08-HH3C-UI-MAN-MIB | 68.38 KB |
hh3cTerminalUserName (1.3.6.1.4.1.25506.2.2.1.1.2.1)
hh3cTerminalSource (1.3.6.1.4.1.25506.2.2.1.1.2.2)
hh3cTerminalUserAuthFailureReason (1.3.6.1.4.1.25506.2.2.1.1.2.3)
hh3cVtyCurrentVty (1.3.6.1.4.1.25506.2.2.1.1.2.4)
hh3cVtyMaxVty (1.3.6.1.4.1.25506.2.2.1.1.2.5)
hh3cVtyThreshold (1.3.6.1.4.1.25506.2.2.1.1.2.6)
HH3C-UI-MAN-MIB
About this MIB
Use this MIB to obtain and manage alarms on user authentication. This MIB also contains notifications about user login changes.
MIB file name
hh3c-ui-man.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cUIMgt(2)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTerminalUserName (1.3.6.1.4.1.25506.2.2.1.1.2.1) |
accessible-for-notify |
DisplayString |
Standard MIB values. |
Name of a login user. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTerminalSource (1.3.6.1.4.1.25506.2.2.1.1.2.2) |
DisplayString |
Login method, including Console, AUX, TTY, and VTY. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTerminalUserAuthFailureReason (1.3.6.1.4.1.25506.2.2.1.1.2.3) |
INTEGER |
exceedRetries(1) authTimeout(2) otherReason(3) |
Failure reason for user authentication. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVtyCurrentVty (1.3.6.1.4.1.25506.2.2.1.1.2.4) |
Unsigned32 |
Number of used VTY lines. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVtyMaxVty (1.3.6.1.4.1.25506.2.2.1.1.2.5) |
Unsigned32 |
Maximum number of VTY lines that the system allows users to log in to concurrently. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVtyThreshold (1.3.6.1.4.1.25506.2.2.1.1.2.6) |
Unsigned32 |
VTY usage alarm threshold. |
As per the MIB. |
Notifications
hh3cLogIn
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.2.1.1.3.0.1 |
User login |
Informational |
Warning |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when a user logs in to the system.
System impact
No negative impact on the system.
Status control
This notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.2.1.1.2.1 (hh3cTerminalUserName) |
Username. |
N/A |
DisplayString |
OCTET STRING (SIZE (0..255)) |
1.3.6.1.4.1.25506.2.2.1.1.2.2 (hh3cTerminalSource) |
User line, including console, AUX, TTY, and VTY. |
N/A |
DisplayString |
Recommended action
No action is required.
hh3cLogOut
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.2.1.1.3.0.2 |
User logout |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when a user logs out of the system.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
Username. |
N/A |
DisplayString |
User line, including AUX, TTY, and VTY. |
N/A |
DisplayString |
Recommended action
hh3cLogInAuthenFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.2.1.1.3.0.3 |
User authentication failed |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when a user failed to log in to the system.
System impact
If this notification is generated consecutively, the system might be attacked.
Status control
Object
OID (object name) |
Index |
Type |
Value range |
Username. |
N/A |
DisplayString |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.2.1.1.2.3 (hh3cTerminalUserAuthFailureReason) |
N/A |
INTEGER |
exceedRetries(1), authTimeout(2), otherReason(3) |
Recommended action
1.Verify that the login username and password are correct.
2.Verify that the server settings such as server type are correct.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
hh3cVtyUsageExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.2.1.1.3.0.4 |
The number of used VTY lines reached or exceeded the alarm threshold. |
Informational |
Warning |
1.3.6.1.4.1.25506.2.2.1.1.3.0.5 (hh3cVtyUsageResume) |
ON |
This notification is generated when the number of used VTY lines reaches or exceeds the alarm threshold.
System impact
Users cannot log in to the system through VTY lines.
Status control
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.2.1.1.2.4 (hh3cVtyCurrentVty) |
N/A |
Integer |
1.3.6.1.4.1.25506.2.2.1.1.2.5 (hh3cVtyMaxVty) |
N/A |
Integer |
1.3.6.1.4.1.25506.2.2.1.1.2.6 (hh3cVtyThreshold) |
N/A |
Integer |
Recommended action
Quit unnecessary sessions to release user lines.
hh3cVtyUsageResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.2.1.1.3.0.5 |
VTY usage alarm was cleared. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the number of used VTY lines drops below the VTY usage alarm threshold.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Integer |
N/A |
Integer |
N/A |
Integer |
Recommended action
