09-Segment Routing Command Reference
HomeSupportSwitchesS12500R SeriesReference GuidesCommand ReferencesH3C S12500R-48Y8C&S12500R-48C6D Switch Router Command References(R52xx)-6W10009-Segment Routing Command Reference
03-SRv6 commands
03-SRv6 commands 320.68 KB
SRv6 commands· 1
advertise srv6 locator 1
anycast enable· 2
diffserv-mode· 2
display bgp egress-engineering ipv6· 4
display bgp egress-engineering srv6 peer-set 6
display isis segment-routing ipv6 capability· 7
display isis segment-routing ipv6 locator 8
display isis segment-routing ipv6 sid-info conflict 11
display isis segment-routing ipv6 sid-info locator 12
display isis segment-routing ipv6 sid-info sid· 15
display isis segment-routing ipv6 sid-info statistics· 17
display isis segment-routing ipv6 sid-info system-id· 18
display ospfv3 segment-routing ipv6 capability· 21
display ospfv3 segment-routing ipv6 locator 21
display segment-routing ipv6 available-static-sid· 23
display segment-routing ipv6 brief 24
display segment-routing ipv6 forwarding· 25
display segment-routing ipv6 local-sid· 26
display segment-routing ipv6 local-sid forwarding statistics· 32
display segment-routing ipv6 local-sid statistics· 34
display segment-routing ipv6 locator 36
display segment-routing ipv6 locator-statistics· 37
egress-engineering srv6 peer-set 38
encapsulation source-address· 40
fast-reroute microloop-avoidance enable· 40
fast-reroute microloop-avoidance rib-update-delay· 42
fast-reroute ti-lfa· 42
flavor-mode switch no-psp· 44
isis ipv6 fast-reroute ti-lfa disable· 45
locator 45
local-sid forwarding statistics enable· 47
local-sid forwarding statistics interval 47
opcode· 48
ospfv3 fast-reroute ti-lfa disable· 51
path-mtu· 52
path-mtu reserved· 53
peer egress-engineering srv6· 53
peer peer-set 55
reset segment-routing ipv6 local-sid forwarding statistics· 56
segment-routing ipv6 (system view) 56
segment-routing ipv6 advertise l3-service-sid· 57
segment-routing ipv6 egress-engineering locator 57
segment-routing ipv6 end-x delete-delay· 58
segment-routing ipv6 locator (IS-IS IPv6 address family view) 59
segment-routing ipv6 locator (OSPFv3 process view) 60
segment-routing microloop-avoidance enable· 61
segment-routing microloop-avoidance rib-update-delay· 63
srh-mode switch normal 64
SRv6 commands
Use advertise srv6 locator to enable the device to generate routes for a locator in the BGP IPv6 unicast routing table and advertise the routes to BGP peers.
Use undo advertise srv6 locator to delete routes for a locator from the BGP IPv6 unicast routing table.
advertise srv6 locator locator-name [ route-policy route-policy-name ]
undo advertise srv6 locator locator-name
The device does not generate routes for a locator in the BGP IPv6 unicast routing table.
BGP IPv6 unicast address family view
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. Only routes that match the routing policy can be generated in the BGP IPv6 unicast routing table for the locator. All routes for the locator can be generated in the BGP IPv6 unicast routing table in the following situations:
·     You do not specify a routing policy when using this command.
·     The specified routing policy does not exist.
·     The specified routing policy does not contain if-match clauses.
Use this command in an inter-AS BGP network. This command enables the device to use BGP to advertise routes for a locator.
Repeat this command to enable the device to use BGP to advertise routes for multiple locators.
# Enable the device to generate routes for locator abc in the BGP IPv6 unicast routing table and advertise the routes to BGP peers.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6
[Sysname-bgp-default-ipv6] advertise srv6 locator abc
locator
anycast enable
Use anycast enable to enable anycast for an SRv6 locator.
Use undo anycast enable to disable anycast for an SRv6 locator.
anycast enable
undo anycast enable
Anycast is disabled for an SRv6 locator.
SRv6 locator view
After you apply a locator to a routing protocol. The routing protocol will advertise the SRv6 SIDs in the locator. By default, the N-bit is set in the Flags field of the Locator TLV in routing protocol packets. The locator belongs to one SRv6 node. If you enable anycast for a locator, the A-bit is set in the Flags field of the Locator TLV in routing protocol packets. The locator is shared by a group of SRv6 nodes.
# Enable anycast for locator test1.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] locator test1 ipv6-prefix 100:: 64 static 32
[Sysname-segment-routing-ipv6-locator-test1] anycast enable
locator
diffserv-mode
Use diffserv-mode to configure the SRv6 DiffServ mode.
Use undo diffserv-mode to restore the default.
diffserv-mode { ingress { pipe service-class | short-pipe service-class | uniform } egress { pipe | short-pipe | uniform } | { pipe service-class | short-pipe service-class | uniform } }
undo diffserv-mode
No SRv6 DiffServ mode is configured.
SRv6 view
ingress: Specifies the inbound direction.
egress: Specifies the outbound direction.
pipe: Specifies the pipe mode.
short-pipe: Specifies the short-pipe mode.
uniform: Specifies the uniform mode.
service-class: Specifies a traffic class for packets that enters the SRv6 network from the IP network. The value range for the traffic class is 0 to 7. Values 0 to 7 represent traffic classes be, af1, af2, af3, af4, ef, cs6, and cs7, respectively.
The following SRv6 DiffServ modes are available:
·     Pipe mode—When a packet enters the SRv6 network, the ingress node adds a new IPv6 header to the original packet. The ingress node ignores the IP precedence or DSCP value in the original packet and uses the value specified by using the service-class argument as the traffic class in the new IPv6 header. In the SRv6 network, SRv6 nodes perform QoS scheduling for the packet based on the specified traffic class. When the packet leaves the SRv6 network, the egress node removes the outer IPv6 header from the packet without modifying the IP precedence or DSCP value in the original packet.
·     Short-pipe mode—When a packet enters and leaves the SRv6 network, all SRv6 nodes process the packet in the same way as in pipe mode except for the egress node. After the egress node removes the outer IPv6 header from the packet, it performs QoS scheduling as follows:
¡     If no priority trust mode is configured, the egress node performs QoS scheduling for the packet based on the IP precedence or DSCP value in the original packet.
¡     If a priority trust mode is configured, the egress node performs QoS scheduling for the packet based on the trusted priority.
·     Uniform mode—When a packet enters the IPv6 network, the ingress node maps the IP precedence or DSCP value in the original IP header to the outer IPv6 header as the traffic class. When the packet leaves the SRv6 network, the egress node maps the traffic class value in the outer IPv6 header to the original packet as the IP precedence or DSCP value.
The accuracy changes when the DSCP value and traffic class value are mapped to each other.
To specify different DiffServ modes for the inbound and outbound directions, use the diffserv-mode command with the ingress and egress keywords. To specify the same DiffServ mode for the inbound and outbound directions, use the diffserv-mode command without the ingress or egress keyword.
If you execute the diffserv-mode command multiple times, the most recent configuration takes effect.
When you configure the SRv6 DiffServ mode on the source and destination nodes of an SRv6 tunnel, follow these restrictions and guidelines:
·     The outbound DiffServ mode on the local end must be the same as the inbound DiffServ mode on the peer end.
·     The inbound DiffServ mode on the local end must be the same as the outbound DiffServ mode on the peer end.
For more information about IP precedence and DSCP, see priority mapping configuration in QoS Configuration Guide.
# Configure the SRv6 DiffServ mode as uniform.
[Sysname-segment-routing-ipv6] diffserv-mode uniform
Use display bgp egress-engineering ipv6 to display BGP-EPE information for IPv6 peers.
display bgp [ instance instance-name ] egress-engineering ipv6 [ ipv6-address ] [ verbose ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays information about the default BGP instance.
ipv6-address: Specifies an IPv6 peer by its IPv6 address. The specified IPv6 peer must already exist. If you do not specify an IPv6 peer, this command displays BGP-EPE information for all IPv6 peers.
verbose: Displays detailed BGP-EPE information. If you do not specify this keyword, the command displays only brief BGP-EPE information.
# Display BGP-EPE information for all IPv6 peers.
<Sysname> display bgp egress-engineering ipv6
BGP peering segment type: Node-Adjacency
  Peer NodeAdj     : 2::9
  Local AS number  : 100
  Remote AS number : 200
  Local router ID  : 1.1.1.9
  Remote router ID : 2.2.2.9
  Interface        : HGE1/0/1
  OriginalNextHop  : 2::9
  RelayNextHop     : FE80::28B6:9EFF:FE23:206
  Interface        : HGE1/0/2
  RelayNextHop     : FE80::28B6:9EFF:FE23:208
# Display detailed BGP-EPE information for all IPv6 peers.
<Sysname> display bgp egress-engineering ipv6 verbose
  PeerAdj Num              : 2
  Nexthop                  : 2::9
  Local interface address  : 10::1
  Remote interface address : 10::2
  SID(no PSP, no USP)      : 200::1
  SID(PSP)                 : 200::2
  Local interface address  : 20::1
  Remote interface address : 20::2
  SID(PSP)                 : 200::2
  BGP peering segment type : Adjacency
    PeerAdj                  : FE80::28B6:9EFF:FE23:206
    Local interface address  : FE80::28B6:9EFF:FE23:D16
    Remote interface address : FE80::28B6:9EFF:FE23:206
    SID(no PSP, no USP)      : 200::3
    SID(PSP)                 : 200::4
    PeerAdj                  : FE80::28B6:9EFF:FE23:208
    Local interface address  : FE80::28B6:9EFF:FE23:D18
    Remote interface address : FE80::28B6:9EFF:FE23:208
    SID(no PSP, no USP)      : 200::5
    SID(PSP)                 : 200::6
BGP peering segment type of the peer:
·     Node—Node type.
·     Adjacency—Adjacency type.
·     Node-Adjacency—Node and adjacency type.
Peer Node
Address of the node-type peer.
Peer Adj
Address of the adjacency-type peer.
Peer NodeAdj
Address of the node- and adjacency-type peer.
PeerAdj Num
Number of adjacency-type peers.
Information about the interface used to establish peer relationship.
OriginalNextHop
IP address of the original next hop.
RelayNextHop
IP address of the recursed next hop.
SID(PSP)
End.X SID (PSP type).
SID(no PSP, no USP)
End.X SID (non-PSP and non-USP type).
Use display bgp egress-engineering srv6 peer-set to display information about BGP-EPE SRv6 peer sets.
display bgp [ instance instance-name ] egress-engineering srv6 peer-set [ srv6-peer-set-name ]
peer-set-name: Specifies a BGP-EPE SRv6 peer set by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a BGP-EPE SRv6 peer set, this command displays information about all BGP-EPE SRv6 peer sets.
# Display information about all BGP-EPE SRv6 peer sets.
<Sysname> display bgp egress-engineering srv6 peer-set
BGP egress peering segment srv6 peer-set: abc
  StaticSID(PSP)           : 210::11
  StaticSID(no PSP, no USP): 210::12
  SID(PSP)                 : 101::1:0:0
  SID(no PSP, no USP)      : 101::1:0:1
Members: 1
  Peer: 4:4:4::4
Name of a BGP-EPE SRv6 peer set.
StaticSID(PSP)
Manually configured End.X SID (PSP flavor type).
Manually configured End.X SID (nonPSP non USP flavor type).
SID(PSP)
SID(no PSP, no USP)
Members
Number of peers in the BGP-EPE SRv6 peer set.
Peer
Peer in the BGP-EPE SRv6 peer set.
Use display isis segment-routing ipv6 capability to display IS-IS SRv6 capability information.
display isis segment-routing ipv6 capability [ level-1 | level-2 ] [ process-id ]
level-1: Specifies IS-IS Level-1.
level-2: Specifies IS-IS Level-2.
process-id: Specifies an IS-IS process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays SRv6 capability information for all IS-IS processes.
If you do not specify a level, this command displays IS-IS SRv6 capability information for both Level-1 and Level-2.
# Display SRv6 capability information for IS-IS process 1.
<Sysname> display isis segment-routing ipv6 capability level-1 1
      IPv6 segment routing capability information for IS-IS(1)
                Level-1 IPv6 segment routing capability
System ID               SRv6 capability
0000.1000.0001          Enabled
0000.2000.0001          Enabled
0000.2000.0002          Enabled
0000.2000.0003          Enabled
System ID
Neighbor system ID.
SRv6 capability
Whether SRv6 is enabled.
Use display isis segment-routing ipv6 locator to display IS-IS SRv6 locator route information.
display isis segment-routing ipv6 locator [ ipv6-address prefix-length ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
ipv6-address prefix-length: Specifies a destination IPv6 address prefix and the prefix length. The value range for the prefix-length argument is 1 to 128.
level-1: Specifies the level-1 area.
level-2: Specifies the level-2 area.
verbose: Displays detailed IS-IS SRv6 locator route information. If you do not specify this keyword, the command displays only brief IS-IS SRv6 locator route information.
process-id: Specifies an IS-IS process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays IS-IS SRv6 locator route information for all IS-IS processes.
# Display IS-IS SRv6 locator route information.
<Sysname> display isis segment-routing ipv6 locator
                          Level-1 Locator Route Table
 Destination : 201::                                   PrefixLen: 64
 Flags       : R/-/-                                   Cost     : 2
 Next hop    : FE80::38A5:3DFF:FEE9:218                Interface: HGE1/0/1
 Destination : 202::                                   PrefixLen: 64
 Flags       : R/-/-                                   Cost     : 1
 Next hop    : FE80::38A5:3DFF:FEE9:218                Interface: HGE1/0/3
Destination
Destination IPv6 prefix.
PrefixLen
Prefix length.
Flag/Flags
Route flags:
·     D—The route is a direct route.
·     R—The route has been flushed to the RIB.
·     L—The route has been advertised in LSPs.
·     U—Penetration flag. Setting it to UP can prevent an LSP sent from L2 to L1 from being sent back to L2.
Cost
Route cost value.
Next hop
Route next hop.
Output interface.
# Display detailed IS-IS SRv6 locator route information.
<Sysname> display isis segment-routing ipv6 locator verbose
 IPv6 dest   : 5000::/64
 Flag        : D/L/-                       Cost        : 0
 Admin tag   : -                           Src count   : 1
 Algorithm   : 0
 Priority    : Low
 Nexthop     : Direct
 NxthopFlag  : -
 Interface   : NULL0                       Delay Flag : N/A
 Nib ID      : 0x0
                          Level-2 Locator Route Table
 Admin tag   : -                           Src count   : 4
 Algorithm   : 0
 Priority    : Low
 Nexthop     : Direct
 NxthopFlag  : -
 Nib ID      : 0x0
Table 5 Command output
Locator route information about the IS-IS process.
IS-IS Level-1 locator route information.
IS-IS Level-2 locator route information.
IPv6 dest
Flag
Route state flag:
·     D—Direct route.
·     R—The route has been added into the routing table.
·     L—The route has been advertised in an LSP.
·     URoute leaking flag, indicating that the Level-1 route is from Level-2. U means that the route will not be returned to Level-2.
Cost
Route cost.
Admin tag
Administrative tag.
Src count
Number of advertisement sources.
Algorithm
Flexible algorithm ID.
Priority
Route convergence priority:
·     Critical.
·     High.
·     Medium.
·     Low.
Next hop
Next hop. If the route is a direct route, this field displays Direct.
NxthopFlag
Next hop flag. Value D indicates that the next hop is the direct next hop of the advertisement source.
Output interface.
Delay Flag
Microloop avoidance delay flag:
·     D—Microloop avoidance is configured. Route convergence is delayed.
·     N/A—Microloop avoidance is not configured or the microloop avoidance delay timer has expired. Route convergence is in progress.
Nib ID
Next hop index assigned by the routing management module.
Use display isis segment-routing ipv6 sid-info conflict to display information about conflicting SRv6 SIDs.
display isis segment-routing ipv6 sid-info conflict [ sid-value ] [ level-1 | level-2 ] [ process-id ]
sid-value: Specifies an SRv6 SID.
process-id: Specifies an IS-IS process by its process ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays information about conflicting SRv6 SIDs for all IS-IS processes.
If you do not specify any parameters, this command displays information about all conflicting SRv6 SIDs.
# Display information about all conflicting SRv6 SIDs.
<Sysname> display isis segment ipv6 sid-info conflict
          Segment Routing IPv6 SID Conflict Information For IS-IS(1)
                       Level-1 SID Conflict Information
SID: 6:5::100
  System ID=3333.3333.3333.00, Flag(A)=0, Function type=End with PSP
  System ID=4444.4444.4444.00, Flag(A)=0, Function type=End with PSP
SID: 6:5::101
  System ID=3333.3333.3333.00, Flag(A)=0, Function type=End (no PSP, no USP)
  System ID=4444.4444.4444.00, Flag(A)=0, Function type=End (no PSP, no USP)
SID: 6:5::103
  System ID=3333.3333.3333.00, Flag(A)=0, Function type=End.X (no PSP, no USP)
  System ID=4444.4444.4444.00, Flag(A)=0, Function type=End.X (no PSP, no USP)
Table 6 Command output
SID
Conflicting SRv6 SID.
System ID
ID of the system that advertised the SID.
Flag (A)
Anycast flag (A flag). The value is 1 if this flag is set, which indicates that the SID is an anycast SID.
Function type
SID function type:
·     End (no PSP, no USP)—End SID, which is not removed on the penultimate segment or the ultimate segment.
·     End with PSP—End SID, which is removed on the penultimate segment.
·     End with USP—End SID, which is removed on the ultimate segment.
·     End with PSP&USP—End SID, which is removed on the penultimate segment and the ultimate segment.
·     End.X (no PSP, no USP)—End.X SID, which is not removed on the penultimate segment or the ultimate segment.
·     End.X with PSP—End.X SID, which is removed on the penultimate segment.
·     End.X with USP—End.X SID, which is removed on the ultimate segment.
·     End.X with PSP&USP—End.T SID, which is removed on the penultimate segment and the ultimate segment.
·     End.DT4—End.DT4 SID.
·     End.DT6—End.DT6 SID.
·     End.DT46—End.DT46 SID.
·     End with COC—End SID.
·     End with PSP&COC—End SID.
·     End with PSP&USP&COC—End SID.
·     End.X with COC—End.X SID.
·     End.X with PSP&COC—End.X SID.
·     End.X with PSP&USP&COC—End.X SID.
·     End with PSP&USD&COC—End SID.
·     End with PSP&USP&USD&COC—End SID.
·     End.X with PSP&USD&COC—End.X SID.
·     End.X with PSP&USP&USD&COC—End.X SID.
Use display isis segment-routing ipv6 sid-info locator to display information about SRv6 SIDs advertised by IS-IS in a locator or all locators.
display isis segment-routing ipv6 sid-info locator [ ipv6-prefix prefix-length ] [ end | end-dt4 | end-dt46 | end-dt6 | end-m | end-x ] [ level-1 | level-2 ] [ process-id ]
ipv6-prefix prefix-length: Specifies a locator by its IPv6 prefix. The ipv6-prefix argument represents the IPv6 prefix address. The prefix-length argument represents the prefix length, in the range of 32 to 120.
end: Specifies End SIDs.
end-dt4: Specifies End.DT4 SIDs.
end-dt46: Specifies End.DT46 SIDs.
end-dt6: Specifies End.DT6 SIDs.
end-m: Specifies End.M SIDs.
end-x: Specifies End.X SIDs.
process-id: Specifies an IS-IS process by its process ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays information about SRv6 SIDs in the specified locator for all IS-IS processes.
If you do not specify any parameters, this command displays information about SRv6 SIDs advertised by IS-IS in all locators.
# Display information about SRv6 SIDs advertised by level-1 IS-IS in all locators.
<Sysname> display isis segment ipv6 sid-info locator level-1
          Segment Routing IPv6 SID Locator Information For IS-IS(1)
                           Level-1 SID Information
Locator: 1:2::/96
    System ID: 1111.1111.1111.00
       Locator Info: Cost=0, Flag(D)=0, Flag(A)=0, Algorithm=0
       SID: 1:2::1
          Function Type: End.DT4
            Neighbor ID: --
       SID: 1:2::2
          Function Type: End.DT6
            Neighbor ID: --
       SID: 1:2::3
          Function Type: End.DT46
            Neighbor ID: --
       SID: 1:2::104
          Function Type: End with PSP
            Neighbor ID: --
       SID: 1:2::105
          Function Type: End (no PSP, no USP)
            Neighbor ID: --
       SID: 1:2::106
          Function Type: End.X (no PSP, no USP)
            Neighbor ID: 2222.2222.2222.00
       SID: 1:2::107
          Function Type: End.X with PSP
Table 7 Command output
System ID
ID of the system that advertised an SRv6 SID.
SID
SRv6 SID.
Locator Info
Locator information.
Cost
Locator TLV cost.
Flag (D)
Leaking flag (D flag). The value is 1 if this flag is set, which indicates that locator TLVs cannot be leaked from Level-1 to Level-2.
Flag (A)
Anycast locator flag (A flag). The value is 1 if this flag is set, which indicates that the locator is an anycast locator.
Algorithm
ID of the algorithm associated with the SRv6 locator:
·     0—SPF algorithm.
·     128 to 255—Flex-Algo algorithm.
Function type
SID function type:
Neighbor ID
Neighbor ID.
This field displays a value only for an End.X SID. For other SRv6 SIDs, this field displays two hyphens (--).
Use display isis segment-routing ipv6 sid-info sid to display information about SRv6 SIDs advertised by IS-IS.
display isis segment-routing ipv6 sid-info sid [ sid-value | [ end | end-dt4 | end-dt46 | end-dt6 | end-m | end-x ] ] [ level-1 | level-2 ] [ process-id ]
process-id: Specifies an IS-IS process by its process ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays information about SRv6 SIDs for all IS-IS processes.
If you do not specify any parameters, this command displays information about all SRv6 SIDs advertised by IS-IS.
# Display information about all SRv6 SIDs advertised by level-1 IS-IS.
<Sysname> display isis segment-routing ipv6 sid-info sid level-1
              Segment Routing IPv6 SID Information For IS-IS(1)
SID: 1:2::1
           Flag(A): 0
       Neighbor ID: --
SID: 1:2::2
           Flag(A): 0, Function Type: End.DT6
       Neighbor ID: --
SID: 1:2::3
           Flag(A): 0, Function Type: End.DT46
       Neighbor ID: --
SID: 1:2::105
           Flag(A): 0, Function Type: End (no PSP, no USP)
       Neighbor ID: --
SID: 1:2::106
           Flag(A): 0, Function Type: End.X (no PSP, no USP)
Table 8 Command output
SID
SRv6 SID advertised by IS-IS
Flag (A)
Function type
SID function type:
System ID
ID of the system that advertised the SRv6 SID.
Neighbor ID
Neighbor ID.
Use display isis segment-routing ipv6 sid-info statistics to display SRv6 SID statistics.
display isis segment-routing ipv6 sid-info statistics [ system-id system-id ] [ level-1 | level-2 ] [ process-id ]
system-id system-id: Specifies an advertisement source by its system ID.
process-id: Specifies an IS-IS process by its process ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays SRv6 SID statistics for all IS-IS processes.
If you do not specify any parameters, this command displays all SRv6 SID statistics.
# Display all SRv6 SID statistics.
<Sysname> display isis segment-routing ipv6 sid-info statistics
          Segment Routing IPv6 SID Statistic Information For IS-IS(1)
                       Level-1 SID Statistic Information
System ID: 3333.3333.3333.00
  Locator: 6:5::/96
    End=2, End.X=0, End.M=0, End.DT4=0, End.DT6=0, End.DT46=0
  Total advertised SIDs:
  Locator: 1:2::/96
    End=2, End.X=2, End.M=0, End.DT4=3, End.DT6=3, End.DT46=1
Table 9 Command output
System ID
ID of the system that advertised SRv6 SIDs.
Locator
Locator of the SRv6 SIDs.
End
Number of advertised End SIDs.
End.X
Number of advertised End.X SIDs.
End.M
Number of advertised End.M SIDs.
End.DT4
Number of advertised End.DT4 SIDs.
End.DT6
Number of advertised End.DT6 SIDs.
End.DT46
Number of advertised End.DT46 SIDs.
Total number of advertised SRv6 SIDs.
Use display isis segment-routing ipv6 sid-info system-id to display information about SRv6 SIDs advertised from an advertisement source or all advertisement sources.
display isis segment-routing ipv6 sid-info system-id [ system-id ] [ end | end-dt4 | end-dt46 | end-dt6 | end-m | end-x ] [ level-1 | level-2 ] [ process-id ]
process-id: Specifies an IS-IS process by its process ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays information about SRv6 SIDs advertised from the specified advertisement source for all IS-IS processes.
If you do not specify any parameters, this command displays information about SRv6 SIDs advertised from all advertisement sources.
# Display information about SRv6 SIDs advertised from 0000.0000.0001.
<Sysname> display isis segment ipv6 sid-info system-id 0000.0000.0001
          Segment Routing IPv6 SID System ID Information For IS-IS(1)
System id: 0000.0000.0001
  Locator: 1:2::/96
  Cost=0, Flag(D)=0,Flag(A)=0,  Algorithm=0
    SID: 1:2::1
        Neighbors ID: --
    SID: 1:2::2
        Neighbors ID: --
    SID: 1:2::3
        Neighbors ID: --
    SID: 1:2::104
        Neighbors ID: --
    SID: 1:2::105
        Neighbors ID: --
    SID: 1:2::106
        Neighbors ID: 2222.2222.2222.00
    SID: 1:2::107
Table 10 Command output
Cost
Locator TLV cost.
Flag (D)
Flag (A)
Algorithm
·     0—SPF algorithm.
SID
SRv6 SID.
Function type
SID function type:
Neighbor ID
Neighbor ID.
Use display ospfv3 segment-routing ipv6 capability to display OSPFv3 SRv6 capability information.
display ospfv3 [ process-id ] segment-routing ipv6 capability
process-id: Specifies an OSPFv3 process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays SRv6 capability information for all OSPFv3 processes.
# Display SRv6 capability information for all OSPFv3 processes.
<Sysname> display ospfv3 segment-routing ipv6 capability
            OSPFv3 Process 1 with Router ID 1.1.1.1
Area 0.0.0.0
 Router ID        SRv6 capability
 2.2.2.2          Enabled
Table 11 Command output
Router ID
Device router ID.
SRv6 capability
Whether SRv6 is enabled. The value can only be Enabled.
Use display ospfv3 segment-routing ipv6 locator to display OSPFv3 SRv6 locator information.
display ospfv3 [ process-id ] segment-routing ipv6 locator [ ipv6-address prefix-length ]
process-id: Specifies an OSPFv3 process by its ID, in the range of 1 to 65535. If you do not specify an OSPFv3 process, this command displays locator information for all OSPFv3 processes.
ipv6-address prefix-length: Specifies an IPv6 address prefix and the prefix length. The ipv6-address argument represents the IPv6 address prefix. The prefix-length argument represents the prefix length, in the range of 32 to 120. If you do not specify this option, the command displays locator information for all IPv6 prefixes.
# Display locator information for all OSPFv3 processes.
<Sysname> display ospfv3 segment-routing ipv6 locator
 I  - Intra area route,  E1 - Type 1 external route,  N1 - Type 1 NSSA route
 IA - Inter area route,  E2 - Type 2 external route,  N2 - Type 2 NSSA route
 *  - Selected route
 *Destination: 192:168::12:0/120
  Type       : I                         Area       : 0.0.0.0
  AdvRouter  : 2.2.2.2                   Preference : 10
  NibID      : 0x23000002                Cost       : 10
  Interface  : HGE1/0/1                  BkInterface: N/A
  Nexthop    : ::
  BkNexthop  : N/A
  Status     : Direct
Table 12 Command output
Destination
Destination network.
Route type.
Area
Area ID.
AdvRouter
ID of the router that advertises LSAs.
Preference
Route preference.
NibID
ID of the next hop information in the route.
Cost
Route cost.
Output interface.
BkInterface
Backup output interface.
Nexthop
Next hop address.
BkNexthop
Backup next hop address.
Status
Route state:
·     Local—The route is a local route and has not been sent to the route management module.
·     Invalid—The next hop of the route is invalid.
·     Stale—The next hop of the route is stale.
·     Normal—The route is usable.
·     Delete—The route is deleted.
·     Direct—The route is a direct route.
·     Rely—The route is recursed by another route.
Use display segment-routing ipv6 available-static-sid to display available static SRv6 SIDs in a locator.
display segment-routing ipv6 available-static-sid locator locator-name [ from begin-value ]
locator locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters.
from begin-value: Specifies available static SRv6 SIDs that start from the specified value. The begin-value argument represents the start value in IPv6 address format. If you do not specify a start value, this command displays available static SRv6 SIDs starting from the smallest available one.
If you specify a static length when configuring an SRv6 locator, the device can allocate static SRv6 SIDs from the locator. Use this command to display a maximum of 10 available static SRv6 SIDs in the locator.
To specify the from begin-value option, you must first identify the static SID range of the locator. For this purpose, use the display segment-routing ipv6 locator command.
# Display available static SRv6 SIDs in locator test1.
<Sysname> display segment-routing ipv6 available-static-sid locator abc
                    Available static SRv6 SID table
 100:1::2
 100:1::3
 100:1::4
 100:1::5
 100:1::6
 100:1::7
 100:1::8
 100:1::9
 100:1::A
 100:1::B
Table 13 Command output
Available static SRv6 SIDs.
N/A
No static SRv6 SIDs are available.
Use display segment-routing ipv6 brief to display brief SRv6 information.
# Display brief SRv6 information.
<Sysname> display segment-routing ipv6 brief
Current SRv6 info:
  Flavor mode: PSP
  SRH encapsulation mode: Reduced
SRv6 info at the next reboot:
  Flavor mode: NO-PSP
SRv6 Locator SBFD: Enabled
SRv6 Locator SBFD Template: LocatorBFD
SRv6 Locator SBFD prefix-list: prefixlist
Table 14 Command output
Current SRv6 info
Current active SRv6 information.
SRv6 information that takes effect at the next startup.
Flavor mode
SRv6 SID flavor:
·     PSP—The penultimate SRv6 node removes the SRH.
·     NO-PSP—The penultimate SRv6 node does not remove the SRH.
·     Normal—Normal encapsulation mode.
·     Reduced—Reduced encapsulation mode.
Template used by the SBFD session for detecting SRv6 locators. If the template is not configured, this field is not displayed.
SRv6 Locator SBFD Prefix-list
Name of the IPv6 prefix list associated with SBFD for detecting SRv6 locators. If the prefix list is not configured, this field is not displayed.
Use display segment-routing ipv6 forwarding to display SRv6 forwarding entry information.
display segment-routing ipv6 forwarding [ entry-id ] [ slot slot-number ]
entry-id: Specifies an SRv6 forwarding entry by its ID, in the range of 0 to 4294967294. If you do not specify an SRv6 forwarding entry ID, this command displays information about all SRv6 forwarding entries.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display all SRv6 forwarding entries.
<Sysname> display segment-routing ipv6 forwarding
Total SRv6 forwarding entries: 4
Flags: T – Forwarded through a tunnel
       N – Forwarded through the outgoing interface to the nexthop IP address
       A - Active forwarding information
       B – Backup forwarding information
       S – Secondary backup path
ID            FWD-Type      Flags   Forwarding info
              Attri-Val             Attri-Val
2148532225    SRv6PSIDList  NA      HGE1/0/1
                                    FE80::54CB:70FF:FE86:316
                                    {6000::1, 7000::1, 8000::1}
2149580801    SRv6PCPath    TA      2148532225
2150629377    SRv6Policy    TA      2149580801
              Policy10
2153775105    SRv6SFC       NA      HGE1/0/1
Table 15 Command output
FWD-Type
Tunnel forwarding type:
·     SRv6PSIDList—Tunnel established based on the SID list in an SRv6 TE policy.
·     SRv6PCPath—Tunnel established on the candidate path selected by an SRv6 TE policy.
·     SRv6Policy—SRv6 TE policy tunnel.
·     SRv6PGroup—SRv6 TE policy group tunnel.
·     SRv6BE—Tunnel corresponding to the next hop in an SRv6 multi-level primary and secondary scenario or a multiple-primary and one-secondary scenario.
·     SRv6SFC—SRv6 service chain static proxy tunnel.
Flags
Forwarding flags:
·     T—Tunnel forwarding.
·     N—Output interface or next hop forwarding.
·     A—Active forwarding information.
·     B—Backup forwarding information.
·     S—Secondary backup forwarding information.
Forwarding info
SRv6 forwarding information.
·     For the N forwarding flag, the forwarding information includes the output interface, next hop, and SID list.
·     For the T forwarding flag, the forwarding information is the SRv6 forwarding entry ID.
Attri-Val
Forwarding attribute.
In the current software version, the value is an SRv6 TE policy name.
This field is available only when the value for the FWD-Type field is SRv6Policy or SRv6PGroup.
Use display segment-routing ipv6 local-sid to display information about the SRv6 local SID forwarding table.
display segment-routing ipv6 local-sid [ locator locator-name ] [ end | end-b6encaps | end-coc32 | end-dt2m | end-dt2u | end-dt2ul | end-dx2 | end-dx2l | end-m | end-op | end-t | end-x-coc32 ] [ owner owner ] [ sid ]
display segment-routing ipv6 local-sid [ locator locator-name ] [ end-dt4 | end-dt46 | end-dt6 | end-dx4 | end-dx6 ] [ owner owner ] [ sid | vpn-instance vpn-instance-name ]
display segment-routing ipv6 local-sid [ locator locator-name ] [ end-x [ sid | interface interface-type interface-number [ nexthop nexthop-ipv6-address ] ] ] [ owner owner ]
locator locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a locator, this command displays information about the SRv6 local SID forwarding table for all locators.
end-b6encaps: Specifies End.B6ENCAPS SIDs.
end-coc32: Specifies End (COC32) SIDs.
end-dt2m: Specifies End.DT2M SIDs.
end-dt2u: Specifies End.DT2U SIDs.
end-dt2ul: Specifies End.DT2UL SIDs.
end-dx2: Specifies End.DX2 SIDs.
end-dx2l: Specifies End.DX2L SIDs.
end-dx4: Specifies End.DX4 SIDs.
end-dx6: Specifies End.DX6 SIDs.
end-op: Specifies End.OP SIDs.
end-t: Specifies End.T SIDs.
end-x-coc32: Specifies End.X (COC32) SIDs.
sid: Specifies an SRv6 SID. If you do not specify an SRv6 SID, this command displays SRv6 local forwarding table information for all SRv6 SIDs of the specified type.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the SRv6 SIDs belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays SRv6 local SID forwarding table information in the public network.
interface interface-type interface-number: Specifies an output interface by its type and number. If you do not specify an output interface, the command displays SRv6 local SID forwarding table information for all End.X SIDs.
nexthop nexthop-ipv6-address: Specifies the IPv6 address of a next hop. If you do not specify a next hop, the command displays SRv6 local SID forwarding table information for all IPv6 next hops.
owner owner: Specifies a protocol. The value for the owner argument is case insensitive. The supported values include SIDMGR, BGP, SRPolicy, IS-IS, and OSPFv3. If you do not specify a protocol, this command displays information about the SRv6 local SID forwarding table for all protocols.
# Display SRv6 local forwarding table information for all End SIDs.
<Sysname> display segment-routing ipv6 local-sid end
                    Local SID forwarding table (End)
Total SIDs: 1
SID           : 100::64/96
Function type : End                             Flavor         : PSP
Locator name  : abc                             Allocation type: Static
Owner         : SIDMGR                          State          : Active
Flags         : F
Create Time   : May 19 17:21:15.687 2020
# Display SRv6 local forwarding table information for all End.X SIDs.
<Sysname> display segment-routing ipv6 local-sid end-x
                    Local SID forwarding table (End.X)
Total SIDs: 1
SID           : 1000:0:0:15::/32
Function type : End.X                           Flavor         : PSP
Interface     : HGE1/0/1                        Interface index: 0x102
Next hop      : FE80::1                         Allocation type: Static
Locator name  : abc
Flags         : F
Create Time   : May 19 17:21:46.740 2020
# Display SRv6 local forwarding table information for all End.X SIDs. (With different output interfaces and nexthops for the same opcode.)
Total SIDs: 1
SID           : 100:1::A/80
Flag          : -                               State          : Active
Owner         : SIDMGR                          Paths          : 2
Path Index    : 1
 Next hop     : 1::1                            Weight         : 1
 Create Time  : May 20 07:23:47.355 2022
Path Index    : 2
 Interface    : HGE1/0/2                        Interface index: 0x2
 Next hop     : 2::2                            Weight         : 1
 Create Time  : May 20 07:23:58.697 2022
# Display SRv6 local forwarding table information for all End.DT4 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dt4
                    Local SID forwarding table (End.DT4)
Total SIDs: 1
SID           : 6:5::1:1/120
Function type : End.DT4                         Flavor         : PSP
VPN instance  : vpn1                            Allocation type: Static
Network type  : MPLS L3VPN
Locator name  : abc
Flags         : F
Create Time   : May 19 17:22:27.356 2020
# Display SRv6 local forwarding table information for all End.DT6 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dt6
                    Local SID forwarding table (End.DT6)
Total SIDs: 1
SID           : 1:2::2:2/120
Function type : End.DT6                         Flavor         : PSP
Locator name  : abc
Flags         : F
# Display SRv6 local forwarding table information for all End.OP SIDs.
<Sysname> display segment-routing ipv6 local-sid end-op
                    Local SID forwarding table (End.OP)
Total SIDs: 1
SID           : 100::190/96
Function type : End.OP
Locator name  : abc
Flags         : F
Create Time   : May 19 17:23:40.248 2020
# Display SRv6 local forwarding table information for all End.DX2 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dx2
                    Local SID forwarding table (End.DX2)
Total SIDs: 1
SID           : 100:1:2:3::6400/96
Function type : End.DX2                         Flavor         : PSP
Xconnect-group: abc                             Connection     : test
VSI name      :                                 Service ID     : 0
Interface     :
Flags         : F
Create Time   : May 20 09:17:58.995 2020
# Display SRv6 local forwarding table information for all End.DT2U SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dt2u
                    Local SID forwarding table (End.DT2U)
Total SIDs: 1
SID           : 100:1:2:3::C800/96
Function type : End.DT2U                        Flavor         : PSP
VSI name      : abc                             Allocation type: Static
Locator name  : abc
Flags         : F
Create Time   : May 20 09:18:14.504 2020
Table 16 Command output
SID
SRv6 SID.
Function type
SRv6 SID type:
·     End.
·     End.B6.Encaps.
·     End (COC32).
·     End.DT2M.
·     End.DT2U.
·     End.DT2UL.
·     End.DT4.
·     End.DT46.
·     End.DT6.
·     End.DX2.
·     End.DX2L.
·     End.M.
·     End.OP.
·     End.X.
·     End.X (COC32).
Flavor
SRv6 SID flavor type:
·     NOPSP—The penultimate SRv6 node does not remove the SRH.
Output interface.
Interface index
Output interface index.
Next hop
Next hop address.
VPN instance
VPN instance name.
For the public network, this field displays Public instance.
Xconnect group
Cross-connect group name.
Connection
Cross-connect name.
VSI name
VSI name.
Service ID
Ethernet service instance ID.
If no Ethernet service instance ID exists, this field displays 0.
Allocation type
SID allocation type:
·     Static—Manually configured.
·     Dynamic—Dynamically allocated.
Network type
Type of the network to which the SRv6 SID is applied:
·     MPLS L3VPN—The SRv6 SID is applied to an MPLS L3VPN network.
·     EVPN L3VPN—The SRv6 SID is applied to an EVPN L3VPN network.
·     MPLS L3VPN, EVPN L3VPN—The SRv6 SID is applied to MPLS L3VPN and EVPN L3VPN networks.
Mirror locator number
Number of protected locators.
Mirror locator
IPv6 address prefix and prefix length of each protected locator.
Owner
Protocol that applies for the SID:
·     SIDMGR.
·     BGP.
·     SRPolicy.
·     IS-IS.
·     OSPFv3.
·     LSM.
Paths
Number of paths.
Path index
Index of the path for the SID.
Weight
Load sharing weight of the path.
SID state:
·     Active.
·     Inactive.
Flags
Flags:
·     If traffic forwarding statistics collection is enabled for local SRv6 SIDs, this field displays F.
·     If traffic forwarding statistics collection is disabled for local SRv6 SIDs, this field displays a hyphen (-).
Create Time
SID creation time.
Use display segment-routing ipv6 local-sid forwarding statistics to display traffic forwarding statistics for local SRv6 SIDs.
display segment-routing ipv6 local-sid forwarding statistics { end | end-dt2m | end-dt2u | end-dt2ul } [ sid ]
display segment-routing ipv6 local-sid forwarding statistics { end-dt4 | end-dt46 | end-dt6 | end-dx4 | end-dx6 } [ sid | vpn-instance vpn-instance-name ]
display segment-routing ipv6 local-sid forwarding statistics end-x [ sid | interface interface-type interface-number [ nexthop nexthop-ipv6-address ] ]
end: Specifies local End SIDs.
end-dt2m: Specifies local End.DT2M SIDs.
end-dt2u: Specifies local End.DT2U SIDs.
end-dt2ul: Specifies local End.DT2UL SIDs.
end-dt4: Specifies local End.DT4 SIDs.
end-dt46: Specifies local End.DT46 SIDs.
end-dt6: Specifies local End.DT6 SIDs.
end-dx4: Specifies local End.DX4 SIDs.
end-dx6: Specifies local End.DX6 SIDs.
end-x: Specifies local End.X SIDs.
sid: Specifies an SRv6 SID. If you do not specify an SRv6 SID, this command displays traffic forwarding statistics for all local SRv6 SIDs of the specified type.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the local SRv6 SIDs belong to the public network, do not specify this option.
interface interface-type interface-number: Specifies an output interface by its type and number. If you do not specify an output interface, this command displays traffic forwarding statistics for all local End.X SIDs.
nexthop nexthop-ipv6-address: Specifies a next hop IPv6 address. If you do not specify a next hop IPv6 address, this command displays traffic forwarding statistics for all next hop IPv6 addresses of local SRv6 SIDs.
# Display traffic forwarding statistics for all local End SIDs.
<Sysname> display segment-routing ipv6 local-sid forwarding statistics end
Total SIDs: 1
SID                  : 100:1::1
Function type      : End
Inbound statistics:
    Total octets   : 0
    Total packets  : 0
    Input rate in last 300 seconds:
      0 bits/sec, 0 pkts/sec
    Input rate in last statistical period (20 sec):
Table 17 Command output
Total SIDs
Total number of SIDs.
SID
SRv6 SID value.
Function type
SRv6 SID type:
·     End.
·     End.DT2M.
·     End.DT2U.
·     End.DT2UL.
·     End.DT4.
·     End.DT46.
·     End.DT6.
·     End.X.
Inbound statistics
Inbound traffic statistics.
Total octets
Total number of incoming octets.
Total packets
Total number of incoming packets.
Number of incoming bits per second and incoming packets per second in the last 300 seconds.
Number of incoming bits per second and incoming packets per second in the last statistical interval. To set the statistical interval, use the local-sid forwarding statistics interval command.
Use display segment-routing ipv6 local-sid statistics to display statistics about SRv6 SIDs allocated for each protocol.
display segment-routing ipv6 local-sid statistics [ locator [ locator-name ] ]
locator: Displays statistics about SRv6 SIDs allocated for each protocol by locator. If you do not specify this keyword, the command does not display statistics about SRv6 SIDs allocated for each protocol by locator.
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a locator, the command displays statistics about SRv6 SIDs for all locators.
# Display statistics about SRv6 SIDs allocated for each protocol (not by locator).
<Sysname> display segment-routing ipv6 local-sid statistics
Total SIDs: 1
Funtion     SIDMGR    SRP       IS-IS     OSPFv3    BGP       L2VPN     Total
END         1         0         0         0         0         0         1
END.X       0         0         0         0         0         0         0
END.COC32   0         0         0         0         0         0         0
END.XCOC32  0         0         0         0         0         0         0
END.B6      0         0         0         0         0         0         0
END.DT4     0         0         0         0         0         0         0
END.DT6     0         0         0         0         0         0         0
END.DT46    0         0         0         0         0         0         0
END.DX4     0         0         0         0         0         0         0
END.DX6     0         0         0         0         0         0         0
END.DX2     0         0         0         0         0         0         0
END.DX2L    0         0         0         0         0         0         0
END.DT2M    0         0         0         0         0         0         0
END.DT2U    0         0         0         0         0         0         0
END.DT2UL   0         0         0         0         0         0         0
END.AS      0         0         0         0         0         0         0
END.AM      0         0         0         0         0         0         0
END.M       0         0         0         0         0         0         0
END.OP      0         0         0         0         0         0         0
END.T       0         0         0         0         0         0         0
# Display statistics about SRv6 SIDs allocated for each protocol from locator abc.
<Sysname> display segment-routing ipv6 local-sid statistics locator abc
Locator: abc    Total SIDs: 1
END         1         0         0         0         0         0         1
END.X       0         0         0         0         0         0         0
END.M       0         0         0         0         0         0         0
END.T       0         0         0         0         0         0         0
Table 18 Command output
Total SIDs
Total number of SRv6 SIDs. If you specify a locator, this field displays the total number of SRv6 SIDs that belong to the specified locator.
Locator
Locator name.
Function
SRv6 SID type:
·     End.
·     End.X.
·     End.COC32—End (COC32) SID.
·     End.XCOC32—End.X (COC32) SID.
·     End.B6—End.B6ENCAPS SID.
·     End.DT4.
·     End.DT6.
·     End.DT46.
·     End.DX4.
·     End.DX6.
·     End.DX2.
·     End.DX2L.
·     End.DT2M.
·     End.DT2U.
·     End.DT2UL.
·     End.AS. The value is not supported in the current software version.
·     End.AM. The value is not supported in the current software version.
·     End.M.
·     End.OP.
·     End.T.
SIDMGR
Static SIDs.
SRP
BSIDs dynamically allocated for SRv6 TE policies.
IS-IS
SRv6 SIDs allocated for IS-IS.
OSPFv3
SRv6 SIDs allocated for OSPFv3.
BGP
SRv6 SIDs allocated for BGP.
Total
Total number for a type of SRv6 SIDs.
Use display segment-routing ipv6 locator to display SRv6 locator information.
display segment-routing ipv6 locator [ locator-name ]
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a locator, this command displays information about all locators.
# Display information about all locators.
<Sysname> display segment-routing ipv6 locator
                      Locator configuration table
Locator name        : abc                                   Flag(A)       : 0
IPv6 prefix         : 100:1:2:3::                           Prefix length : 96
Static length       : 24                                    Args length   : 8
Common prefix length: 0
Algorithm           : 0
Auto SID start      : N/A
Auto SID end        : N/A
Static SID start    : 100:1:2:3::100
Static SID end      : 100:1:2:3::FFFF:FF00
Compressed Auto SID count      : 0
Compressed Static SID count    : 0
Non-compressed Auto SID count  : 0
Non-compressed Static SID count: 1
Table 19 Command output
Flag(A)
Anycast locator flag (A-bit). If A-bit is set, the locator is an anycast locator.
IPv6 prefix
IPv6 address prefix of the locator.
Prefix length
Prefix length of the locator.
Static length
Static length of the locator.
Args length
Argument length.
Common prefix length of the locator.
Algorithm
Algorithm ID:
·     0—SPF algorithm.
Auto SID start
Start dynamic SRv6 SID.
If no dynamic SRv6 SIDs exist, this field displays N/A.
Auto SID end
End dynamic SRv6 SID.
Static SID start
Start static SRv6 SID.
If no static SRv6 SIDs exist, this field displays N/A.
Static SID end
End static SRv6 SID.
Number of dynamic compressible SRv6 SIDs.
Number of static compressible SRv6 SIDs.
Number of dynamic non-compressible SRv6 SIDs.
Number of static non-compressible SRv6 SIDs.
Use display segment-routing ipv6 locator-statistics to display SRv6 locator configuration and statistics about allocated SRv6 SIDs in locators.
display segment-routing ipv6 locator-statistics [ locator-name ]
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a locator, this command displays SRv6 locator configuration and statistics about allocated SRv6 SIDs in all locators.
# Display SRv6 locator configuration and statistics about allocated SRv6 SIDs in all locators.
<Sysname> display segment-routing ipv6 locator-statistics
Total Locators: 1    Total SIDs: 1
Name       IPv6 prefix/Prefix length       CDyn/CStatic/Dyn/Static   Flag   Algo
abc        100:1::/64                      0   /0      /0  /1        0      0
Table 20 Command output
Total Locators
Total number of locators.
Total SIDs
Total number of SIDs that have been allocated in the locators.
Name
Locator name.
Locator prefix and prefix length.
Number of dynamic compressible SRv6 SIDs, number of static compressible SRv6 SIDs, number of dynamic non-compressible SRv6 SIDs, and number of static non-compressible SRv6 SIDs.
Flag
Algo
Algorithm ID:
·     0—SPF algorithm.
Use egress-engineering srv6 peer-set to create a BGP-EPE SRv6 peer set.
Use undo egress-engineering srv6 peer-set to delete a BGP-EPE SRv6 peer set.
egress-engineering srv6 peer-set peer-set-name [ static-sid { psp psp-sid | no-psp-usp no-psp-usp-sid } * ]
undo egress-engineering srv6 peer-set peer-set-name
No BGP-EPE SRv6 peer sets exist.
BGP instance view
peer-set-name: Specifies a name for the BGP-EPE SRv6 peer set, which is a case-sensitive string of 1 to 63 characters.
static-sid: Specifies a static SRv6 SID for the BGP-EPE SRv6 peer set. If you do not specify a static SRv6 SID, dynamic SRv6 SID allocation applies.
psp psp-sid: Specifies an End.X SID and enables PSP to remove the SRH on the penultimate segment.
no-psp-usp no-psp-usp-sid: Specifies an End.X SID and disables PSP and USP. The SRH is not removed on the penultimate segment or the ultimate segment.
BGP-EPE allocates BGP peer SIDs to inter-AS segments. The device advertises the peer SIDs to a network controller through BGP LS messages. The controller orchestrates the IGP SIDs and BGP peer SIDs to realize optimal inter-AS traffic forwarding.
If the device establishes BGP peer relationship with multiple devices, use this command to add the peer devices to a peer set and allocate a PeerSet SID to the peer set. When the device forwards traffic based on the PeerSet SID, it distributes the traffic among the peers for load sharing.
Before you use this command, apply a locator to BGP-EPE by using the segment-routing ipv6 egress-engineering locator command in BGP instance view.
·     If automatic SID allocation is used, the device dynamically allocates an SRv6 SID to the BGP-EPE SRv6 peer set from the specified locator.
·     If you specify a static SRv6 SID for the BGP-EPE SRv6 peer set, the specified static SRv6 SID must belong to the specified locator.
If you execute the egress-engineering srv6 peer-set command to specify multiple SRv6 SIDs for one peer set, the effective configuration depends on whether the SRv6 SIDs are the same type.
·     If all the SRv6 SIDs belong to the same type, only the most recent configuration takes effect.
·     If the SRv6 SIDs belong to different types, the configuration for all the SRv6 SID types takes effect. For the SRv6 SIDs that belong to the same type, only the most recent configuration takes effect. Make sure each SRv6 SID is unique among all the SRv6 SID types.
The static SRv6 SIDs configured by using the following commands cannot be the same in a BGP instance:
·     egress-engineering srv6 peer-set.
·     peer egress-engineering srv6.
# Create a BGP-EPE SRv6 peer set named epe and configure the peer set to use a dynamically allocated SRv6 SID.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering srv6 peer-set epe
peer peer-set
Use encapsulation source-address to specify a source address for the outer IPv6 header of SRv6 packets.
Use undo encapsulation source-address to restore the default.
encapsulation source-address ipv6-address [ ip-ttl ttl-value ]
No source address is specified for the outer IPv6 header of SRv6 packets.
SRv6 view
ipv6-address: Specifies a source IPv6 address. The IPv6 address cannot be a loopback address, link-local address, multicast address, or unspecified address.
ip-ttl ttl-value: Specifies the TTL of the outer IPv6 header, in the range of 1 to 255. The default value is 255.
As a best practice to ensure correct traffic forwarding in an SRv6 network, specify a source address for the outer IPv6 header of SRv6 packets.
You must specify an IPv6 address of the local device as the source IPv6 address, and make sure the IPv6 address has been advertised by a routing protocol. As a best practice, specify a loopback interface address of the local device as the source IPv6 address.
# Specify 1::1 as the source address of SRv6 packets in the outer IPv6 header and set the TTL of the outer IPv6 header to 200.
[Sysname-segment-routing-ipv6] encapsulation source-address 1::1 ip-ttl 200
Use fast-reroute microloop-avoidance enable to enable FRR microloop avoidance.
Use undo fast-reroute microloop-avoidance enable to disable FRR microloop avoidance.
fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
FRR microloop avoidance is disabled.
IS-IS IPv6 unicast address family view
level-1: Specifies FRR microloop avoidance for IS-IS Level-1.
level-2: Specifies FRR microloop avoidance for IS-IS Level-2.
Use this command only on the source node.
On an network configured with TI-LFA FRR, if a node or link fails, traffic will be switched to the backup path calculated by TI-LFA. If a device along the backup path has not finished route convergence, a traffic loop will occur. Traffic will be looped between the device and the source node (the node prior to the node or link that failed) until the device finishes route convergence.
To resolve this issue, configure this feature on a node enabled with TI-LFA FRR. FRR microloop avoidance first switches traffic to the backup path calculated by TI-LFA to avoid packet loss after a node or link failure on the optimal path. Then, that node starts an FRR microloop avoidance RIB-update-delay timer configured by the fast-reroute microloop-avoidance rib-update-delay command after it finishes route convergence. The node performs the following operations only after all nodes on the backup path finish route convergence and the timer times out:
·     Issues the forwarding path after route convergence to the FIB.
·     Switches traffic from the backup path calculated by TI-LFA to the forwarding path after route convergence.
If you configure both the segment-routing microloop-avoidance enable and fast-reroute and microloop-avoidance enable commands, FRR microloop avoidance takes precedence over SR microloop avoidance. The FRR microloop avoidance RIB-update-delay timer and SR microloop avoidance RIB-update-delay timer are started for the two features, respectively. The following situations exist depending on the configuration of the two timers:
·     If the FRR microloop avoidance RIB-update-delay timer is equal to or greater than the SR microloop avoidance RIB-update-delay timer, traffic is switched to the post-convergence path immediately when the former timer times out.
·     If the FRR microloop avoidance RIB-update-delay timer is larger than the SR microloop avoidance RIB-update-delay timer, traffic is switched to the post-convergence path until after the latter timer times out.
If you do not specify the level-1 or level-2 keyword, the command enables or disables FRR microloop avoidance on all IS-IS levels.
# Enable FRR microloop avoidance for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv6
[Sysname-isis-1-ipv6] fast-reroute microloop-avoidance enable
Use fast-reroute microloop-avoidance rib-update-delay to set the FRR microloop avoidance RIB-update-delay time.
Use undo fast-reroute microloop-avoidance rib-update-delay to restore the default.
fast-reroute microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance rib-update-delay [ level-1 | level-2 ]
The FRR microloop avoidance RIB-update-delay time is 5000 ms.
delay-time: Specifies the FRR microloop avoidance RIB-update-delay time in milliseconds. The value range is 1 to 60000.
level-1: Specifies the FRR microloop avoidance RIB-update-delay time for IS-IS Level-1.
level-2: Specifies the FRR microloop avoidance RIB-update-delay time for IS-IS Level-2.
If you do not specify the level-1 or level-2 keyword, the command sets the FRR microloop avoidance RIB-update-delay time for all IS-IS levels.
# Set the FRR microloop avoidance RIB-update-delay time to 6000 ms for Level-1 of IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] fast-reroute microloop-avoidance rib-update-delay 6000 level-1
fast-reroute ti-lfa
Use fast-reroute ti-lfa to enable Topology-Independent Loop-free Alternate Fast Re-Route (TI-LFA FRR).
Use undo fast-refroute ti-lfa to disable TI-LFA FRR.
In IS-IS IPv6 unicast address family view:
fast-reroute ti-lfa [ per-prefix ] [ route-policy route-policy-name | host ] [ level-1 | level-2 ]
undo fast-reroute ti-lfa [ level-1 | level-2 ]
In OSPFv3 process view:
TI-LFA FRR is disabled.
OSPFv3 process view
per-prefix: Calculates backup information for each advertising source of a route. Specify this keyword only if routes are advertised by multiple sources. If you do not specify this keyword, the device calculates backup information for each route.
route-policy route-policy-name: Enables TI-LFA FRR for prefixes identified by the routing policy. The route-policy-name argument specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
host: Enables TI-LFA for host routes.
level-1: Specifies TI-LFA FRR for IS-IS Level-1.
level-2: Specifies TI-LFA FRR for IS-IS Level-2.
TI-LFA FRR provides link and node protection for SR tunnels. When a link or node fails, TI-LFA FRR switches the traffic to the backup path to ensure continuous data forwarding.
Before configuring TI-LFA FRR on a level, you must execute the fast-reroute lfa command in IS-IS IPv6 unicast address family view or OSPFv3 process view to enable LFA FRR on that level. TI-LFA FRR takes effect only after you enable LFA FRR.
If you do not specify the route-policy route-policy-name option or the host keyword, the device calculates backup information for all routes.
If you do not specify the level-1 or level-2 keyword, the command applies to both IS-IS levels.
# Enable TI-LFA FRR for IS-IS process 1 and calculate backup information for all routes.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv4
[Sysname-isis-1-ipv4] fast-reroute ti-lfa
# Enable TI-LFA FRR for OSPFv3 process 1 and calculate backup information for all routes.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] fast-reroute ti-lfa
fast-reroute (IS-IS in Layer 3—IP Routing Command Reference)
fast-reroute (OSPFv3 in Layer 3—IP Routing Command Reference)
route-policy (Layer 3—IP Routing Command Reference)
Use flavor-mode switch no-psp to set the SRv6 SID flavor to NO-PSP.
Use undo flavor-mode switch no-psp to restore the default.
The SRv6 SID flavor is PSP.
SRv6 view
Use this command to set the flavor of SRv6 SIDs in a unified manner to reduce user workload. The following flavors are available for an SRv6 SID:
·     PSP—The penultimate SRv6 node removes the SRH to reduce the workload of the endpoint SRv6 node and improve the forwarding efficiency. The endpoint SRv6 node does not read the SRH, and it only looks up the local SID table for the destination IPv6 address of packets to forward the packets.
·     NO PSP—The penultimate SRv6 node does not remove the SRH. The endpoint SRv6 node reads the SRH and executes the function of the SID in the SRH.
For the flavor change to take effect, you must reboot the device.
You can use the flavor-mode switch no-psp or opcode command to change the SRv6 SID flavor. The flavor-mode switch no-psp command takes effect on all SIDs. The opcode command takes effect only on a specific SID. For an SID, the flavor-mode switch no-psp command takes precedence over the opcode command.
# Set the SRv6 SID flavor to NO-PSP.
[Sysname-segment-routing-ipv6] flavor-mode switch no-psp
opcode
Use isis ipv6 fast-reroute ti-lfa disable to prevent an IS-IS interface from participating in TI-LFA calculation.
Use undo isis ipv6 fast-reroute ti-lfa disable to allow an IS-IS interface to participate in TI-LFA calculation.
isis ipv6 fast-reroute ti-lfa disable [ level-1 | level-2 ]
undo isis ipv6 fast-reroute ti-lfa disable [ level-1 | level-2 ]
An IS-IS interface participates in TI-LFA calculation.
Interface view
level-1: Specifies TI-LFA calculation on IS-IS Level-1.
level-2: Specifies TI-LFA calculation on IS-IS Level-2.
Disable the output interface to the primary next hop from participating in TI-LFA calculation.
If you do not specify the level-1 or level-2 keyword, this command applies to both IS-IS levels.
# Prevent HundredGigE1/0/1 from participating in TI-LFA calculation.
[Sysname-HundredGigE1/0/1] isis ipv6 fast-reroute ti-lfa disable
fast-reroute ti-lfa
locator
Use locator to create an SRv6 locator and enter its view, or enter the view of an existing SRv6 locator.
Use undo locator to delete an SRv6 locator.
locator locator-name [ ipv6-prefix ipv6-address prefix-length [ args args-length | static static-length ] * ]
locator locator-name [ ipv6-prefix ipv6-address prefix-length common-prefix common-prefix-length coc32 [ args args-length | static static-length ] * ]
undo locator locator-name
No SRv6 locators exist.
SRv6 view
locator-name: Specifies a locator name, a case-sensitive string of 1 to 31 characters.
ipv6-prefix ipv6-address prefix-length: Specifies an IPv6 address prefix and the prefix length. The ipv6-address argument represents the IPv6 address prefix. The prefix-length argument represents the prefix length, in the range of 32 to 120.
args args-length: Specifies an argument length. The value range for the args-length argument depends on the value of the prefix-length argument and varies by device model. If you do not specify an argument length, the argument length is 0.
static static-length: Specifies the static length. The value range for the static-length argument varies by the value of the prefix-length argument and varies by device model. If you do not specify a static length, the static length is 0.
common-prefix common-prefix-length: Specifies the G-SID common prefix length. The value range for the common-prefix-length argument varies by the value of the prefix-length argument and varies by device model. If you do not specify a G-SID common prefix length, the common prefix length is 0.
coc32: Enables 32-bit G-SID compression.
An SRv6 locator can be one of the following types:
·     COC32 type—An SRv6 locator with the coc32 keyword specified.
·     Common type—An SRv6 locator without the coc32 keyword specified.
For more information about the SRv6 SID fields, see SRv6 configuration in Segment Routing Configuration Guide.
If SRv6 compression is enabled, use the locator command to configure the G-SID common prefix length and specify the G-SID compression mode. Only the 32-bit G-SID compression mode is supported in the current software version. In this mode, a standard 128-bit SRv6 SID is compressed to a 32-bit G-SID.
If a static opcode has been configured, a routing protocol preferentially uses the static opcode to construct SRv6 SIDs. If no static opcode exists, the routing protocol dynamically allocates SRv6 SIDs.
By applying a locator to IGP and BGP, you can use IGP and BGP to advertise the SRv6 SIDs on the locator.
When you create a locator, you must specify an IPv6 address prefix, prefix length, and static length for the locator. When you enter the view of an existing SRv6 locator, you do not need to specify the IPv6 address prefix, prefix length, or static length of the locator.
Each locator must have a unique name.
Do not specify the same IPv6 address prefix and prefix length for different locators. In addition, the IPv6 address prefixes of different locators cannot overlap.
You cannot delete a locator if that locator has dynamic SRv6 SIDs that are being used.
# Configure locator test1, setting the IPv6 address prefix to 100::, prefix length to 64, and static length to 32, and enter the SRv6 locator view of this locator.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] locator test1 ipv6-prefix 100:: 64 static 32
[Sysname-segment-routing-ipv6-locator-test1]
opcode
srv6 compress enable
local-sid forwarding statistics enable
Use local-sid forwarding statistics enable to enable traffic forwarding statistics collection for local SRv6 SIDs.
Use undo local-sid forwarding statistics enable to disable traffic forwarding statistics collection for local SRv6 SIDs.
Traffic forwarding statistics collection is disabled for local SRv6 SIDs.
SRv6 view
This command cannot take effect on traffic that is forwarded through End.B6.Encaps, End (COC32), End.X (COC32), End.DX2, End.DX2L, End.OP, and End.M SIDs.
# Enable traffic forwarding statistics collection for local SRv6 SIDs.
[Sysname-segment-routing-ipv6] local-sid forwarding statistics enable
reset segment-routing ipv6 local-sid forwarding statistics
Use local-sid forwarding statistics interval to set the interval at which traffic forwarding statistics are collected for local SRv6 SIDs.
Use undo local-sid forwarding statistics interval to restore the default.
local-sid forwarding statistics interval interval
Traffic forwarding statistics are collected at intervals of 30 seconds for local SRv6 SIDs.
SRv6 view
interval: Sets the interval at which traffic forwarding statistics are collected for local SRv6 SIDs. The value range is 5 to 65535, in seconds.
# Configure the device to collect traffic forwarding statistics for local SRv6 SIDs at intervals of 90 seconds.
[Sysname-segment-routing-ipv6] local-sid forwarding statistics interval 90
opcode
Use opcode to configure the opcode of SRv6 SIDs for a locator.
Use undo opcode to delete the opcode of SRv6 SIDs for a locator.
opcode { opcode | hex hex-opcode } end
opcode { opcode | hex hex-opcode } end-x interface interface-type interface-number nexthop nexthop-ipv6-address [ path-index index-value | weight weight-value ] *
opcode { opcode | hex hex-opcode } end-coc32
opcode { opcode | hex hex-opcode } end-x-coc32 interface interface-type interface-number nexthop nexthop-ipv6-address [ path-index index-value | weight weight-value ] *
opcode { opcode | hex hex-opcode } end-dt4 [ vpn-instance vpn-instance-name [ evpn | l3vpn-evpn ] ]
opcode { opcode | hex hex-opcode } end-dt46 [ vpn-instance vpn-instance-name [ evpn | l3vpn-evpn ] ]
opcode { opcode | hex hex-opcode } end-dt6 [ vpn-instance vpn-instance-name [ evpn | l3vpn-evpn ] ]
opcode { opcode | hex hex-opcode } end-dx4 interface interface-type interface-number nexthop nexthop-ipv4-address [ vpn-instance vpn-instance-name [ evpn ] ]
opcode { opcode | hex hex-opcode } end-dx6 interface interface-type interface-number nexthop np-ipv6-address [ vpn-instance vpn-instance-name [ evpn ] ]
opcode { opcode | hex hex-opcode } end-dx2 xconnect-group group-name connection connection-name
opcode { opcode | hex hex-opcode } end-dx2 vsi vsi-name interface interface-type interface-number service-instance instance-id
opcode { opcode | hex hex-opcode } end-dx2l xconnect-group group-name connection connection-name
opcode { opcode | hex hex-opcode } end-dx2l vsi vsi-name interface interface-type interface-number service-instance instance-id
opcode { opcode | hex hex-opcode } end-dt2m vsi vsi-name
opcode { opcode | hex hex-opcode } end-dt2u vsi vsi-name
opcode { opcode | hex hex-opcode } end-dt2ul vsi vsi-name
opcode { opcode | hex hex-opcode } end-m mirror-locator ipv6-address prefix-length
opcode { opcode | hex hex-opcode } end-op
undo opcode { opcode | hex hex-opcode } [ end-m mirror-locator ipv6-address prefix-length | { end-x | end-x-coc32 } interface interface-type interface-number nexthop nexthop-ipv6-address ]
No opcode exists.
SRv6 locator view
opcode: Specifies an opcode in the range of 1 to 2static-length-1, in which the static-length argument is configured by using the locator command.
end: Specifies the End type.
end-x: Specifies the End.X type.
end-coc32: Specifies the End (COC32) type.
end-x-coc32: Specifies the End.X (COC32) type.
end-dt4: Specifies the End.DT4 type.
end-dt46: Specifies the End.DT46 type.
end-dt6: Specifies the End.DT6 type.
end-dx4: Specifies the End.DX4 type.
end-dx6: Specifies the End.DX6 type.
end-dx2: Specifies the End.DX2 type.
end-dx2l: Specifies the End.DX2L type.
end-dt2m: Specifies the End.DT2M type.
end-dt2u: Specifies the End.DT2U type.
end-dt2ul: Specifies the End.DT2UL type.
end-m: Specifies the End.M type.
end-op: Specifies the End.OP type.
path-index index-value: Specifies the index of a path for an SRv6 SID, in the range of 0 to 65534. The default value is 0. Specify this option to distinguish paths when you specify different output interfaces and next hops for the same opcode.
weight weight-value: Specifies the load sharing weight value for the path, in the range of 1 to 254. The default value is 1.
interface interface-type interface-number: Specifies an output interface.
nexthop nexthop-ipv4-address: Specifies a next hop IPv4 address.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the SRv6 SIDs belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. The specified VPN instance must exist. If the SRv6 SIDs belong to the public network, do not specify this option.
evpn: Specifies EVPN routes. If you do not specify this keyword, the command specifies the SRv6 SIDs of VPNv4 or VPNv6 routes.
l3vpn-evpn: Specifies EVPN routes, VPNv4 routes, and VPNv6 routes.
xconnect-group group-name: Specifies the cross-connect group to which the SRv6 SIDs belong. The group-name argument represents the cross-connect group name, a case-sensitive string of 1 to 31 characters. The name cannot contain a hyphen (-). The specified cross-connect group must exist.
connection connection-name: Specifies the cross-connect to which the SRv6 SIDs belong. The connection-name argument represents the cross-connect name, a case-sensitive string of 1 to 20 characters. The name cannot contain a hyphen (-). The specified cross-connect must exist.
vsi vsi-name: Specifies the VSI to which the SRv6 SIDs belong. The vsi-name argument represents the VSI name, a case-sensitive string of 1 to 31 characters. The specified VSI must exist.
service-instance instance-id: Specifies an Ethernet service instance by its ID, in the range of 1 to 4096.
mirror-locator ipv6-address prefix-length: Specifies a protected locator by its IPv6 address prefix and prefix length. The ipv6-address argument represents the IPv6 address prefix. The prefix-length argument represents the prefix length, in the range of 32 to 120. Make sure the specified locator is the same as the locator on a protected node.
An SRv6 locator and its opcode and argument generate unique SRv6 SIDs. SRv6 SIDs form local SID forwarding table entries.
Use this command to configure the opcode of static SRv6 SIDs on a locator. The number of static SRv6 SIDs is determined by the static static-length option in the locator command.
You can execute the opcode command multiple times with the end-m keyword to specify multiple protected locators for the same opcode. Each protected locator represents one or multiple remote SRv6 SIDs that require protection. A protected locator can be specified only for one opcode. Different opcodes cannot have protected locators belonging to the same subnet.
To modify the opcode of static SRv6 SIDs on a locator, you must first delete the original opcode by using the undo opcode command.
To configure End (COC32) SRv6 SIDs or End.X (COC32) SRv6 SIDs, you must also perform the following tasks:
·     Enable SRv6 compression by using the srv6 compress enable command.
·     Configure the G-SID common prefix length by using the locator command.
When you configure End.X SIDs or End.X_COC32 SIDs, you can specify different output interfaces and next hops for the same opcode. When packets are forwarded as instructed by the End.X SIDs or End.X_COC32 SIDs, they are load shared among those output interfaces based on the specified weights. For example, assume you configure End.X SID a, End.X SID b, and End.X SID c and set their weights for them as x, y, z, respectively. Then, the proportion of the traffic forwarded through End.X SID a is x/(x+y+z).
When you configure End.X SIDs or End.X_COC32 SIDs, follow these restrictions and guidelines:
·     If you specify the same opcode and different output interfaces and next hops, you cannot configure the same path index for the SIDs.
·     If you specify the same opcode and the same output interface and next hop, you cannot change the path index by repeating this command. To change the path index for a opcode, use the undo opcode command to delete the opcode, and then execute the opcode command again to specify a new path index.
# Configure End SRv6 SIDs, and set the opcode to 64. Configure End.X SRv6 SIDs, set the opcode to 128, and configure HundredGigE 1/0/1 as the output interface and 2001::1 as the next hop IPv6 address.
[Sysname-segment-routing-ipv6] locator test ipv6-prefix 100:: 64 static 32
[Sysname-segment-routing-ipv6-locator-test] opcode 64 end
[Sysname-segment-routing-ipv6-locator-test] opcode 128 end-x interface hundredgige 1/0/1 nexthop 2001::1
locator
ospfv3 fast-reroute ti-lfa disable
Use ospfv3 fast-reroute ti-lfa disable to prevent an OSPFv3 interface from participating in TI-LFA calculation.
Use undo ospfv3 fast-reroute ti-lfa disable to allow an OSPFv3 interface to participate in TI-LFA calculation.
ospfv3 fast-reroute ti-lfa disable [ instance instance-id ]
undo ospfv3 fast-reroute ti-lfa disable [ instance instance-id ]
An OSPFv3 interface participates in TI-LFA calculation.
Interface view
instance instance-id: Specifies an instance by its ID, in the range of 0 to 255. The default value is 0.
[Sysname-HundredGigE1/0/1] ospfv3 1 area 0
[Sysname-HundredGigE1/0/1] ospfv3 fast-reroute ti-lfa disable
path-mtu
Use path-mtu to set the SRv6 path MTU.
Use undo path-mtu to restore the default.
path-mtu mtu-value
undo path-mtu
The SRv6 path MTU is 9000 bytes.
SRv6 view
mtu-value: Sets the path MTU, in bytes. The value range for this argument is 1280 to 9000.
This command specifies the maximum bytes that can be contained in an SRv6 tunneled packets.
The transit nodes do not fragment SRv6 tunneled packets. If a packet is larger than the MTU of the output interface, the packet will be discarded. If the MTU is too small, the bandwidth is not sufficiently used. To address these issues, use this command to set an appropriate SRv6 path MTU.
# Set the SRv6 path MTU to 2000 bytes.
[Sysname-segment-routing-ipv6] path-mtu 2000
path-mtu reserved
Use path-mtu reserved to specify a reserved MTU for SRv6 path MTU.
Use undo path-mtu reserved to restore the default.
path-mtu reserved [ reserved-value ]
No reserved MTU is specified for SRv6 path MTU.
SRv6 view
reserved-value: Specifies an MTU value, in bytes. The value range for this argument is 0 to 7720. The default value is 72 bytes.
Use this command in the TI-LFA scenario. When packets are switched to the backup path after the primary path fails, the device reconstrcts an IPv6 header and SRH for the packets. As a result, packet drop might occur because the packet size has exceeded the MTU. To resolve this issue, configure a reserved MTU on the source node to reserve bytes for adding a new SRH to SRv6 packets in case of primary path failure.
The SRv6 path MTU minus the reserved MTU is the active MTU. Make sure the active MTU is equal to or greater than 1280 bytes.
The effective MTU for SRv6 packets on the source node is the smaller value from the following values:
·     The active MTU.
·     The IPv6 MTU of the physical output interface.
For example, if the SRv6 path MTU is 1600 bytes and the reserved MTU is 100 bytes, the active MTU is 1500 bytes.
·     If the IPv6 MTU of the physical output interface is equal to or greater than the 1500 bytes, the effective MTU on the source node is 1500 bytes.
·     If the IPv6 MTU of the physical output interface is smaller than 1500 bytes, the effective MTU on the source node is the IPv6 MTU of the physical output interface.
# Reserve 200 bytes for SRv6 path MTU.
[Sysname-segment-routing-ipv6] path-mtu reserved 200
Use peer egress-engineering srv6 to enable SRv6 BGP-EPE.
Use undo peer egress-engineering srv6 to disable SRv6 BGP-EPE.
peer group-name egress-engineering srv6
undo peer group-name egress-engineering srv6
peer ipv6-address [ prefix-length ] egress-engineering srv6 [ locator locator-name | static-sid { psp psp-sid | no-psp-usp no-psp-usp-sid } * ]
undo peer ipv6-address [ prefix-length ] egress-engineering srv6 [ locator | static-sid { psp | no-psp-usp } * ]
SRv6 BGP-EPE is disabled.
BGP instance view
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The specified peer group must already exist.
ipv6-address: Specifies a peer by its IPv6 address. The specified peer must already exist.
prefix-length: Specifies the prefix length, in the range of 0 to 128. To specify dynamic peers within a subnet, you must specify both the ipv6-address and prefix-length arguments.
locator locator-name: Specifies a locator by its name. If you specify a locator, the device can dynamically allocate an End.X SID in the locator to the peer.
static-sid: Specifies a static SRv6 SID for the peer.
psp psp-sid: Specifies an End.X SID and enables PSP to remove the SRH on penultimate segment.
This command enables the device to allocate PeerNode SIDs and PeerAdj SIDs to peers.
If you do not specify any parameters, the device will dynamically allocate SRv6 SIDs to peers. The SRv6 SIDs belong to the locator specified by using the segment-routing ipv6 egress-engineering locator command in BGP instance view.
When you use the peer egress-engineering srv6 command for a peer, follow these restrictions and guidelines:
·     If you use this command to specify multiple locators for that peer, only the most recent configuration takes effect.
·     If you use this command to specify multiple static SRv6 SIDs and the SIDs belong to different types, all types of SRv6 SIDs can take effect. For the same type of SRv6 SIDs, only the most recent configuration takes effect.
If you specify a static SRv6 SID for a peer, the specified static SRv6 SID must belong to the locator specified by using the segment-routing ipv6 egress-engineering locator command in BGP instance view. To identify whether the static SRv6 SID takes effect, use the display bgp egress-engineering ipv6 command. If the static SRv6 SID does not take effect, the static SRv6 SID has been used by other protocols. Before the static SRv6 SID is released, BGP-EPE does not allocate a dynamic SRv6 SID. After the static SRv6 SID is released, first use the undo peer egress-engineering srv6 command to remove the original static SRv6 SID configuration. Then, use the peer egress-engineering srv6 command to reconfigure the static SRv6 SID.
The static SRv6 SIDs specified by using the following commands cannot be the same:
# Enable SRv6 BGP-EPE.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1::1 egress-engineering srv6
peer peer-set
Use peer peer-set to add a peer to a BGP-EPE SRv6 peer set.
Use undo peer peer-set to remove a peer from a BGP-EPE SRv6 peer set.
peer { ipv6-address [ prefix-length ] } peer-set srv6-peer-set-name
undo peer { ipv6-address [ prefix-length ] } peer-set
No peers are added to a BGP-EPE SRv6 peer set.
BGP instance view
ipv6-address: Specifies a peer by its IPv6 address. The peer must exist.
prefix-length: Specifies a prefix length in the range of 0 to 128. To specify a subnet, you must specify both the ipv6-address and prefix-length arguments.
peer-set-name: Specifies a BGP-EPE SRv6 peer set by its name, a case-sensitive string of 1 to 63 characters.
A PeerSet SID can be allocated to a BGP-EPE SRv6 peer set. When the device forwards traffic based on the PeerSet SID, it distributes the traffic among the peers in the peer set for load sharing.
Before adding a peer to a BGP-EPE SRv6 peer set, you must enable SRv6 BGP-EPE for that peer.
To change the BGP-EPE SRv6 peer set for a peer, you must first use undo peer peer-set command to remove that peer from the original BGP-EPE SRv6 peer set.
# Add peer 10::1 to the BGP-EPE SRv6 peer set named abc.
[Sysname] bgp 100
[Sysname-bgp-default] peer 10::1 peer-set abc
Use reset segment-routing ipv6 local-sid forwarding statistics to clear traffic forwarding statistics for all local SRv6 SIDs.
# Clear traffic forwarding statistics for all local SRv6 SIDs.
<Sysname> reset segment-routing ipv6 local-sid forwarding statistics
segment-routing ipv6 (system view)
Use segment-routing ipv6 to enable SRv6 and enter SRv6 view.
Use undo segment-routing ipv6 to disable SRv6.
SRv6 is disabled.
After you execute this command, you can configure locators in SRv6 view. Then, you can configure the opcode portion in SRv6 locator view to generate local SID forwarding table entries.
You cannot disable SRv6 when a locator in SRv6 view has dynamic SRv6 SIDs that are being used.
# Enable SRv6 and enter SRv6 view.
segment-routing ipv6 advertise l3-service-sid
Use segment-routing ipv6 advertise l3-service-sid to configure IS-IS to advertise SRv6 SIDs for L3 services.
Use undo segment-routing ipv6 advertise l3-service-sid to restore the default.
IS-IS does not advertise SRv6 SIDs for L3 services.
Use this command only when the cost style of IS-IS is wide, compatible, or wide-compatible.
This command is supported only by the IS-IS processes in the public network.
This command enables IS-IS to advertise SRv6 SIDs for L3 services in LSPs. With this command, IS-IS reports link state information for L3 service-related SRv6 SIDs to the controller to meet the requirements for applications that need the information. IS-IS can advertise only End.DT4 SIDs, End.DT6 SIDs, and End.DT46 SIDs in the current software version.
# Configure IS-IS to advertise SRv6 SIDs for L3 services.
[Sysname] isis 1
[Sysname-isis-1-ipv6] segment-routing ipv6 advertise l3-service-sid
cost-style (Layer 3—IP Routing Command Reference)
Use segment-routing ipv6 egress-engineering locator to apply a locator to BGP-EPE.
Use undo segment-routing ipv6 egress-engineering locator to restore the default.
segment-routing ipv6 egress-engineering locator locator-name
No locator is applied to BGP-EPE.
BGP instance view
Use this command to restrict the range of End.X SIDs that can be allocated to BGP-EPE SRv6 peer sets and BGP-EPE-enabled peers in a BGP instance. All static SRv6 SIDs configured for the BGP-EPE SRv6 peer sets and peers must belong to the locator specified by using this command.
To dynamically allocate End.X SIDs from the specified locator:
·     Do not configure a static SRv6 SID when you create a BGP-EPE SRv6 peer set by using the egress-engineering srv6 peer-set command.
·     Do not specify a locator or configure a static SRv6 SID when you enable SRv6 BGP-EPE for a peer by using the peer egress-engineering srv6 command.
When you execute this command to apply a locator to BGP-EPE, BGP-EPE takes the following actions:
·     If static SRv6 SIDs are configured in the locator, BGP-EPE preferentially uses static SRv6 SIDs.
·     If the static SRv6 SIDs configured in the locator are End.X SIDs with the same opcode and different output interfaces and next hops, BGP-EPE does not use the static SRv6 SIDs but dynamically collocates SRv6 SIDs.
·     If no static SRv6 SIDs are configured, BGP-EPE dynamically allocates SRv6 SIDs.
# Apply locator test to BGP-EPE.
[Sysname] bgp 100
[Sysname-bgp-default] segment-routing ipv6 egress-engineering locator test
segment-routing ipv6 end-x delete-delay
Use segment-routing ipv6 end-x delete-delay to enable dynamic End.X SID deletion delay and set the delay time.
Use undo segment-routing ipv6 end-x delete-delay to disable dynamic End.X SID deletion delay.
segment-routing ipv6 end-x delete-delay [ time-value ]
Dynamic End.X SID deletion delay is enabled. The delay time is 1800 seconds.
IS-IS IPv6 address family view
OSPFv3 process view
time-value: Sets the dynamic End.X SID deletion delay time in seconds, in the range of 1 to 3600. The default value is 1800.
Packet loss occurs between OSPFv3 or IS-IS neighbors if the neighbors frequently delete and request dynamically allocated End.X SIDs for the links between them because of neighbor flapping. To resolve this issue, set a delay timer for deleting dynamically allocated End.X SIDs when the neighbors are disconnected. If the neighbors are still disconnected when the delay timer expires, the device deletes the dynamically allocated End.X SIDs.
The device always immediately deletes automatically allocated End.X SIDs without any delay in the following situations:
·     The reset ospfv3 process command is executed.
·     The reset isis all command is executed.
·     Interfaces are deleted or removed. For example, an interface module is removed, or a subinterface or VLAN interface is deleted.
# Enable dynamic End.X SID deletion delay for IPv6 IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] segment-routing ipv6 end-x delete-delay
# Enable dynamic End.X SID deletion delay for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] segment-routing ipv6 end-x delete-delay
reset isis all (Layer 3—IP Routing Command Reference)
reset ospfv3 process (Layer 3—IP Routing Command Reference)
segment-routing ipv6 locator (IS-IS IPv6 address family view)
Use segment-routing ipv6 locator to apply an SRv6 locator to an IPv6 IS-IS process.
Use undo segment-routing ipv6 locator to remove the specified SRv6 locator from an IPv6 IS-IS process.
segment-routing ipv6 locator locator-name [ level-1 | level-2 ] [ auto-sid-disable ]
undo segment-routing ipv6 locator locator-name
No SRv6 locators are applied to an IPv6 IS-IS process.
level-1: Specifies the level-1 area.
level-2: Specifies the level-2 area.
auto-sid-disable: Disables automatic SRv6 SID allocation. If you do not specify this keyword, the device allows dynamically allocated SRv6 SIDs. If static SRv6 SIDs are configured when automatic SRv6 SID allocation is enabled, the static SRv6 SIDs take precedence. If no static SRv6 SIDs are configured when automatic SRv6 SID allocation is enabled, the system dynamically allocates SRv6 SIDs.
Use this command to enable IPv6 IS-IS to advertise SRv6 SIDs.
If you do not specify a level, this command applies the specified locator to both level-1 and level-2 areas.
Execute this command multiple times to apply multiple locators to an IPv6 IS-IS process so that the process can advertise multiple SRv6 SIDs.
# Apply locator abc to an IPv6 IS-IS process.
[Sysname] isis 1
[Sysname-isis-1] cost-style wide
[Sysname-isis-1-ipv6] segment-routing ipv6 locator abc
locator
segment-routing ipv6 locator (OSPFv3 process view)
Use segment-routing ipv6 locator to apply an SRv6 locator to an OSPFv3 process.
Use undo segment-routing ipv6 locator to remove the specified SRv6 locator from an OSPFv3 process.
segment-routing ipv6 locator locator-name [ auto-sid-disable ]
No SRv6 locators are applied to an OSPFv3 process.
OSPFv3 process view
Use this command to enable OSPFv3 to advertise SRv6 SIDs.
Execute this command multiple times to apply multiple locators to an OSPFv3 process so that the process can advertise multiple SRv6 SIDs.
# Apply locator abc to an OSPFv3 process.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] segment-routing ipv6 locator abc
locator
Use segment-routing microloop-avoidance enable to enable SR microloop avoidance.
Use undo segment-routing microloop-avoidance enable to disable SR microloop avoidance.
segment-routing microloop-avoidance enable [ level-1 | level-2 ]
undo segment-routing microloop-avoidance enable [ level-1 | level-2 ]
SR microloop avoidance is disabled.
OSPFv3 process view
level-1: Specifies IS-IS Level-1.
level-2: Specifies IS-IS Level-2.
After a network failure occurs or recovers, route convergence occurs on relevant network devices. Because of nonsimultaneous convergence on network devices, microloops might be formed. After you configure SR microloop avoidance, the devices will forward traffic along the specified path before route convergence is finished on all the relevant network devices. Because the forwarding path is independent of route convergence, microloops are avoided.
Microloop avoidance after a network failure and a failure recovery is as follows:
·     When a network failure occurs, a node enabled with this feature issues the calculated forwarding path to the FIB after route convergence and switches the traffic to the forwarding path after the delay timer times out. Before the timer times out, traffic is forwarded along the TI-LFA FRR backup path to avoid microloops.
·     When the failure recovers, a node enabled with this feature also calculates an explicit path that contains SIDs except for the primary forwarding path. Before the timer times out, traffic is forwarded along the backup path to avoid microloops.
If you configure both the segment-routing microloop-avoidance enable and fast-reroute microloop-avoidance enable commands, FRR microloop avoidance takes precedence over SR microloop avoidance. The FRR microloop avoidance RIB-update-delay timer and SR microloop avoidance RIB-update-delay timer are started for the two features, respectively. The following situations exist depending on the configuration of the two timers:
# Enable SR microloop avoidance for IPv6 IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] segment-routing microloop-avoidance enable
# Enable SR microloop avoidance for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] segment-routing microloop-avoidance enable
segment-routing microloop-avoidance rib-update-delay
Use segment-routing microloop-avoidance rib-update-delay to set the SR microloop avoidance RIB-update-delay time.
Use undo segment-routing microloop-avoidance rib-update-delay to restore the default.
segment-routing microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo segment-routing microloop-avoidance rib-update-delay [ level-1 | level-2 ]
The SR microloop avoidance RIB-update-delay time is 5000 milliseconds.
OSPFv3 process view
delay-time: Sets the delay time in milliseconds, in the range of 1 to 60000.
To ensure sufficient time for IGP to complete route convergence, set the SR microloop avoidance RIB-update-delay time. Before the timer expires, faulty relevant devices will forward traffic along the specified path. Upon expiration of the timer and completion of IGP route convergence, traffic will traverse along the IGP-calculated path.
# Set the SR microloop avoidance RIB-update-delay time to 6000 milliseconds for IPv6 IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] segment-routing microloop-avoidance rib-update-delay 6000
# Set the SR microloop avoidance RIB-update-delay time to 6000 milliseconds for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] segment-routing microloop-avoidance rib-update-delay 6000
srh-mode switch normal
Use srh-mode switch normal to set the SRH encapsulation mode to normal encapsulation.
Use undo srh-mode switch normal to restore the default.
The SRH encapsulation mode is reduced encapsulation.
SRv6 view
SRv6 forwarding supports the following SRH encapsulation modes:
·     Normal encapsulation mode—In this mode, the SRH includes all SIDs on the forwarding path. The device can obtain the complete path information from the SRH.
·     Reduced encapsulation mode—In this mode, the SRH includes all SIDs except the first SID on the forwarding path. The first SID is encapsulated in the IPv6 header as the destination IPv6 address to reduce the SRH length.
For this command to take effect, you must reboot the device.
# Set the SRH encapsulation mode to normal encapsulation.
[Sysname-segment-routing-ipv6] srh-mode switch normal
The configuration requires a reboot to take effect.
