H3C SecPath F10X0 Firewall Series Installation Guide-6W107
HomeSupportSecurityH3C SecPath F1000 FirewallInstall & UpgradeInstallation GuidesH3C SecPath F10X0 Firewall Series Installation Guide-6W107
00-Preface
00-Preface 100.39 KB
Preface
This document describes the installation procedure for the H3C SecPath F10X0 firewalls. It covers preparing for installation, installing the firewall, logging in to the firewall, hardware replacement, hardware management and maintenance, and troubleshooting.
·     Audience
·     Conventions
·     Documentation feedback
Audience
·     Network planners
·     Field technical support and servicing engineers
·     Network administrators working with H3C SecPath F10X0 firewalls
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Represents an access point.
We appreciate your comments.
