03-HH3C-FTPS-MIB | 47.25 KB |
hh3cFtpsLoginFailedTimes (1.3.6.1.4.1.25506.2.248.1.1)
hh3cFtpsLoginFailedStatPeriod (1.3.6.1.4.1.25506.2.248.1.2)
HH3C-FTPS-MIB
About this MIB
Use this MIB to obtain basic FTP server information and information about notifications.
MIB file name
hh3c-ftps.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2). hh3cFtps(248)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFtpsLoginFailedTimes (1.3.6.1.4.1.25506.2.248.1.1) |
accessible-for-notify |
Unsigned32 |
Standard MIB values. |
Number of login failures. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFtpsLoginFailedStatPeriod (1.3.6.1.4.1.25506.2.248.1.2) |
Unsigned32 |
Statistics interval for user login failures. |
As per the MIB. |
Notifications
hh3cFtpsLoginFailed
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.248.2.0.1 |
FTP login fails frequently. |
Error |
Warning |
1.3.6.1.4.1.25506.2.248.2.0.2 (hh3cFtpsLoginFailedClear) |
ON |
Notification triggers
This notification is generated when the number of FTP login failures reaches the upper alarm threshold in the specified interval. The reason for this notification might be that user has attempted to log in to the FTP server for a long time, but no attempt succeeds.
System impact
The system might be under attack.
Status control
This notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.248.1.1 (hh3cFtpsLoginFailedTimes) |
Number of user login failures. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.248.1.2 (hh3cFtpsLoginFailedStatPeriod) |
N/A |
Unsigned32 |
Recommended action
To resolve the issue:
1.Verify that the login username and password are correct.
2.Configure ACLs to deny access requests from illegal addresses.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.248.2.0.2 |
An alarm on FTP login failures is cleared. |
Recovery |
Informational |
N/A (N/A) |
ON |
This notification is generated when an alarm on FTP login failures is cleared. The reason for this notification might be that the number of FTP login failures in a statistics period drops below the alarm clearance threshold.
System impact
No impact on the system.
Status control
Object
OID (object name) |
Index |
Type |
Value range |
N/A (N/A) |
N/A |
N/A |
N/A |
N/A |
Recommended action
No action is required.
