06-RMON-MIB | 89.54 KB |
RMON-MIB
About this MIB
Use this MIB to monitor data traffic on a network segment or the entire network.
MIB file name
rfc2819-rmon.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).rmon(16)
Tabular objects
etherStatsTable
About this table
Use this table to obtain statistics about Ethernet interfaces.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
You must specify etherStatsDataSource and etherStatsStatus in pairs when creating a row of instances. |
Not supported |
Supported |
Supported |
Columns
The table index is etherStatsIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
etherStatsIndex (1.3.6.1.2.1.16.1.1.1.1) |
read-only |
Integer32 |
Integer32 (1..65535) |
Index of an etherStats entry. |
As per the MIB. |
etherStatsDataSource (1.3.6.1.2.1.16.1.1.1.2) |
read-create |
OBJECT IDENTIFIER |
Standard MIB values. |
Interface on which statistics are gathered. |
As per the MIB. |
etherStatsDropEvents (1.3.6.1.2.1.16.1.1.1.3) |
read-only |
Counter32 |
Total number of events in which packets were dropped. |
Implementation varies by product.. |
etherStatsOctets (1.3.6.1.2.1.16.1.1.1.4) |
read-only |
Counter32 |
Total number of octets received on the interface. |
Implementation varies by product. |
etherStatsPkts (1.3.6.1.2.1.16.1.1.1.5) |
read-only |
Counter32 |
Total number of packets received on the interface. |
etherStatsBroadcastPkts (1.3.6.1.2.1.16.1.1.1.6) |
read-only |
Counter32 |
Total number of broadcast packets received on the interface. |
etherStatsMulticastPkts (1.3.6.1.2.1.16.1.1.1.7) |
read-only |
Counter32 |
Total number of multicast packets received on the interface. |
etherStatsCRCAlignErrors (1.3.6.1.2.1.16.1.1.1.8) |
read-only |
Counter32 |
Total number of packets with CRC errors received on the interface. |
etherStatsUndersizePkts (1.3.6.1.2.1.16.1.1.1.9) |
read-only |
Counter32 |
Total number of undersize packets received on the interface. |
etherStatsOversizePkts (1.3.6.1.2.1.16.1.1.1.10) |
read-only |
Counter32 |
Total number of oversize packets received on the interface. |
etherStatsFragments (1.3.6.1.2.1.16.1.1.1.11) |
read-only |
Counter32 |
Total number of undersize packets with FCS errors received on the interface. |
etherStatsJabbers (1.3.6.1.2.1.16.1.1.1.12) |
read-only |
Counter32 |
Total number of oversize packets with FCS errors received on the interface. |
etherStatsCollisions (1.3.6.1.2.1.16.1.1.1.13) |
read-only |
Counter32 |
Total number of colliding packets received on the interface. |
etherStatsPkts64Octets (1.3.6.1.2.1.16.1.1.1.14) |
read-only |
Counter32 |
Total number of packets with a length smaller than or equal to 64 octets received on the interface. |
etherStatsPkts65to127Octets (1.3.6.1.2.1.16.1.1.1.15) |
read-only |
Counter32 |
Total number of 65- to 127-octet packets received on the interface. |
etherStatsPkts128to255Octets (1.3.6.1.2.1.16.1.1.1.16) |
read-only |
Counter32 |
Total number of 128- to 255-octet packets received on the interface |
etherStatsPkts256to511Octets (1.3.6.1.2.1.16.1.1.1.17) |
read-only |
Counter32 |
Total number of 256- to 511-octet packets received on the interface. |
etherStatsPkts512to1023Octets (1.3.6.1.2.1.16.1.1.1.18) |
read-only |
Counter32 |
Total number of 512- to 1023-octet packets received on the interface |
etherStatsPkts1024to1518Octets (1.3.6.1.2.1.16.1.1.1.19) |
read-only |
Counter32 |
Total number of 1024- to 1518-octet packets received on the interface |
etherStatsOwner (1.3.6.1.2.1.16.1.1.1.20) |
read-create |
OwnerString |
OCTET STRING (0..127) |
Owner of the etherStats entry. |
Not-displayable characters or question marks are not allowed. The default value is a zero-length string. |
etherStatsStatus (1.3.6.1.2.1.16.1.1.1.21) |
read-create |
EntryStatus |
valid(1), |
Status of the etherStats entry. |
As per the MIB. |
historyControlTable
About this table
Use this table to configure history control entries.
Create |
Edit/Modify |
Delete |
Read |
You must specify historyControlDataSource and historyControlStatus in pairs when creating an instance. |
Not supported |
Supported |
Supported |
Columns
The table index is historyControlIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
historyControlIndex (1.3.6.1.2.1.16.2.1.1.1) |
read-only |
Integer32 |
Index of a historyControl entry. |
As per the MIB. |
historyControlDataSource (1.3.6.1.2.1.16.2.1.1.2) |
read-create |
OBJECT IDENTIFIER |
Interface on which historical data was collected. |
As per the MIB. |
historyControlBucketsRequested (1.3.6.1.2.1.16.2.1.1.3) |
read-create |
Integer32 |
Requested number of samples to be retained for the entry. |
A maximum of 50 samples are supported. You can set a value larger than 50 for this object, but only 50 samples are supported. |
historyControlBucketsGranted (1.3.6.1.2.1.16.2.1.1.4) |
read-only |
Integer32 |
Granted number of samples to be retained for the entry. |
As per the MIB. |
historyControlInterval (1.3.6.1.2.1.16.2.1.1.5) |
read-create |
Integer32 |
Integer32 (1..3600) |
Sampling interval in seconds. |
Value range: 5 to 3600 Default: 1800 |
historyControlOwner (1.3.6.1.2.1.16.2.1.1.6) |
read-create |
OwnerString |
Owner of this entry. |
historyControlStatus (1.3.6.1.2.1.16.2.1.1.7) |
read-create |
EntryStatus |
valid(1), |
Statistics about this entry. |
As per the MIB. |
etherHistoryTable
About this table
Use this table to obtain information about RMON history control entries and history samples of Ethernet statistics for Ethernet interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are etherHistoryIndex and etherHistorySampleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
etherHistoryIndex (1.3.6.1.2.1.16.2.2.1.1) |
read-only |
Integer32 |
Index of an etherHistory entry. |
As per the MIB. |
etherHistorySampleIndex (1.3.6.1.2.1.16.2.2.1.2) |
read-only |
Integer32 |
Integer32 (1..2147483647) |
Index of a sample. |
As per the MIB. |
etherHistoryIntervalStart (1.3.6.1.2.1.16.2.2.1.3) |
read-only |
TimeTicks |
Sampling start time. |
As per the MIB. |
etherHistoryDropEvents (1.3.6.1.2.1.16.2.2.1.4) |
read-only |
Counter32 |
Total number of events in which packets were dropped during this sampling interval. |
etherHistoryOctets (1.3.6.1.2.1.16.2.2.1.5) |
read-only |
Counter32 |
Total number of octets received on the interface during this sampling interval. |
etherHistoryPkts (1.3.6.1.2.1.16.2.2.1.6) |
read-only |
Counter32 |
Total number of packets received during this sampling interval. |
etherHistoryBroadcastPkts (1.3.6.1.2.1.16.2.2.1.7) |
read-only |
Counter32 |
Total number of broadcast packets received during this sampling interval. |
etherHistoryMulticastPkts (1.3.6.1.2.1.16.2.2.1.8) |
read-only |
Counter32 |
Total number of multicast packets received during this sampling interval. |
etherHistoryCRCAlignErrors (1.3.6.1.2.1.16.2.2.1.9) |
read-only |
Counter32 |
Total number of packets with CRC alignment errors received during the sampling interval. |
etherHistoryUndersizePkts (1.3.6.1.2.1.16.2.2.1.10) |
read-only |
Counter32 |
Total number of undersize packets received during the sampling interval. |
etherHistoryOversizePkts (1.3.6.1.2.1.16.2.2.1.11) |
read-only |
Counter32 |
Total number of oversize packets received during the sampling interval. |
etherHistoryFragments (1.3.6.1.2.1.16.2.2.1.12) |
read-only |
Counter32 |
Total number of undersize packets with FCS errors received during the sampling interval. |
etherHistoryJabbers (1.3.6.1.2.1.16.2.2.1.13) |
read-only |
Counter32 |
Total number of oversize packets with FCS errors received during the sampling interval. |
etherHistoryCollisions (1.3.6.1.2.1.16.2.2.1.14) |
read-only |
Counter32 |
Total number of colliding packets received during the sampling interval. |
etherHistoryUtilization (1.3.6.1.2.1.16.2.2.1.15) |
read-only |
Integer32 |
Integer32 (0..10000) |
Bandwidth utilization during the sampling period. |
alarmTable
About this table
Use this table to configure alarm entries.
Create |
Edit/Modify |
Delete |
Read |
You must specify alarmVariable and alarmStatus in pairs when creating a row of instances. If the buildruns of the instances exceed the maximum specification, the creation fails. |
Not supported |
Supported |
Supported |
Columns
The table index is alarmIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
alarmIndex (1.3.6.1.2.1.16.3.1.1.1) |
read-only |
Integer32 |
Index of an RMON alarm entry. |
As per the MIB. |
alarmInterval (1.3.6.1.2.1.16.3.1.1.2) |
read-create |
Integer32 |
Value range: 5 to 3600. Default value: 1800. |
alarmVariable (1.3.6.1.2.1.16.3.1.1.3) |
read-create |
OBJECT IDENTIFIER |
OID of the variable to be sampled. |
As per the MIB. |
alarmSampleType (1.3.6.1.2.1.16.3.1.1.4) |
read-create |
INTEGER |
absoluteValue(1), |
Sampling type. |
Default value: absoluteValue(1). |
alarmValue (1.3.6.1.2.1.16.3.1.1.5) |
read-only |
Integer32 |
Value of the sampled variable. |
If the object value exceeds the maximum positive value, the negation of the object value is returned when read. |
alarmStartupAlarm (1.3.6.1.2.1.16.3.1.1.6) |
read-create |
INTEGER |
risingAlarm(1), |
Alarms that can be generated at the first sampling. |
Default value: risingOrFallingAlarm(3). |
alarmRisingThreshold (1.3.6.1.2.1.16.3.1.1.7) |
read-create |
Integer32 |
Rising threshold. |
Default value: 1. |
alarmFallingThreshold (1.3.6.1.2.1.16.3.1.1.8) |
read-create |
Integer32 |
Falling threshold. |
Default value: 0. |
alarmRisingEventIndex (1.3.6.1.2.1.16.3.1.1.9) |
read-create |
Integer32 |
Integer32 (0..65535) |
Index of the event that is triggered when the rising threshold is crossed. |
Default value: 0. |
alarmFallingEventIndex (1.3.6.1.2.1.16.3.1.1.10) |
read-create |
Integer32 |
Index of the event that is triggered when the falling threshold is crossed. |
Default value: 0. |
alarmOwner (1.3.6.1.2.1.16.3.1.1.11) |
read-create |
OwnerString |
Owner of the alarm entry. |
Not-displayable characters or question marks are not allowed. Default value: zero-length string. |
alarmStatus (1.3.6.1.2.1.16.3.1.1.12) |
read-create |
EntryStatus |
valid(1), createRequest(2), underCreation(3), invalid(4) |
Status of the alarm entry. |
As per the MIB. |
eventTable
About this table
Use this table to configure event entries.
Create |
Edit/Modify |
Delete |
Read |
Supported. You must specify eventStatus when creating a row of instances. If the buildruns of the instances exceed the maximum specification, the creation fails. |
Not supported |
Supported |
Supported |
Columns
The table index is eventIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
eventIndex (1.3.6.1.2.1.16.9.1.1.1) |
read-only |
Integer32 |
Event entry index. |
As per the MIB. |
eventDescription (1.3.6.1.2.1.16.9.1.1.2) |
read-create |
DisplayString |
Event description. |
Default value: Zero-length string. |
eventType (1.3.6.1.2.1.16.9.1.1.3) |
read-create |
INTEGER |
none(1), log(2), snmptrap(3), logandtrap(4) |
Event type. |
Default value: none(1) |
eventCommunity (1.3.6.1.2.1.16.9.1.1.4) |
read-create |
OCTET STRING |
SNMP community to which an SNMP trap is sent. |
Not supported. |
eventLastTimeSent (1.3.6.1.2.1.16.9.1.1.5) |
read-only |
TimeTicks |
TimeTicks (0..4294967295) |
Time at which the most recent event occurs. |
As per the MIB. |
eventOwner (1.3.6.1.2.1.16.9.1.1.6) |
read-create |
OwnerString |
Event owner. |
Not-displayable characters or question marks are not allowed. Default value: Zero-length string. |
eventStatus (1.3.6.1.2.1.16.9.1.1.7) |
read-create |
EntryStatus |
Event status. |
As per the MIB. |
logTable
About this table
Use this table to obtain event logs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are logEventIndex and logIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
logEventIndex (1.3.6.1.2.1.16.9.2.1.1) |
read-only |
Integer32 |
Index of the event entry that generated this log entry. |
As per the MIB. |
logIndex (1.3.6.1.2.1.16.9.2.1.2) |
read-only |
Integer32 |
Index of the log entry. |
As per the MIB. |
logTime (1.3.6.1.2.1.16.9.2.1.3) |
read-only |
TimeTicks |
Time when the log entry was created. |
As per the MIB. |
logDescription (1.3.6.1.2.1.16.9.2.1.4) |
read-only |
DisplayString |
OCTET STRING (0..255) |
Description of the event that activated this log entry. |
As per the MIB. |
Notifications
This section contains the RMON-MIB notifications.
risingAlarm
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.16.0.1 |
An alarm entry crossed its rising threshold |
Informational |
N/A |
N/A |
ON |
This notification is generated when an alarm entry crosses its rising threshold and generates an event configured for sending SNMP traps.
Status control
ON
CLI: Use the rmon event entry-number [ description string ] { log-trap security-string | trap security-string } [ owner text ] command.
OFF
CLI: Use the rmon event entry-number [ description string ] { log | none } [ owner text ] command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.16.3.1.1.1 (alarmIndex) |
Index of the alarm entry |
Y |
Integer32 |
1..65535 |
1.3.6.1.2.1.16.3.1.1.3 (alarmVariable) |
Variable to be sampled |
N |
OBJECT IDENTIFIER |
1.3.6.1.2.1.16.3.1.1.4 (alarmSampleType) |
Sampling type |
N |
INTEGER |
absoluteValue(1) deltaValue(2) |
1.3.6.1.2.1.16.3.1.1.5 (alarmValue) |
Sampled value |
N |
Integer32 |
1.3.6.1.2.1.16.3.1.1.7 (alarmRisingThreshold) |
Rising threshold |
N |
Integer32 |
Recommended action
To resolve the issue:
1. Check the monitored object for the reason that causes the alarm.
2. If the issue persists, contact H3C Support.
fallingAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.16.0.2 |
An alarm entry crossed its falling threshold |
Informational |
N/A |
N/A |
ON |
A notification sent when an alarm entry crosses its falling threshold and generates an event configured for sending SNMP traps.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Y |
Integer32 |
1..65535 |
N |
OBJECT IDENTIFIER |
Sampling type |
N |
INTEGER |
absoluteValue(1), deltaValue(2) |
Sampled value |
N |
Integer32 |
1.3.6.1.2.1.16.3.1.1.8 (alarmFallingThreshold) |
Falling threshold |
N |
Integer32 |
Recommended action
No action is required.
