- 16-Security Configuration Guide
- 01-Keychain configuration
- 02-Public key management
- 03-PKI configuration
- 04-Crypto engine configuration
- 05-SSH configuration
- 06-SSL configuration
- 07-Packet filter configuration
- 08-DHCP snooping configuration
- 09-DHCPv6 snooping configuration
- 10-ARP attack protection configuration
- 11-ND attack defense configuration
- 12-Attack detection and prevention configuration
- 13-IP source guard configuration
- 14-uRPF configuration
- 15-MACsec configuration
| 02-Public key management | 138.39 KB |
Asymmetric key algorithm overview
Usage of asymmetric key algorithms
Public key management tasks at a glance
Distributing a local host public key
About distribution of local host public keys
Configuring a peer host public key
About peer host public key configuration
Restrictions and guidelines for peer host public key configuration
Importing a peer host public key from a public key file
Entering a peer host public key
Verifying and maintaining public keys
Examples of public key management
Managing public keys
About public key management
This chapter describes public key management for the following asymmetric key algorithms:
· Revest-Shamir-Adleman Algorithm (RSA).
· Digital Signature Algorithm (DSA).
· Elliptic Curve Digital Signature Algorithm (ECDSA).
Asymmetric key algorithms are used by security applications to secure communications between two parties, as shown in Figure 1. Asymmetric key algorithms use two separate keys (one public and one private) for encryption and decryption. Symmetric key algorithms use only one key.
Figure 1 Encryption and decryption
A key owner can distribute the public key in plain text on the network but must keep the private key in privacy. It is mathematically infeasible to calculate the private key even if an attacker knows the algorithm and the public key.
Security applications (such as SSH, SSL, and PKI) use the asymmetric key algorithms for the following purposes:
· Encryption and decryption—Any public key receiver can use the public key to encrypt information, but only the private key owner can decrypt the information.
· Digital signature—The key owner uses the private key to digitally sign information to be sent. The receiver decrypts the information with the sender's public key to verify information authenticity.
RSA, DSA, and ECDSA can all perform digital signature, but only RSA can perform encryption and decryption.
To manage public keys, perform the following tasks:
3. Distributing a local host public key
¡ Displaying a host public key
To enable the peer device to authenticate the local device, you must distribute the local device's public key to the peer device.
4. Configuring a peer host public key
¡ Importing a peer host public key from a public key file
¡ Entering a peer host public key
To encrypt information sent to a peer device or authenticate the digital signature of the peer device, you must configure the peer device's public key on the local device.
5. (Optional.) Destroying a local key pair
6. (Optional.) Configuring master keys
Creating a local key pair
When you create a local key pair, follow these guidelines:
· The key algorithm must be the same as required by the security application.
· When you create an RSA or DSA key pair, enter an appropriate key modulus length at the prompt. The longer the key modulus length, the higher the security, and the longer the key generation time.
When you create an ECDSA key pair, choose the appropriate elliptic curve. The elliptic curve determines the ECDSA key length. The longer the key length, the higher the security, and the longer the key generation time.
See Table 1 for more information about key modulus lengths and key lengths.
· If you do not assign the key pair a name, the system assigns the default name to the key pair and marks the key pair as default. You can also assign the default name to another key pair, but the system does not mark the key pair as default. The key pair name must be unique among all manually named key pairs that use the same key algorithm. If a name conflict occurs, the system asks whether you want to overwrite the existing key pair.
· The key pairs are automatically saved and can survive system reboots.
Table 1 A comparison of different types of asymmetric key algorithms
Type |
Generated key pairs |
Modulus/key length |
RSA |
· One host key pair, if you specify a key pair name. · One server key pair and one host key pair, if
you do not specify a key pair name. NOTE: Only SSH 1.5 uses the RSA server key pair. |
Key modulus length: 512 to 2048 bits. Default: 1024 bits. To ensure security, use a minimum of 768 bits. |
DSA |
One host key pair. |
ECDSA |
Key length: 192, 256, 384, or 521 bits. |
1. Enter system view.
2. Create a local key pair.
public-key local create { dsa | ecdsa [ secp192r1 | secp256r1 | secp384r1 | secp521r1 ] | rsa } [ name key-name ]
Importing a local key pair
This task imports a key pair from a key pair file to the device. The imported key pairs are automatically saved and can survive system reboots.
Perform this task when the key pair to be imported is saved in a different file than the certificate. If the key pair and the certificate are saved in the same file, the device can obtain the key pair by importing the certificate.
The device supports importing the RSA host key pair but not the RSA server key pair.
If you do not assign the key pair a name, the system assigns the default name to the key pair and marks the key pair as default. You can also assign the default name to another key pair, but the system does not mark the key pair as default. The name of a key pair must be unique among all manually named key pairs that use the same key algorithm. If a name conflict occurs, the system asks whether you want to overwrite the existing key pair.
To import the encrypted key pair into the device successfully, provide the decryption password.
See Table 2 for information about supported key modulus lengths and key lengths.
Type |
RSA |
Key modulus length: 512 to 2048 bits. |
ECDSA |
Before performing this task, save the key pair file to the local storage directory of the device through FTP or other methods.
2. Import a local key pair.
public-key local import { ecdsa | rsa } [ key-name ] filename filename
You must distribute a local host public key to a peer device so the peer device can perform the following operations:
· Use the public key to encrypt information sent to the local device.
· Authenticate the digital signature signed by the local device.
To distribute a local host public key, you must first export or display the key.
· Export a host public key:
¡ Export a host public key to a file.
¡ Export a host public key to the monitor screen, and then save it to a file.
After the key is exported to a file, transfer the file to the peer device. On the peer device, import the key from the file.
· Display a host public key.
After the key is displayed, record the key, for example, copy it to an unformatted file. On the peer device, you must literally enter the key.
Exporting a host public key
When you export a host public key, follow these restrictions and guidelines:
· If you specify a file name in the command, the command exports the key to the specified file.
· If you do not specify a file name, the command exports the key to the monitor screen. You must manually save the exported key to a file.
2. Export a local host public key.
¡ Export an RSA host public key:
public-key local export rsa [ name key-name ] { openssh | ssh1 | ssh2 } [ filename ]
¡ Export an ECDSA host public key.
public-key local export ecdsa [ name key-name ] { openssh | ssh2 } [ filename ]
¡ Export a DSA host public key.
public-key local export dsa [ name key-name ] { openssh | ssh2 } [ filename ]
Perform the following tasks in any view:
· Display local RSA public keys.
display public-key local rsa public [ name key-name ]
Do not distribute the RSA server public key serverkey (default) to a peer device.
· Display local ECDSA public keys.
display public-key local ecdsa public [ name key-name ]
· Display local DSA public keys.
display public-key local dsa public [ name key-name ]
You can configure the peer host public key by using the following methods:
· Import the peer host public key from a public key file (recommended).
· Manually enter (type or copy) the peer host public key.
For information about how to obtain the host public key of a device, see "Distributing a local host public key."
When you configure a peer host public key, follow these restrictions and guidelines:
· When you manually enter the peer host public key, make sure the entered key is in the correct format. To obtain the peer host public key in the correct format, use the display public-key local public command to display the public key on the peer device and record the key. The format of the public key displayed in any other way might be incorrect. If the key is not in the correct format, the system discards the key and displays an error message.
· Always import rather than enter the peer host public key if you are not sure whether the device supports the format of the recorded peer host public key.
Before you perform this task, make sure you have exported the host public key to a file on the peer device and obtained the file from the peer device. For information about exporting a host public key, see "Exporting a host public key."
After you import the key, the system automatically converts the imported public key to a string in the Public Key Cryptography Standards (PKCS) format.
2. Import a peer host public key from a public key file.
public-key peer keyname import sshkey filename
By default, no peer host public keys exist.
Before you perform this task, make sure you have displayed the key on the peer device and recorded the key. For information about displaying a host public key, see "Displaying a host public key."
2. Specify a name for the peer host public key and enter public key view.
3. Type or copy the key.
You can use spaces and carriage returns, but the system does not save them.
4. Exit public key view.
peer-public-key end
When you exit public key view, the system automatically saves the peer host public key.
To ensure security, destroy the local key pair and generate a new key pair in any of the following situations:
· The local key has leaked. An intrusion event might occur.
· The storage media of the device is replaced.
· The local certificate has expired. For more information about local certificates, see "Configuring PKI."
2. Destroy a local key pair.
public-key local destroy { dsa | ecdsa | rsa } [ name key-name ]
Setting a master key
By default, a device uses the unified default master key to encrypt the key strings configured for each service module on the device. After you load the exported configuration file of a device on another device, you can use the default master key to decrypt and obtain the configured key strings. In this way, keys can be copied between devices, bringing security risks.
To improve the security and reliability of data, you can set a master key for the device. After you configure this feature on the device, you need to configure the relevant settings as prompted:
1. Validate your identity:
¡ If the login authentication mode is password or scheme, the CLI prompts you to enter your password for login. After you pass the authentication, you go to step 2.
¡ If the login authentication mode is none, you do not need to perform identity authentication but go to step 2 directly.
For more information about login authentication modes, see login management in Fundamentals Configuration Guide.
2. Select whether to enter the master key:
¡ If you enter N or n, the device will automatically and randomly generate a master key.
¡ If you enter Y or y, manually enter the prepared master key and confirm it.
The device stores the master key in the hard disk. Power-off or reboot of the device will not affect the set master key. The device uses the master key to encrypt the key strings configured for each service module on the device.
You can only use the display master-key type command to view the type of the master key. You cannot view or obtain the value of the master key by any means. This prevents copying the keys on the device to another device.
IMPORTANT: · This feature is supported only in Release R5210 and later. · A device configured with the master key feature cannot be rolled back to release earlier than R5210. |
When the storage space for master keys is insufficient, the device prompts whether to overwrite the oldest master key.
When the login authentication mode is password or scheme, you will be logged off after three consecutive authentication failures and thus cannot perform master key-related operations.
After you execute the set master-key command to set a master key, you must wait for more than 3 minutes before you can set a master key again or clear master keys (through the clear master-key command).
To manually enter a master key, prepare the master key and keep it safe before configuring this feature.
2. Set a master key.
set master-key
Clearing master keys
You can configure this feature to clear master keys in the following situations:
· You do not need to use the master key feature.
· The storage space for master keys is insufficient, and you want to clear existing master keys to release storage space.
On the device, the current active master key is Active1, the last active master key is Active2, and other configured master keys are history master keys.
If the default master key uses the fixed factory default value, executing this command once clears all history master keys, and sets the value of Active1 to the default master key value and that of Active2 to the former Active1 value. If you execute this command for the second time consecutively, Active2 will be cleared and only Active1 is reserved.
After you execute the clear master-key command to clear master keys, you must wait for more than 3 minutes before you can clear master keys again or set a master key (through the set master-key command).
2. Clear master keys.
clear master-key
Perfrom all display tasks in any view.
· Display local public keys.
display public-key local { dsa | ecdsa | rsa } public [ name key-name ]
· Display peer host public keys.
display public-key peer [ brief | name publickey-name ]
· Display information about the device's master keys.
display master-key info slot slot-number
· Display the type of the current master key.
Example: Entering a peer host public key
As shown in Figure 2, to prevent illegal access, Device B authenticates Device A through a digital signature. Before configuring authentication parameters on Device B, use the following procedure to configure the public key of Device A on Device B:
· Create RSA key pairs on Device A and display the public keys of the RSA key pairs.
· Manually specify the RSA host public key of Device A on Device B.
1. Assign IP addresses to interfaces and make sure the network connections are available. (Details not shown.)
2. Configure Device A:
# Create local RSA key pairs with the default names on Device A, and use the default key modulus length (1024 bits).
[DeviceA] public-key local create rsa
The range of public key modulus is (512 ~ 2048).
If the key modulus is greater than 512, it will take a few minutes.
Press CTRL+C to abort.
Generating Keys...
# Display all local RSA public keys.
[DeviceA] display public-key local rsa public
Key name: hostkey (default)
Key type: RSA
Key length: 1024
Time when key pair created: 16:48:31 2011/05/12
Key code:
30819F300D06092A864886F70D010101050003818D0030818902818100DA3B90F59237347B
8D41B58F8143512880139EC9111BFD31EB84B6B7C7A1470027AC8F04A827B30C2CAF79242E
45FDFF51A9C7E917DB818D54CB7AEF538AB261557524A7441D288EC54A5D31EFAE4F681257
6D7796490AF87A8C78F4A7E31F0793D8BA06FB95D54EBB9F94EB1F2D561BF66EA27DFD4788
CB47440AF6BB25ACA50203010001
Key name: serverkey (default)
Key type: RSA
Key length: 768
Key code:
307C300D06092A864886F70D0101010500036B003068026100C9451A80F7F0A9BA1A90C7BC
1C02522D194A2B19F19A75D9EF02219068BD7FD90FCC2AF3634EEB9FA060478DD0A1A49ACE
E1362A4371549ECD85BA04DEE4D6BB8BE53B6AED7F1401EE88733CA3C4CED391BAE633028A
AC41C80A15953FB22AA30203010001
3. Configure Device B:
# Enter the host public key of Device A in public key view. The key must be literally the same as displayed on Device A.
[DeviceB] public-key peer devicea
Enter public key view. Return to system view with "peer-public-key end" command.
[DeviceB-pkey-public-key-devicea]30819F300D06092A864886F70D010101050003818D003081890
[DeviceB-pkey-public-key-devicea]8D41B58F8143512880139EC9111BFD31EB84B6B7C7A1470027A
[DeviceB-pkey-public-key-devicea]45FDFF51A9C7E917DB818D54CB7AEF538AB261557524A7441D2
[DeviceB-pkey-public-key-devicea]6D7796490AF87A8C78F4A7E31F0793D8BA06FB95D54EBB9F94E
[DeviceB-pkey-public-key-devicea]CB47440AF6BB25ACA50203010001
# Save the public key and return to system view.
[DeviceB-pkey-public-key-devicea] peer-public-key end
# Verify that the peer host public key configured on Device B is the same as the key displayed on Device A.
[DeviceB] display public-key peer name devicea
Key name: devicea
Key type: RSA
Key length: 1024
Key code:
Example: Importing a public key from a public key file
As shown in Figure 3, Device B authenticates Device A through a digital signature. Before configuring authentication parameters on Device B, use the following procedure to configure the public key of Device A on Device B:
· Create RSA key pairs on Device A and export the RSA host public key to a file.
· Import the RSA host public key of Device A from the public key file to Device B.
Generating Keys...
Key type: RSA
Key length: 1024
Key code:
Key type: RSA
Key length: 768
Key code:
# Export the RSA host public key to file devicea.pub.
[DeviceA] public-key local export rsa ssh2 devicea.pub
# Enable the FTP server, create an FTP user with username ftp and password 123456TESTplat&!, and configure the FTP user role as network-admin.
[DeviceA] ftp server enable
[DeviceA] local-user ftp
[DeviceA-luser-manage-ftp] password simple 123456TESTplat&!
[DeviceA-luser-manage-ftp] service-type ftp
[DeviceA-luser-manage-ftp] authorization-attribute user-role network-admin
[DeviceA-luser-manage-ftp] quit
# Use FTP in binary mode to get public key file devicea.pub from Device A.
<DeviceB> ftp 10.1.1.1
Connected to 10.1.1.1 (10.1.1.1).
220 FTP service ready.
User(10.1.1.1:(none)):ftp
331 Password required for ftp.
Password:
230 User logged in.
Remote system type is UNIX.
Using binary mode to transfer files.
ftp> binary
200 TYPE is now 8-bit binary
ftp> get devicea.pub
227 Entering Passive Mode (10,1,1,1,118,252)
150 Accepted data connection
226 File successfully transferred
301 bytes received in 0.003 seconds (98.0 kbyte/s)
ftp> quit
221-Goodbye. You uploaded 0 and downloaded 1 kbytes.
221 Logout.
# Import the host public key from key file devicea.pub.
[DeviceB] public-key peer devicea import sshkey devicea.pub
Key name: devicea
Key type: RSA
Key length: 1024
Key code:
