04-Layer 2—LAN Switching Configuration Guide
HomeSupportSwitchesH3C S10500X-G Switch SeriesConfigure & DeployConfiguration GuidesH3C S10500X-G Switch Series Configuration Guides-R7753Pxx-6W10004-Layer 2—LAN Switching Configuration Guide
12-Service loopback group configuration
12-Service loopback group configuration 44.68 KB
Configuring service loopback groups
About service loopback groups
A service loopback group loops packets sent out by the device back to the device. This feature must work with other features. In the current software version, a service loopback group can be applied only to the EVPN VXLAN gateway service.
Restrictions and guidelines: Service loopback group configuration
When you apply service loopback groups to features, follow these restrictions and guidelines:
·     You can apply a service loopback group to other features once the group is created. The service loopback group will process services for the features.
·     Do not delete a service loopback group that is being used by a feature.
Configuring a service loopback group
2.     Create a service loopback group and specify its service type.
service-loopback group group-id type vsi-gateway
You can configure only one service loopback group for a service type.
Display and maintenance commands for service loopback groups
Display information about service loopback groups.
display service-loopback group [ group-id ]
