H3C SecPath F10X0 Firewall Series Installation Guide-6W107
HomeSupportSecurityH3C SecPath F1000 FirewallInstall & UpgradeInstallation GuidesH3C SecPath F10X0 Firewall Series Installation Guide-6W107
03-Appendix B LEDs
03-Appendix B LEDs 301.17 KB
1 Appendix B  LEDs
F1003-C/F1003-S/F1003-M
The F1003-C, F1003-S, and F1003-M firewalls use similar LEDs. This section uses the LEDs on the F1003-C firewall as an example.
Figure1-1 LEDs
(1) 10/100/1000BASE-T Ethernet copper port LEDs
(2) 1000BASE-X Ethernet fiber port LEDs
(3) Micro SD card LED
(4) Power status LED
(5) System status LED
Table1-1 LED description
LED
Mark
Status
10/100/1000BASE-T
Off
No link is present.
Steady green
A link is present.
Flashing green
The port is receiving or sending data.
1000BASE-X
Off
No link is present.
Steady green
A 1000 Mbps link is present.
Flashing green
The port is receiving or sending data at 1000 Mbps.
Micro SD card LED
Micro SD
On
The Micro SD card is present.
Off
No Micro SD card is detected.
Power status LED
PWR
Off
The power system is faulty.
Steady green
The power system is operating correctly.
System status LED
SYS
Off
The firewall is not powered on or has failed.
Slow flashing green
The firewall is operating correctly.
Fast flashing green
The firewall is loading software.
F1005/F1010/F1020/F1030/F1050/F1060/F1070/F1080/F1090
The F1005, F1010, F1020, F1030, F1050, F1060, F1070, F1080, and F1090 firewalls use similar LEDs. This section uses the LEDs on the F1080 firewall as an example.
Figure1-2 LEDs
(1) System status LED
(2) Drive status LED
(3) 10/100/1000BASE-T Ethernet copper port LED
(4) 1000BASE-X Ethernet fiber port LED
(5) 10GBASE-R Ethernet fiber port LED
(6) Interface module LED
(7) Power status LED
Table1-2 LED description
LED
Mark
Status
System status LED
SYS
Off
Slow flashing green
Fast flashing green
Drive status LED
HD0, HD1
Off
Fast flashing green
Data is being read from or written to the drive.
Steady green
The drive is operating correctly.
10/100/1000BASE-T copper port LED
10/100/1000BASE-T
Off
No link is present.
Steady green
A link is present.
Flashing green
1000BASE-X fiber port LED
1000BASE-X
Off
No link is present.
Steady green
Flashing green
10GBASE-R fiber port LED
10GBASE-R
Off
No link is present.
Steady green
A 10 Gbps link is present.
Flashing green
The port is receiving or sending data at 10 Gbps.
SLOT1, SLOT2
Off
No interface module is present or the interface module has failed.
Steady green
The interface module is operating correctly.
Power status LED
PWR0, PWR1
Off
No power module is present or the power module has failed.
Steady green
The power module is operating correctly.
