02-Fundamentals
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10002-Fundamentals
04-HH3C-ISSU-MIB
04-HH3C-ISSU-MIB 92.47 KB
HH3C-ISSU-MIB
About this MIB
Use this table to perform in-service software upgrade (ISSU) operations.
You can obtain information from the hh3cIssuTestResultTable and cIssuUpgradeResultTable objects only if you have performed test or install operations by using the hh3cIssuUpgrageImageTable object.
MIB file name
hh3c-issu.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIssuUpgrade(133)
Scalar objects
hh3cIssuOpType (1.3.6.1.4.1.25506.2.133.1.1.2.1)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
none(1)
done(2)
test(3)
install(4)
rollback(5)
ISSU operation.
As per the MIB.
hh3cIssuImageFileOverwrite (1.3.6.1.4.1.25506.2.133.1.1.2.2)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1)
false(2)
Enables or disables ISSU to overwrite the current image file when copying the upgrade image file to the node to be upgraded.
As per the MIB.
hh3cIssuOpTrapEnable (1.3.6.1.4.1.25506.2.133.1.1.2.3)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1)
false(2)
SNMP ISSU notification control.
As per the MIB.
hh3cIssuOpStatus (1.3.6.1.4.1.25506.2.133.1.1.2.4)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
none(1)
failure(2)
inProgress(3)
success(4)
rollbackInProgress(5)
rollbackSuccess(6)
ISSU upgrade state.
As per the MIB.
hh3cIssuFailedReason (1.3.6.1.4.1.25506.2.133.1.1.2.5)
Object (OID)
Access
Value range
Implementation
read-only
DisplayString
OCTET STRING (0..255)
ISSU upgrade failure cause.
As per the MIB.
hh3cIssuOpTimeCompleted (1.3.6.1.4.1.25506.2.133.1.1.2.6)
Object (OID)
Access
Value range
Implementation
read-only
DisplayString
Time when the ISSU operation finished.
As per the MIB.
hh3cIssuLastOpType (1.3.6.1.4.1.25506.2.133.1.1.2.7)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
none(1)
done(2)
test(3)
install(4)
rollback(5)
Previous ISSU operation.
As per the MIB.
hh3cIssuLastOpStatus (1.3.6.1.4.1.25506.2.133.1.1.2.8)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
none(1)
failure(2)
inProgress(3)
success(4)
rollbackSuccess(6)
State of the previous ISSU operation.
As per the MIB.
hh3cIssuLastOpFailedReason (1.3.6.1.4.1.25506.2.133.1.1.2.9)
Object (OID)
Access
Value range
Implementation
read-only
DisplayString
Cause of the most recent ISSU upgrade failure.
As per the MIB.
hh3cIssuLastOpTimeCompleted(1.3.6.1.4.1.25506.2.133.1.1.2.10)
Object (OID)
Access
Value range
Implementation
read-only
DisplayString
Time when the previous ISSU operation finished.
As per the MIB.
hh3cIssuCompatibleResultStatus (1.3.6.1.4.1.25506.2.133.1.2.1.1)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
none(1)
inCompatible(2)
compatible(3)
failure(4)
ISSU compatibility check result.
As per the MIB.
hh3cIssuCompatibleResultFailedReason (1.3.6.1.4.1.25506.2.133.1.2.1.2)
Object (OID)
Access
Value range
Implementation
read-only
DisplayString
Cause of ISSU compatibility check failure.
As per the MIB.
Tabular objects
hh3cIssuUpgradeImageTable
About this table
Use this table to set the image file for an ISSU or obtain information about the image file.
Support for operations
CreateSupported
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table index is hh3cIssuUpgradeImageIndex.
Object (OID)
Access
Value range
Implementation
hh3cIssuUpgradeImageIndex (1.3.6.1.4.1.25506.2.133.1.1.1.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
Image file index.
As per the MIB.
hh3cIssuUpgradeImageType (1.3.6.1.4.1.25506.2.133.1.1.1.1.2)
read-create
INTEGER
boot(1) system(2)
feature(3)
ipe(4)
patch(5)
Image file type.
As per the MIB.
hh3cIssuUpgradeImageURL
(1.3.6.1.4.1.25506.2.133.1.1.1.1.3)
read-create
DisplayString
OCTET STRING (1..127)
Image file path.
As per the MIB.
hh3cIssuUpgradeImageRowStatus (1.3.6.1.4.1.25506.2.133.1.1.1.1.4)
read-create
RowStatus
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
About this table
Use this table to obtain the result of an ISSU test operation.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cIssuTestResultIndex.
Object (OID)
Access
Value range
Implementation
hh3cIssuTestResultIndex (1.3.6.1.4.1.25506.2.133.1.2.2.1.1)
not-accessible
Integer32
Integer32 (1..65535)
Test result index.
As per the MIB.
hh3cIssuTestDeviceChassisID (1.3.6.1.4.1.25506.2.133.1.2.2.1.2)
read-only
Integer32
Integer32 (0..255)
Chassis number of the node on which the test operation was performed.
As per the MIB.
hh3cIssuTestDeviceSlotID (1.3.6.1.4.1.25506.2.133.1.2.2.1.3)
read-only
Integer32
Integer32 (0..255)
Slot number of the node on which the test operation was performed.
As per the MIB.
hh3cIssuTestDeviceCpuID (1.3.6.1.4.1.25506.2.133.1.2.2.1.4)
read-only
Integer32
Integer32 (0..7)
CPU number of the node on which the test operation was performed.
As per the MIB.
hh3cIssuTestDeviceUpgradeWay (1.3.6.1.4.1.25506.2.133.1.2.2.1.5)
read-only
INTEGER
none(1)
reboot(2)
sequenceReboot(3)
issuReboot(4)
serviceUpgrade(5)
fileUpgrade(6)
incompatibleUpgrade(7)
Recommended ISSU upgrade method.
As per the MIB.
hh3cIssuUpgradeResultTable
About this table
Use this table to obtain the result of an ISSU install operation.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cIssuUpgradeResultIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.133.1.2.3.1.1)
not-accessible
Integer32
Table index of hh3cIssuUpgradeResultTable.
As per the MIB.
hh3cIssuUpgradeDeviceChassisID
(1.3.6.1.4.1.25506.2.133.1.2.3.1.2)
read-only
Integer32
Integer32 (0..255)
Chassis number of the node on which ISSU was performed.
As per the MIB.
hh3cIssuUpgradeDeviceSlotID
(1.3.6.1.4.1.25506.2.133.1.2.3.1.3)
read-only
Integer32
Integer32 (0..255)
Slot number of the node on which ISSU was performed.
As per the MIB.
hh3cIssuUpgradeDeviceCpuID
(1.3.6.1.4.1.25506.2.133.1.2.3.1.4)
read-only
Integer32
Integer32 (0..7)
CPU number of the node on which ISSU was performed.
As per the MIB.
hh3cIssuUpgradeState
(1.3.6.1.4.1.25506.2.133.1.2.3.1.5)
read-only
INTEGER
init(1)
loading(2)
loaded(3)
switching(4)
switchover(5)
committing(6)
committed(7)
rollbacking(8)
rollbacked(9)
Node state.
As per the MIB.
hh3cIssuDeviceUpgradeWay
(1.3.6.1.4.1.25506.2.133.1.2.3.1.6)
read-only
INTEGER
none(1),
reboot(2)
sequenceReboot(3)
issuReboot(4)
serviceUpgrade(5)
fileUpgrade(6)
ISSU method for the node.
As per the MIB.
hh3cIssuUpgradeDeviceStatus
(1.3.6.1.4.1.25506.2.133.1.2.3.1.7)
read-only
INTEGER
waitingUpgrade(1)
inProcess(2)
success(3)
failure(4)
Current upgrade state of the node.
As per the MIB.
hh3cIssuUpgradeFailedReason
(1.3.6.1.4.1.25506.2.133.1.2.3.1.8)
read-only
DisplayString
Upgrade failure cause.
As per the MIB.
