| 10-SYSLOG-MSG-MIB | 63.86 KB |
SYSLOG-MSG-MIB
About this MIB
Use this MIB to manage syslog messages as SNMP objects and enable and view syslog message notifications.
MIB file name
rfc5676-syslog-msg.mib
Root object
iso(1).org(3).dod(6).internet(1)..mgmt(2).mib-2(1).syslogMsgMib(192)
Scalar objects
syslogMsgTable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
syslogMsgTableMaxSize (1.3.6.1.2.1.192.1.1.1) |
read-write |
Unsigned32 |
Standard MIB values. |
Maximum number of syslog messages in syslogMsgTable. |
Default value: 1024. |
syslogMsgEnableNotifications (1.3.6.1.2.1.192.1.1.2) |
read-write |
SyslogFacility |
true(1),false(2) |
Whether syslogMsgNotification notifications are generated. |
As per the MIB. |
Tabular objects
syslogMsgTable
About this table
This table contains recent syslog messages.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is syslogMsgIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
syslogMsgIndex (1.3.6.1.2.1.192.1.2.1.1) |
not-accessible |
Unsigned32 |
Standard MIB values |
Index of an entry in the syslogMsgTable. |
As per the MIB. |
syslogMsgFacility (1.3.6.1.2.1.192.1.2.1.2) |
read-only |
SyslogFacility |
kern(0), |
Facility of the syslog message. |
As per the MIB. |
syslogMsgSeverity (1.3.6.1.2.1.192.1.2.1.3) |
read-only |
SyslogSeverity |
emerg(0), |
Severity of the syslog message. |
As per the MIB. |
syslogMsgVersion (1.3.6.1.2.1.192.1.2.1.4) |
read-only |
Unsigned32 |
Unsigned32 (0..999) |
Version of the syslog message. |
As per the MIB. |
syslogMsgTimeStamp (1.3.6.1.2.1.192.1.2.1.5) |
read-only |
SyslogTimeStamp |
OCTET STRING (0 | 10 | 13) |
Timestamp of the syslog message. |
As per the MIB. |
syslogMsgHostName (1.3.6.1.2.1.192.1.2.1.6) |
read-only |
DisplayString |
OCTET STRING (0..255) |
Host name of the syslog message. |
As per the MIB. |
syslogMsgAppName (1.3.6.1.2.1.192.1.2.1.7) |
read-only |
DisplayString |
OCTET STRING (0..48) |
Application name of the syslog message. |
As per the MIB. |
syslogMsgProcID (1.3.6.1.2.1.192.1.2.1.8) |
read-only |
DisplayString |
OCTET STRING (0..128) |
Process ID of the syslog message. |
A zero-length string indicates an unknown process ID. |
syslogMsgMsgID (1.3.6.1.2.1.192.1.2.1.9) |
read-only |
DisplayString |
OCTET STRING (0..32) |
Message ID of the syslog message. |
A zero-length string indicates an unknown message ID. |
syslogMsgSDParams (1.3.6.1.2.1.192.1.2.1.10) |
read-only |
Unsigned32 |
Total number of structured data element parameters carried in the syslog message. |
As per the MIB. |
syslogMsgMsg (1.3.6.1.2.1.192.1.2.1.11) |
read-only |
OCTET STRING |
OCTET STRING (0..65535) |
Message part of the syslog message. |
As per the MIB. |
syslogMsgSDTable
About this table
This table contains structured data elements of syslog messages.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are syslogMsgIndex, syslogMsgSDParamIndex, syslogMsgSDID, and syslogMsgSDParamName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
syslogMsgSDParamIndex (1.3.6.1.2.1.192.1.3.1.1) |
not-accessible |
Unsigned32 |
Index of the structured data element parameters contained in a syslog message. |
As per the MIB. |
syslogMsgSDID (1.3.6.1.2.1.192.1.3.1.2) |
not-accessible |
DisplayString |
OCTET STRING (1..32) |
Name (SD-ID) of a structured data element. |
As per the MIB. |
syslogMsgSDParamName (1.3.6.1.2.1.192.1.3.1.3) |
not-accessible |
DisplayString |
Name of a parameter of the structured data element. |
As per the MIB. |
syslogMsgSDParamValue (1.3.6.1.2.1.192.1.3.1.4) |
read-only |
SyslogParamValueString |
Value of the parameter of the syslog message. |
As per the MIB. |
Notifications
This section contains the SYSLOG-MSG-MIB notifications.
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.192.0.1 |
A syslog message generated |
Informational |
Warning |
N/A |
OFF |
This notification is generated when a new syslog message is received and the value of syslogMsgGenerateNotifications is true.
Status control
ON
· CLI: Use the snmp-agent trap enable syslog command.
· MIB: Set syslogMsgEnableNotifications to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable syslog command.
· MIB: Set syslogMsgEnableNotifications to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.192.1.2.1.2 (syslogMsgFacility) |
N |
SyslogFacility |
kern(0) user(1) mail(2) daemon(3) auth(4) syslog(5) lpr(6) news(7) uucp(8) cron(9) authpriv(10) ftp(11) ntp(12) audit(13) console(14) cron2(15) local0(16) local1(17) local2(18) local3(19) local4(20) local5(21) local6(22) local7(23) |
1.3.6.1.2.1.192.1.2.1.3 (syslogMsgSeverity) |
N |
SyslogSeverity |
emerg(0) alert(1) crit(2) err(3) warning(4) notice(5) info(6) debug(7) |
1.3.6.1.2.1.192.1.2.1.4 (syslogMsgVersion) |
N |
Unsigned32 |
0..999 |
1.3.6.1.2.1.192.1.2.1.5 (syslogMsgTimeStamp) |
N |
SyslogTimeStamp |
OCTET STRING (SIZE (0|10|13)) |
1.3.6.1.2.1.192.1.2.1.6 (syslogMsgHostName) |
N |
DisplayString |
OCTET STRING (SIZE (0..255)) |
1.3.6.1.2.1.192.1.2.1.7 (syslogMsgAppName) |
N |
DisplayString |
OCTET STRING (SIZE (0..48)) |
1.3.6.1.2.1.192.1.2.1.8 (syslogMsgProcID) |
N |
DisplayString |
OCTET STRING (SIZE (0..128)) |
1.3.6.1.2.1.192.1.2.1.9 (syslogMsgMsgID) |
N |
DisplayString |
OCTET STRING (SIZE (0..32)) |
1.3.6.1.2.1.192.1.2.1.10 (syslogMsgSDParams) |
Number of structured data element parameters carried in the syslog message. |
N |
Unsigned32 |
1.3.6.1.2.1.192.1.2.1.11 (syslogMsgMsg) |
N |
OCTET STRING |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
