H3C SecPath F10X0 Firewall Series Installation Guide-6W107
HomeSupportSecurityH3C SecPath F1000 FirewallInstall & UpgradeInstallation GuidesH3C SecPath F10X0 Firewall Series Installation Guide-6W107
01-Text
01-Text 4.30 MB
1 Preparing for installation· 1
Safety recommendations· 1
Safety symbols· 1
General safety recommendations· 1
Electrical safety· 2
Laser safety· 2
Handling safety· 2
Examining the installation site· 3
Weight support 3
Temperature and humidity· 3
Cleanliness· 3
Cooling system·· 4
ESD prevention· 4
EMI 5
Lightning protection· 5
Power supply· 5
Installation tools· 6
Accessories· 6
Pre-installation checklist 6
2 Installing the firewall 9
Installation flow· 9
Mounting the firewall on a workbench· 9
Installing the firewall in a standard 19-inch rack· 10
Rack-mounting the firewall by using front and rear mounting brackets· 10
Rack-mounting the firewall by using front mounting brackets· 13
Grounding the firewall 15
Grounding the firewall with a grounding strip· 15
Grounding the firewall with the grounding terminal on the rack· 16
Installing power modules· 16
Installing a power module for an F1070 or F1080 firewall 16
Installing a power module for an F1090 firewall 17
Installing an interface module· 18
Installing a Micro SD card· 19
Installing a drive· 19
Connecting Ethernet cables· 20
Connecting a copper Ethernet port 20
Connecting a fiber port 20
Connecting power cords· 22
Connecting an AC power cord· 22
Connecting a DC power cord· 24
Connecting a high-voltage DC power cord for an F1090 firewall 25
Verifying the installation· 25
3 Accessing the firewall 3-26
Starting the firewall 3-26
Check before starting the firewall 3-26
Starting the firewall and observing the initial startup conditions· 3-26
Logging in to the firewall 3-28
Logging in from the Web interface· 3-28
Logging in from the serial console port or micro USB console port 3-29
Logging in through Telnet 3-29
4 Hardware replacement 4-30
Replacing a power module· 4-30
Replacing a power module for an F1070 or F1080 firewall 4-30
Replacing a power module for an F1090 firewall 4-30
Replacing an interface module· 4-31
Replacing a drive· 4-32
Replacing a transceiver module· 4-32
5 Hardware management and maintenance· 5-34
Displaying detailed information about the firewall 5-34
Displaying software and hardware version information for the firewall 5-34
Displaying electrical label information for the firewall 5-35
Displaying the CPU usage of the firewall 5-35
Displaying the memory usage of the firewall 5-36
Displaying the operational status of power modules· 5-37
Displaying temperature information for the firewall 5-37
Displaying the operational statistics about the firewall 5-38
Displaying transceiver module information· 5-38
Rebooting the firewall 5-39
6 Troubleshooting· 6-41
Power module failure· 6-41
Configuration terminal display problem·· 6-41
Password loss· 6-41
Cooling system failure· 6-42
Software loading failure· 6-42
The H3C SecPath F10X0 firewall series include the following models:
·     F1003-C
·     F1003-S
·     F1003-M
·     F1005
·     F1010
·     F1020
·     F1030
·     F1050
·     F1060
·     F1070
·     F1080
·     F1090
To avoid any equipment damage or bodily injury, read the following safety recommendations before installation. Note that the recommendations do not cover every possible hazardous condition.
Safety symbols
When reading this document, note the following symbols:
WARNING WARNING means an alert that calls attention to important information that if not understood or followed can result in personal injury.
CAUTION CAUTION means an alert that calls attention to important information that if not understood or followed can result in data loss, data corruption, or damage to hardware or software.
·     Do not place the firewall on an unstable case or desk. The firewall might be severely damaged in case of a fall.
·     Make sure the ground is dry and flat and anti-slip measures are in place.
·     Keep the chassis and installation tools away from walk areas.
·     Keep the chassis clean and dust-free.
·     Do not place the firewall near water or in a damp environment. Prevent water or moisture from entering the firewall chassis.
·     Ensure good ventilation of the equipment room and keep the air inlet and outlet vents of the firewall free of obstruction.
·     Make sure the operating voltage is in the required range.
·     Use a screwdriver, rather than your fingers, to fasten screws.
·     Stack devices according to the sizes of and packing symbols on the packages.
Figure1-1 Packing symbols
Symbol
Stored with a maximum stack of n units.
Transported and stored with the arrows up.
Transported and stored with care.
Transported and stored avoiding humidity, rains and wet floor.
Electrical safety
·     Carefully examine your work area for possible hazards such as moist floors, ungrounded power extension cables, and missing safety grounds.
·     Locate the emergency power-off switch in the room before installation. Shut the power off at once in case accident occurs.
·     Do not work alone when the firewall has power.
·     Always verify that the power has been disconnected.
Laser safety
WARNING
WARNING!
Disconnected optical fibers or transceiver modules might emit invisible laser light. Do not stare into beams or view directly with optical instruments when the firewall is operating.
·     Before you disconnect the fiber connector, execute the shutdown command in interface view to disable the optical source.
·     Install dust caps to disconnected optical fiber connectors and ports on disconnected transceiver modules to avoid damage caused by built-up dust.
·     Insert a dust plug into empty fiber ports.
Handling safety
When you move the firewall, follow these guidelines:
·     Move and unpack the firewall carefully to avoid firewall damage.
·     Unpack the firewall at least half an hour and power on the firewall at least two hours after you move it from a place below 0°C (32°F) to the equipment room. This prevents condensation and even damage to the firewall.
·     Use a safety hand truck when you move multiple firewalls.
·     Before you move the firewall, remove all cables.
·     For long-distance transportation, remove all removable components, such as power modules and interface modules, and package them separately, and install the filler panels supplied with the firewall. For short-distance transportation, make sure all removable components are securely seated in the slots and the screws are fastened.
·     When you move or lift the firewall chassis, support the bottom of the chassis, rather than holding any removable component. Make sure the accessories of the firewall are not lost or damaged during firewall moving.
The firewall can only be used indoors. To make sure the firewall operates correctly and to prolong its service lifetime, the installation site must meet the following requirements.
Weight support
Make sure the floor can support the total weight of the rack, chassis, modules, and all other components. For more information, see "Appendix A  Chassis views and technical specifications."
Maintain appropriate temperature and humidity in the equipment room.
·     Lasting high relative humidity can cause poor insulation, electricity leakage, mechanical property change of materials, and metal corrosion.
·     Lasting low relative humidity can cause washer contraction and ESD and bring problems including loose captive screws and circuit failure.
·     High temperature can accelerate the aging of insulation materials and significantly lower the reliability and lifespan of the firewall.
For the temperature and humidity requirements of the firewall, see Table1-1.
Table1-1 Temperature/humidity requirements
Temperature
Relative humidity
·     Operating:
¡     Without drives: 0°C to 45°C (32°F to 113°F)
¡     With drives: 5°C to 40°C (41°F to 104°F)
·     Storage: –40°C to +70°C (–40°F to +158°F)
·     Operating:
¡     Without drives: 5% RH to 95% RH, noncondensing
¡     With drives: 10% RH to 90% RH, noncondensing
·     Storage: 5% RH to 95% RH, noncondensing
Cleanliness
Dust buildup on the chassis might result in electrostatic adsorption, which causes poor contact of metal components and contact points, especially when indoor relative humidity is low. In the worst case, electrostatic adsorption can cause communication failure.
Table1-2 Dust concentration limit in the equipment room
Substance
Concentration limit (particles/m3)
Dust particles
≤ 3 × 104 (No visible dust on desk in three days)
Dust particle diameter ≥ 5 µm
The equipment room must also meet strict limits on salts, acids, and sulfides to eliminate corrosion and premature aging of components, as shown in Table1-3.
Table1-3 Harmful gas limits in an equipment room
Gas
Max. (mg/m3)
SO2
0.2
H2S
0.006
NH3
0.05
Cl2
0.01
NO2
0.04
Cooling system
For adequate cooling of the firewall, follow these guidelines:
·     Install the firewall at the installation site with its airflow direction meeting the ventilation requirements.
¡     Workbench mounting—Ensure a minimum clearance of 100 mm (3.94 in) around the air inlet and outlet vents of the chassis.
¡     19-inch rack mounting—Ensure a minimum clearance of 80 mm (3.15 in) around the air inlet and outlet vents of the chassis and a distance of 1U (44.45 mm, or 1.75 in) between the chassis and other devices.
·     Make sure the installation site has a good cooling system.
The F1003-C, F1003-S, F1003-M, F1005, and F1010 firewalls use passive cooling for heat dissipation.
The F1020, F1030, F1050, F1060, F1070, F1080, and F1090 firewalls provide left side-intake and right-side exhaust airflow for heat dissipation.
Figure1-2 Airflow through the F1080 firewall chassis
ESD prevention
To prevent electrostatic discharge (ESD), follow these guidelines:
·     Make sure the firewall, the workbench, and the rack are reliably grounded.
·     Take dust-proof measures for the equipment room. For more information, see "Cleanliness."
·     Maintain the humidity and temperature at an acceptable level. For more information, see "Temperature and humidity."
·     Put the removed interface modules away on an ESD workbench, with the PCB upward, or put them in ESD bags for future use.
·     Always wear ESD clothing, ESD gloves, and an ESD wrist strap.
EMI
All electromagnetic interference (EMI) sources, from outside or inside of the firewall and application system, adversely affect the firewall in the following ways:
·     A conduction pattern of capacitance coupling.
·     Inductance coupling.
·     Electromagnetic wave radiation.
·     Common impedance (including the grounding system) coupling.
To prevent EMI, use the following guidelines:
·     If AC power is used, use a single-phase three-wire power receptacle with protection earth (PE) to filter interference from the power grid.
·     Keep the firewall far away from radio transmitting stations, radar stations, and high-frequency devices.
·     Use electromagnetic shielding, for example, shielded interface cables, when necessary.
·     To prevent signal ports from getting damaged by overvoltage or overcurrent caused by lightning strikes, route interface cables only indoors. If part of the network cable of an Ethernet port must be routed outdoors, connect a lightning arrester to the cable before you plug the cable into the port.
To protect the firewall from lightning better, follow these guidelines:
·     Make sure the grounding cable of the chassis is reliably grounded.
·     Make sure the grounding terminal of the AC power receptacle is reliably grounded.
·     If an AC power cord is routed from outdoors for connecting to the device, connect the power cord first to a power lightning arrester before connecting it to the power receptacle on the device.
·     If a network cable is routed from outdoors for connecting to an Ethernet port on the firewall, connect the network cable first to a network port lightning arrester before connecting it to the port.
IMPORTANT
IMPORTANT:
No network port lightning arrester or AC power lightning arrester is provided with the device. Prepare them as required. For the technical specifications and installation instructions for the lightning protectors, see the documents shipped with them.
Power supply
Verify that the power system at the installation site meets the requirements of the power modules, including the input method and rated input voltage. For more information, see "Appendix A  Chassis views and technical specifications."
Installation tools
All installation tools are user supplied.
Flat-head screwdriver
Phillips screwdriver
Needle-nose pliers
Diagonal pliers
ESD wrist strap
Marker
Accessories
Mounting bracket for the F1003-C/F1003-S/F1003-M
Mounting bracket for the F1005/F1010
Mounting brackets (including an M4 shoulder screw) for the F1020/F1030/F1050/F1060/F1070/F1080/F1090
M4 screw
M6 rack screw and cage nut (shipped with the F1005/F1010 and user supplied for other models)
Rubber feet
Power cord retainer clip
Power cord
Power adapter for the F1003-C/F1003-S/F1003-M
Grounding cable
Console cable
Table1-4 Checklist before installation
Item
Requirements
Result
Installation site
Ventilation
·     Workbench mounting—Ensure a minimum clearance of 100 mm (3.94 in) around the air inlet and outlet vents of the chassis.
·     19-inch rack mounting—Ensure a minimum clearance of 80 mm (3.15 in) around the air inlet and outlet vents of the chassis and a distance of 1U (44.45 mm, or 1.75 in) between the chassis and other devices.
·     A good ventilation system is available at the installation site.
Temperature
·     Operating:
Relative humidity
·     Operating:
Cleanness
·     Dust concentration ≤ 3 × 104 particles/m3
·     No dust on desk within three days
ESD prevention
·     The equipment, workbench, and rack are reliably grounded.
·     The equipment room is dust-proof.
·     The humidity and temperature are at an acceptable level.
·     Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded when installing FRUs.
·     Touch only the edges, instead of electronic components when observing or moving a removed interface module.
EMI prevention
·     Take effective measures to protect the power system from the power grid system.
·     Separate the protection ground of the firewall from the grounding device or lightning protection grounding device as far as possible.
·     Keep the firewall far away from radio stations, radar and high-frequency devices working in high current.
·     Use electromagnetic shielding when necessary.
·     The grounding cable of the chassis is reliably grounded.
·     The grounding terminal of the AC power receptacle is reliably grounded.
·     (Optional.) A power lightning arrester is installed.
Electricity safety
·     Equip a UPS.
·     Locate the power switch in the equipment room. In case of emergency during operation, switch off the power switch.
Rack-mounting requirements
·     Make sure the cabinet is equipped with a good ventilation system.
·     The rack is sturdy enough to support the weight of the firewall and installation accessories.
·     The size of the rack is appropriate for the firewall.
·     The front and rear of the rack are a minimum of 0.8 m (31.50 in) away from walls or other devices.
Safety precautions
·     The firewall is far away from any moist area and heat source.
·     The emergency power switch in the equipment room is located.
Tools and accessories
·     Installation accessories supplied with the firewall
·     User-supplied tools
Reference
·     Documents shipped with the firewall
·     Online documents
WARNING
WARNING!
Keep the tamper-proof seal on a mounting screw on the chassis cover intact, and if you want to open the chassis, contact H3C for permission. Otherwise, H3C shall not be liable for any consequence.
The firewall view varies by model. The following figures are for illustration only. This document uses an F1080 firewall as an example.
Installation flow
Table2-1 Installation flow for the firewall
Step
1.     Start
Before installation, make sure all requirements on the checklist are met and the firewall is powered off.
2.     Mounting the firewall on a workbench
Verify that the workbench is sturdy and reliably grounded. Ensure a minimum clearance of 100 mm (3.94 in) around the air inlet and outlet vents of the chassis.
3.     Installing the firewall in a standard 19-inch rack
To avoid bodily injury and device damage, use a minimum of two people to rack-mount the device.
4.     Grounding the firewall
Before installation, make sure the firewall and rack are reliably grounded and you wear an ESD wrist strap.
5.     Installing power modules
Before you install a power module, make sure the power module is not connected to any power source and the grounding cable of the firewall is connected reliably.
6.     Installing an interface module
Install compatible interface modules on the firewall.
7.     Installing a Micro SD card
Install compatible Micro SD cards on the firewall.
8.     Installing a drive
Install compatible drives on the firewall.
9.     Connecting Ethernet cables
The firewall provides various ports. Choose compatible transceiver modules and cables as required. To avoid bodily injury or device damage, read the restrictions and guidelines carefully before connection.
10.     Connecting power cords
Connect compatible power cords to the power modules.
11.     Verifying the installation
Verify that the firewall is installed securely and reliably grounded, and that the power modules are as required.
IMPORTANT
IMPORTANT:
·     Ensure good ventilation and a minimum clearance of 100 mm (3.94 in) around the chassis for heat dissipation.
·     Avoid placing heavy objects on the firewall.
If a standard 19-inch rack is not available, you can place the firewall on a workbench.
To mount the firewall on a workbench:
1.     Verify that the workbench is sturdy and reliably grounded.
2.     Place the firewall upside down on the workbench and clean the four round holes in the chassis bottom with a dry cloth.
3.     Attach the four rubber feet to the round holes in the chassis bottom.
4.     Place the firewall with upside up on the workbench.
Figure2-1 Mounting the firewall on a workbench
WARNING
WARNING!
To avoid bodily injury and device damage, use a minimum of two persons to rack-mount the firewall.
CAUTION
CAUTION:
·     For adequate heat dissipation, ensure a minimum clearance of 80 mm (3.15 in) around the air inlet and outlet vents of the chassis and a distance of 1U (44.45 mm, or 1.75 in) between the chassis and other devices in the rack.
·     As a best practice, use a rack shelf together with the mounting brackets to support the weight of the chassis.
The F1020, F1030, F1050, F1060, F1070, F1080, and F1090 firewalls support this installation method.
To install the firewall in a standard 19-inch rack by using front and rear mounting brackets:
1.     Wear an ESD wrist strap and make sure the wrist strap makes good skin contact and is reliably grounded.
2.     Unpack the firewall and accessories.
3.     Mark the cage nut installation positions on the rack posts by using the mounting brackets.
Use a front mounting bracket to mark the positions on the front rack posts and use a rear mounting bracket to mark the positions on the rear rack posts.
4.     Install cage nuts.
Figure2-2 Installing cage nuts
5.     Attach the front mounting brackets and shoulder screws to both sides of the firewall with M4 screws provided with the firewall.
Figure2-3 Attaching mounting brackets and shoulder screws to the firewall
6.     Attach the rear mounting brackets to the rear rack posts. The rear mounting brackets can be attached to the rear rack posts with the wide flange inside or outside the rack.
Table2-2 Installation methods for rear mounting brackets
Distance between the front and rear rack posts
Rear mounting bracket installation method
405 to 569 mm (15.94 to 22.40 in)
With the wide flange inside the rack.
247 to 411 mm (9.72 to 16.18 in)
With the wide flange outside the rack.
Caution:
To prevent the rear mounting brackets from obstructing the closing of the rack door, ensure a distance greater than 153 mm (6.02 in) between the rear rack posts and the interior side of the rack door.
Figure2-4 Attaching the rear mounting brackets (with the wide flange inside the rack)
Figure2-5 Attaching the rear mounting brackets (with the wide flange outside the rack)
7.     Mount the firewall in the rack. Use M6 screws to secure the mounting brackets to the front rack posts and make sure the shoulder screws rest firmly on the upper edge of the rear mounting brackets.
Figure2-6 Mounting the firewall in the rack (with the wide flange of the rear mounting brackets inside the rack)
Figure2-7 Mounting the firewall in the rack (with the wide flange of the rear mounting brackets outside the rack)
The F1003-C, F1003-S, F1003-M, F1005, and F1010 firewalls support this installation method.
To install the firewall in a standard 19-inch rack by using front mounting brackets:
Figure2-8 Installing cage nuts
5.     Attach the front mounting brackets to both sides of the firewall with M4 screws provided with the firewall.
Figure2-9 Attaching the front mounting brackets to the firewall
6.     Mount the firewall in the rack. Use M6 screws to secure the mounting brackets to the front rack posts.
Figure2-10 Mounting the firewall in the rack
WARNING
WARNING!
·     Correctly connecting the firewall grounding cable is crucial to lightning protection and EMI protection.
·     Do not connect the firewall grounding cable to a fire main or lightning rod.
You can ground the firewall in one of the following ways, depending on the grounding conditions available at the installation site.
If a grounding strip is available at the installation site, connect the grounding cable through the grounding strip.
To connect the grounding cable:
1.     Remove the grounding screw from the firewall chassis.
2.     Attach the grounding screw to the ring terminal of the grounding cable.
3.     Use a Phillips screwdriver to fasten the grounding screw into the grounding hole on the firewall.
4.     Remove the hex nut from the grounding strip.
5.     Use a pair of needle-nose pliers to bend a hook at the other end of the grounding cable. Attach the hook to the grounding point, and secure the hook with a screw.
Figure2-11 Grounding the firewall with a grounding strip
4.     Remove the grounding screw from the grounding point on the rack.
5.     Use a pair of needle-nose pliers to bend a hook at the other end of the grounding cable. Attach the hook to the grounding point, and secure the hook with the screw.
Figure2-12 Grounding the firewall with the grounding terminal on the rack
CAUTION:
·     Make sure the power module is powered off and the grounding cable is correctly connected before installation.
·     Do not install both AC and DC power modules on the same firewall.
·     Only the F1070, F1080, and F1090 firewalls support removable power modules.
The installation procedures for AC and DC power modules are similar. The following procedure installs an AC power module.
To install a power module for an F1070 or F1080 firewall:
1.     Remove the filler panel (if any) from the target power module slot.
Figure2-13 Removing the filler panel from an F1070 or F1080 firewall
The firewall came with the PWR1 slot empty and the PWR0 slot installed with a filler panel.
2.     Orient the power module with its handle at the left. Holding the handle of the module with one hand and supporting the module bottom with the other, slide the power module slowly into the slot along the guide rails.
3.     Use a Phillips screwdriver to fasten the captive screws on the power module to secure the power module in place.
Figure2-14 Installing a power module for an F1070 or F1080 firewall
To install a power module for an F1090 firewall:
Figure2-15 Removing the filler panel from an F1090 firewall
2.     Orient the power module with its handle at the right. Holding the handle of the module with one hand and supporting the module bottom with the other, slide the power module slowly into the slot along the guide rails.
Figure2-16 Installing a power module for an F1090 firewall
CAUTION
CAUTION:
·     Do not hot swap interface modules.
·     To install two or more interface modules, use the upper interface module slots as a best practice. If you have installed an interface module in a lower slot, you must press down the ejector levers of the interface module while inserting it into an upper slot.
Only the F1020, F1030, F1050, F1060, F1070, F1080, and F1090 firewalls support interface modules.
No interface modules are provided with the firewall. Purchase them as needed.
The installation procedure is the same for all interface modules.
To install an interface module:
1.     Face the rear panel of the firewall.
2.     Use a Phillips screwdriver to remove the screws on the filler panel and then remove the filler panel.
Keep the filler panel for future use.
Figure2-17 Removing the filler panel
3.     Pull the ejector levers on the module outward and slide the module slowly into the slot along the guide rails.
4.     Press the ejector levers inward until they touch the panel tightly and the module seats into the slot securely.
5.     Use a Phillips screwdriver to fasten the captive screws on the module.
Figure2-18 Installing an interface module
CAUTION
CAUTION:
To avoid damaging the Micro SD card slot, do not use excessive force when you install a Micro SD card.
Only the F1003-C, F1003-S, and F1003-M firewalls support Micro SD cards.
No Micro SD cards are provided with the firewall. Purchase them as needed.
To install a Micro SD card:
1.     Face the front panel of the firewall. Use a Phillips screwdriver to remove the fastening screw on the Micro SD card slot cover and take off the cover.
2.     Push the Micro SD card along the guide rails into the slot until it clicks into place.
3.     Reinstall the cover, and then fasten the fastening screw on the cover.
Figure2-19 Installing a Micro SD card
Installing a drive
CAUTION
CAUTION:
·     Do not hot swap drives.
·     To avoid damage to drives, always hold a drive by its sides. Do not touch any components and do not squeeze, vibrate, or strike a drive.
·     Install a filler panel in empty drive slots to prevent dust and ESD damage.
·     Before using a drive, execute the fdisk and format commands from the CLI to partition and format the drive.
Only the F1005, F1010, F1020, F1030, F1050, F1060, F1070, F1080, and F1090 firewalls support drives.
The device does not come with any drives and cannot recognize drives from other vendors. Purchase drives from H3C as needed.
To install a drive:
1.     Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
2.     Remove the filler panel from the drive slot.
3.     Press the button on the drive panel to release the locking lever.
4.     Hold the locking lever and push the drive into the slot slowly along the guide rails. Then close the locking lever.
Figure2-20 Installing a drive
You can use either a straight-through or a cross-over network cable. For more information about Ethernet twisted pair cables, see "Appendix C  Cables."
To connect a copper Ethernet port:
1.     Connect one end of the Ethernet cable to the copper Ethernet port of the firewall, and the other end to the Ethernet port of the peer device.
2.     Examine whether the LEDs of the Ethernet port are normal. For more information about LEDs, see "Appendix B  LEDs."
After connecting the firewall to the network, you can use the ping or tracert command to examine network connectivity. For more information, see the related command reference.
WARNING
WARNING!
CAUTION
CAUTION:
·     Never bend or curve a fiber excessively. The bend radius of a fiber must be not less than 100 mm (3.94 in).
·     Keep the fiber end clean.
·     Make sure the fiber connector matches the transceiver module.
·     Before connecting a fiber, make sure the optical power at the receiving end does not exceed the transceiver module's upper threshold of the optical receive power. If the optical power at the receiving end exceeds the threshold, the transceiver module might be damaged.
·     Do not install a transceiver module connected with a fiber into a fiber port. To connect an optical fiber, first install the transceiver module in the fiber port and then connect the fiber.
·     Insert a dust plug into any open fiber port.
·     Make sure the Tx and Rx ports on a transceiver module are connected to the Rx and Tx ports on the peer end, respectively.
The firewall supports GE SFP transceiver modules and 10GE SFP+ transceiver modules. For the transceiver module specifications, see "Appendix A  Chassis views and technical specifications."
No transceiver module is provided with the firewall. As a best practice, use H3C transceiver modules.
Figure2-21 GE SFP transceiver module
图-1副本
Figure2-22 10GE SFP+ transceiver module
To connect the firewall to the network through an optical fiber:
1.     Remove the dust plug from the fiber port.
2.     Remove the dust cap from the transceiver module and insert it into the fiber port.
3.     Remove the dust cap of the optical fiber connector, and use dust free paper and absolute alcohol clean the end face of the fiber connector.
4.     Identify the Rx and Tx ports on the transceiver module. Plug one end of the optical fiber into the transceiver module in the firewall, and plug the other end into the transceiver module in the peer device.
Make sure the Rx port and the Tx port are connected to the Tx port and the Rx port on the peer device, respectively.
Figure2-23 Installing and connecting an optical fiber
CAUTION
CAUTION:
Make sure the grounding cable of the firewall is correctly connected and the power source is powered off before connecting the power cord.
Connecting an AC power cord for an F1005 or F1010 firewall
1.     Attach the hooks of the power cord retainer clip into the holes on the top of the AC-input power receptacle, and pull the power cord retainer clip upwards.
2.     Connect one end of the AC power cord to the AC-input power receptacle on the firewall.
3.     Pull the power cord retainer clip downwards and secure the connector to the power receptacle.
4.     Connect the other end of the power cord to an AC power source.
Figure2-24 Connecting an AC power cord for an F1005 or F1010 firewall
Connecting an AC power cord for an F1020, F1030, F1050, or F1060 firewall
1.     Connect the connector of the AC power cord to the target AC power receptacle on the rear panel of the chassis. Then use a power cord retainer clip (see Figure2-25) or a cable tie (see Figure2-26) to secure the power cord.
2.     Connect the other end of the power cord to an AC power source.
Figure2-25 Connecting an AC power cord (using a power cord retainer clip to secure the power cord)
Figure2-26 Connecting an AC power cord (using a cable tie to secure the power cord)
Connecting an AC power cord for an F1070 or F1080 firewall
1.     Connect the connector of the AC power cord to the AC power receptacle on the rear panel of the chassis. Then use a power cord retainer clip (see Figure2-27) or a cable tie (see Figure2-28) to secure the power cord.
Figure2-27 Connecting an AC power cord (using a power cord retainer clip to secure the power cord)
Figure2-28 Connecting an AC power cord (using a cable tie to secure the power cord)
Connecting an AC power cord for an F1090 firewall
1.     Connect the female connector of the AC power cord to the AC-input power receptacle on the power module.
2.     Use a cable tie to secure the AC power cord to the power module handle.
3.     Connect the other end of the power cord to an AC power source.
Figure2-29 Connecting an AC power cord for an F1090 firewall
Connecting a power adapter for an F1003-C, F1003-S, or F1003-M firewall
1.     Verify that the firewall is grounded correctly.
2.     Connect one end of the power adapter to the power source.
3.     Connect the DC output end of the power adapter to the power adapter receptacle on the firewall.
Figure2-30 Connecting a power adapter for an F1003-C, F1003-S, or F1003-M firewall
Connecting a DC power cord for an F1070, F1080, or F1090 firewall
1.     Correctly orient the DC power cord connector with the power receptacle on the power module, and insert the connector into the receptacle.
The receptacle is foolproof. If you cannot insert the connector into the receptacle, re-orient the connector rather than use excessive force to push it in.
2.     Fasten the captive screws on the power cord connector with a flathead screwdriver to secure the power cord connector.
3.     Use a cable tie to secure the power cord to the handle.
4.     Connect the other end of the power cord to a DC power source.
Figure2-31 Connecting a DC power cord for an F1070, F1080, or F1090 firewall
Only the F1090 firewall supports high-voltage DC power cords.
The connection procedure is similar for high-voltage DC power cords and AC power cords. For information about connecting a high-voltage DC power cord, see "Connecting an AC power cord for an F1090 firewall."
Verify the following items to ensure correct installation:
·     There is enough space for heat dissipation around the firewall.
·     The firewall and its components are installed securely. The screws are fastened tightly.
·     The power source specifications are as required by the firewall.
·     The grounding cable and power cords are connected correctly.
WARNING
WARNING!
Locate the emergency power-off switch in the room before powering on the firewall so you can quickly shut power off when an electrical accident occurs.
Before powering on the firewall, verify that the following conditions are met:
·     The power cord and grounding cable are correctly connected.
·     The power source specifications meet the firewall requirements.
·     The firewall is connected correctly to a configuration terminal (a PC for example). The configuration terminal has been started and the parameters have been set correctly. For more information, see "Logging in from the serial console port or micro USB console port."
·     The interface modules (if any) are installed correctly.
1.     Turn on the circuit breakers to power on the firewall.
2.     Observe the initial startup conditions to verify that the firewall starts up correctly.
¡     The LEDs on the front panel indicate that the device is operating correctly. For more information about LEDs, see "Appendix B  LEDs."
¡     The fan blades are rotating and air is exhausted from the air outlet vents.
¡     The configuration terminal displays the following information:
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start heavy memory test
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing......Done.
*                   H3C F1080 BootWare, Version 1.04                     *
Compiled Date       : Sep 10 2014
CPU Type            : xxx
CPU Clock Speed     : 1000MHz
Memory Type         : DDR3 SDRAM
Memory Size         : 4096MB
Memory Speed        : 1332MHz
BootWare Size       : 768KB
Flash Size          : 8MB
CPLD_A Version      : 2.0
CPLD_B Version      : 2.0
PCB Version         : Ver.A
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Loading the main image files...
Loading file flash:/f1000fw-cmw710-system-E9308.bin.............................
........................Done.
Loading file flash:/f1000fw-cmw710-boot-E9308.bin....    Done.
Image file flash:/f1000fw-cmw710-boot-E9308.bin is self-decompressing.......
......................................................Done.
System image is starting...
Cryptographic Algorithms Known-Answer Tests are running ...
CPU 0 of slot 1 in chassis 0:
Starting Known-Answer tests in the user space.
Known-answer test for SHA1 passed.
Known-answer test for SHA224 passed.
Known-answer test for SHA256 passed.
Known-answer test for SHA384 passed.
Known-answer test for SHA512 passed.
Known-answer test for HMAC-SHA1 passed.
Known-answer test for HMAC-SHA224 passed.
Known-answer test for HMAC-SHA256 passed.
Known-answer test for HMAC-SHA384 passed.
Known-answer test for HMAC-SHA512 passed.
Known-answer test for AES passed.
Known-answer test for RSA(signature/verification) passed.
Known-answer test for RSA(encrypt/decrypt) passed.
Known-answer test for DSA(signature/verification) passed.
Known-answer test for random number generator passed.
Known-Answer tests in the user space passed.
Starting Known-Answer tests in the kernel.
Known-Answer tests in the kernel passed.
Starting Known-Answer tests in the engine.
Known-Answer tests in the engine passed.
Cryptographic Algorithms Known-Answer Tests passed.
Line con0 is available.
Press ENTER to get started..
Press Enter to access user view of the firewall.
To access the EXTENDED-BOOTWARE menu, press Ctrl + B within four seconds at the prompt "Press Ctrl+B to access EXTENDED-BOOTWARE MENU." If you do not press Ctrl+B at the prompt, the system starts to read and decompress program files. To enter the EXTENDED-BOOT menu afterwards, you need to reboot the device.
You can use the following methods to access and manage the firewall. For more information about logging in to the firewall, see the configuration guides and command references for the firewall.
·     Logging in from the Web interface
·     Logging in from the serial console port or micro USB console port
·     Logging in through Telnet
The default Web interface login information is as follows:
·     Username—admin
·     Password—admin
·     IP address of the Ethernet management port GigabitEthernet 1/0/0 (0/MGMT)—192.168.0.1/24
To log in to the firewall from the Web interface by using the default account:
1.     Use an Ethernet cable to connect a PC to the Ethernet management interface on the firewall.
2.     Configure an IP address in subnet 192.168.0.0/24 for the PC. Make sure the PC and the firewall are reachable to each other.
The PC must use a different IP address than the Ethernet management interface.
3.     Start a browser, enter 192.168.0.1 in the address bar, and press Enter.
4.     Enter the default username admin and password admin and then click Login.
5.     Modify the login information.
At the first login from the Web interface, change the password as required in the pop-up window, and then click OK.
Keep the new password secure.
CAUTION
CAUTION:
·     When you connect the console cable, identify the port marks and make sure you are connecting the correct ports.
·     The serial ports on PCs do not support hot swapping. To connect a PC to an operating firewall, first connect the PC end. To disconnect a PC from an operating firewall, first disconnect the firewall end.
To access and manage the firewall locally, connect the serial console port or the micro USB console port on the firewall to a configuration terminal (a PC for example). Only the micro USB console port is available if you connect both the serial console port and micro USB console port.
By default, the firewall uses the scheme access authentication mode. The username and password are both admin.
To configure and manage the firewall through the serial console port or micro USB console port, you must run a terminal emulator program, TeraTermPro or PuTTY, on your configuration terminal and configure the following settings for the terminal. For more information about the terminal emulator programs, see the user guides for these programs.
·     Bits per second—9600.
·     Data bits—8.
·     Stop bits—1.
·     Parity—None.
·     Flow control—None.
1.     Log in to the firewall through the serial console port or micro USB console port, and enable the Telnet function in system view by using the telnet server enable command.
2.     Enter VTY user line view, and configure the authentication mode, user role, and common properties in VTY user line view.
By default, the authentication mode is scheme, and the username and password are admin.
3.     Connect a PC to the Ethernet management port GigabitEthernet 1/0/0 (0/MGMT) on the firewall.
4.     Specify an IP address for the network port of the PC. The IP address must be in subnet 192.168.0.0/24 and cannot be 192.168.0.1.
5.     Run the Telnet client on the PC and enter the default login information.
CAUTION
CAUTION:
Wear an ESD wrist strap or ESD gloves for hardware maintenance. They are not provided with the firewall. Prepare them yourself.
CAUTION
CAUTION:
·     Before you replace a power module, turn off the circuit breaker and remove the power cord.
·     Before hot swapping a power module, make sure another power module is operating correctly on the firewall.
This section applies only to F1070, F1080, and F1090 firewalls that support removable power modules.
The replacement procedure is the same for an AC power module and a DC power module. This section takes a DC power module as an example.
To replace a power module for an F1070 or F1080 firewall:
2.     Use a Phillips screwdriver to loosen the captive screw of the power module.
3.     Hold the power module with one hand and pull the power module part way out of the slot.
4.     Supporting the bottom of the power module with the other hand, gently pull the power module out of the slot along the slide rails.
Figure4-1 Removing a power module from an F1070 or F1080 firewall
5.     Put the removed power module on a workbench or into an antistatic bag.
6.     Install a new power module. If you do not install a new power module in the slot, install a filler panel. For the installation procedure, see "Installing power modules."
The replacement procedure is the same for an AC power module and a DC power module. This section takes an AC power module as an example.
To replace a power module for an F1090 firewall:
2.     Remove the cable tie from the power cord and then remove the power cord connector from the power module.
3.     Hold the power module handle with one hand, press the latch towards the handle, and then pull the power module part way out of the slot. Supporting the power module bottom with one hand, slowly pull the power module out of the slot along the guide rails with the other.
4.     Put the removed power module in an antistatic bag or on the workbench.
5.     Install a new power module. For the installation procedure, see "Installing a power module for an F1090 firewall."
If you are not to install a new power module, install a filler panel in the slot to ensure good ventilation in the firewall.
Figure4-2 Removing a power module from an F1090 firewall
CAUTION
CAUTION:
·     Do not hot swap interface modules. Power off the firewall before you replace an interface module.
The F1003-C, F1003-S, F1003-M, F1005, and F1010 firewalls do not support interface modules.
To replace an interface module:
1.     Power off the firewall.
2.     Use a Phillips screwdriver to loosen the captive screws of the interface module.
3.     Holding the ejector levers of the interface module with both hands, pull the ejector levers outward, and pull the interface module part way out of the slot along the slide rails. Supporting the bottom of the interface module with one hand, gently pull the interface module out of the slot with the other.
4.     Put the removed interface module (with the circuit board facing upward) on an antistatic workbench or into an antistatic bag.
5.     Install a new interface module. For the installation procedure, see "Installing an interface module."
If you are not to install a new interface module, install a filler panel in the slot to ensure good ventilation in the firewall.
Figure4-3 Removing an interface module
Replacing a drive
CAUTION
CAUTION:
·     To avoid storage medium damage, execute the umount command from the CLI to unmount all partitions before removing a drive.
The F1003-C, F1003-S, and F1003-M firewalls do not support drives.
To replace a drive:
1.     Log in to the Web interface. Click the Unmount button on the Storage settings page.
2.     Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
3.     Press the button at the right side of the drive panel to release the locking lever.
4.     Hold the locking lever and pull the drive out of the slot.
5.     Install a new drive. For the installation procedure, see "Installing a drive."
Figure4-4 Removing a drive
WARNING
WARNING!
When you replace a transceiver module, make sure the two transceiver modules connected by the same optical fiber are the same type. Do not touch the golden plating of the transceiver module.
Figure4-5 Transceiver module golden plating
To replace a transceiver module:
1.     Use the shutdown command in interface view at the CLI to shut down the optical source before you remove the fiber connector.
2.     Remove the LC connectors with the optical fiber from the transceiver module, and install dust caps to the LC connectors.
3.     Pivot the clasp of the transceiver module down to the horizontal position, and gently pull the transceiver module out.
Figure4-6 Removing the transceiver module
4.     Install dust caps to the removed transceiver module, and put it into the package.
5.     Install a new transceiver module. If you do not install a new transceiver module in the slot, install a dust cap. For information about installing a transceiver module, see "Connecting a fiber port."
The output depends on your firewall model. For more information about the commands used in this chapter, see the configuration guides and command references for the firewall.
Use the display device verbose command to display detailed information, including the running status and hardware version, about the firewall and its interface modules.
<Sysname> display device verbose
Status           :   Normal
Type             :   F1080
PCB 1 Ver        :   VER.A
Software Ver     :   9313P11
CPU Ver          :   1.0
CPLD_A           :   1.0
CPLD_B           :   1.0
CFCard Num       :   0
Use the display version command to display software and hardware version information for the firewall.
<Sysname> display version
H3C Comware Software, Version 7.1.064, Release 9313P11
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. All rights reserved.
H3C SecPath F1080 uptime is 0 weeks, 0 days, 2 hours, 23 minutes
Last reboot reason: User reboot
Boot image: flash:/f1000fw-cmw710-boot- R9313P11.bin
Boot image version: 7.1.064, Release 9313P11
  Compiled Nov 29 2016 16:00:00
System image: flash:/f1000fw-cmw710-system-R9313P11.bin
System image version: 7.1.064, Release 9313P11
SLOT 1
CPU type: Multi-core CPU
DDR3 SDRAM Memory      16382M bytes
Board PCB        Version:Ver.A
CPLD_A           Version:  1.0
CPLD_B           Version:  1.0
Basic  BootWare  Version: 1.05
Extend BootWare  Version: 1.05
Board PFC        Version:Ver.A
NandFlash PCB    Version:Ver.A
HD PCB           Version:Ver.A
[SubSlot 0]16GE+8SFP+2XGE  (Hardware)Ver.A, (Driver)1.0, (Cpld)1.0
Use the display device manuinfo command to display the electrical label information for the firewall.
<Sysname> display device manuinfo
 Slot 1 CPU 0:
 DEVICE_NAME          : SecPath F1080
 DEVICE_SERIAL_NUMBER : 210235A1FXH164000026
 MAC_ADDRESS          : 487A-DA95-91BB
 MANUFACTURING_DATE   : 2016-04-29
 VENDOR_NAME          : H3C
Fan 0:
The operation is not supported on the specified fan.
Fan 1:
Fan 2:
Fan 3:
Power 1:
The operation is not supported on the specified power.
Table5-1 Output description
DEVICE_NAME
Firewall name.
Firewall serial number.
MAC_ADDRESS
MAC address of the firewall.
MANUFACTURING_DATE
Manufacturing date of the firewall.
VENDOR_NAME
Vendor name.
Use the display cpu-usage command to display the CPU usage of the firewall.
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       3% in last 5 seconds
       3% in last 1 minute
       3% in last 5 minutes
Table5-2 Output description
CPU 0 usage information for the interface module in slot 1.
Average CPU usage in the last 5 seconds. (After the firewall boots, the firewall calculates and records the average CPU usage at the interval of 5 seconds.)
3% in last 1 minute
Average CPU usage in the last minute. (After the firewall boots, the firewall calculates and records the average CPU usage at the interval of 1 minute.)
Average CPU usage in the last 5 minutes. (After the firewall boots, the firewall calculates and records the average CPU usage at the interval of 5 minutes.)
Use the display memory command to display the memory information of the firewall.
<Sysname> display memory
The statistics about memory is measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:       1718140    921604    796536         0      1108    187644       46.4%
-/+ Buffers/Cache:    732852    985288
Swap:           0         0         0
Table5-3 Output description
Slot
Slot number of the interface module
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
The memory space is virtually divided into two parts. Part 1 is used for kernel codes, kernel management, and ISSU functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
Buffers
Physical memory used for buffers.
Cached
Physical memory used for caches.
FreeRatio
Free memory ratio.
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Swap memory.
Use the display power command to display the operational status of power modules.
<Sysname> display power
Power 0     Status: Normal
Power 1     Status: Absent
Table5-4 Output description
Power
Number of the power module.
Status
Power module state:
·     Normal—The power module is operating correctly.
·     Absent—The power module is not in position.
·     Abnormal—The power module has failed.
IMPORTANT
IMPORTANT:
Only F1020, F1030, F1050, F1060, F1070, F1080, and F1090 firewalls support the display environment command.
Use the display environment command to display the temperature information of the firewall.
<Sysname> display environment
System Temperature information (degree centigrade):
 Sensor   Temperature LowerLimit Warning-UpperLimit  Alarm-UpperLimit Shutdown-U
pperLimit
inflow 1      26          -5              48                56                NA
Table5-5 Output description
Sensor
Temperature sensor:
·     inflow—Air inlet vent temperature sensor.
·     outflow—Air outlet vent temperature sensor.
·     hotspot—Hotspot temperature sensor.
Temperature
Current temperature.
LowerLimit
Low temperature alarm threshold.
Warning-UpperLimit
Warning-level high temperature alarm threshold.
Alarm-UpperLimit
Alarm-level high temperature alarm threshold.
Shutdown-Upperlimit
Shutdown-level high temperature alarm threshold. The firewall automatically powers off when the temperature exceeds this threshold.
When you perform routine maintenance or the system fails, you might need to view the operational information of each functional module for locating failures. Typically you need to run display commands one by one. To collect more information one time, you can execute the display diagnostic-information command in any view to display or save the operational statistics of multiple functional modules of the firewall.
·     Save the operational statistics of each functional module of the firewall:
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.gz)[flash:/diag.gz]:
Diagnostic information is outputting to flash:/diag.gz.
Please wait...
Save successfully.
To view the diag.gz file:
a.     Execute the gunzip diag.gz command in user view to decompress the file.
b.     Execute the more diag command.
c.     Press Pg Up and Pg Down.
·     Display the operational statistics for each functional module of the firewall:
<Sysname>display diagnostic-information
  ===============display cpu===============
      13% in last 5 seconds
      13% in last 1 minute
      13% in last 5 minutes
Identifying transceiver modules
To identify transceiver modules, you can use the following command to view the key parameters of the transceiver modules, including transceiver module type, connector type, central wavelength of the laser sent, transmission distance, and vendor name or name of the vendor who customizes the transceiver modules.
To display transceiver module information:
Remarks
Display key parameters of the transceiver module in a specific interface.
Available for all transceiver modules.
Troubleshooting transceiver modules
The system outputs alarm information for you to locate and troubleshoot faults of transceiver modules.
To display the alarming information or fault detection parameters of a transceiver module:
Remarks
Display the current alarm information of the transceiver module in a specific interface.
CAUTION
CAUTION:
·     If the main system software image file does not exist, do not use the reboot command to reboot the firewall. Specify the main system software image file first, and then reboot the firewall.
·     The precision of the rebooting timer is 1 minute. 1 minute before the rebooting time, the firewall prompts "REBOOT IN ONE MINUTE" and reboots in one minute.
·     If you are performing file operations when the firewall is to be rebooted, the system does not execute the reboot command for security.
To reboot a firewall, use one of the following methods:
·     Use the reboot command to reboot the firewall immediately.
·     Enable the scheduled reboot function at the CLI. You can set a time at which the firewall can automatically reboot, or set a delay so that the firewall can automatically reboot within the delay.
·     Power on the firewall after powering it off, which is also called hard reboot or cold start. H3C does not recommend that you use this method because it might cause data loss and hardware damages.
To reboot the firewall immediately:
Remarks
Reboot the firewall immediately.
reboot
Available in user view.
To enable the scheduled reboot function:
Remarks
Enable the scheduled reboot function.
·     Enable the scheduled reboot function and specify a specific reboot time and date:
scheduler reboot at
·     Enable the scheduled reboot function and specify a reboot waiting time:
scheduler reboot delay
Use either approach.
The scheduled reboot function is disabled by default.
6 Troubleshooting
Symptom
The firewall cannot be powered on, and the power LED (PWR0/PWR1) on the front panel is off.
Solution
To solve the issue:
2.     Verify that the power supply is as required by the firewall.
3.     Verify that the power cords of the firewall are firmly connected.
4.     Verify that the power cords are not damaged.
5.     If the issue persists, contact your local sales agent.
Symptom
The configuration terminal displays nothing or garbled text when the firewall is powered on.
Solution
To solve the issue:
1.     Verify that the power supply system is operating correctly.
2.     Verify that the serial console cable or micro USB console cable is correctly connected.
3.     Verify that the serial console cable or micro USB console cable is connected to the serial port configured on the configuration terminal.
4.     Verify that the configuration terminal parameters are configured as follows:
¡     Baud rate—9600.
¡     Data bits—8.
¡     Parity—None.
¡     Stop bits—1.
¡     Flow control—None.
¡     Terminal emulation—VT100.
5.     Verify that the serial console cable or micro USB console cable is in good condition.
6.     If the issue persists, contact your local sales agent.
Password loss
To deal with loss of the password used for accessing the firewall through the serial console port or micro USB console port, see the release notes for the firewall.
Symptom
The temperature of the firewall is higher than the normal operating temperature (45°C or 113°F).
Solution
To solve the issue:
1.     Verify that the fans are operating correctly.
2.     Verify that the operating environment of the firewall has good ventilation.
3.     If the following alarm information is generated, the temperature of the firewall has reached the warning-level high temperature alarm threshold,
%Nov 28 20:02:59:085 2019 H3C DEV/4/TEMPERATURE_WARNING: -Context=1; Temperature is greater than the high-temperature warning threshold on slot 1 sensor outflow 1. Current temperature is 58 degrees centigrade.
Use the display environment command to examine whether the temperature of the firewall keeps rising. If the temperature has reached the alarming-level high temperature alarm threshold, back up data immediately, power off the firewall, and contact your local sales agent.
Information about the firewall temperature in the display environment command output varies by firewall model.
4.     If the issue persists, contact your local sales agent.
Symptom
Software loading fails and the system runs the software of the previous version.
Solution
To solve the issue:
1.     Verify that the physical ports are correctly connected.
2.     Verify that no parameter is configured incorrectly during the loading process. You can examine the software loading process displayed on the HyperTerminal for configuration errors. The following errors can lead to software loading failure.
¡     When XMODEM is used to load software, a baud rate other than 9600 bps is selected, but the baud rate for the HyperTerminal is not reset.
¡     When TFTP is used to load software, an incorrect IP address, software name, or TFTP serve path is configured.
¡     When FTP is used to load software, an incorrect IP address, software name, username, or password is entered.
3.     If the issue persists, contact your local sales agent.
