value of a sampled object crosses the falling threshold multiple times before it crosses the rising threshold, only the first crossing triggers a falling alarm event.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Trigger name. |
N |
SnmpAdminString |
Target host name. |
N |
SnmpAdminString |
Context name. |
N |
SnmpAdminString |
N |
OBJECT IDENTIFIER |
N |
Integer32 |
Recommended action
mteTriggerFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.88.2.0.4 |
Trigger test failure notification. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the system fails a trigger test.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.88.2.1.1(mteHotTrigger) |
Trigger name. |
N |
SnmpAdminString |
1.3.6.1.2.1.88.2.1.2(mteHotTargetName) |
Target host name. |
N |
SnmpAdminString |
Context name. |
N |
SnmpAdminString |
N |
OBJECT IDENTIFIER |
1.3.6.1.2.1.88.2.1.6(mteFailedReason) |
Failure reason |
N |
INTEGER |
Recommended action
No action is required.
mteEventSetFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.88.2.0.5 |
Event set-action failure notification. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the system fails to perform a set operation in response to an event.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Trigger name. |
N |
SnmpAdminString |
Target host name. |
N |
SnmpAdminString |
Context name. |
N |
SnmpAdminString |
N |
OBJECT IDENTIFIER |
Failure reason |
N |
INTEGER |
