| 07-HH3C-RES-MON-MIB | 83.95 KB |
hh3cResMonMinorRecoverNotification
hh3cResMonSevereRecoverNotification
hh3cResMonUsedUpRecoverNotification
HH3C-RES-MON-MIB
About this MIB
Use this MIB to monitor and manage state changes of cards and hardware resources on the device and enable the device to send notifications.
MIB file name
hh3c-res-mon.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cResMon(169)
Scalar objects
hh3cResMonMinorResendEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cResMonMinorResendEnable(1.3.6.1.4.1.25506.2.169.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of the minor resource depletion alarm resending feature. |
As per the MIB. |
hh3cResMonOutputEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cResMonOutputEnable (1.3.6.1.4.1.25506.2.169.1.2) |
read-write |
BITS |
BITS {syslog(0), snmpNotification(1), netconfEvent(2)} |
Destinations for resource depletion alarms. |
As per the MIB. |
Tabular objects
hh3cResMonConfigTable
About this table
Use this table to configure resource monitoring settings.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are hh3cResMonChassisIndex, hh3cResMonSlotIndex, hh3cResMonCpuIndex, and hh3cResMonResourceName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cResMonChassisIndex (1.3.6.1.4.1.25506.2.169.2.1.1.1) |
read-only |
Unsigned32 |
Standard MIB values. |
Member ID of the device. |
As per the MIB. |
hh3cResMonSlotIndex (1.3.6.1.4.1.25506.2.169.2.1.1.2) |
read-only |
Unsigned32 |
Slot number. |
As per the MIB. |
hh3cResMonCpuIndex (1.3.6.1.4.1.25506.2.169.2.1.1.3) |
read-only |
Unsigned32 |
CPU ID. |
As per the MIB. |
hh3cResMonResourceName (1.3.6.1.4.1.25506.2.169.2.1.1.4) |
read-only |
OCTET STRING |
OCTET STRING (1..31) |
Resource name. |
As per the MIB. |
hh3cResMonThresholdUnit (1.3.6.1.4.1.25506.2.169.2.1.1.5) |
read-write |
INTEGER |
absolute(1), |
Method for specifying resource depletion thresholds. |
As per the MIB. |
hh3cResMonMinorThreshold (1.3.6.1.4.1.25506.2.169.2.1.1.6) |
read-write |
Unsigned32 |
Minor resource depletion threshold. |
As per the MIB. |
hh3cResMonSevereThreshold (1.3.6.1.4.1.25506.2.169.2.1.1.7) |
read-write |
Unsigned32 |
Severe resource depletion threshold. |
As per the MIB. |
hh3cResMonInfoTable
About this table
Use this table to obtain information about hardware resources.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cResMonUnit (1.3.6.1.4.1.25506.2.169.2.2.1.1) |
read-only |
INTEGER |
absolute(1), percentage(2) |
Expression method for the resource thresholds |
As per the MIB. |
hh3cResMonCurrent (1.3.6.1.4.1.25506.2.169.2.2.1.2) |
read-only |
Unsigned32 |
Amount of the used resource. |
As per the MIB. |
hh3cResMonFree (1.3.6.1.4.1.25506.2.169.2.2.1.3) |
read-only |
Unsigned32 |
Amount of the free resource. |
As per the MIB. |
hh3cResMonTotal (1.3.6.1.4.1.25506.2.169.2.2.1.4) |
read-only |
Unsigned32 |
Total size of resource. |
As per the MIB. |
Notifications
hh3cResMonMinorNotification
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.169.3.0.1 |
Minor resource depletion alarm occurred |
Error |
Minor |
1.3.6.1.4.1.25506.2.169.3.0.2(hh3cResMonMinorRecoverNotification) |
ON |
This notification is generated when the amount of the free resource decreased to or below the hh3cResMonMinorThreshold.
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.169.2.1.1.1 (hh3cResMonChassisIndex) |
Member ID of the device |
Y |
Unsigned32 |
1.3.6.1.4.1.25506.2.169.2.1.1.2 (hh3cResMonSlotIndex) |
Slot number |
Y |
Unsigned32 |
1.3.6.1.4.1.25506.2.169.2.1.1.3 (hh3cResMonCpuIndex) |
CPU ID |
Y |
Unsigned32 |
1.3.6.1.4.1.25506.2.169.2.1.1.4 (hh3cResMonResourceName) |
Resource name |
Y |
OCTET STRING |
1.3.6.1.4.1.25506.2.169.2.1.1.5 (hh3cResMonThresholdUnit) |
Expression method for resource depletion thresholds |
N |
INTEGER |
1.3.6.1.4.1.25506.2.169.2.1.1.6 (hh3cResMonMinorThreshold) |
Minor resource depletion threshold |
N |
Unsigned32 |
1.3.6.1.4.1.25506.2.169.2.1.1.7 (hh3cResMonSevereThreshold) |
Severe resource depletion threshold |
N |
Unsigned32 |
1.3.6.1.4.1.25506.2.169.2.2.1.1 (hh3cResMonCurrent) |
Amount of the used resource |
N |
Unsigned32 |
1.3.6.1.4.1.25506.2.169.2.2.1.2 (hh3cResMonFree) |
Amount of the free resource |
N |
Unsigned32 |
1.3.6.1.4.1.25506.2.169.2.2.1.3 (hh3cResMonTotal) |
Total size of resource |
N |
Unsigned32 |
1.3.6.1.4.1.25506.2.169.3.1.1 (hh3cResMonAdditionalInfo) |
Additional information |
N |
OCTET STRING |
Recommended action
This issue has minor impact on the current services. To avoid more serious issues, take actions at an appropriate time or perform further observation.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.169.3.0.2 |
Minor resource depletion alarm cleared |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the amount of the free resource increased to or above the hh3cResMonMinorThreshold.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Y |
Unsigned32 |
Slot number |
Y |
Unsigned32 |
CPU ID |
Y |
Unsigned32 |
Resource name |
Y |
OCTET STRING |
N |
INTEGER |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
OCTET STRING |
Recommended action
No action is required.
hh3cResMonSevereNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.169.3.0.3 |
Severe resource depletion alarm occurred |
Error |
Major |
1.3.6.1.4.1.25506.2.169.3.0.4(hh3cResMonSevereRecoverNotification) |
ON |
This notification is generated when the amount of the free resource increased to or above the hh3cResMonSevereThreshold.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Y |
Unsigned32 |
Slot number |
Y |
Unsigned32 |
CPU ID |
Y |
Unsigned32 |
Resource name |
Y |
OCTET STRING |
N |
INTEGER |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
OCTET STRING |
Recommended action
The issue has significant impact on current services. Immediate action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.169.3.0.4 |
Severe resource depletion alarm cleared |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the amount of the free resource is increased to or above hh3cResMonSevereThreshold.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Y |
Unsigned32 |
Slot number |
Y |
Unsigned32 |
CPU ID |
Y |
Unsigned32 |
Resource name |
Y |
OCTET STRING |
N |
INTEGER |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
OCTET STRING |
Recommended action
hh3cResMonUsedUpNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.169.3.0.5 |
Resource used up alarm occurred |
Error |
Critical |
1.3.6.1.4.1.25506.2.169.3.0.6(hh3cResMonUsedUpRecoverNotification) |
ON |
This notification is generated when the resource is used up.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Y |
Unsigned32 |
Slot number |
Y |
Unsigned32 |
CPU ID |
Y |
Unsigned32 |
Resource name |
Y |
OCTET STRING |
N |
INTEGER |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
OCTET STRING |
Recommended action
The issue puts system assets and services at risk. Immediate action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.169.3.0.6 |
Resource used up alarm cleared |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the free resource increases from zero up.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Y |
Unsigned32 |
Slot number |
Y |
Unsigned32 |
CPU ID |
Y |
Unsigned32 |
Resource name |
Y |
OCTET STRING |
N |
INTEGER |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
Unsigned32 |
N |
OCTET STRING |
Recommended action
