| 01-SR-MPLS commands | 429.08 KB |
display bgp egress-engineering ipv4
display bgp egress-engineering peer-set
display bgp segment-routing label-range
display isis segment-routing adjacency
display isis segment-routing global-block
display isis segment-routing prefix-sid-map
display isis segment-routing routing-table
display mpls static-sr-mpls adjacency
display mpls static-sr-mpls ipv6 adjacency
display mpls static-sr-mpls lsp
display mpls static-sr-mpls prefix
display mpls static-sr-mpls ipv6 prefix
display mpls te segment-routing tunnel path
display mpls te tunnel lsp-event
display ospf segment-routing adjacency
display ospf segment-routing global-block
display ospf segment-routing prefix-sid-map
display ospf segment-routing routing-table
display segment-routing label-block
display segment-routing mapping-server prefix-sid-map
fast-reroute microloop-avoidance enable
fast-reroute microloop-avoidance rib-update-delay
isis fast-reroute ti-lfa disable
isis label-conflict-check enable
isis member-port adjacency-sid
mpls te path-selection adjacency-sid
ospf fast-reroute ti-lfa disable
segment-routing adjacency enable
segment-routing mapping-server advertise-local
segment-routing mapping-server receive
segment-routing member-port adjacency enable
segment-routing microloop-avoidance enable
segment-routing microloop-avoidance rib-update-delay
tunnel-bfd min-echo-receive-interval
tunnel-bfd min-receive-interval
tunnel-bfd min-transmit-interval
SR-MPLS commands
bfd detect-multiplier
Use bfd detect-multiplier to set the BFD detection time multiplier for SRLSPs.
Use undo bfd detect-multiplier to restore the default.
bfd detect-multiplier value
The BFD detection time multiplier is not set for SRLSPs. The BFD detection time multiplier set by the bfd multi-hop detect-multiplier command applies.
Segment Routing view
value: Specifies a detection time multiplier, which is the maximum number of consecutive BFD packets that can be discarded. The value range for this argument is 3 to 50.
The device sends BFD packets to a peer periodically. If the device does not receive BFD packets from the peer within the actual detection interval, it determines that the session is down. The actual detection interval of the sender is the detection time multiplier of the receiver × the actual sending interval of the receiver.
This command takes effect only on BFD sessions created by the bfd enable command.
# Set the BFD detection time multiplier to 3 for SRLSPs.
[Sysname] segment-routing
[Sysname-segment-routing] bfd detect-multiplier 3
bfd enable
bfd multi-hop detect-multiplier (High Availability Command Reference)
bfd enable
Use bfd enable to enable BFD for SRLSPs.
Use undo bfd enable to restore the default.
bfd enable [ prefix-list prefix-list-name ] [ echo | nil-fec ]
undo bfd enable
BFD for SRLSPs is not enabled.
Segment routing view
prefix-list prefix-list-name: Specifies an IPv4 prefix list by the prefix list name, a case-sensitive string of 1 to 63 characters. The device can create BFD sessions only for the SRLSPs permitted by the specified IPv4 prefix list. If you do not specify an IPv4 prefix list, the device can create BFD sessions for all SRLSPs.
echo: Specifies the BFD echo packet mode. If you do not specify this keyword, the BFD control packet mode is used to verify SRLSP connectivity.
nil-fec: Encapsulates the Nil FEC in MPLS echo request packets when BFD control packet mode is used to detect SRLSPs. In SR to LDP interworking mode, the ingress node (source node) cannot determine whether the LDP LSP is connected to the SRLSP. When the ingress node uses MPLS BFD to detect LSPs, it encapsulates LDP FEC in MPLS echo request packets, which will fail the FEC type verification on the egress node (end-point node). Then, the BFD session will go down. To resolve this issue, specify the nil-fec keyword to enable the ingress node to encapsulate the Nil FEC in MPLS echo request packets. The egress node will not check the FEC type of packets encapsulated with the Nil FEC.
This command enables the device to create a BFD session for each primary SRLSP to verify the connectivity of the primary SRLSP. When a primary SRLSP fails, BFD can quickly detect the failure and switches traffic to the backup SRLSP to reduce packet loss.
Before you execute this command, enable MPLS BFD by using the mpls bfd enable command.
If you execute both the bfd enable command and the mpls bfd command for SRLSPs, the mpls bfd command takes effect on the SRLSPs.
# Enable BFD for SRLSPs.
[Sysname-segment-routing] bfd enable
mpls bfd (for LSP) (MPLS Command Reference)
mpls bfd enable (MPLS Command Reference)
Use bfd min-echo-receive-interval to set the minimum interval for receiving BFD echo packets for SRLSP BFD.
Use undo bfd min-echo-receive-interval to restore the default.
The minimum interval for receiving BFD echo packets is not set for SRLSP BFD. The interval set by the bfd multi-hop min-echo-receive-interval command applies.
interval: Specifies the minimum interval for receiving BFD echo packets, in milliseconds. The value range for this argument is 3 to 10000.
The interval for receiving BFD echo packets is also the interval for sending BFD echo packets. By executing this command, you can control both the receiving interval and sending interval for BFD echo packets.
This command takes effect only on the echo mode BFD sessions created by the bfd enable command.
# Set the minimum BFD echo packet receiving interval for SRLSP BFD to 450 milliseconds.
[Sysname-segment-routing] bfd min-echo-receive-interval 450
bfd enable
bfd multi-hop min-echo-receive-interval (High Availability Command Reference)
Use bfd min-receive-interval to set the minimum BFD packet receiving interval for SRLSP BFD.
Use undo bfd min-receive-interval to restore the default.
The minimum interval for receiving BFD packets is not set for SRLSP BFD. The interval set by the bfd multi-hop min-receive-interval command applies.
interval: Specifies the minimum interval for receiving BFD packets, in milliseconds. The value range for this argument is 3 to 10000.
Use this command to prevent the packet sending rate of the peer end from exceeding the packet receiving rate of the local end. If the receiving rate is exceeded, the peer end dynamically adjusts the BFD packet transmitting interval to the minimum receiving interval of the local end.
# Set the minimum BFD packet receiving interval for SRLSP BFD to 550 milliseconds.
[Sysname-segment-routing] bfd min-receive-interval 550
bfd enable
bfd multi-hop min-receive-interval (High Availability Command Reference)
Use bfd min-transmit-interval to set the minimum BFD packet transmitting interval for SRLSP BFD.
Use undo bfd min-transmit-interval to restore the default.
The minimum interval for transmitting BFD packets is not set for SRLSP BFD. The interval set by the bfd multi-hop min-transmit-interval command applies.
interval: Specifies the minimum interval for transmitting BFD packets, in milliseconds. The value range is 3 to 10000.
Use this command to prevent the BFD packet sending rate from exceeding the packet receiving rate of the peer end.
The actual BFD packet transmitting interval on the local end is the greater value between the following values:
· Minimum interval for transmitting BFD packets on the local end.
· Minimum interval for receiving BFD packets on the peer end.
# Set the minimum BFD packet transmitting interval for SRLSP BFD to 450 milliseconds.
[Sysname-segment-routing] bfd min-transmit-interval 450
bfd enable
bfd multi-hop min-transmit-interval (High Availability Command Reference)
Use display bgp egress-engineering ipv4 to display BGP EPE information.
display bgp [ instance instance-name ] egress-engineering ipv4 [ ipv4-address ] [ verbose ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays information about the default BGP instance.
ipv4-address: Specifies the IPv4 address of an existing peer. If you do not specify this argument, the command displays information about all peers and peer groups.
verbose: Displays detailed BGP EPE information. If you do not specify this keyword, the command displays brief BGP EPE information.
# Display brief BGP EPE information.
<Sysname> display bgp egress-engineering ipv4
PeerSet : 192.168.1.2
Local AS number : 1
Remote AS number : 2
Local router ID : 1.1.1.3
Remote router ID : 1.1.1.4
OriginNextHop : 192.168.1.2
RelyNextHop : 192.168.1.2
Interface : HGE1/0/1
# Display brief BGP EPE information for a peer.
<Sysname> display bgp egress-engineering ipv4 192.168.1.5
BGP peering segment type: Node-Adjacency
PeerNodeAdj : 192.168.1.5
Local AS number : 1
Remote router ID : 1.1.1.5
OriginalNextHop : 192.168.1.5
RelayNextHop : 192.168.1.5
Interface : HGE1/0/5
# Display detailed BGP EPE information for a peer.
<Sysname> display bgp egress-engineering ipv4 1.1.1.1 verbose
BGP peering segment type : Node
PeerAdj Num : 2
PeerNode : 1.1.1.1
Local AS number : 1
Remote As number : 2
Local interface address : 2.2.2.2
Remote interface address : 1.1.1.1
OriginalNextHop : 1.1.1.1
RelayNextHop : 100.0.27.7
RelayNextHop : 100.0.28.7
Label : 15000
TunnelPolicy : abc
BGP peering segment type : Adjacency
PeerAdj : 100.0.27.7
Local AS number : 1
Local router ID : 1.1.1.1
Remote router ID : 2.2.2.2
OriginalNextHop : 100.0.27.7
Local interface address : 100.0.27.2
Remote interface address : 100.0.27.7
Interface : GE1/0/1
Label : 24001
TunnelPolicy : abc
PeerAdj : 100.0.28.7
Local AS number : 1
OriginalNextHop : 100.0.28.7
Local interface address : 100.0.28.2
Remote interface address : 100.0.28.7
Interface : GE1/0/2
Label : 24002
TunnelPolicy : abc
BGP peering segment type |
Type of the BGP peering segments to the specified peer: · Node. · Adjacency. · Set. · Node-Adjacency. |
PeerAdj Num |
Number of peering adjacencies. |
Interface on which the neighborship is established. |
OriginalNextHop |
Original next hop. |
RelayNextHop |
Recursive next hop. |
Use display bgp egress-engineering peer-set to display BGP EPE peer set information.
display bgp [ instance instance-name ] egress-engineering peer-set [ peer-set-name ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays BGP EPE peer set information for the default BGP instance.
peer-set-name: Specifies a BGP EPE peer set by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a peer set, this command displays information about all BGP EPE peer sets.
# Display information about all BGP EPE peer sets.
<Sysname> display bgp egress-engineering peer-set
BGP egress peering segment peer-set: a
PeerSet label : 2172
Members: 0
BGP egress peering segment peer-set: b
PeerSet label : 5555
Members: 1
BGP PeerNodeAdj : 3.3.3.3
BGP egress peering segment peer-set: c
PeerSet label: 65001
Label : 65001
Members: 2
BGP PeerNode: 1.1.1.1
BGP PeerAdj : 10.1.1.1
PeerSet name: d
PeerSet label: 65002
Members: 2
BGP PeerNode: 2.2.2.2
BGP PeerAdj : 11.1.1.1
BGP egress peering segment peer-set |
Name of a BGP EPE peer set. |
PeerSet label |
SID used by the BGP EPE peer set. |
Label |
SID assigned to the BGP EPE peer set. |
Members |
Number of peers in the BGP EPE peer set. |
BGP PeerNode |
Address of the node peer. |
BGP PeerAdj |
Address of the adjacency peer. |
BGP PeerNodeAdj |
Address of the node-adjacency peer. |
Use display bgp segment-routing label-range to display BGP SR label ranges.
display bgp [ instance instance-name ] segment-routing label-range
# Display BGP SR label ranges.
<Sysname> display bgp segment-routing label-range
BGP peering segment labels:
56000-250000
Prefix labels:
16000-55999
Use display isis segment-routing adjacency to display IS-IS SR adjacency SID information.
display isis [ process-id ] segment-routing adjacency [ { member-port | non-member-port } | sid sid-value | vpn-instance vpn-instance-name ] *
process-id: Specifies an IS-IS process ID in the range of 1 to 65535. If you do not specify this argument, the command displays SR adjacency SID information about all IS-IS processes.
member-port: Displays SR adjacency SID information on Layer 3 aggregation group member interfaces.
non-member-port: Displays SR adjacency SID information on Layer 3 Ethernet interfaces except aggregation group member interfaces.
sid sid-value: Specifies an adjacency SID value in the range of 15000 to 250000.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
If you do not specify the member-port or non-member-port keyword, this command displays SR adjacency SID information on all interfaces.
If you do not specify the sid sid-value option, this command displays information about all IS-IS SR adjacency SIDs.
If you do not specify the vpn-instance vpn-instance-name option, this command displays SR adjacency SID information on the public network.
# Display SR adjacency SID information about IS-IS process 1.
<Sysname> display isis 1 segment-routing adjacency
Adjacency SID: 15020 Type: Non-member-port Request result: Init
SystemID Interface NextHop State ProcessID
0000.0000.0000.00 HGE1/0/1 2.2.2.2 Inactive 1
Adjacency SID |
Adjacency SID value. |
Type |
Type of the adjacency SID assigned to the adjacency link: · Member-port—Adjacency SID assigned to a Layer 3 aggregation group member interface. · Non-member-port—Adjacency SID assigned to a Layer 3 Ethernet interface that is not an aggregation group member interface. |
Request result |
Adjacency SID application result: · Succeeded—The application succeeded. · Conflicting—The adjacency SID is already used. · Init—The application is in progress or the adjacency SID allocation feature is not enabled. · Out-of-range—The adjacency SID is not the in the range of the SRLB. |
SystemID |
System ID of the neighbor. |
Interface connected to the neighbor. |
Nexthop |
Next hop of the adjacency SID. |
State |
SID status: · Active—The SID is effective and is available for use. · Inactive—The SID is not effective and is not available for use. |
ProcessID |
IS-IS process ID. |
Use display isis segment-routing global-block to display IS-IS SRGB information.
display isis segment-routing global-block [ level-1 | level-2 ] [ process-id ]
level-1: Specifies Level-1 SRGB.
level-2: Specifies Level-2 SRGB.
process-id: Specifies an IS-IS process ID in the range of 1 to 65535. If you do not specify this argument, the command displays the SRGBs of all IS-IS processes.
If you do not specify the level-1 or level-2 keyword, the command displays information about both the Level-1 SRGB and Level-2 SRGB.
# Display information about the SRGBs for IS-IS process 1.
<Sysname> display isis segment-routing global-block 1
Segment routing global block information for IS-IS(1)
Level-1 SRGB
System ID Base Range
0000.0000.0011 16666 5557
0000.0000.0012 18012 4001
System ID |
Base |
Minimum label value of the SRGB. |
Range |
Number of labels in the SRGB. |
Use display isis segment-routing prefix-sid-map to display IS-IS SR prefix-SID mappings.
display isis segment-routing prefix-sid-map [ active-policy | backup-policy ] [ process-id ] [ verbose ]
active-policy: Displays active prefix-SID mappings.
backup-policy: Displays backup prefix-SID mappings.
process-id: Specifies an IS-IS process ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all IS-IS processes.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
If you do not specify the active-policy or backup-policy keyword, the command displays information about both active and backup prefix-SID mappings.
# Display active IS-IS SR prefix-SID mappings.
<Sysname> display isis segment-routing prefix-sid-map active-policy
ISIS 1 - Active policy
Number of mappings: 5
Prefix SID index Range Flags
2.2.2.2/32 10 10 -
3.3.3.3/32 300 1 -
8.8.8.8/32 600 20 -
11.11.11.11/32 100 10 -
12.12.12.1/32 44 3 -
# Display detailed information about active IS-IS SR prefix-SID mappings.
<Sysname> display isis segment-routing prefix-sid-map active-policy verbose
Number of mappings: 2
Prefix 1.1.1.1 32
Source : Local
Router ID : 1010.1020.1030
Level : Not set
SID index : 100
Range : 1
Last prefix : 1.1.1.1/32
Last SID index: 100
Flags : -
Prefix 2.2.2.2 32
Source : Remote
Router ID : 1010.1020.1040
Level : L1
SID index : 200
Range : 1
Last prefix : 2.2.2.2/32
Last SID index: 200
Flags : -
# Display backup IS-IS SR prefix-SID mappings.
<Sysname> display isis segment-routing prefix-sid-map backup-policy
ISIS 1 - Backup policy
Number of mappings: 4
2.2.2.2/32 200 30 -
8.8.8.8/32 600 20 -
2.2.2.2/32 10 10 -
# Display all IS-IS SR prefix-SID mappings.
ISIS 1 – Both active policy and backup policy
Number of mappings: 9
2.2.2.2/32 10 10 -
2.2.2.2/32 10 10 -
2.2.2.2/32 200 30 -
3.3.3.3/32 300 1 -
8.8.8.8/32 600 20 -
8.8.8.8/32 600 20 -
Table 5 Command output
SID index |
Start SID index value. |
Range |
Number of consecutive SIDs assigned. |
Flags |
Mapping flags. The A flag indicates that the peer specified by the prefix is directly connected to the device. If no flags are set, this field display a hyphen (-). |
Source |
Source of the prefix-SID mapping: · Local—The mapping is configured on the local device. · Remote—The mapping is configured on the remote device. |
Router ID |
ID of the route advertiser. |
Level |
Level of the route advertiser: · L1—Level-1 IS-IS route. · L2—Level-2 IS-IS route. · Not set—The route was locally advertised. |
Use display isis segment-routing routing-table to display IS-IS SR routing information.
display isis segment-routing routing-table [ vpn-instance vpn-instance-name ] [ ip ip-address { mask-length | mask } ] [ flex-algo flex-algo-id ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify an MPLS L3VPN instance, this command displays IS-IS SR routing information on the public network.
ip ip-address { mask-length | mask }: Specifies a destination IP address. The ip-address represents the network address in dotted decimal notation. The mask argument represents the network address mask. The mask-length argument represents the mask length in the range of 0 to 32. If you do not specify a destination address, this command displays IS-IS SR routing information for all destination addresses.
flex-algo flex-algo-id: Specifies a Flex-Algo by its ID, in the range of 128 to 255. If you do not specify a Flex-Algo, this command displays IS-IS SR routing information calculated by Flex-Algo 0 (SPF algorithm).
# Display IS-IS SR routing information for all destination addresses on the public network.
<Sysname> display isis segment-routing routing-table
Segment-routing routing-table information
Flags : D-Delete C-On change list
Outlabel flags : E-Explicit-Null I-Implicit-Null
N-Normal
Total number of routes: 1
Destination: 14.159.100.2/32
Flags: -/-
SourceCount: 1
ProcessID : 1 Active : True InLabel : 17234
Pref : 3 SubProtocolID: 1 Metric : 0
Route type : Learnt OutLabel cnt : 1
NextHop : 0.0.0.0 VrfIndex : 0 Interface : GE1/0/1
OutLabel : 17234 Selected : True OutLabel flag: E
LDPLabel : 2173
BkNextHop : 13.0.0.2 BkVrfIndex: 4 BkInterface : GE1/0/2
BkOutLabel: 16021 BkOutLabel flag: N
BkLDPLabel: 4294967295
Table 6 Command output
Flags |
Flags in the routing entry: · D—The routing entry has been deleted. · C—The routing entry has changed. · Hyphen (-)—The routing entry has no change. |
SourceCount |
Number of route advertisement sources. |
ProcessID |
IS-IS process ID. |
Active |
State of the route source: · True—The device is directly connected to the route source and has the outgoing label for the route source. · False—The device is not directly connected to the route source and does not have the outgoing label for the route source. |
InLabel |
Incoming label. |
Pref |
Route preference. |
SubProtocolID |
Routing subprotocol ID. |
Metric |
Metric of the route: |
Route type |
Type of the route: · Direct · Learnt · Redist (redistributed route) · Summary · Attached · Invalid |
OutLabel cnt |
Number of outgoing labels. |
NextHop |
Nexthop address. |
VrfIndex |
VRF index. |
Brief name of the outgoing interface. |
OutLabel |
Outgoing label. |
Selected |
Whether the outgoing label for the next hop has been selected: · True · False |
OutLabel flag |
Flag of the outgoing label: · E—Explicit null label. The upstream neighbor of the SID node must change the SID to the explicit null label before forwarding packets to the SID node. · I—Implicit null label. The upstream neighbor of the SID node must change the SID to the implicit null label before forwarding packets to the SID node. · N—Normal label. |
BkNextHop |
Backup next hop address. |
BkVrfIndex |
Backup VRF index |
BkInterface |
Brief outgoing interface name. |
BkOutLabel |
Backup outgoing label. |
BkOutLabel flag |
Flag of the backup outgoing label: · E—Explicit null label. The upstream neighbor of the SID node must change the SID to the explicit null label before forwarding packets to the SID node. · I—Implicit null label. The upstream neighbor of the SID node must change the SID to the implicit null label before forwarding packets to the SID node. · N—Normal label. |
BkLDPLabel |
Backup LDP label. |
Use display mpls static-sr-mpls adjacency to display IPv4 static adjacency segment information.
display mpls static-sr-mpls adjacency [ adjacency-path-name ]
adjacency-path-name: Specifies an adjacency segment by its name, a case-sensitive string of 1 to 67 characters. If you do not specify this argument, the command displays information about all IPv4 adjacency segments.
# Display information about static adjacency segments.
<Sysname> display mpls static-sr-mpls adjacency
Type : Adjacency
In-Label : 16
Out-Label : -
Out-Interface : HGE1/0/1
Nexthop : 10.1.1.2
State : Up
Table 7 Command output
Name |
Name of the adjacency segment. |
Type |
Information type. The value is fixed at Adjacency, which indicates adjacency segment information. |
In-Label |
Incoming label. |
Out-Label |
Outgoing label. |
Out-Interface |
Output interface. |
Nexthop |
Next hop address. |
State |
Status of the adjacency segment: · Down. · Up. |
Use display mpls static-sr-mpls ipv6 adjacency to display IPv6 static adjacency segment information.
display mpls static-sr-mpls ipv6 adjacency [ adjacency-path-name ]
adjacency-path-name: Specifies an adjacency segment by its name, a case-sensitive string of 1 to 67 characters. If you do not specify this argument, the command displays information about all IPv6 adjacency segments.
# Display information about all IPv6 static adjacency segments.
<Sysname> display mpls static-sr-mpls ipv6 adjacency
Type : Adjacency
In-Label : 16
Out-Label : -
Nexthop : 10::2
State : Up
Table 8 Command output
Name |
Type |
In-Label |
Incoming label. |
Out-Label |
Outgoing label. |
Out-Interface |
Output interface. |
Nexthop |
Next hop address. |
State |
Use display mpls static-sr-mpls lsp to display static SRLSP information.
display mpls static-sr-mpls lsp [ lsp-name ]
lsp-name: Specifies a static SRLSP by its name, a case-sensitive string of 1 to 67 characters. If you do not specify this argument, the command displays information about all static SRLSPs.
# Display information about static SRLSP lsp1.
<Sysname> display mpls static-sr-mpls lsp lsp1
Type : LSP
In-Label : -
Out-Label : 60,70,80
Out-Interface : -
Nexthop : -
State : Up
Table 9 Command output
Name |
Name of the static SRLSP. |
Type |
Information type. The value is fixed at LSP, which indicates static SRLSP information. |
In-Label |
Incoming label. |
Out-Label |
Outgoing label. |
Out-Interface |
Output interface. |
Nexthop |
Next hop address. |
State |
Status of the static SRLSP: · Down. · Up. |
static-sr-mpls lsp
Use display mpls static-sr-mpls prefix to display IPv4 static prefix segment information.
display mpls static-sr-mpls prefix [ path prefix-path-name | destination ipv4-address [ mask | mask-length ] ]
path prefix-path-name: Specifies a prefix segment by its name, a case-sensitive string of 1 to 67 characters.
destination ipv4-address: Specifies the destination IPv4 address of the prefix segment.
mask: Specifies the mask.
mask-length: Specifies the mask length, in the range of 0 to 32.
If you do not specify any parameters, this command displays information about all IPv4 static prefix segments.
# Display information about all static prefix segments.
<Sysname> display mpls static-sr-mpls prefix
Prefix Name : prefixname
Destination : 2.2.2.2/32
In-Label : 1024
Active : Yes(1)
Nexthop : 10.0.0.2
Out-Label : 600000
Status : up
Out-Interface : HGE1/0/2
Nexthop : 11.0.0.2
Out-Label : 600002
Status : down(No Route)
Out-Interface : HGE1/0/3
Nexthop : 12.0.0.2
Out-Label : 600001
Status : down(MPLS not enabled)
Table 10 Command output
Prefix Name |
Name of the prefix segment. |
Destination |
Destination IP address of the prefix segment. |
In-Label |
Incoming label of the prefix segment. |
Active |
Status of the prefix segment: · Yes(count)—The prefix segment is active. The value of count represents the number of egresses in up status. · No—The prefix segment is inactive. |
Out-Label |
Outgoing label of the prefix segment. |
Status |
Status of the egress: · down—The egress is inactive. The cause is displayed in brackets, which can be the following: ¡ No Route—The device has no route to reach the destination IP address over the output interface. ¡ MPLS not enabled—MPLS is disabled on the output interface. ¡ No main route—No main route exists. ¡ Static SRLSP not supported—The output interface is a tunnel interface that uses a static SRLSP. · up—The egress is active. · duplicate—An egress conflict has occurred because the output interface is already used by another prefix segment. |
Use display mpls static-sr-mpls ipv6 prefix to display IPv6 static prefix segment information.
display mpls static-sr-mpls ipv6 prefix [ path prefix-path-name | destination ipv6-address prefix-length ]
destination ipv6-address: Specifies the destination IPv6 address of the prefix segment.
prefix-length: Specifies the prefix length, in the range of 0 to 128.
If you do not specify any parameters, this command displays information about all IPv6 static prefix segments.
# Display information about all IPv6 static prefix segments.
<Sysname> display mpls static-sr-mpls ipv6 prefix
Destination : 2::2/128
In-Label : 1024
Active : Yes(1)
Nexthop : 10::2
Out-Label : 600000
Status : up
Nexthop : 11.0.0.2
Out-Label : 600002
Nexthop : 12::2
Out-Label : 600001
Status : down(No Mpls)
Table 11 Command output
Prefix Name |
Destination |
Destination IPv6 address of the prefix segment. |
In-Label |
Active |
Out-Label |
Status |
Status of the egress: · down—The egress is inactive. The cause is displayed in brackets, which can be No Route or No Mpls. No Route means that the device has no route to reach the destination IP address over the output interface. No Mpls means that MPLS is disabled on the output interface. · up—The egress is active. · duplicate—An egress conflict has occurred because the output interface is already used by another prefix segment. |
Use display mpls te segment-routing tunnel path to display path information of SR-signaled MPLS TE tunnels (SR-MPLS TE tunnels for short).
display mpls te segment-routing tunnel path [ tunnel number ]
tunnel number: Specifies a tunnel interface. The number argument represents the interface number of an existing tunnel interface on the device. If you do not specify a tunnel interface, this command displays path information for all SR-MPLS TE tunnels.
# Display path information for all SR-MPLS TE tunnels.
<Sysname> display mpls te segment-routing tunnel path
Tunnel name : Tunnel1
Main path info : 1.1.1.1/1/61103
Path state: Active
Forwarding information:
HGE1/0/1 20.0.0.2
HGE1/0/2 40.0.0.2
Hop information:
Hop 0 Prefix SID 16030 NAI 3.3.3.3
Hop 1 Adjacency SID 1151 NAI 21.0.0.1, 21.0.0.2
Hop 2 SID 1140 NAI -
Main Modify path info : 1.1.1.1/1/61105
Path state: Up
HGE1/0/1 10.0.0.2
HGE1/0/2 30.0.0.2 (Backup)
Hop information:
Backup path info : 1.1.1.1/1/61104
Path state: Up
NID : 268435458
Hop information:
Hop 1 Adjacency SID 18040 NAI 4.4.4.4, 21.0.0.2
Backup Modify path info : 1.1.1.1/1/61105
HGE1/0/1 10.0.0.2
Hop information:
Table 12 Command output
Tunnel Name |
Name of the tunnel interface. |
Main Path Info |
Primary path information. The value is Ingress LSR ID/Tunnel ID/LSP ID. |
Main Modify Path Info |
Information about the primary path established by using the make-before-break mechanism. |
Backup Path Info |
Backup path information. |
Backup Modify Path Info |
Information about the backup path established by using the make-before-break mechanism. |
Path state |
Path state: · Active—The SRLSP is successfully established and being used for traffic forwarding. · Up—The SRLSP is successfully established. · Down—The SRLSP is not established or the establishment fails. |
Forwarding information |
Forwarding information, which includes the following: · Outgoing interface and next hop. (Backup) represents the outgoing interface and next hop of the backup path. · NID (NHLFE entry index). |
Hop information |
Information about the hops of the path. |
Hop |
Hop index. |
Binding SID |
Binding SID value. |
Prefix SID |
Prefix SID value. |
Adjacency SID |
SID |
SID of an unknown type. |
NAI |
Node or Adjacency Identifier. For a binding SID, the NAI is displayed as a hyphen (-). For a prefix SID, the NAI is the node identifier, which is the IP address of the node. For an adjacency SID, the NAI is the adjacency identifier, which displays the local and remote IP addresses of the link. If the NAI is not available or is unknown, this field displays a hyphen (-). |
Use display mpls te tunnel lsp-event to display SRLSP event information for MPLS TE tunnels.
display mpls te tunnel lsp-event { down | switch } [ tunnel number ]
down: Specifies the most recent five SRLSP down events.
switch: Specifies the most recent five SRLSP path switching events.
tunnel number: Specifies an existing MPLS TE tunnel by the tunnel interface number. If you do not specify an MPLS TE tunnel, this command displays information about SRLSP events for all MPLS TE tunnels.
# Display information about the most recent five SRLSP down events for all MPLS TE tunnels.
<Sysname> display mpls te tunnel lsp-event down
Tunnel ID : 1
Down Event Number : 1
LSP ID: 100 LSP Type: Backup
Tunnel Signaling : Segment Routing
Down Time : 2020-3-14 14:30:29.734
Down Info : No out segment
Status After Down : Tunnel went down
Down Event Number : 2
LSP ID: 100 LSP Type: Main
Down Time : 2020-3-14 14:30:28.621
Down Info : Configuration changed
Detailed Info : mpls te bandwidth
Table 13 Command output
Down Event Number: number |
Reverse ordinal number of the SRLSP down event. Events are displayed from the most recent to the oldest. The most recent event is displayed as number 1. |
LSP ID |
LSP ID |
LSP Type |
LSP type: · Main—Primary LSP. · Backup—Backup LSP. |
Tunnel Signaling |
Tunnel signaling protocol. The value is Segment Routing. |
Down Time |
Time when the SRLSP went down. |
Down Info |
Reason why the SRLSP went down: · No out segment. · IGP calculated path failed. · SRLG check failed. · Configuration changed. · PCE state recover. |
Detailed Info |
More detailed information about the down event. This field is displayed only when the Down Info value is Configuration changed to provide the key configuration commands that caused the SRLSP down event. |
Status After Down |
Tunnel status after the SRLSP went down: · Tunnel went down. · Main LSP MBB succeeded. · Main LSP failed, switched to backup LSP. · Backup LSP failed, hot-standby disabled. · Backup LSP MBB succeeded. · Backup LSP is same as main LSP. |
# Display information about the most recent five SRLSP path switching events for all MPLS TE tunnels.
<Sysname> display mpls te tunnel lsp-event switch
Tunnel ID : 1
Tunnel Signaling : Static
Switch Event Number : 1
Switch Type : Backup LSP inused
Switch Reason : Main LSP down
Switch Time : 2021-8-14 14:30:29.734
Path Detail :
Old path : 16010 - 2371 - 17030
New path : 16010 - 18020
Table 14 Command output
Tunnel Signaling |
Tunnel signaling protocol. The value is Static or Segment Routing. |
Switch Event Number: number |
Reverse ordinal number of the SRLSP path switching event. Events are displayed from the most recent to the oldest. The most recent event is displayed as number 1. |
Switch Type |
Path switching type: · Backup LSP inused—Traffic has been switched to the backup path because the primary path failed. · Main LSP recovered—Traffic has been switched back to the primary path because the primary path recovered. · Main LSP make-before-break—The primary path underwent MBB because of configuration change or other reasons. |
Switch Reason |
Reason why a path switching occurs: · Main LSP down. · Main LSP up. · Main LSP BFD down. · Main LSP BFD up. · Configuration changed. |
Switch Time |
Time when the SRLSP switched its path. |
Path Detail |
Detailed information of the path. |
Old path |
Path before switching, which is displayed as a stack of labels from top to bottom. |
New path |
Path after switching, which is displayed as a stack of labels from top to bottom. |
Use display ospf segment-routing adjacency to display OSPF SR adjacency SID information.
display ospf [ process-id ] segment-routing adjacency [ sid sid-value ] [ vpn-instance vpn-instance-name ]
process-id: Specifies an OSPF process ID in the range of 1 to 65535. If you do not specify this argument, the command displays SR adjacency SID information about all OSPF processes.
sid sid-value: Specifies an adjacency SID value in the range of 15000 to 250000. If you do not specify an adjacency SID, this command displays information about all OSPF SR adjacency SIDs.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify an MPLS L3VPN instance, this command displays SR adjacency SID information on the public network.
# Display SR adjacency SID information about OSPF process 1.
<Sysname> display ospf 1 segment-routing adjacency
Adjacency SID: 15040 Type: Non-member-port Request result: Init
NbrID Interface NextHop State ProcessID
2.2.2.2 HGE1/0/1 10.1.1.1 Inactive 1
Table 15 Command output
Adjacency SID |
Type |
Type of the adjacency SID assigned to the adjacency link: · Non-member-port—Adjacency SID assigned to a Layer 3 Ethernet interface that is not an aggregation group member interface. · Member-port—Adjacency SID assigned to a Layer 3 aggregation group member interface. (Not supported.) |
Request result |
NbrID |
NextHop |
State |
ProcessID |
OSPF process ID. |
Use display ospf segment-routing global-block to display OSPF SRGB information.
display ospf [ process-id ] [ area area-id ] segment-routing global-block
process-id: Specifies an OSPF process ID in the range of 1 to 65535. If you do not specify this argument, the command displays the SRGBs of all OSPF processes.
area area-id: Specifies an area by its ID. The area ID can be a value in dotted decimal notation or a decimal value in the range of 0 to 4294967295. If you specify a decimal value, the system automatically transforms it to a value in dotted decimal notation. If you do not specify this option, the command displays the SRGBs of all areas.
# Display the SRGBs of all OSPF processes.
<Sysname> display ospf segment-routing global-block
Segment Routing Global Block
Area: 0.0.0.0
Router ID Min SID Max SID Total
1.1.1.1 16000 24000 8001
2.2.2.2 18000 18999 1000
3.3.3.3 16000 24000 8001
4.4.4.4 17000 17999 1000
5.5.5.5 16000 16999 1000
Table 16 Command output
Router ID |
Router ID of the device or the neighbor. |
Min SID |
Max SID |
Maximum label value of the SRGB. |
Total |
Use display ospf segment-routing prefix-sid-map to display OSPF SR prefix-SID mappings.
display ospf segment-routing prefix-sid-map [ active-policy | backup-policy ] [ process-id ] [ verbose ]
process-id: Specifies an OSPF process ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all OSPF processes.
# Display active OSPF SR prefix-SID mappings.
<Sysname> display ospf segment-routing prefix-sid-map active-policy
OSPF 1 - Active policy
Flags: IA - Inter-Area, L – Local, R - Remote
1.1.1.11/32 10 10 L/-
1.1.1.22/32 20 20 R/-
# Display detailed information about active OSPF SR prefix-SID mappings.
<Sysname> display ospf segment-routing prefix-sid-map active-policy verbose
Prefix 1.1.1.11
Source : Local
Router ID : 10.1.1.1
Area ID : Not set
LS ID : Not set
SID index : 10
Range : 10
Last prefix : 1.1.1.20
Last SID index: 19
Flags : -
Prefix 1.1.1.22
Source : Remote
Router ID : 10.2.1.1
Area ID : 0.0.0.1
LS ID : 7.0.0.0
SID index : 20
Range : 20
Last prefix : 1.1.1.41
Last SID index: 39
Flags : -
# Display backup OSPF SR prefix-SID mappings.
<Sysname> display ospf segment-routing prefix-sid-map backup-policy
OSPF 1 - Backup policy
Number of mappings: 1
1.1.1.33/32 30 30 R/IA
# Display all OSPF SR prefix-SID mappings.
OSPF 1 - Both active policy and backup policy
Number of mappings: 3
Table 17 Command output
SID index |
Range |
Flags |
Mapping flags: · IA—The prefix was from another area. · L—The mapping is a local mapping. · R—The mapping is a remote mapping. If no flags are set, this field display a hyphen (-). |
Source |
Router ID |
Area ID |
Area ID. If the mapping is a local mapping, this field displays Not set. |
LS ID |
Link state ID. If the mapping is a local mapping, this field displays Not set. |
Use display ospf segment-routing routing-table to display OSPF SR routing information.
display ospf segment-routing routing-table [ vpn-instance vpn-instance-name ] [ ip ip-address { mask-length | mask } ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify an MPLS L3VPN instance, this command displays OSPF SR routing information on the public network.
ip ip-address { mask-length | mask }: Specifies a destination IP address. The ip-address represents the network address in dotted decimal notation. The mask argument represents the network address mask. The mask-length argument represents the mask length in the range of 0 to 32. If you do not specify a destination address, this command displays OSPF SR routing information for all destination addresses.
# Display OSPF SR routing information for all destination addresses on the public network.
<Sysname> display ospf segment-routing routing-table
N-Normal P-SR label prefer
Destination: 1.1.1.1/32
Flags: -/-/-
SrouceCount: 1
ProcessID : 1 Active : True InLabel : 18555
Pref : 10 SubProtocolID: 1 Metric : 1
Route type : Stub OutLabel cnt : 1
NextHop : 12.0.0.2 VrfIndex : 1 Interface : GE1/0/1
OutLabel : 17555 Selected : True OutLabel flag : I
LDPLabel : 4294967295
BkNextHop : 13.0.0.2 BkVrfIndex : 4 BkInterface : GE1/0/2
Table 18 Command output
Flags |
SourceCount |
ProcessID |
OSPF process ID. |
Active |
InLabel |
Incoming label. |
Pref |
Route preference. |
SubProtocolID |
Metric |
Route type |
Type of the route: · Transit · Stub · Inter · Type1 · Type2 |
OutLabel cnt |
NextHop |
Nexthop address. |
VrfIndex |
VRF index. |
OutLabel |
Outgoing label. |
Selected |
OutLabel flag |
Flag of the outgoing label: · E—Explicit null label. The upstream neighbor of the SID node must change the SID to the explicit null label before forwarding packets to the SID node. · I—Implicit null label. The upstream neighbor of the SID node must change the SID to the implicit null label before forwarding packets to the SID node. · N—Normal label. · P—SR label preferred. |
LDPLabel |
LDP label. |
BkNextHop |
BkVrfIndex |
Backup VRF index |
BkInterface |
BkOutLabel |
BkOutLabel flag |
Flag of the backup outgoing label: · E—Explicit null label. The upstream neighbor of the SID node must change the SID to the explicit null label before forwarding packets to the SID node. · I—Implicit null label. The upstream neighbor of the SID node must change the SID to the implicit null label before forwarding packets to the SID node. · N—Normal label. · P—SR label preferred. |
BkLDPLabel |
Backup LDP outgoing label. |
Use display segment-routing label-block to display SR label block information.
display segment-routing label–block [ protocol { isis | ospf } ]
protocol: Specifies a protocol. If you do not specify this keyword, the command displays SR label block information about all protocols.
isis: Displays IS-IS SR label block information.
ospf: Displays OSPF SR label block information.
# Display SR label block information about all protocols.
<Sysname> display segment-routing label-block
Default label block:
SRLB: 15000-15999
SRGB: 16000-55999
Configurate label block:
SRLB: 200000-210000
SRGB: 16000-17000
Type Protocol Process-ID Label range State
SRLB Global - 200000-210000 Active
SRGB Global - 16000-17000 Active
Table 19 Command output
Type |
Label block type, SRGB or SRLB. |
Protocol to which the label block belongs: · ISIS—A IS-IS process. · OSPF—An OSPF process. · Global—The label block is the global SRGB or SRLB, which is configured in segment routing view.. |
Process-ID |
ID of the protocol process that owns the label block. If label block is the global SRGB or SRLB, this field displays a hyphen (-). |
State |
Whether the label block is available for use: · Active—The label block is available for use. · Inactive—The label block is not available for use. |
Use display segment-routing mapping-server prefix-sid-map to display prefix-SID mappings.
display segment-routing mapping-server prefix-sid-map [ ip-address mask-length | verbose ]
ip-address: Specifies an IPv4 address prefix in dotted decimal notation.
mask-length: Specifies the mask length, in the range of 1 to 32.
verbose: Displays detailed information about all configured prefix-SID mappings.
If you do not specify any parameters, this command displays brief information about all configured prefix-SID mappings.
# Display the prefix-SID mapping for prefix 1.1.1.1.
<Sysname> display segment-routing mapping-server prefix-sid-map 1.1.1.1 32
SRMS mappings
Prefix SID index Flags
1.1.1.1/32 10 A
# Display all configured prefix-SID mappings.
SRMS mappings
1.1.1.1/32 10 100 A
2.2.2.2/32 256 520 -
# Display detailed information about all configured prefix-SID mappings.
<Sysname> display segment-routing mapping-server prefix-sid-map verbose
SRMS mappings
Prefix 1.1.1.1/32
SID index : 10
Range : 100
Last prefix : 1.1.1.100/24
Last SID index: 109
Flags : A
Prefix 2.2.2.2/32
SID index : 256
Range : 520
Last prefix : 2.2.4.9/24
Last SID index: 775
Flags : -
Table 20 Command output
SID index |
Range |
Flags |
Last Prefix |
Final prefix. |
Last SID index |
SID assigned to the final prefix. |
Use egress-engineering peer-set to create a BGP EPE peer set.
Use undo egress-engineering peer-set to delete a BGP EPE peer set.
egress-engineering peer-set peer-set-name [ label label-value ] [ link-down relate-bfd-state ]
undo egress-engineering peer-set peer-set-name
No BGP EPE peer sets exist.
BGP instance view
peer-set-name: Specifies a BGP EPE peer set name, a case-sensitive string of 1 to 63 characters.
label label-value: Specifies a SID for the BGP EPE peer set. The value range for the label-value argument is 16 to 250000. If you do not specify a SID, this command dynamically assigns a SID for the BGP EPE peer set.
link-down relate-bfd-state: Enables BGP-EPE to collaborate with SBFD when a link between ASs fails. The node configured with BGP-EPE will send an SBFD response packet to the source node of an SR-MPLS TE policy. After receiving the SBFD response packet, the source node sets the SBFD session detecting the backup path to down and triggers traffic switchover. If you do not specify this parameter, BGP-EPE will not collaborate with SBFD when a link between ASs fails. This parameter must work together with the sr-policy sbfd enable command in SR-TE view or the sbfd command in SR-MPLS TE policy view.
BGP EPE assigns BGP peering SIDs to segments across ASs. The device sends BGP peering SIDs to the controller through BGP-LS extensions. The controller orchestrates IGP SIDs and BGP peering SIDs for inter-AS forwarding over optimal paths.
You can add multiple BGP peers into a BGP EPE peer set and assign a Peer-Set-SID to the set. A Peer-Set-SID corresponds to multiple outgoing interfaces.
# Create a BGP EPE peer set named bgpepe, and assign SID 5555 to the set.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering peer-set bgpepe label 5555
peer egress-engineering
peer peer-set
sbfd
Use fast-reroute microloop-avoidance enable to enable FRR microloop avoidance.
Use undo fast-reroute microloop-avoidance enable to disable FRR microloop avoidance.
In IS-IS IPv4 unicast address family view:
fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
In OSPF view:
FRR microloop avoidance is disabled.
OSPF view
level-1: Specifies FRR microloop avoidance for IS-IS Level-1.
level-2: Specifies FRR microloop avoidance for IS-IS Level-2.
Use this command only on the source node.
On an network configured with TI-LFA FRR, if a node or link fails, traffic will be switched to the backup path calculated by TI-LFA. However, if a device along the backup path has not finished route convergence, traffic might be looped between the device and the source node. (The source node refers to the node prior to the node or link that failed.) The loop will exist until the device finishes route convergence.
To resolve this problem, configure microloop avoidance on the source node enabled with TI-LFA FRR. Then, when a node or link on the optimal path fails, traffic will be switched to the backup path calculated by TI-LFA. The source node starts a delay timer for other devices to finish route convergence. After the delay timer expires, the source node installs the converged path to the FIB and switches traffic from the TI-LFA-calculated backup path to the converged path.
If you configure both FRR microloop avoidance and SR microloop avoidance, both timers are started and FRR microloop avoidance takes effect.
· The value of the delay timer of FRR microloop avoidance is greater than or equal to the value of the delay timer of SR microloop avoidance, the device switches to the converged path immediately after the delay timer of the latter expires.
· The value of the delay timer of FRR microloop avoidance is smaller than or equal to the value of the delay timer of SR microloop avoidance, the device switches to the converged path after the delay timer of the former expires.
If you do not specify the level-1 or level-2 keyword, the command enables or disables FRR microloop avoidance on all IS-IS levels.
# Enable FRR microloop avoidance for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv4
[Sysname-isis-1-ipv4] fast-reroute microloop-avoidance enable
# Enable FRR microloop avoidance for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute microloop-avoidance enable
Use fast-reroute microloop-avoidance rib-update-delay to set the FRR microloop avoidance RIB-update-delay time.
Use undo fast-reroute microloop-avoidance rib-update-delay to restore the default.
fast-reroute microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance rib-update-delay [ level-1 | level-2 ]
In OSPF view:
The FRR microloop avoidance RIB-update-delay time is 5000 ms.
OSPF view
delay-time: Specifies the FRR microloop avoidance RIB-update-delay time in milliseconds. The value range is 1 to 60000.
level-1: Specifies the FRR microloop avoidance RIB-update-delay time for IS-IS Level-1.
level-2: Specifies the FRR microloop avoidance RIB-update-delay time for IS-IS Level-2.
If you do not specify the level-1 or level-2 keyword, the command sets the FRR microloop avoidance RIB-update-delay time for all IS-IS levels.
# Set the FRR microloop avoidance RIB-update-delay time to 6000 ms for Level-1 of IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] fast-reroute microloop-avoidance rib-update-delay 6000 level-1
# Set the FRR microloop avoidance RIB-update-delay time to 6000 ms for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute microloop-avoidance rib-update-delay 6000
fast-reroute ti-lfa
Use fast-reroute ti-lfa to enable Topology-Independent Loop-Free Alternate Fast Re-Route (TI-LFA FRR).
Use fast-reroute ti-lfa to disable TI-LFA FRR.
fast-reroute ti-lfa [ per-prefix ] [ route-policy route-policy-name | host ] [ level-1 | level-2 ]
undo fast-reroute ti-lfa [ level-1 | level-2 ]
In OSPF view:
TI-LFA FRR is disabled.
OSPF view
level-1: Specifies TI-LFA FRR for IS-IS Level-1.
level-2: Specifies TI-LFA FRR for IS-IS Level-2.
per-prefix: Calculates backup information for each advertising source of a route. Specify this keyword only if routes are advertised by multiple sources. If you do not specify this keyword, the device calculates backup information for each route.
route-policy route-policy-name: Enables TI-LFA FRR for prefixes identified by the routing policy. The route-policy-name argument specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
host: Enables TI-LFA for host routes.
TI-LFA FRR provides link and node protection for SR tunnels. When a link or node fails, TI-LFA FRR switches the traffic to the backup path to ensure continuous data forwarding.
Before configuring TI-LFA FRR, you must execute the following commands in IS-IS IPv4 unicast address family view or OSPF view:
· segment-routing mpls
· fast-reroute lfa
TI-LFA FRR takes effect only after you enable LFA FRR.
TI-LFA FRR operates in a level only after you enable LFA FRR for the level.
If you do not specify the level-1 or level-2 keyword, the command enables or disables TI-LFA FRR for all IS-IS levels.
If you do not specify the route-policy route-policy-name option or the host keyword, the device calculates backup information for all routes.
# Enable TI-LFA FRR for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] fast-reroute ti-lfa
# Enable TI-LFA FRR for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute ti-lfa
fast-reroute (Layer 3—IP Routing Command Reference)
route-policy (Layer 3—IP Routing Command Reference)
global-block
Use global-block to configure the global MPLS SRGB.
Use undo global-block to restore the default.
global-block { minimum-value maximum-value | name name }
undo global-block
The label range for the global MPLS SRGB is 16000 to 55999. The lables in this range cannot be assigned to other protocols or SRLBs.
minimum-value: Specifies the minimum label value. The value is 16000.
maximum-value: Specifies the maximum label value. The value is 55999.
name name: Specifies an MPLS label block by its name, a case-sensitive string of 1 to 127 characters. The specified MPLS label block must already exist. An MPLS label block is configured by using the mpls label-block command. For more information, see basic MPLS commands in MPLS Command Reference.
The global MPLS SRGB is used for static prefix segments and BGP prefix SIDs. If no MPLS SRGB is configured for a protocol process, the process uses the global MPLS SRGB.
If you have configured prefix SIDs when you configure the global MPLS SRGB, the global MPLS SRGB must contain the configured prefix SIDs.
# Configure the global MPLS SRGB to be from 200000 to 220000.
[Sysname-segment-routing] global-block 200000 220000
mpls label-block (MPLS Command Reference)
isis adjacency-sid
Use isis adjacency-sid to assign an IS-IS adjacency SID to an IS-IS adjacency.
Use undo isis adjacency-sid to reclaim an IS-IS adjacency SID.
isis adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
undo isis adjacency-sid { absolute absolute-value | index index-value }
An IS-IS adjacency does not have an adjacency SID.
Interface view
absolute absolute-value: Specifies an absolute value as the adjacency SID. The value range for the absolute-value argument is 15000 to 250000.
index index-value: Specifies an adjacency SID index value in the range of 0 to 235000.
nexthop nexthop-address: Specifies a next hop by its IP address. If the network type of the interface is broadcast, you must specify this option. If the network type of the interface is P2P, you cannot specify this option.
After you enable SR-MPLS adjacency label allocation, the device randomly allocates adjacency SIDs to the links to its IGP neighbors. If the link to an IGP neighbor flaps, the adjacency SID of the link keeps changing. For a link to always use the same adjacency SID, use this command to assign a specific adjacency SID to the link.
You can assign adjacency SID by using absolute values or index values. If you use index values, the adjacency SID of a link is the base value of the SRLB plus the index value for the link.
Before assigning adjacency SIDs, execute the display mpls label command to display the usage status of the labels that you want to assign as adjacency SIDs. Make sure the labels are in Idle state. A label that is not in Idle state is being used by another protocol. If you assign it to a link as an adjacency SID, the adjacency SID is not available even if the status of the label changes to Idle later. To use the adjacency SID, you must remove the adjacency SID assignment and assign the adjacency SID again.
Before executing the isis adjacency-sid command on an interface, you must complete the following tasks:
· Enable IS-IS on the interface.
· Execute the segment-routing mpls and segment-routing adjacency enable commands.
If you execute the isis adjacency-sid command multiple times on an interface of the P2P network type, the most recent configuration takes effect.
If you execute the isis adjacency-sid command multiple times on an interface of the broadcast network type, the effective configuration varies depending on how you specify the next hop address:
· If you specify a different next hop address each time, all configurations take effect.
· If you specify the same next hop address each time, the most recent configuration takes effect.
To change the network type of an interface, execute the isis circuit-type p2p command before executing the isis adjacency-sid command on the interface. To change the network type of an interface after assigning an adjacency SID to the interface, you must remove the assignment first.
If you execute this command on an interface after enabling SR-MPLS adjacency label allocation for an IGP, the interface prefers the assigned adjacency SID.
# Set the absolute value of the adjacency SID to 20000 on interface HundredGigE 1/0/1. Specify 1.1.1.1 as the next hop.
[Sysname-HundredGigE1/0/1] isis enable 1
[Sysname-HundredGigE1/0/1] isis adjacency-sid absolute 20000 nexthop 1.1.1.1
display mpls label (MPLS Command Reference)
isis circuit-type p2p (Layer 3—IP Routing Command Reference)
isis enable (Layer 3—IP Routing Command Reference)
isis adjacency-sid weight
Use isis adjacency-sid weight to set the load balancing weight for an IS-IS adjacency.
Use undo isis adjacency-sid weight to restore the default.
isis adjacency-sid weight weight-value
The load balancing weight for an IS-IS adjacency is not set.
Interface view
weight-value: Specifies the load balancing weight for the IS-IS adjacency, in the range of 1 to 254.
If you use the isis adjacency-sid command to assign the same IS-IS adjacency SID to the IS-IS adjacencies on multiple interfaces, multiple forwarding paths are available for adjacency SID-based forwarding. By default, packets are assigned to the adjacencies evenly. If the adjacencies have different bandwidths, you can set the load balancing weights for the adjacencies to avoid congestion. The traffic ratio on an adjacency will be its load balancing weight divided by the total load balancing weights of the adjacencies with the same IS-IS adjacency SID.
# Set the load balancing weight to 10 for the IS-IS adjacency SID on interface HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] isis adjacency-sid weight 10
isis adjacency-sid
Use isis fast-reroute ti-lfa disable to disable an IS-IS interface from participating in TI-LFA calculation.
Use undo isis fast-reroute ti-lfa disable to enable an IS-IS interface to participate in TI-LFA calculation.
isis fast-reroute ti-lfa disable [ level-1 | level-2 ]
undo isis fast-reroute ti-lfa disable [ level-1 | level-2 ]
An IS-IS interface participates in TI-LFA calculation.
Interface view
level-1: Specifies TI-LFA calculation on IS-IS Level-1.
level-2: Specifies TI-LFA calculation on IS-IS Level-2.
Disable the output interface to the primary next hop from participating in TI-LFA calculation.
If you do not specify the level-1 or level-2 keyword, the command disables or enables the interface to participate in TI-LFA calculation in any level.
# Disable interface HundredGigE 1/0/1 from participating in TI-LFA calculation.
[Sysname-HundredGigE1/0/1] isis fast-reroute ti-lfa disable
fast-reroute ti-lfa
isis label-conflict-check enable
Use isis label-conflict-check enable to enable checking for IS-IS prefix SID conflicts.
Use undo isis label-conflict-check enable to disable checking for IS-IS prefix SID conflicts.
IS-IS prefix SID conflicts checking is disabled.
In an SR-MPLS network where multiple downstream devices advertise prefix SIDs in inform of index values to the device through IS-IS routes, the device determines SID conflicts in routes in the following cases:
· Different IP prefixes with the same prefix SID.
· Different prefix SIDs for the same IP prefix.
· Duplicate IP prefix and duplicate prefix SID.
By default, the device does not check SID conflicts when it receives the previous routes and process the routes as follows:
· When the device receives IS-IS routes that contain the same IP prefix and different prefix SIDs, it does not generate label forwarding entries for those routes.
· When the device receives IS-IS routes that contain the same prefix SID and the same or different IP prefixes, the device generates a label forwarding entry for the last of those routes.
If SID conflicts are ignored, the device might not able to detect faults on the network and might generate incorrect label forwarding entries.
After SID conflict checking is enabled, the device checks the SID conflicts and if any conflicts are detected in routes, it does not generate label forwarding entries for the routes.
# Enable checking for IS-IS prefix SID conflicts.
[Sysname] isis label-conflict-check enable
isis prefix-sid
isis member-port adjacency-sid
Use isis member-port adjacency-sid to assign an IS-IS adjacency SID to an aggregation group member interface.
Use undo isis member-port adjacency-sid to restore the default.
isis process-id member-port adjacency-sid { absolute absolute-value | index index-value } nexthop nexthop-address
undo isis process-id member-port adjacency-sid { absolute absolute-value | index index-value } nexthop nexthop-address
An aggregation group member interface does not have an IS-IS adjacency SID.
process-id process-id: Specifies an IS-IS process by its process ID in the range of 1 to 65535.
index index-value: Specifies an index value as the adjacency SID. The value range for the index-value argument is 0 to 235000.
After you enable adjacency SID allocation for aggregation group member interfaces, the device randomly allocates adjacency SIDs to the links to its IGP neighbors on aggregation group member interfaces. If the link to a neighbor flaps, the adjacency SID of the link keeps changing. For a link to always use the same adjacency SID, use this command to assign a specific adjacency SID to the link.
You can assign adjacency SIDs by using absolute values or index values. If you use index values, the adjacency SID of a link is the base value of the SRLB plus the index value for the link.
Before executing the isis member-port adjacency-sid command on an interface, you must complete the following tasks:
· Execute the segment-routing mpls and segment-routing member-port adjacency enable commands.
If you execute the isis member-port adjacency-sid command multiple times on an interface, the most recent configuration takes effect.
You can assign the same adjacency SID on multiple interfaces.
# Set the adjacency SID to absolute value 20000 on aggregation group member interface HundredGigE 1/0/1 for IS-IS process 1. Set the next hop to 1.1.1.1
[Sysname-HundredGigE1/0/1] isis 1 member-port adjacency-sid absolute 20000 nexthop 1.1.1.1 1
isis prefix-sid
Use isis prefix-sid to configure an IS-IS prefix SID.
Use undo isis prefix-sid to restore the default.
isis [ process-id process-id ] prefix-sid [ algorithm algorithm-id ] { absolute absolute-value | index index-value } [ n-flag-clear | { explicit-null | no-php } ] *
undo isis [ process-id process-id ] prefix-sid [ algorithm algorithm-id ]
No IS-IS prefix SID is configured.
Loopback interface view
algorithm algorithm-id: Specifies a Flex-Algo for the prefix SID. The algorithm-id argument represents the Flex-Algo ID, in the range of 128 to 255. If you do not specify a Flex-Algo, IS-IS uses the SPF algorithm to calculate the shortest path to the prefix SID.
absolute absolute-value: Specifies an absolute value as the prefix SID. The value range for the absolute-value argument is 15000 to 250000.
index index-value: Specifies an index value in the range of 0 to 235000.
n-flag-clear: Sets the Node-SID flag bit of the prefix SID to 0 to use the prefix SID for a group of SR nodes. If you do not specify this keyword, the flag bit is 1 and the prefix SID is used for a single SR node.
explicit-null: Sets the Explicit-null flag bit of the prefix SID to 1. This setting requires that the upstream neighbor uses an explicit null label to replace the prefix SID. If you do not specify this keyword, the flag bit is 0 and the upstream neighbor continues to forward the packet based on the prefix SID. For more information about the explicit null label, see MPLS basics configuration in MPLS Configuration Guide.
no-php: Sets the P-flag bit of the prefix SID to 1 so the penultimate hop does not pop out the SID. If you do not specify this keyword, the P-flag bit is 0 and the penultimate hop pops out the SID.
An absolute value used as the prefix SID takes effect only if it is in the SRGB of the node.
If you specify an index value, the sum of the index value and the SRGB base value is used as the prefix SID. The prefix SID takes effect only if it is in the SRGB of the node.
To use a prefix SID for a group of SR nodes in anycast scenarios, specify the n-flag-clear keyword to set the Node-SID flag bit of the prefix SID to 0.
To configure an IS-IS prefix SID, you must enable an IS-IS process on the loopback interface.
If you execute this command on an interface multiple times, the most recent configuration takes effect.
# Set the IS-IS prefix SID index value to 20 on loopback interface 1.
[Sysname] interface loopback 1
[Sysname-LoopBack1] isis enable 1
[Sysname-LoopBack1] isis prefix-sid index 20
local-block
Use local-block to configure the SRLB.
Use undo local-block to restore the default.
local-block { minimum-value maximum-value | name name }
undo local-block
The label range for the SRLB is 15000 to 15999. The labels in this range cannot be assigned to other protocols or SRGBs.
Segment routing view
minimum-value: Specifies the minimum label value. The value is 15000.
maximum-value: Specifies the maximum label value. The value is 15999.
The segment routing local block (SRLB) is the range of local labels dedicated for SR-MPLS adjacency SIDs.
Before executing this command, use the display mpls label command to display MPLS label usage information. Make sure that all labels in the specified range are idle. If a label in the range is not idle, the MPLS SRLB takes effect only after you save the running configuration and reboot the device.
# Configure the SRLB to be from 200000 to 220000.
[Sysname] segment-routing
[Sysname-segment-routing] local-block 200000 220000
display mpls label
display mpls summary (MPLS Command Reference)
Use mapping-server prefix-sid-map to configure a prefix-SID mapping.
Use undo mapping-server prefix-sid-map to delete a prefix-SID mapping.
mapping-server prefix-sid-map ip-address mask-length start-value [ range range-value ] [ attached ]
undo mapping-server prefix-sid-map ip-address mask-length
No prefix-SID mappings exist.
ip-address: Specifies an IPv4 address prefix to be mapped or specifies the start IP prefix for a range of prefix-SID mappings, in dotted decimal notation.
start-value: Specifies the index value of the SID to be mapped to the specified prefix, or specifies the index value of the start SID for a range of prefix-SID mappings. The value range for this argument is 0 to 234999.
range range-value: Specifies the number of prefix-SID mappings, in the range of 1 to 235000. Specify this option if you want to configure more than one mapping by using a single command. The system creates the specified number of mappings, starting from the start IP prefix and SID index value. The increment step for the prefix and SID index value is 1.
attached: Specifies that the specified prefixes represent local networks.
The specified prefixes must not belong to any existing prefix-SID mappings.
Before you configure prefix-SID mappings in bulk, plan the number of mappings. Make sure there are enough mappings to use.
If you specify a value greater than 65535 for the range-value argument, the prefix-SID mappings cannot be advertised through IS-IS or OSPF.
# Map prefix 1.1.1.1/32 to SID index value 100.
[Sysname-segment-routing] mapping-server prefix-sid-map 1.1.1.1 32 100
# Configure two prefix-SID mappings, starting from prefix 10.1.1.1/32 and SID index value 200.
[Sysname-segment-routing] mapping-server prefix-sid-map 10.1.1.1 32 200 range 2
In the first mapping, the prefix is 10.1.1.1/32 and the SID is 200. In the second mapping, the prefix is 10.1.1.2/32 and the SID is 201.
mpls te path-selection adjacency-sid
Use mpls te path-selection adjacency-sid to configure a tunnel interface to perform CSPF calculation strictly based on adjacency SID information when establishing an SRLSP for an MPLS TE tunnel.
Use undo mpls te path-selection adjacency-sid to restore the default.
A tunnel interface does not perform CSPF calculation strictly based on adjacency SID information when establishing an SRLSP for an MPLS TE tunnel.
Tunnel interface view
This command takes effect only on an MPLS TE tunnel established by using SR.
Before executing this command, you must enable SR-MPLS and SR adjacency SID allocation on each node that the TE tunnel might traverse.
If an MPLS TE tunnel is already established when you execute this command, the tunnel interface calculates a new SRLSP based on adjacency SID information.
· If the new SRLSP is successfully established, the tunnel interface removes the old SRLSP and uses the new SRLSP to establish a new MPLS TE tunnel.
· If the new SRLSP fails to be established, the tunnel interface continues to use the old SRLSP.
# Configure a tunnel interface to perform CSPF calculation strictly based on adjacency SID information when establishing an SRLSP for an MPLS TE tunnel.
[Sysname] interface tunnel 1 mode mpls-te
[Sysname-Tunnel1] mpls te path-selection adjacency-sid
mpls te static-sr-mpls
Use mpls te static-sr-mpls to bind a static SRLSP to an MPLS TE tunnel interface.
Use undo mpls te static-sr-mpls to unbind a static SRLSP from an MPLS TE tunnel interface.
mpls te static-sr-mpls lsp-name [ backup ]
undo mpls te static-sr-mpls lsp-name
An MPLS TE tunnel interface does not use any static SRLSPs.
lsp-name: Specifies a static SRLSP by its name, a case-sensitive string of 1 to 67 characters. The specified static SRLSP must be already created by using the static-sr-mpls lsp command.
backup: Specifies the backup static SRLSP. If you do not specify this keyword, this command specifies the main static SRLSP.
This command takes effect only if you have configured the mpls te signaling static command in tunnel interface view.
Execute this command only on the ingress node of a static SRLSP.
If you execute the mpls te static-sr-mpls and mpls te static-cr-lsp commands on a device, only the mpls te static-cr-lsp command takes effect. For the mpls te static-sr-mpls command to take effect, execute the undo mpls te static-cr-lsp command.
# Bind static SRLSP static-sr-3 to MPLS TE tunnel interface 0.
[Sysname] interface tunnel 0 mode mpls-te
[Sysname-Tunnel0] mpls te static-sr-mpls static-sr-3
display mpls te tunnel-interface (MPLS Command Reference)
mpls te signaling (MPLS Command Reference)
mpls te static-sr-mpls wtr
Use mpls te static-sr-mpls wtr to configure the static SRLSP switchback delay time.
Use undo mpls te static-sr-mpls wtr to restore the default.
mpls te static-sr-mpls wtr delay-time
The static SRLSP switchback delay is 10 seconds.
delay-time: Static SRLSP switchback delay time, in the range of 0 to 2592000 seconds. As a best practice to avoid packet loss during the switchback, set the switchback delay to more than 10 seconds.
The switchback delay time refers to the period of time that a TE tunnel waits before it performs a backup-to-primary static SRLSP switchover when the primary static SRLSP recovers.
It might happen that the upstream primary static SRLSP becomes up before the downstream primary static CRLSP becomes up. In this case, if the upstream node switches traffic back to the primary SRLSP, the traffic will be dropped until the primary SRLSP on the downstream node becomes up. Setting a proper switchback delay can resolve this issue.
# Set the static SRLSP switchback delay to 30 seconds.
[Sysname-Tunnel0] mpls te static-sr-mpls wtr 30
ospf adjacency-sid
Use ospf adjacency-sid to assign an OSPF adjacency SID to an OSPF adjacency.
Use undo ospf adjacency-sid to reclaim an OSPF adjacency SID.
ospf adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
undo ospf adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
An OSPF adjacency does not have an adjacency SID.
Interface view
index index-value: Specifies an adjacency SID index value as the adjacency SID. The value range for the index-value argument is 0 to 235000.
nexthop nexthop-address: Specifies a next hop by its IP address. If the network type of the interface is not P2P, you must specify this option. If the network type of the interface is P2P, you cannot specify this option.
After you enable OSPF adjacency SID allocation, the device randomly allocates adjacency SIDs to the links to its OSPF neighbors. If the link to an OSPF neighbor flaps, the adjacency SID of the link keeps changing. For a link to always use the same adjacency SID, use this command to assign a specific adjacency SID to the link.
You can assign adjacency SIDs by using absolute values or index values. If you If you use index values, the adjacency SID of a link is the base value of the SRLB plus the index value for the link.
The ospf adjacency-sid command takes effect only after you execute the segment-routing mpls and segment-routing adjacency enable commands.
If you execute the ospf adjacency-sid command multiple times on an interface of the P2P network type, the most recent configuration takes effect.
If you execute the ospf adjacency-sid command multiple times on an interface of the broadcast network type, the effective configuration varies depending on how you specify the next hop address:
To change the network type of an interface, execute the ospf network-type command.
# Set the absolute value of the adjacency ID to 20000 on interface HundredGigE 1/0/1. Specify 1.1.1.1 as the next hop.
[Sysname-HundredGigE1/0/1] ospf adjacency-sid absolute 20000 nexthop 1.1.1.1
ospf network-type (Layer 3—IP Routing Command Reference)
ospf adjacency-sid weight
Use ospf adjacency-sid weight to set the load balancing weight for an OSPF adjacency.
Use undo ospf adjacency-sid weight to restore the default.
ospf adjacency-sid weight weight-value
The load balancing weight for an OSPF adjacency is not set.
Interface view
weight-value: Specifies the load balancing weight for the OSPF adjacency, in the range of 1 to 254.
If you use the ospf adjacency-sid command to assign the same OSPF adjacency SID to the OSPF adjacencies on multiple interfaces, multiple forwarding paths are available for adjacency SID-based forwarding. By default, packets are assigned to the adjacencies evenly. If the adjacencies have different bandwidths, you can set the load balancing weights for the adjacencies to avoid congestion. The traffic ratio on an adjacency will be its load balancing weight divided by the total load balancing weights of the adjacencies with the same OSPF adjacency SID.
# Set the load balancing weight to 1 for the OSPF adjacency SID on interface HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] ospf adjacency-sid weight 1
ospf adjacency-sid
ospf fast-reroute ti-lfa disable
Use ospf fast-reroute ti-lfa disable to disable an OSPF interface from participating in TI-LFA calculation.
Use undo ospf fast-reroute ti-lfa disable to enable an OSPF interface to participate in TI-LFA calculation.
An OSPF interface participates in TI-LFA calculation.
Interface view
On the source node, the route's output interface to the primary next hop might not be on the backup path calculated by TI-LFA. Disable TI-LFA on the interface to prevent it from participating in TI-LFA calculation.
[Sysname-HundredGigE1/0/1] ospf fast-reroute ti-lfa disable
fast-reroute ti-lfa (OSPF view)
ospf prefix-sid
Use ospf prefix-sid to configure an OSPF prefix SID.
Use undo ospf prefix-sid to restore the default.
ospf process-id prefix-sid { absolute absolute-value | index index-value } [ n-flag-clear | { explicit-null | no-php } ] *
undo ospf process-id prefix-sid
No OSPF prefix SID is configured.
index index-value: Specifies an index value as the prefix SID. The value range for the index-value argument is 0 to 235000.
The configured OSPF prefix SID takes effect only if the OSPF process enabled on the loopback interface is the same as the OSPF process associated with the prefix SID.
# Set the OSPF prefix SID index value to 20 on loopback interface 1.
[Sysname-LoopBack1] ospf 1 prefix-sid index 20
Use peer egress-engineering to enable BGP EPE for a peer or peer group and specify a routing policy to assign a label (SID) to the peer or peer group.
Use undo peer egress-engineering to restore the default for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } egress-engineering [ adjacency | node-adjacency ] [ label label-value | route-policy policy-name ] [ link-down relate-bfd-state ]
peer { group-name | ipv4-address [ mask-length ] } egress-engineering [ set ] [ label label-value | route-policy policy-name ]
undo peer { group-name | ipv4-address [ mask-length ] } egress-engineering
BGP EPE is disabled.
BGP instance view
group-name: Specifies an existing peer group by its name, a case-sensitive string of 1 to 47 characters.
ipv4-address: Specifies the IPv4 address of an existing peer.
mask-length: Specifies the mask length, in the range of 0 to 32. This argument and the ipv4-address argument together specify a subnet. If you specify this argument, the command applies to dynamic peers on the specified subnet.
adjacency: Assigns a Peer-Adjacency-SID.
node-adjacency: Assigns both a Peer-Node-SID and a Peer-Adjacency-SID.
set: Assigns a Peer-Set-SID.
label label-value: Specifies the SID value, in the range of 16 to 250000.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the device assigns SIDs to neighbors randomly.
If you do not specify the adjacency, node-adjacency, or set keyword, the device assigns a Peer-Node-SID.
You can use the apply label-value command to assign an SID value but cannot use the apply label-index command to assign a label index value .
You cannot assign the same peer node SID or peer adjacency SID to multiple BGP peers or peer groups.
You can assign the same set type SIDs to BGP peers or peer groups.
You can use if-match interface as a filtering condition only when you assign peer adjacency SIDs to BGP peers or peer groups.
Before assigning BGP-EPE SIDs, execute the display mpls label command to display the usage status of the labels that you want to assign as BGP-EPE SIDs. Make sure the labels are in Idle state. A label that is not in Idle state is being used by another protocol. If you assign it to a peer or peer group as a BGP-EPE SID, the BGP-EPE SID is not available even if the status of the label changes to Idle later. To use the BGP-EPE SID, you must remove the BGP-EPE SID assignment and assign the BGP-EPE SID again.
# Enable BGP EPE for peer 1.1.1.1 and assign a Peer-Node-SID to the peer.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 egress-engineering
sbfd
peer peer-set
Use peer peer-set to add a peer or peer group to a BGP EPE peer set.
Use undo peer peer-set to remove a peer or peer group from its BGP EPE peer set.
peer { group-name | ipv4-address [ mask-length ] } peer-set peer-set-name
undo peer { group-name | ipv4-address [ mask-length ] } peer-set
A peer or peer group does not belong to a BGP EPE peer set.
BGP instance view
ipv4-address: Specifies an existing peer by its IPv4 address.
mask-length: Specifies a mask length in the range of 0 to 32. The IPv4 address and the mask length together specify a network segment. This command applies to the dynamic peers in the specified network segment.
peer-set-name: Specifies the name of the BGP EPE peer set to which the specified BGP peers will be added. The peer set name is a case-sensitive string of 1 to 63 characters.
Before you execute this command, make sure BGP EPE is enabled.
If a peer or peer group is assigned a Peer-Set-SID (by using the peer egress-engineering set command), the peer or peer group cannot be added to a BGP EPE peer set, and vice versa.
# Add peer 10.1.1.1 to BGP EPE peer set abc.
[Sysname] bgp 100
[Sysname-bgp-default] peer 10.1.1.1 peer-set abc
sbfd detect-multiplier
Use sbfd detect-multiplier to set the SBFD detection time multiplier for SRLSPs.
Use undo sbfd detect-multiplier to restore the default.
sbfd detect-multiplier value
The SBFD detection time multiplier is not set for SRLSPs. The BFD detection time multiplier set by the bfd multi-hop detect-multiplier command applies.
value: Specifies a detection time multiplier, which is the maximum number of consecutive SBFD packets that can be discarded. The value range for this argument is 3 to 50.
The device sends SBFD packets to a peer periodically. If the device does not receive SBFD packets from the peer within the actual detection interval, it determines that the session is down. The actual detection interval of the sender is the detection time multiplier of the receiver × the actual sending interval of the receiver.
This command takes effect only on SBFD sessions created by the sbfd enable command.
# Set the SBFD detection time multiplier to 3 for SRLSPs.
[Sysname-segment-routing] sbfd enable
[Sysname-segment-routing] sbfd detect-multiplier 3
bfd multi-hop detect-multiplier (High Availability Command Reference)
sbfd enable
sbfd enable
Use sbfd enable to enable SBFD for SRLSPs.
Use undo sbfd enable to restore the default.
sbfd enable [ prefix-list prefix-list-name ]
undo sbfd enable
SBFD for SRLSPs is not enabled.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by the prefix list name, a case-sensitive string of 1 to 63 characters. The device can create SBFD sessions only for the SRLSPs permitted by the specified IPv4 prefix list. If you do not specify an IPv4 prefix list, the device can create SBFD sessions for all SRLSPs.
This command enables the device to create an SBFD session for each primary SRLSP to verify the connectivity of the primary SRLSP. When a primary SRLSP fails, SBFD can quickly detect the failure and switches traffic to the backup SRLSP to reduce packet loss.
Before you execute this command, enable MPLS BFD by using the mpls bfd enable command.
After you execute this command, the local end uses the destination address of an SRLSP as the remote discriminator to establish an SBFD session for the SRLSP. Make sure you specify the local discriminator of the SBFD session on the remote end as the SRLSP's destination address by using the sbfd local-discriminator command.
If you execute both the sbfd enable command and the mpls sbfd command for SRLSPs, the mpls sbfd command takes effect on the SRLSPs.
# Enable SBFD for SRLSPs.
mpls bfd enable (MPLS Command Reference)
mpls sbfd (for LSP) (MPLS Command Reference)
sbfd local-discriminator (MPLS Command Reference)
sbfd min-receive-interval
Use sbfd min-receive-interval to set the minimum interval for receiving SBFD packets for SRLSP SBFD.
Use undo sbfd min-receive-interval to restore the default.
sbfd min-receive-interval interval
The minimum interval for receiving SBFD packets is not set for SRLSP SBFD. The interval set by the bfd multi-hop min-receive-interval command applies.
interval: Specifies the minimum interval for receiving SBFD packets, in milliseconds. The value range is 3 to 10000.
Use this command to prevent the packet sending rate of the peer end from exceeding the packet receiving rate of the local end. If the receiving rate is exceeded, the peer end dynamically adjusts the BFD packet transmitting interval to the minimum receiving interval of the local end.
# Set the minimum SBFD packet receiving interval for SRLSP SBFD to 450 milliseconds.
[Sysname-segment-routing] sbfd min-receive-interval 450
bfd multi-hop min-receive-interval (High Availability Command Reference)
sbfd enable
sbfd min-transmit-interval
Use sbfd min-transmit-interval to set the minimum interval for transmitting SBFD packets for SRLSP SBFD.
Use undo sbfd min-transmit-interval to restore the default.
sbfd min-transmit-interval interval
The minimum interval for transmitting SBFD packets is not set for SRLSP SBFD. The interval set by the bfd multi-hop min-transmit-interval command applies.
interval: Specifies the minimum interval for transmitting SBFD packets, in milliseconds. The value range is 3 to 10000.
Use this command to prevent the SBFD packet sending rate from exceeding the packet receiving rate of the peer end.
The actual SBFD packet transmitting interval on the local end is the greater value between the following values:
· Minimum interval for transmitting SBFD packets on the local end.
· Minimum interval for receiving SBFD packets on the peer end.
# Set the minimum SBFD packet transmitting interval for SRLSP SBFD to 450 milliseconds.
[Sysname-segment-routing] sbfd min-transmit-interval 450
bfd multi-hop min-transmit-interval (High Availability Command Reference)
sbfd enable
segment-routing
Use segment-routing to enable segment routing and enter segment routing view.
Use undo segment-routing to disable segment routing.
segment-routing
Segment routing is disabled.
To configure the Segment Routing Mapping Server (SRMS) features, you must execute this command on the SRMS. The SRMS is an entity that advertises prefix-SID mappings in an IGP. By deploying an SRMS, you can allocate SIDs to devices that do not support SR-MPLS, allowing for SR-MPLS and LDP interworking.
# Enable segment routing and enter segment routing view.
Use segment-routing adjacency enable to enable SR-MPLS adjacency label allocation.
Use undo segment-routing adjacency enable to disable SR-MPLS adjacency label allocation.
SR-MPLS adjacency label allocation is disabled.
OSPF view
For this command to take effect, you must enable MPLS SR.
# Enable SR-MPLS adjacency label allocation for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing adjacency enable
# Enable SR-MPLS adjacency SID allocation for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing adjacency enable
Use segment-routing global-block to configure the MPLS SRGB.
Use undo segment-routing global-block to restore the default.
segment-routing global-block minimum-value maximum-value
IS-IS and OSPF uses the global MPLS SRGB configured in segment routing view.
IS-IS view
OSPF view
minimum-value: Specifies the minimum label value, in the range of 15000 to 249999.
maximum-value: Specifies the maximum label value, in the range of 15001 to 250000.
If you have configured prefix SIDs when you configure the SRGB, the SRGB must contain the configured prefix SIDs.
In the following situations, the configured SRGB takes effect after a device reboot:
· The SRGB contains a label that is already used by another protocol. For example, the SRGB contains a label that is already used by LDP.
· The SRGB overlaps with the label range of another protocol.
# Configure the MPLS SRGB to be from 17000 to 22000 for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] segment-routing global-block 17000 22000
# Configure the MPLS SRGB to be from 17000 to 22000 for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing global-block 17000 22000
global-block
segment-routing lsp-trigger
Use segment-routing lsp-trigger to configure the SRLSP establishment triggering policy.
Use undo segment-routing lsp-trigger to restore the default.
segment-routing lsp-trigger { host | none | prefix-list prefix-name }
The device allows all FECs to trigger SRLSP establishment.
OSPF view
host: Allows host FECs to trigger SRLSP establishment.
none: Allows no FECs to trigger SRLSP establishment.
prefix-list prefix-name: Allows FECs permitted by a prefix list to trigger SRLSP establishment. The prefix-name argument is a case-sensitive string of 1 to 63 characters.
To save system resources, you can configure the SRLSP establishment triggering policy to allow only certain FECs to trigger SRLSP establishment.
# Configure the SRLSP establishment triggering policy to allow only host FECs to trigger SRLSP establishment.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing lsp-trigger host
segment-routing mapping-server advertise-local
Use segment-routing mapping-server advertise-local to enable advertisement of locally configured prefix-SID mappings.
Use undo segment-routing mapping-server advertise-local to disable advertisement of locally configured prefix-SID mappings.
Advertisement is disabled for locally configured prefix-SID mappings.
OSPF view
In an SR to LDP interworking scenario, you must execute this command on the SRMS so the device advertises locally configured prefix-SID mappings to neighbors.
# Enable IS-IS to advertise locally configured prefix-SID mappings for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing mapping-server advertise-local
# Enable OSPF to advertise locally configured prefix-SID mappings for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing mapping-server advertise-local
segment-routing mapping-server receive
Use segment-routing mapping-server receive to enable reception of prefix-SID mappings.
Use undo segment-routing mapping-server receive to disable reception of prefix-SID mappings.
Reception of prefix-SID mappings is enabled.
OSPF view
In an SR to LDP interworking scenario, you must execute this command on the SRMCs so they can identify the prefix-SID mappings advertised by the SRMS.
# Disable reception of prefix-SID mappings for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] undo segment-routing mapping-server receive
# Disable reception of prefix-SID mappings for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] undo segment-routing mapping-server receive
mapping-server prefix-sid-map advertise-local
Use segment-routing member-port adjacency enable to enable SR-MPLS adjacency SID allocation for aggregation group member interfaces.
Use undo segment-routing member-port adjacency enable to disable SR-MPLS adjacency SID allocation for aggregation group member interfaces.
SR-MPLS adjacency SID allocation is disabled for aggregation group member interfaces.
Before executing this command, you must execute the segment-routing mpls command.
After you execute this command, the device will automatically select and assign adjacency SIDs from the SRLB to links to its IGP neighbors on aggregation group member interfaces.
# Enable SR-MPLS adjacency SID allocation for aggregation group member interfaces in IPv4 unicast address family view of IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing member-port adjacency enable
segment-routing microloop-avoidance enable
Use segment-routing microloop-avoidance enable to enable SR microloop avoidance.
Use undo segment-routing microloop-avoidance enable to disable SR microloop avoidance.
segment-routing microloop-avoidance enable [ level-1 | level-2 ]
undo segment-routing microloop-avoidance enable [ level-1 | level-2 ]
In OSPF view:
SR microloop avoidance is disabled.
OSPF view
level-1: Specifies SR microloop avoidance for IS-IS Level-1.
level-2: Specifies SR microloop avoidance for IS-IS Level-2.
After a network failure occurs or recovers, route convergence occurs on relevant network devices. Because of non-simultaneous convergence on network devices, microloops might be formed. After you configure SR microloop avoidance, the devices will forward traffic along the specified path before route convergence is finished on all the relevant network devices. Because the forwarding path is independent of route convergence, microloops are avoided.
The specific process is as follows:
· After a network failure occurs, the device installs the calculated forwarding path to the FIB and switches to the forwarding path after a delay time. During the delay time, the device still uses the TI-LFA FRR backup path.
· After a network failure recovers, the device calculates an active path and a backup path with a SID. During the delay time, the device still uses the backup path.
If you do not specify the level-1 or level-2 keyword, the segment-routing microloop-avoidance enable command enables or disables SR microloop avoidance on all IS-IS levels.
# Enable SR microloop avoidance for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing microloop-avoidance enable
# Enable SR microloop avoidance for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing microloop-avoidance enable
segment-routing microloop-avoidance rib-update-delay
Use segment-routing microloop-avoidance rib-update-delay to set the SR microloop avoidance RIB-update-delay time.
Use undo segment-routing microloop-avoidance rib-update-delay to restore the default.
segment-routing microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo segment-routing microloop-avoidance rib-update-delay [ level-1 | level-2 ]
In OSPF view:
The SR microloop avoidance RIB-update-delay time is 5000 ms.
OSPF view
delay-time: Specifies the SR microloop avoidance RIB-update-delay time in milliseconds. The value range is 1 to 60000.
level-1: Specifies the SR microloop avoidance RIB-update-delay time for IS-IS Level-1.
level-2: Specifies the SR microloop avoidance RIB-update-delay time for IS-IS Level-2.
To leave sufficient time for IGP to finish route convergence, specify a proper value for the SR microloop avoidance RIB-update-delay timer. Before the timer expires, failure relevant devices will forward traffic along the specified path. After the timer expires, traffic will traverse the usual path.
If you do not specify the level-1 or level-2 keyword, this command sets the SR microloop avoidance RIB-update-delay time for all IS-IS levels.
# Set the SR microloop avoidance RIB-update-delay time to 6000 ms for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing microloop-avoidance rib-update-delay 6000
# Set the SR microloop avoidance RIB-update-delay time to 6000 ms for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing microloop-avoidance rib-update-delay 6000
Use segment-routing mpls to enable MPLS SR.
Use undo segment-routing mpls to disable MPLS SR.
SR-MPLS is disabled.
OSPF view
For SR-MPLS to take effect, perform the following tasks before configuring the IGP to support MPLS SR:
· If the IGP is IS-IS, set the cost style to wide, compatible, or wide-compatible. For more information about the cost style, see IS-IS configuration in Layer 3—IP Routing Configuration Guide.
· If the IGP is OSPF, enable opaque LSA reception and advertisement capability. For more information about the capability, see OSPF configuration in Layer 3—IP Routing Configuration Guide.
# Enable SR-MPLS in IS-IS IPv4 unicast address family view of IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] cost-style wide
[Sysname-isis-1-ipv4] segment-routing mpls
# Enable SR-MPLS for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing mpls
cost-style (Layer 3—IP Routing Command Reference)
opaque-capability enable (Layer 3—IP Routing Command Reference)
segment-routing sr-prefer
Use segment-routing sr-prefer to configure the device to prefer SRLSPs in traffic forwarding.
Use undo segment-routing sr-prefer to restore the default.
segment-routing sr-prefer [ prefix-list prefix-list-name ]
The device prefers LDP LSPs in traffic forwarding.
OSPF view
prefix-list prefix-list-name: Specifies an IP address prefix list by its name, a case-sensitive string of 1 to 63 characters. The device preferentially uses SRLSPs to forward traffic destined for addresses on the prefix list, and preferentially uses LDP LSPs to forward traffic destined for other addresses. If you do not specify an IP address prefix list, the device preferentially uses SRLSPs to forward all traffic.
This command determines whether the device prefers SRLSPs or LDP LSPs when both SRLSPs and LDP LSPs are available for traffic forwarding.
This command takes effect only when SR-MPLS is enabled and the SRLSPs use prefix SIDs.
# Configure the device to preferentially use SRLSPs established by IS-IS to forward all traffic.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing sr-prefer
# Configure the device to preferentially use SRLSPs established by OSPF to forward traffic that is identified by prefix list 8.
[Sysname] ip prefix-list 8 permit 4.4.4.4 32
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing sr-prefer prefix-list 8
ip prefix-list (Layer 3—IP Routing Command Reference)
static-sr-mpls adjacency
Use static-sr-mpls adjacency to configure an IPv4 adjacency segment for static SR.
Use undo static-sr-mpls adjacency to delete an IPv4 adjacency segment.
static-sr-mpls adjacency adjacency-path-name in-label label-value { nexthop ip-address | outgoing-interface interface-type interface-number }
undo static-sr-mpls adjacency adjacency-path-name
No IPv4 adjacency segments exist.
adjacency-path-name: Specifies the adjacency segment name, a case-sensitive string of 1 to 67 characters.
in-label label-value: Specifies the incoming label, in the range of 16 to 14999.
nexthop ip-address: Specifies the next hop IPv4 address.
outgoing-interface interface-type interface-number: Specifies an output interface by its type and number. The output interface must be a P2P interface.
Execute this command on a node of a static SRLSP to assign an incoming label to an IPv4 next hop or output interface. After the node receives a packet with that incoming label, it will forward the packet through the corresponding next hop or output interface.
Execute this command on all nodes of a static SRLSP.
If you specify the next hop IPv4 address, make sure the following requirements are met:
· The device has a route to reach the next hop IPv4 address.
· MPLS is enabled on the output interface of the route.
If you specify an output interface, make sure the following requirements are met:
· The interface is up.
· The interface can receive direct routes.
· MPLS is enabled on the interface.
On a device, the incoming label specified by this command must be different than other static LSPs and static CRLSPs. If not, this command fails to be executed.
# Configure adjacency segment adj1, and specify the incoming label as 100 and the next hop IPv4 address as 12.2.1.2.
[Sysname] static-sr-mpls adjacency adj1 in-label 100 nexthop 12.2.1.2
static-sr-mpls lsp
display mpls static-sr-mpls adjacency
static-sr-mpls ipv6 adjacency
Use static-sr-mpls ipv6 adjacency to configure an IPv6 adjacency segment for static SR.
Use undo static-sr-mpls ipv6 adjacency to delete an IPv6 adjacency segment.
static-sr-mpls ipv6 adjacency adjacency-path-name in-label label-value { nexthop ipv6-address | outgoing-interface interface-type interface-number } *
undo static-sr-mpls ipv6 adjacency adjacency-path-name
No IPv6 adjacency segments exist.
nexthop ipv6-address: Specifies the next hop IPv6 address.
Execute this command on a node of a static SRLSP to assign an incoming label to an IPv6 next hop or output interface. After the node receives a packet with that incoming label, it will forward the packet through the corresponding next hop or output interface.
If you specify the next hop IPv6 address, make sure the following requirements are met:
· The device has a route to reach the next hop IPv6address.
If you specify a link local address as the next hop address in an IPv6 static adjacency segment, you must also specify an output interface.
# Configure adjacency segment adj1, and specify the incoming label as 100 and the next hop IPv6 address as 1::2.
[Sysname] static-sr-mpls ipv6 adjacency adj1 in-label 100 nexthop 1::2
display static-sr-mpls ipv6 adjacency
static-sr-mpls lsp
static-sr-mpls lsp
Use static-sr-mpls lsp to configure a static SRLSP.
Use undo static-sr-mpls lsp to delete a static SRLSP.
static-sr-mpls lsp lsp-name out-label out-label-value&<1-11>
undo static-sr-mpls lsp lsp-name
No static SRLSPs exist.
lsp-name: Specifies the static SRLSP name, a case-sensitive string of 1 to 67 characters.
out-label out-label-value&<1-11>: Specifies a space-separated list of up to 11 outgoing labels. The outgoing labels represent the incoming MPLS labels of the nodes that a static SRLSP traverses, from the nearest to the farthest away from the ingress node. The value range for the out-label-value argument is 0, 3, and 16 to 1048575.
Execute this command only on the ingress node of a static SRLSP. Packets forwarded over the static SRLSP will carry the label values in the specified outgoing label list. The nodes of the static CRLSP will pop outgoing label values or insert new labels in sequence.
# Configure static SRLSP lsp1, and specify the outgoing labels as 100, 200, and 300.
[Sysname] static-sr-mpls lsp lsp1 out-label 100 200 300
display mpls static-sr-mpls ipv6 prefix
display mpls static-sr-mpls lsp
display mpls static-sr-mpls prefix
Use static-sr-mpls prefix to configure an IPv4 prefix segment for static SR.
Use undo static-sr-mpls prefix to delete an IPv4 prefix segment.
static-sr-mpls prefix prefix-path-name destination ipv4-address { mask | mask-length } in-label in-label-value [ { nexthop ipv4-address | outgoing-interface interface-type interface-number } out-label out-label-value ]
undo static-sr-mpls prefix prefix-path-name [ destination ipv4-address { mask | mask-length } in-label in-label-value [ nexthop ipv4-address | outgoing-interface interface-type interface-number ] ]
No IPv4 prefix segments exist.
prefix-path-name: Specifies the prefix segment name, a case-sensitive string of 1 to 67 characters.
destination ipv4-address: Specifies the destination IPv4 address.
mask: Specifies the mask.
in-label label-value: Specifies the incoming label, in the range of 16000 to 55999.
nexthop ipv4-address: Specifies the next hop IPv4 address.
out-label out-label-value: Specifies the outgoing label, in the range of 0, 3, and 16 to 1048575. If you do not specify this option, the device does not insert an outgoing label after popping the incoming label.
Execute this command on a node of a static SRLSP to assign an incoming label and an outgoing label to a destination IPv4 address. After the node receives a packet with that incoming label, it will pop the incoming label, insert the outgoing label, and forward the packet through the specified next hop or output interface.
If you do not specify the next hop and outgoing label or do not specify the output interface and outgoing label, the device does not insert an outgoing label after popping the incoming label. On the egress node of a static SRLSP, you can execute this command without specifying a next hop, an output interface, and an outgoing label.
A prefix segment must use the next hop or output interface of the optimal route (non-BGP route) to the destination address of the prefix segment. You can configure multiple prefix segments to the destination address for load sharing if the optimal route has more than one next hops or output interfaces. To avoid configuration failure, make sure all prefix segments use the same prefix segment name, incoming label, and outgoing label.
A static prefix segment must use a different incoming label than existing static LSPs, static PWs, and static CRLSPs. If not, this command fails to be executed.
If you specify only the prefix-path-name argument, the undo static-sr-mpls prefix command deletes all IPv4 prefix segments with the specified name. If you specify a prefix segment name, destination IPv4 address, and an incoming label, the undo static-sr-mpls prefix command deletes all IPv4 prefix segments with the specified name, destination IPv4 address, and incoming label. If you specify all parameters, only the IPv4 prefix segment that matches the specified name, destination IPv4 address, and next hop or output interface is deleted.
# Configure prefix segment prefix1, specify the destination IPv4 address, incoming label, outgoing label, and next hop as 2.2.2.2, 16000, 16001, and 10.0.0.2, respectively.
[Sysname] static-sr-mpls prefix prefix1 destination 2.2.2.2 32 in-label 16000 nexthop 10.0.0.2 out-label 16001
static-sr-mpls lsp
Use static-sr-mpls ipv6 prefix to configure an IPv6 prefix segment for static SR.
Use undo static-sr-mpls ipv6 prefix to delete an IPv6 prefix segment.
static-sr-mpls ipv6 prefix prefix-path-name destination ipv6-address prefix-length in-label in-label-value [ { nexthop ipv6-address | outgoing-interface interface-type interface-number } out-label out-label-value ]
undo static-sr-mpls ipv6 prefix prefix-path-name [ destination ipv6-address prefix-length in-label in-label-value [ nexthop ipv6-address | outgoing-interface interface-type interface-number ] ]
No IPv6 prefix segments exist.
destination ipv6-address: Specifies the destination IPv6 address.
prefix-length: Specifies the prefix length, in the range of 0 to 128.
out-label out-label-value: Specifies the outgoing label, in the range of 2, 3, and 16 to 1048575.
Execute this command on a node of a static SRLSP to assign an incoming label and an outgoing label to a destination IPv6 address. After the node receives a packet with that incoming label, it will pop the incoming label, insert the outgoing label, and forward the packet through the specified next hop or output interface.
If you specify only the prefix-path-name argument, the undo static-sr-mpls ipv6 prefix command deletes all IPv6 prefix segments with the specified name. If you specify a prefix segment name, destination IPv6 address, and an incoming label, the undo static-sr-mpls ipv6 prefix command deletes all IPv6 prefix segments with the specified name, destination IPv6 address, and incoming label. If you specify all parameters, only the IPv6 prefix segment that matches the specified name, destination IPv6 address, and next hop or output interface is deleted.
# Configure prefix segment prefix1, specify the destination IPv6 address, incoming label, outgoing label, and next hop as 2::2, 16000, 16001, and 1::2, respectively.
[Sysname] static-sr-mpls ipv6 prefix prefix1 destination 2::2 128 in-label 16000 nexthop 1::2 out-label 16001
static-sr-mpls lsp
tunnel-bfd detect-multiplier
Use tunnel-bfd detect-multiplier to set the tunnel BFD detection time multiplier for SRLSPs.
Use undo tunnel-bfd detect-multiplier to restore the default.
tunnel-bfd detect-multiplier value
The tunnel BFD detection time multiplier is not set for SRLSPs and the setting for the bfd multi-hop detect-multiplier command applies.
value: Specifies a detection time multiplier, which is the maximum number of consecutive BFD packets that can be discarded. The value range for this argument is 3 to 50.
The device sends BFD packets periodically to a peer. If the device does not receive BFD packets from the peer within the detection time, it determines that the BFD session with the peer has gone down.
The actual detection time is the detection time multiplier of the receiver multiplied by the actual BFD packet transmitting interval of the receiver.
This command takes effect only on the BFD sessions created by the tunnel-bfd enable command.
# Set the BFD detection time multiplier to 3.
[Sysname-segment-routing] tunnel-bfd detect-multiplier 3
tunnel-bfd enable
tunnel-bfd enable
Use tunnel-bfd enable to enable tunnel BFD for all SRLSPs.
Use undo tunnel-bfd enable to restore the default.
tunnel-bfd enable [ prefix-list prefix-list-name ] [ echo | nil-fec ]
Tunnel BFD is not enabled to verify the connectivity of SRLSPs.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by the prefix list name, a case-sensitive string of 1 to 63 characters. The device can create tunnel BFD sessions only for the SRLSPs permitted by the specified IPv4 prefix list. If you do not specify an IPv4 prefix list, the device can create tunnel BFD sessions for all SRLSPs.
echo: Specifies the BFD echo packet mode. If you do not specify this keyword, the BFD control packet mode is used to verify SRLSP connectivity.
nil-fec: Encapsulates the Nil FEC in MPLS echo request packets when BFD control packet mode is used to detect SRLSPs. In LDP to SR interworking mode, the ingress node (source node) cannot determine whether the LDP LSP is connected to the SRLSP. When the ingress node uses MPLS BFD to detect LSPs, it encapsulates LDP FEC in MPLS echo request packets, which will fail the FEC type verification on the egress node (end-point node). Then, the BFD session will go down. To resolve this issue, specify the nil-fec keyword to enable the ingress node to encapsulate the Nil FEC in MPLS echo request packets. The egress node will not check the FEC type of packets encapsulated with the Nil FEC.
This command establishes tunnel BFD sessions to verify the connectivity of all SRLSPs.
A tunnel BFD session is a BFD session established for the primary and backup SRLSPs of a specific FEC (destination IP/mask). The BFD session is up as long as an SRLSP is available for the FEC. If both the primary and backup SRLSPs for the FEC are faulty, the BFD session goes down. BFD then quickly triggers a protection measure (such as MPLS L3VPN FRR) to switch traffic to other forwarding paths to reduce traffic loss.
If you configure both the mpls tunnel-bfd command for an SRLSP and the tunnel-bfd enable command for all SRLSPs, the mpls tunnel-bfd command takes effect for that SRLSP.
# Enable tunnel BFD to verify the connectivity of all SRLSPs.
[Sysname-segment-routing] tunnel-bfd enable
mpls tunnel-bfd (for LSP) (MPLS Command Reference)
tunnel-bfd min-echo-receive-interval
Use tunnel-bfd min-echo-receive-interval to set the minimum interval for receiving BFD echo packets for SRLSP tunnel BFD.
Use undo tunnel-bfd min-echo-receive-interval to restore the default.
tunnel-bfd min-echo-receive-interval interval
The minimum interval for receiving BFD echo packets is not set for SRLSP tunnel BFD. The interval set by the bfd multi-hop min-echo-receive-interval command applies.
interval: Specifies the minimum interval for receiving BFD echo packets, in milliseconds. The value range is 3 to 10000.
The interval for receiving BFD echo packets is also the interval for sending BFD echo packets. By executing this command, you can control both the receiving interval and sending interval for BFD echo packets.
This command takes effect only on the echo mode BFD sessions created by the tunnel-bfd enable command.
# Set the minimum BFD echo packet receiving interval for SRLSP tunnel BFD to 450 milliseconds.
[Sysname-segment-routing] tunnel-bfd min-echo-receive-interval 450
bfd multi-hop min-echo-receive-interval (High Availability Command Reference)
tunnel-bfd enable
tunnel-bfd min-receive-interval
Use tunnel-bfd min-receive-interval to set the minimum BFD packet receiving interval for SRLSP tunnel BFD.
Use undo tunnel-bfd min-receive-interval to restore the default.
tunnel-bfd min-receive-interval interval
The minimum interval for receiving BFD packets is not set for SRLSP tunnel BFD. The setting for the bfd multi-hop min-receive-interval command applies.
interval: Specifies the minimum interval for receiving BFD packets, in milliseconds. The value range is 3 to 10000.
The actual BFD packet transmitting interval on the peer end is the greater value between the following values:
· Minimum interval for transmitting BFD packets on the peer end.
· Minimum interval for receiving BFD packets on the local end.
# Set the minimum BFD packet receiving interval to 30 milliseconds for SRLSP tunnel BFD.
[Sysname-segment-routing] tunnel-bfd min-receive-interval 30
tunnel-bfd enable
tunnel-bfd min-transmit-interval
Use tunnel-bfd min-transmit-interval to set the minimum BFD packet transmitting interval for SRLSP tunnel BFD.
Use undo tunnel-bfd min-transmit-interval to restore the default.
tunnel-bfd min-transmit-interval interval
The minimum interval for transmitting BFD packets is not set for tunnel BFD. The setting for the bfd multi-hop min-transmit-interval command applies.
interval: Specifies the minimum interval for transmitting BFD packets, in milliseconds. The value range is 3 to 10000.
Use this command to prevent the BFD packet sending rate from exceeding the packet receiving rate of the peer end.
The actual BFD packet transmitting interval on the local end is the greater value between the following values:
· Minimum interval for transmitting BFD packets on the local end.
· Minimum interval for receiving BFD packets on the peer end.
# Set the minimum BFD packet transmitting interval to 30 milliseconds for SRLSP tunnel BFD.
[Sysname-segment-routing] tunnel-bfd min-transmit-interval 30
tunnel-bfd enable
