HomeSupportSwitchesS6520X-EI SeriesConfigure & DeployConfiguration GuidesH3C S6520X & S6520-SI & S5560X-HI & S5000-EI & MS4600 Configuration Guides-R6636Pxx-6W10009-Security Configuration Guide
08-User profile configuration
08-User profile configuration 77.32 KB
Configuring user profiles
About user profiles
A user profile defines a set of parameters, such as a QoS policy, for a user or a class of users. A user profile can be reused when a user connected to the network on a different interface.
The user profile application allows flexible traffic policing on a per-user basis. Each time a user passes authentication, the server sends the device the name of the user profile specified for the user. The device applies the parameters in the user profile to the user.
User profiles are typically used for resource allocation per user. For example, the interface-based traffic policing limits the total amount of bandwidth available to a group of users. However, user-profile-based traffic policing can limit the amount of bandwidth available to a single user.
Prerequisites for user profile
A user profile works with authentication methods. You must configure authentication for a user profile. For information about supported authentication methods, see the configuration guides for the related authentication modules.
Configuring a user profile
2.     Create a user profile and enter user profile view.
user-profile profile-name
3.     Configure the user profile. Choose the options to configure as needed:
¡     Apply an existing QoS policy to the user profile.
By default, no QoS policy is applied to a user profile.
¡     Configure a CAR policy for the user profile.
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
By default, no CAR policy is configured for a user profile.
For more information about QoS policies and CAR policies, see ACL and QoS Configuration Guide.
Display and maintenance commands for user profiles
Display configuration and online user information for the specified user profile or all user profiles.
display user-profile [ name profile-name ] [ slot slot-number ]
User profile configuration examples
Example: Configuring user profiles and QoS policies
Network requirements
As shown in Figure 1, the device performs local 802.1X authentication on the users in domain user for authentication and authorization efficiency.
Configure user profiles and QoS policies on the device to meet the following requirements:
·     User A cannot access the Internet during 8: 30 and 12:00 every day even if User A passes 802.1X authentication.
·     User B has an upload speed of 2 Mbps after passing 802.1X authentication.
·     User C has a download speed of 4 Mbps after passing 802.1X authentication.
Figure 1 Network diagram
Configuration procedure
1.     Configure a QoS policy for User A:
# Create a periodic time range from 8:30 to 12:00 every day.
[Device] time-range for_usera 8:30 to 12:00 daily
# Create IPv4 basic ACL 2000, and configure a rule to match all packets during the time range for_usera.
[Device] acl basic 2000
[Device-acl-basic-2000] rule permit time-range for_usera
[Device-acl-basic-2000] quit
# Create a traffic class named for_usera, and use ACL 2000 as the match criterion.
[Device] traffic classifier for_usera
[Device-classifier-for_usera] if-match acl 2000
[Device-classifier-for_usera] quit
# Create a traffic behavior named for_usera, and configure the deny action.
[Device] traffic behavior for_usera
[Device-behavior-for_usera] filter deny
[Device-behavior-for_usera] quit
# Create a QoS policy named for_usera, and associate traffic class for_usera and traffic behavior for_usera in the QoS policy.
[Device] qos policy for_usera
[Device-qospolicy-for_usera] classifier for_usera behavior for_usera
[Device-qospolicy-for_usera] quit
2.     Create a user profile for User A and apply the QoS policy to the user profile:
# Create a user profile named usera.
[Device] user-profile usera
# Apply QoS policy for_usera to the inbound direction of user profile usera.
[[Device-user-profile-usera] qos apply policy for_usera inbound
[Device-user-profile-usera] quit
3.     Configure a QoS policy for limiting the traffic rate for User B:
# Create a traffic class named class to match all packets.
[Device] traffic classifier class
[Device-classifier-class] if-match any
[Device-classifier-class] quit
# Create a traffic behavior named for_userb, and configure a traffic policing action (CIR 2000 kbps).
[Device] traffic behavior for_userb
[Device-behavior-for_userb] car cir 2000
[Device-behavior-for_userb] quit
# Create a QoS policy named for_userb, and associate traffic class class and traffic behavior for_userb in the QoS policy.
[Device] qos policy for_userb
[Device-qospolicy-for_userb] classifier class behavior for_userb
[Device-qospolicy-for_userb] quit
4.     Create a user profile for User B and apply the QoS policy to the user profile:
# Create a user profile named userb.
[Device] user-profile userb
# Apply QoS policy for_userb to the inbound direction of user profile userb.
[Device-user-profile-userb] qos apply policy for_userb inbound
[Device-user-profile-userb] quit
5.     Configure a QoS policy for limiting the traffic rate for User C:
# Create a traffic behavior named for_userc, and configure a traffic policing action (CIR 4000 kbps).
[Device] traffic behavior for_userc
[Device-behavior-for_userc] car cir 4000
[Device-behavior-for_userc] quit
# Create a QoS policy named for_userc, and associate traffic class class and traffic behavior for_userc in the QoS policy.
[Device] qos policy for_userc
[Device-qospolicy-for_userc] classifier class behavior for_userc
[Device-qospolicy-for_userc] quit
6.     Create a user profile for User C and apply the QoS policy to the user profile:
# Create a user profile named userc.
[Device] user-profile userc
# Apply QoS policy for_userc to the outbound direction of user profile userc.
[Device-user-profile-userc] qos apply policy for_userc outbound
[Device-user-profile-userc] quit
7.     Configure local users:
# Create a local user named usera.
[Device] local-user usera class network
New local user added.
# Set the password to 123456TESTusera&! for user usera.
[Device-luser-network-usera] password simple 123456TESTusera&!
# Authorize user usera to use the LAN access service.
[Device-luser-network-usera] service-type lan-access
# Specify user profile usera as the authorization user profile for user usera.
[Device-luser-network-usera] authorization-attribute user-profile usera
[Device-luser-network-usera] quit
# Create a local user named userb.
[Device] local-user userb class network
# Set the password to 123456TESTuserb&! for user userb.
[Device-luser-network-userb] password simple 123456TESTuserb&!
# Authorize user userb to use the LAN access service.
[Device-luser-network-userb] service-type lan-access
# Specify user profile userb as the authorization user profile for user userb.
[Device-luser-network-userb] authorization-attribute user-profile userb
[Device-luser-network-userb] quit
# Create a local user named userc.
[Device] local-user userc class network
# Set the password to 123456TESTuserc&! for user userc.
[Device-luser-network-userc] password simple 123456TESTuserc&!
# Authorize user userc to use the LAN access service.
[Device-luser-network-userc] service-type lan-access
# Specify user profile userc as the authorization user profile for user userc.
[Device-luser-network-userc] authorization-attribute user-profile userc
[Device-luser-network-userc] quit
8.     Configure the authentication, authorization, and accounting methods for local users:
[Device] domain user
[Device-isp-user] authentication lan-access local
[Device-isp-user] authorization lan-access local
[Device-isp-user] accounting login none
[Device-isp-user] quit
9.     Configure 802.1X:
# Enable 802.1X on Ten-GigabitEthernet 1/0/1.
[Device-Ten-GigabitEthernet1/0/1] dot1x
# Enable MAC-based access control on the port. By default, a port uses MAC-based access control.
[Device-Ten-GigabitEthernet1/0/1] dot1x port-method macbased
# Enable 802.1X globally.
[Device] dot1x
# Verify that the three users can pass 802.1X authentication and that QoS policies take effect on these users. (Details not shown.)
# Display user profile information.
<Device> display user-profile
  User-Profile: usera
    Inbound:
      Policy: for_usera
    slot 1:
      User -:
        Authentication type: 802.1X
        Network attributes:
          Interface    : Ten-GigabitEthernet1/0/1
          MAC address  : 6805-ca06-557b
          Service VLAN : 1
  User-Profile: userb
    Inbound:
      Policy: for_userb
    slot 1:
      User -:
        Network attributes:
          MAC address  : 80c1-6ee0-2664
          Service VLAN : 1
  User-Profile: userc
    Outbound:
      Policy: for_userc
    slot 1:
      User -:
        Network attributes:
          MAC address  : 6805-ca05-3efa
          Service VLAN : 1
