H3C SecPath F10X0 Firewall Series Installation Guide-6W107
HomeSupportSecurityH3C SecPath F1000 FirewallInstall & UpgradeInstallation GuidesH3C SecPath F10X0 Firewall Series Installation Guide-6W107
02-Appendix A Chassis views and technical specifications
1 Appendix A  Chassis views and technical specifications
Chassis views
F1003-C/F1003-S
The F1003-C or F1003-S firewall provides the following ports on the front panel:
·     Two 1000BASE-X Ethernet fiber ports.
·     Five 10/100/1000BASE-T autosensing Ethernet copper ports (including one management Ethernet port).
·     One USB port.
·     One console port.
·     One reset button.
·     One Micro SD card slot.
Figure1-1 Front panel
(1) 10/100/1000BASE-T Ethernet copper ports
(2) 1000BASE-X Ethernet fiber ports
(3) Console port
(4) Reset button (for device reboot only, and does not restore the factory default)
(5) LEDs
(6) Power adapter receptacle
(7) Micro SD card slot
(8) USB port (host mode, Type A connector)
(9) Management Ethernet port (MGMT)
Figure1-2 Rear panel
(1) Grounding screw
F1003-M
The F1003-M firewall provides the following ports on the front panel:
·     Ten 10/100/1000BASE-T autosensing Ethernet copper ports (including one management Ethernet port).
·     One USB port.
·     One console port.
·     One reset button.
Figure1-3 Front panel
(3) Console port
(5) LEDs
(9) Management Ethernet port (0/MGMT)
Figure1-4 Rear panel
(1) Grounding screw
F1005/F1010
The F1005 or F1010 firewall provides the following ports on the front panel:
·     Eight 10/100/1000BASE-T autosensing Ethernet copper ports.
·     Two bypass ports.
·     Two combo interfaces.
·     Two USB ports.
·     One console port.
·     One drive slot.
Figure1-5 Front panel
(1) Drive slot
(2) Console port
(3) USB ports (host mode, Type A connector)
(4) Combo interfaces
(5) Bypass ports
(6) 10/100/1000BASE-T Ethernet copper ports
(7) LEDs
(8) Management Ethernet port (0/MGMT)
Figure1-6 Rear panel
(1) Grounding screw
(2) Power receptacle
F1020
The F1020 firewall provides the following ports on the front panel:
·     Sixteen 10/100/1000BASE-T autosensing Ethernet copper ports.
·     Eight 1000BASE-X Ethernet fiber ports.
·     Two USB ports.
·     One console port.
·     One drive slot.
Figure1-7 Front panel
(1) Drive slot
(2) LEDs
(3) 10/100/1000BASE-T Ethernet copper ports
(4) 1000BASE-X Ethernet fiber ports
(5) Console port
(6) USB ports (host mode, Type A connector)
(7) Management Ethernet port (0/MGMT)
Figure1-8 Rear panel
(1) Power receptacle
(2) Interface module slot 1
(3) Interface module slot 2 (not supported)
(4) Grounding screw
F1030/F1050/F1060
The F1030, F1050, or F1060 firewall provides the following ports on the front panel:
·     Two USB ports.
·     One console port.
·     One drive slot.
Figure1-9 Front panel
(1) Drive slot
(2) LEDs
(5) Console port
Figure1-10 Rear panel
(4) Grounding screw
F1070/F1080
The F1070 or F1080 firewall provides the following ports on the front panel:
·     Two 10GBASE-R Ethernet fiber ports.
·     Two USB ports.
·     One console port.
·     Two drive slots.
Figure1-11 Front panel
(1) Drive slots
(2) LEDs
(5) 10GBASE-R Ethernet fiber ports
(6) Console port
(7) USB ports (host mode, Type A connector)
Figure1-12 Rear panel
(1) Power module slot 0
(2) Power module slot 1
(3) Interface module slot 1
(4) Interface module slot 2
(5) Grounding screw
F1090
The F1090 firewall provides the following ports on the front panel:
·     Fourteen 10/100/1000BASE-T autosensing Ethernet copper ports.
·     Eight 10GBASE-R Ethernet fiber ports.
·     Two USB ports.
·     One console port.
·     One micro USB port.
·     Two drive slots.
·     Two management Ethernet ports.
Figure1-13 Front panel
(1) Drive slots
(2) Management Ethernet port (1/MGMT)
(4) 10GBASE-R Ethernet fiber ports
(5) 1000BASE-X Ethernet fiber ports
(6) LEDs
(7) Reset button (for device reboot only, and does not restore the factory default)
(8) Micro USB console port
(9) USB port (host mode, Type A connector)
(10) Console port
(11) Management Ethernet port (0/MGMT)
Figure1-14 Rear panel
(1) Power module slot 1
(2) Power module slot 2
(4) Interface module slot 4
(5) Grounding screw
(6) Interface module slot 3
(7) Interface module slot 1
Interface modules
CAUTION
CAUTION:
Do not hot swap interface modules.
Table1-1 displays the slots available for interface module installation.
Table1-1 Interface module and device slot compatibility
Firewall model
Slot number
Slot specification
Available interface modules
F1003-C/F1003-S/F1003-M/F1005/F1010
N/A
N/A
Not supported
F1020
Slot 1
Low speed
·     NSQM1GT4PFC
·     NSQM1GP4FBA
F1030/F1040/F1050/F1060/F1070/F1080
Slots 1 and 2
Low speed
·     NSQM1GT4PFC
·     NSQM1GP4FBA
F1090
Slots 1 to 3
High speed
NS-NIM-TG6A
Slots 2 to 4
Low speed
·     NSQM1GT4PFC
·     NSQM1GP4FBA
NSQM1GT4PFC
The NSQM1GT4PFC interface module provides four 10/100/1000BASE-T Ethernet copper ports.
·     When the firewall is operating correctly, the four ports operate as common data ports.
·     When the firewall is powered off, the four ports are divided into two bypass port pairs with ports 0 and 1 in one pair and ports 2 and 3 in another pair. The two ports in a pair can act as the uplink and downlink interfaces for a Layer 2 link and form a bypass link. This enables traffic to be transmitted through the firewall even if the firewall is powered off and ensures service continuity.
Figure1-15 Front panel of the NSQM1GT4PFC interface module
(2) Captive screw
(3) Ejector lever
NSQM1GP4FBA
The NSQM1GP4FBA interface module provides four 1000BASE-X Ethernet fiber ports.
Figure1-16 Front panel of the NSQM1GP4FBA interface module
(1) 1000BASE-X Ethernet fiber ports
(2) Captive screw
(3) Ejector lever
NS-NIM-TG6A
The NS-NIM-TG6A interface module provides six 10GBASE-R Ethernet fiber ports.
Figure1-17 Front panel of the NS-NIM-TG6A interface module
(1) 10GBASE-R Ethernet fiber ports
(2) Captive screw
(3) Ejector lever
Network data encryption modules
CAUTION
CAUTION:
Do not hot swap network data encryption modules.
The appearance of network data encryption modules varies by models. For more information, see H3C SecPath Firewall Network Data Encryption Module Guide.
Table1-2 describes the hardware and software compatibility with the network data encryption modules.
Table1-2 Hardware and software compatibility with the network data encryption modules
Applicable firewalls
Applicable slots
Applicable software version
NSQM1F1KGM0
F1003-C, F1003-S, F1003-M, F1005, F1010
N/A
N/A
F1020, F1030, F1050, F1060, F1070, F1080
Slot 1
R9333 and later
F1090
Slots 1 and 3
R8601P24 and later
NSQM1F1KGMB
N/A
N/A
F1020
Slot 1
R9345 and later
Slots 1 and 2
R9345 and later
F1090
Slots 1 to 4
R8601P24 and later
NSQM1F1KGMC
N/A
N/A
F1020
Slot 1
R9345P14 and later
Slots 1 and 2
R9345P14 and later
F1090
Subslots 1 to 4
R8601P24 and later
Drives
CAUTION
CAUTION:
Do not hot swap drives.
Table1-3 describes the compatibility between drives and F10X0 firewalls.
Table1-3 Drive compatibility with F10X0 firewalls
Drive
F1005/F1010
F1020/F1030/F1050/F1060
F1070/F1080
F1090
NS-SSD-480G-SATA-SFF
No
Yes
Yes
Yes
Yes
NS-HDD-500G-SATA-SFF
No
No
Yes
No
Yes
NS-HDD-1T-SATA-SFF
No
No
Yes
No
Yes
Power modules
The F1070/F1080/F1090 firewall came with power module slot PWR0 installed with a filler panel and power module slot PWR1 empty. It supports both AC and DC power modules. No power modules are provided with the firewall. Prepare power modules for the firewall yourself as required.
The F1070/F1080/F1090 firewall supports hot swapping of power modules and 1+1 power module redundancy. To install two power modules for the firewall, make sure they are the same model.
Table1-4 Power modules available for the firewall
Firewall model
Available power modules
One built-in power module
F1005/F1010
Two built-in power modules
F1070/F1080
Two power module slots, supporting the following power modules:
·     PSR150-A1
·     PSR150-D1
F1090
·     PSR250-12A1
·     PSR450-12AHD
·     PSR450-12D
AC power modules
PSR150-A1
The PSR150-A1 power module with a product code of PSR150-A1-B provides a maximum output power of 150 W.
Figure1-18 PSR150-A1 power module
(1) Handle
PSR250-12A1
The PSR250-12A1 power module with a product code of PSR250-12A1 provides a maximum output power of 250 W.
Figure1-19 PSR250-12A1 power module
(1) Latch
(2) Status LED
(3) Handle
(4) Power receptacle
DC power modules
PSR150-D1
The PSR150-D1 power module with a product code of PSR150-D1-B provides a maximum output power of 150 W.
Figure1-20 PSR150-D1 power module
(1) Handle
PSR450-12D
The PSR450-12D power module with a product code of PSR450-12D provides a maximum output power of 450 W.
Figure1-21 PSR450-12D power module
(1) Latch
(2) Status LED
(3) Handle
High-voltage DC power modules
CAUTION
CAUTION:
You can install high-voltage DC power modules only on the F1090 firewall.
PSR450-12AHD
The PSR450-12AHD power module with a product code of PSR450-12AHD provides a maximum output power of 450 W.
Figure1-22 PSR450-12AHD power module
(1) Latch
(2) Status LED
(3) Handle
Dimensions and weights
The weight of the firewall includes the chassis and its removable components.
Chassis
Table1-5 Chassis dimensions and weights
Firewall model
Dimensions (H × W × D), excluding rubber feet and mounting brackets
Weight
F1003-C/F1003-S
44 × 266 × 161 mm (1.73 × 10.47 × 6.34 in)
1 kg (2.20 lb)
F1003-M
44 × 330 × 230 mm (1.73 × 12.99 × 9.06 in)
1.5 kg (3.31 lb)
F1005/F1010
44 × 440 × 230 mm (1.73 × 17.32 × 9.06 in)
3 kg (6.61 lb)
F1020
44.2 × 440 × 435 mm (1.74 × 17.32 × 17.13 in)
6.75 kg (14.88 lb)
F1030/F1050/F1060
7.3 kg (16.09 lb)
F1070/F1080
8.5 kg (18.74 lb)
F1090
44 × 440 × 435 mm (1.73 × 17.32 × 17.13 in)
10 kg (22.05 lb)
Interface modules
Table1-6 Interface module dimensions and weights
Interface module model
Weight
NSQM1GT4PFC
19 × 150 × 172.9 mm (0.75 × 5.91 × 6.81 in)
0.45 kg (0.99 lb)
NSQM1GP4FBA
0.42 kg (0.93 lb)
NS-NIM-TG6A
0.4 kg (0.88 lb)
Table1-7 Network data encryption module dimensions and weights
Network data encryption module model
Weight
NSQM1F1KGM0
40.1 × 150 × 172.9 mm (1.58 × 5.91 × 6.81 in)
0.64 kg (1.41 lb)
NSQM1F1KGMB
19.8 × 150 × 172.9 mm (0.78 × 5.91 × 6.81 in)
0.36 kg (0.79 lb)
NSQM1F1KGMC
0.38 kg (0.84 lb)
Drives
Table1-8 Drive dimensions and weights
Drive model
Weight
19 × 75.7 × 118.4 mm (0.75 × 2.98 × 4.66 in)
0.069 kg (0.15 lb)
0.12 kg (0.26 lb)
NS-HDD-1T-SATA-SFF
0.14 kg (0.31 lb)
Storage media
Table1-9 Storage media specifications
Firewall model
Memory
F1003-C
1GB DDR4
F1003-S/F1003-M
2GB DDR4
F1005/F1010
2GB DDR3
F1020
2GB DDR3
F1030/F1050
4GB DDR3
F1060/F1070
8GB DDR3
F1080
16GB DDR3
F1090
16GB DDR4
Table1-10 Memory specifications of drives
Drive model
Memory
480 GB
500 GB
NS-HDD-1T-SATA-SFF
1 TB
Power consumption
The system power consumption includes the power consumptions of the chassis and the removable components.
Chassis
Table1-11 Chassis power consumption
Firewall model
Power consumption
F1003-C
10.5 W
F1003-S
10.5 W
F1003-M
12 W
F1005/F1010
32 W
79 W
F1070/F1080
116 W
F1090
180 W
Interface modules
Table1-12 Interface module power consumption
Power consumption
NSQM1GT4PFC
11.5 W
NSQM1GP4FBA
10.4 W
NS-NIM-TG6A
11 W
Table1-13 Network data encryption module power consumption
Power consumption
NSQM1F1KGM0
4.14 W
NSQM1F1KGMB
3.7 W
NSQM1F1KGMC
5.7 W
Drives
Table1-14 Drive power consumption
Drive model
Power consumption
3 W
4.9 W
NS-HDD-1T-SATA-SFF
5 W
Power module specifications
Table1-15 Power specifications for the F1003-C/F1003-S/F1003-M firewall
Item
Specification
Rated input voltage
12 VDC
Maximum input current
·     F1003-C/F1003-S: 1.5 A
·     F1003-M: 2 A
Maximum power
24 W
Table1-16 AC power module specifications
Model
Rated input voltage range
Maximum power
PSR150-A1
100 VAC to 240 VAC @ 50 Hz or 60 Hz
2 A
150 W
PSR250-12A1
5 A
250 W
Table1-17 DC power module specifications
Model
Maximum power
PSR150-D1
–48 VDC to –60 VDC
6 A
150 W
PSR450-12D
–48 VDC to –60 VDC
15 A
450 W
Table1-18 High-voltage DC power module specifications
Model
Maximum power
PSR450-12AHD
AC input
7 A
450 W
High-voltage DC input
240 VDC to 380 VDC
3.5 A
450 W
Port specifications
Console port
Table1-19 Console port specifications
Item
Specification
Connector
RJ-45
Standard compliant
RS-232
Baud rate
9600 bps (default) to 115200 bps
Cable type
Common asynchronous serial port cable
Transmission distance
≤ 15 m (49.21 ft)
Services
·     Connection to an ASCII terminal
·     Connection to the serial port of a local PC running the terminal emulation program
·     CLI
Table1-20 Micro USB console port specifications
Item
Specification
Connector
Micro USB
Standard compliant
Micro USB
Baud rate
Cable type
USB console cable
≤ 10 m (32.81 ft)
Services
·     CLI
GE copper port
Table1-21 GE copper port specifications
Item
Specification
Connector
RJ-45
Standard compliance
802.3, 802.3u, and 802.3ab
Interface type
MDI/MDI-X autosensing
Cable type
Category 5 or above twisted pair cable
100 m (328.08 ft)
Interface speed and duplex mode
10 Mbps, half/full-duplex
100 Mbps, half/full-duplex
1000 Mbps, full-duplex
The media dependent interface (MDI) standard is typically used on the Ethernet port of network adapters. The media dependent interface crossover (MDI-X) standard is typically used on hubs or LAN switches.
GE fiber port
Table1-22 GE fiber port specifications
Item
Specification
Connector type
LC
Transceiver module type
SFP
Standard compliance
1000BASE-X
Interface speed
1000 Mbps
Duplex mode
Full duplex
Table1-23 1000BASE-X SFP transceiver module specifications
Transceiver module
Central wavelength (nm)
Connector
Cable specifications (µm)
Max transmission distance
SFP-GE-SX-MM850-A
850
LC
50/125, multi-mode optical fiber (MMF)
0.55 km (1804.46 ft)
SFP-GE-LX-SM1310-A
1310
LC
9/125, single-mode optical fiber (SMF)
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310
LC
9/125, SMF
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
9/125, SMF
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
9/125, SMF
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
9/125, SMF
100 km (62.14 miles)
10GE fiber port
The F1070/F1080 firewall provides two 10GBASE-R Ethernet fiber ports and the F1090 provides eight 10GBASE-R Ethernet fiber ports.
Table1-24 10GE fiber port specifications
Item
Specification
Connector type
LC
SFP+
Standard compliance
10GBASE-R
Interface speed
LAN PHY: 10.3125 Gbps/1000 Mbps
Table1-25 10 Gbps SFP+ transceiver module specifications
Transceiver module
Connector
SFP-XG-SX-MM850-A
850
LC
50/125, MMF
300 m (984.25 ft)
82 m (269.03 ft)
66 m (216.54 ft)
62.5/125, MMF
33 m (108.27 ft)
26 m (85.30 ft)
SFP-XG-LX220-MM1310
1310
LC
62.5/125, MMF
220 m (721.78 ft)
50/125, MMF
220 m (721.78 ft)
100 m (328.08 ft)
SFP-XG-LX-SM1310
1310
LC
9/125, SMF
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550
LC
9/125, SMF
40 km (24.86 miles)
The 10GE fiber ports on the F1090 support only SFP-XG-LH40-SM1550 transceiver modules.
