| 03-Data buffer commands | 89.94 KB |
buffer packet-drop alarm enable
buffer packet-drop alarm interval
buffer threshold alarm interval
buffer usage threshold headroom
buffer usage threshold headroom queue
buffer usage threshold queue (interface view)
buffer usage threshold queue (system view)
display buffer usage interface
Inappropriate data buffer changes can cause system problems. Before manually changing data buffer settings, make sure you understand its impact on your device. As a best practice, use the burst-mode enable command if the system requires large buffer spaces. The burst-mode enable command and the buffer apply command are mutually exclusive. If you have configured the data buffer by using one command, you must execute the undo form of the command before using the other command.
Use buffer packet-drop alarm enable to enable packet-drop alarms.
Use undo buffer packet-drop alarm enable to disable packet-drop alarms.
Packet-drop alarms are disabled.
The device generates and reports packet-drop alarms to a network management system (such as IMC) for displaying the data buffer usage.
This command does not take effect only on the Headroom buffer.
# Enable packet-drop alarms.
[Sysname] buffer packet-drop alarm enable
Use buffer packet-drop alarm interval to set the interval for sending packet-drop alarms.
Use undo buffer packet-drop alarm interval to restore the default.
buffer packet-drop alarm interval interval
The interval for sending packet-drop alarms is 5 seconds.
interval: Specifies the interval for sending packet-drop alarms, in the range of 0 to 60 seconds. The value of 0 indicates that packet-drop alarms are sent immediately after they are generated.
This command takes effect only when packet-drop alarms are enabled.
# Set the interval for sending packet-drop alarms to 20 seconds.
[Sysname] buffer packet-drop alarm interval 20
buffer threshold alarm enable
Use buffer threshold alarm enable to enable threshold-crossing alarms.
Use undo buffer threshold alarm enable to disable threshold-crossing alarms.
buffer threshold alarm { egress | headroom | ingress } enable
undo buffer threshold alarm { egress | headroom | ingress } enable
Threshold-crossing alarms are disabled.
ingress: Specifies the ingress buffer.
headroom: Specifies the Headroom buffer.
egress: Specifies the egress buffer.
The device generates and reports threshold-crossing alarms to a network management system (such as IMC) for displaying the data buffer usage.
The alarm threshold for the Headroom buffer is fixed at 100% and is not configurable.
# Enable threshold-crossing alarms.
[Sysname] buffer threshold alarm ingress enable
Use buffer threshold alarm interval to set the interval for sending threshold-crossing alarms.
Use undo buffer threshold alarm interval to restore the default.
buffer threshold alarm { egress | headroom | ingress } interval interval
undo buffer threshold alarm { egress | headroom | ingress } interval
The interval for sending threshold-crossing alarms is 5 seconds.
interval: Specifies the interval for sending threshold-crossing alarms, in the range of 0 to 60 seconds. 0 indicates that threshold-crossing alarms are sent immediately after they are generated.
This command takes effect only when threshold-crossing alarms are enabled.
# Set the interval for sending threshold-crossing alarms to 20 seconds.
[Sysname] buffer threshold alarm ingress interval 20
Use buffer usage threshold to set a per-interface buffer usage threshold.
Use undo buffer usage threshold to restore the default.
buffer usage threshold slot slot-number ratio ratio
undo buffer usage threshold slot slot-number
The per-interface buffer usage threshold is 100%.
slot slot-number: Specifies a card by its slot number.
ratio ratio: Specifies the buffer usage threshold in percentage, in the range of 1 to 100.
After you configure this command, the switch automatically records buffer usage for each interface. When a queue on an interface uses more buffer space than the set threshold, the system counts one threshold violation for the queue.
To display the buffer usage statistics for interfaces, use the display buffer usage interface command.
# Set the per-interface buffer usage threshold to 50% for card 3.
[Sysname] buffer usage threshold slot 3 ratio 50
Use buffer usage threshold headroom to set the global per-queue alarm threshold for the Headroom buffer.
Use undo buffer usage threshold headroom to restore the default.
buffer usage threshold headroom slot slot-number ratio ratio
undo buffer usage threshold headroom slot-number ratio
The global per-queue alarm threshold for the Headroom buffer is 100%.
ratio ratio: Specifies the alarm threshold in percentage, in the range of 1 to 100.
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the global alarm threshold for the Headroom buffer, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
This command is supported only for interface cards.
# Set the global per-queue alarm threshold to 50% for slot 1.
[Sysname] buffer usage threshold headroom slot 1 ratio 50
Use buffer usage threshold headroom queue to set the Headroom buffer alarm threshold for a queue on an interface.
Use undo buffer usage threshold headroom queue to restore the default.
buffer usage threshold headroom queue queue-id ratio ratio
undo buffer usage threshold headroom queue queue-id ratio
The global per-queue alarm threshold for the Headroom buffer is used.
Interface view
queue-id: Specifies a queue by its ID in the range of 0 to 7.
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the alarm threshold, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the Headroom buffer alarm threshold to 50% for queue 1 on HundredGigE 1/0/1.
[Sysname–HundredGigE1/0/1] buffer usage threshold headroom queue 1 ratio 50
Use buffer usage threshold queue to set the ingress or egress buffer alarm threshold for a queue on an interface.
Use undo buffer usage threshold queue to restore the default.
buffer { egress | ingress } usage threshold queue queue-id ratio ratio
undo buffer { egress | ingress } usage threshold queue queue-id ratio
The global per-queue alarm threshold for the ingress or egress buffer is used.
Interface view
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the alarm threshold for the ingress or egress buffer, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the ingress buffer alarm threshold to 50% for queue 1 on HundredGigE 1/0/1.
[Sysname–HundredGigE1/0/1] buffer ingress usage threshold queue 1 ratio 50
Use buffer usage threshold queue to set the global ingress or egress buffer alarm threshold for a queue.
buffer { egress | ingress } usage threshold slot slot-number queue queue-id ratio ratio
undo buffer { egress | ingress } usage threshold slot slot-number queue queue-id ratio
The global ingress or egress buffer alarm threshold for a queue is 100%.
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the global ingress or egress alarm threshold, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the global ingress alarm threshold to 50% for queue 1 in slot 1.
[Sysname] buffer ingress usage threshold slot 1 queue 1 ratio 50
burst-mode enable
Use burst-mode enable to enable the Burst feature.
Use undo burst-mode enable to disable the Burst feature.
burst-mode enable
The Burst feature is disabled.
The Burst feature is especially useful for reducing packet losses under the following circumstances:
· Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
· Traffic enters a device from a high-speed interface and goes out of a low-speed interface.
· Traffic enters a device from multiple same-rate interfaces and goes out of an interface with the same rate.
# Enable the Burst feature.
[Sysname] burst-mode enable
Use display buffer usage to display buffer usage.
display buffer usage [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays buffer usage for all cards.
# Display buffer usage.
<Sysname> display buffer usage
Egress total-shared cell buffer usage on slot 1 :
XPE 0
Total: 4033 KB
Used: 0 KB
Free: 4033 KB
XPE 1
Total: 4033 KB
Used: 0 KB
Free: 4033 KB
XPE 2
Total: 4033 KB
Used: 0 KB
Free: 4033 KB
XPE 3
Total: 4033 KB
Used: 0 KB
Free: 4033 KB
5sec 1min 5min
Ten-GigabitEthernet1/0/1 XPE 0 0% 0% 0%
XPE 1 0% 0% 0%
XPE 2 0% 0% 0%
XPE 3 0% 0% 0%
Ten-GigabitEthernet1/0/2 XPE 0 0% 0% 0%
XPE 1 0% 0% 0%
XPE 2 0% 0% 0%
XPE 3 0% 0% 0%
Ten-GigabitEthernet1/0/3 XPE 0 0% 0% 0%
XPE 1 0% 0% 0%
XPE 2 0% 0% 0%
XPE 3 0% 0% 0%
Egress total-shared cell buffer usage on slot |
Usage of cell resources in the shared area on a card. |
XPE |
Type of the data buffer. |
Total |
Total size of the data buffer. |
Used |
Size of used data buffer. |
Free |
Size of free data buffer. |
5sec |
Percentage of the buffer that the port used for the last 5 seconds. |
1min |
Percentage of the buffer that the port used for the last 1 minute. |
5min |
Percentage of the buffer that the port used for the last 5 minutes. |
Use display buffer usage interface to display buffer usage statistics for interfaces.
display buffer usage interface [ interface-type [ interface-number ] ] [ verbose ]
interface-type [ interface-number ]: Specifies an interface by its type and number. If you do not specify the interface-type argument, this command displays buffer usage statistics for all Ethernet interfaces. If you specify the interface-type argument without the interface-number argument, this command displays buffer usage statistics for all Ethernet interfaces of the specified type.
verbose: Displays detailed buffer usage statistics. If you do not specify this keyword, the command displays brief buffer usage statistics.
# Display brief buffer usage statistics for HundredGigE 1/0/1.
<Sysname> display buffer usage interface hundredgige 1/0/1
Interface QueueID Total Used Threshold(%) Violations
HGE1/0/1 0 838860800 0 100 0
1 838860800 0 100 0
2 838860800 0 100 0
3 838860800 0 100 0
4 838860800 0 100 0
5 838860800 0 100 0
6 838860800 0 100 0
7 838860800 0 100 0
Total |
Data buffer size in bytes allowed for a queue. |
Used |
Data buffer size in bytes that has been used by a queue. |
Threshold(%) |
Buffer usage threshold for a queue. The threshold value is the same as the per-interface threshold value. |
Violations |
Number of threshold violations for a queue. The value of this field is reset upon a switch reboot. |
# Display detailed buffer usage statistics for HundredGigE 1/0/1.
[Sysname] display buffer usage interface hundredgige 1/0/1 verbose
HGE1/0/1
Ingress:
QueueID: 0
Total: 36 cell 55000 bytes Used: 0 cell 0 bytes
Threshold(%): 3 Violations: 4
Shared: 1 cell 5 bytes Headroom: 6 cell 30 bytes
Xoff threshold: 36 cell 55000 bytes Is dynamic: 0
Used(%): 0 Free: 36 cell 55000 bytes
UsedPeak: 0 cell 0 bytes HeadroomUsed(%): 0
HeadroomFree: 0 cell 0 bytes HeadroomPeak: 0 cell 0 bytes
UsedPeakTime: 2022-04-19 20:20:43 HeadroomPeakTime: 2022-04-19 20:20:43
QueueID: 7
UsedPeakTime: 2022-04-19 21:20:43 HeadroomPeakTime: 2022-04-19 21:20:43
Egress:
QueueID: 0
Threshold(%): 22 Violations: 12
TailDropThreshold: 1 cell 13 bytes Is dynamic: 0
DeadlockCount: 0 DeadlockRecover: 0
UsedPeak: 0 cell 0 bytes UsedPeakTime: -
QueueID: 7
Ingress |
Usage statistics for the ingress buffer. |
Egress |
Usage statistics for the egress buffer. |
Total |
Data buffer size allowed for a queue, in the number of cell resources. |
Used |
Data buffer size that has been used by a queue, in the number of cell resources. |
Threshold(%) |
Buffer usage threshold for a queue, which is configured by using the buffer usage threshold queue command. |
Violations |
Shared |
Number of cell resources and bytes in the shared area used by a queue |
Headroom |
Number of cell resources and bytes in the Headroom area used by a queue. When a queue on an interface enabled with PFC enters PFC XOFF state, the interface sends XOFF frames to notify the peer interface to stop sending packets to that queue. Packets sent by the peer interface before it receives XOFF frames are stored in the Headroom area. |
XoffThres |
Back pressure frame triggering threshold. If a dynamic back pressure frame triggering threshold is configured, this field displays a percentage value. If a static back pressure frame triggering threshold is configured, this field displays an absolute value. For commands to configure back pressure frame triggering thresholds, see PFC commands in Layer 2—LAN Switching Command Reference |
TailDropThres |
Tail drop threshold, in the number of cell resources calculated according to the ratio value set in the buffer queue shared command. |
IsDynamic |
For the inbound direction, this field can be one of the following values: · 0—Indicates a static back pressure frame triggering threshold. · 1—Indicates a dynamic back pressure frame triggering threshold. For the outbound direction, this field can only be 1, which indicates a dynamic tail drop threshold. |
Used(%) |
Buffer usage in percentage. |
Free |
Free buffer in the number of cell resources and bytes. |
UsedPeak |
Peak used buffer in the number of cell resources and bytes during the time between two executions of the display buffer usage interface command. |
HeadroomUsed(%) |
Headroom area usage in percentage for the ingress buffer. |
HeadroomFree |
Free Headroom area in the number of cell resources and bytes for the ingress buffer. |
HeadroomPeak |
Peak used Headroom area in the number of cell resources and bytes during the time between two executions of the display buffer usage interface command. |
UsedPeakTime |
Peak time for buffer use. This field displays a hyphen (-) if the buffer is not used. |
HeadroomPeakTime |
Peak time for Headroom buffer use. This field displays a hyphen (-) if the Headroom buffer is not used. |
DeadlockCount |
Number of times the device entered the PFC deadlock state in the egress buffer. |
DeadlockRecover |
Number of times the device released the PFC deadlock state in the egress buffer. |
