12-High Availability
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10012-High Availability
08-VRRP-MIB
08-VRRP-MIB 75.84 KB
VRRP-MIB
About this MIB
This MIB contains general VRRP entries.
MIB file name
rfc2787-vrrp.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).vrrpMIB(68)
Scalar objects
vrrpNodeVersion
Object (OID)
Access
Value range
Implementation
vrrpNodeVersion (1.3.6.1.2.1.68.1.1)
read-only
Integer32
Standard MIB values.
VRRP version
As per the MIB.
vrrpNotificationCntl
Object (OID)
Access
Value range
Implementation
vrrpNotificationCntl (1.3.6.1.2.1.68.1.2)
read-write
INTEGER
enabled (1),
disabled (2)
Whether SNMP notifications is enabled for VRRP.
As per the MIB.
vrrpTrapPacketSrc
Object (OID)
Access
Value range
Implementation
vrrpTrapPacketSrc (1.3.6.1.2.1.68.1.5)
accessible-for-notify
IpAddress
OCTET STRING (4)
IP address of the received VRRP packet.
As per the MIB.
vrrpTrapAuthErrorType
Object (OID)
Access
Value range
Implementation
vrrpTrapAuthErrorType (1.3.6.1.2.1.68.1.6)
INTEGER
invalidAuthType (1),
authTypeMismatch (2),
authFailure (3)
Potential types of configuration conflicts.
As per the MIB.
vrrpRouterChecksumErrors
Object (OID)
Access
Value range
Implementation
vrrpRouterChecksumErrors (1.3.6.1.2.1.68.2.1)
read-only
Counter32
Total number of received VRRP advertisement packets with an invalid checksum value.
As per the MIB.
vrrpRouterVersionErrors
Object (OID)
Access
Value range
Implementation
vrrpRouterVersionErrors (1.3.6.1.2.1.68.2.2)
read-only
Counter32
Total number of received VRRP advertisement packets with an unknown or unsupported version number.
As per the MIB.
vrrpRouterVrIdErrors
Object (OID)
Access
Value range
Implementation
vrrpRouterVrIdErrors (1.3.6.1.2.1.68.2.3)
read-only
Counter32
Total number of received VRRP advertisement packets with an invalid virtual router ID.
As per the MIB.
Tabular objects
vrrpOperTable
About this table
Use this table to define operation parameters for a VRRP group.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are ifIndex and vrrpOperVrId.
Object (OID)
Access
Value range
Implementation
vrrpOperVrId (1.3.6.1.2.1.68.1.3.1.1)
not-accessible
VrId
Integer32(1..255)
Virtual router ID of the VRRP group.
As per the MIB.
vrrpOperVirtualMacAddr (1.3.6.1.2.1.68.1.3.1.2)
read-only
MacAddress
OCTET STRING (6)
Virtual MAC address of the VRRP group.
As per the MIB.
vrrpOperState (1.3.6.1.2.1.68.1.3.1.3)
read-only
INTEGER
initialize(1),
backup(2),
master(3)
Current state of the VRRP group.
As per the MIB.
vrrpOperAdminState (1.3.6.1.2.1.68.1.3.1.4)
read-create
INTEGER
up(1),
down(2)
Whether the VRRP group is enabled.
As per the MIB.
vrrpOperPriority (1.3.6.1.2.1.68.1.3.1.5)
read-create
Integer32
Integer32(0..255)
Priority of the device in the VRRP group.
As per the MIB.
vrrpOperIpAddrCount (1.3.6.1.2.1.68.1.3.1.6)
read-only
Integer32
Integer32(0..255)
Number of virtual IP addresses in the VRRP group.
As per the MIB.
vrrpOperMasterIpAddr (1.3.6.1.2.1.68.1.3.1.7)
read-only
IpAddress
OCTET STRING (4)
Real IP address of the master device.
As per the MIB.
vrrpOperPrimaryIpAddr (1.3.6.1.2.1.68.1.3.1.8)
read-create
IpAddress
OCTET STRING (4)
Object used to specify the IP address that will become the vrrpOperMasterIpAddr when the device transitions from backup to master (in the case where the interface has multiple IP addresses).
Supports only the read operation.
vrrpOperAuthType (1.3.6.1.2.1.68.1.3.1.9)
read-create
INTEGER
noAuthentication(1),
simpleTextPassword(2),
ipAuthenticationHeader(3)
Authentication mode used for authenticating VRRP packets
Not supported.
vrrpOperAuthKey (1.3.6.1.2.1.68.1.3.1.10)
read-create
OCTET STRING
OCTET STRING (0..16)
Authentication key.
Not supported.
vrrpOperAdvertisementInterval (1.3.6.1.2.1.68.1.3.1.11)
read-create
Integer32
Integer32(1..255)
VRRP advertisement interval in seconds.
Value range: 1 to 41.
vrrpOperPreemptMode (1.3.6.1.2.1.68.1.3.1.12)
read-create
TruthValue
true(1),
false(2)
Whether the preemptive mode is enabled for the VRRP group.
As per the MIB.
vrrpOperVirtualRouterUpTime (1.3.6.1.2.1.68.1.3.1.13)
read-only
TimeStamp
TimeTicks
Time when the VRRP group transitions from Initialize state to another state.
As per the MIB.
vrrpOperProtocol (1.3.6.1.2.1.68.1.3.1.14)
read-create
INTEGER
ip (1),
bridge (2),
decnet (3),
other (4)
Protocol controlled by the VRRP group.
The value is fixed at ip(1).
vrrpOperRowStatus (1.3.6.1.2.1.68.1.3.1.15)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status of the table.
As per the MIB.
vrrpAssoIpAddrTable
About this table
This table contains the virtual IP addresses associated with VRRP groups.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are ifIndex, vrrpOperVrId, and vrrpAssoIpAddr.
Object (OID)
Access
Value range
Implementation
vrrpAssoIpAddr (1.3.6.1.2.1.68.1.4.1.1)
not-accessible
IpAddress
OCTET STRING (4)
Virtual IP address associated with the VRRP group.
As per the MIB.
vrrpAssoIpAddrRowStatus (1.3.6.1.2.1.68.1.4.1.2)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Supports only active(1), createAndgo(4), and destroy(6).
vrrpRouterStatsTable
About this table
This table contains VRRP group statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
vrrpStatsBecomeMaster (1.3.6.1.2.1.68.2.4.1.1)
read-only
Counter32
INTEGER(0..4294967295)
Total number of transitions to master state.
As per the MIB.
vrrpStatsAdvertiseRcvd (1.3.6.1.2.1.68.2.4.1.2)
read-only
Counter32
Total number of received VRRP advertisement packets.
As per the MIB.
vrrpStatsAdvertiseIntervalErrors (1.3.6.1.2.1.68.2.4.1.3)
read-only
Counter32
Total number of received VRRP advertisement packets with a different advertisement interval than the local configuration.
As per the MIB.
vrrpStatsAuthFailures (1.3.6.1.2.1.68.2.4.1.4)
read-only
Counter32
Total number of VRRP advertisement packets that failed to pass authentication.
As per the MIB.
vrrpStatsIpTtlErrors (1.3.6.1.2.1.68.2.4.1.5)
read-only
Counter32
Total number of received VRRP advertisement packets with IP TTL not equal to 255.
As per the MIB.
vrrpStatsPriorityZeroPktsRcvd (1.3.6.1.2.1.68.2.4.1.6)
read-only
Counter32
Total number of received VRRP advertisement packets with a priority of 0.
As per the MIB.
vrrpStatsPriorityZeroPktsSent (1.3.6.1.2.1.68.2.4.1.7)
read-only
Counter32
Total number of sent VRRP advertisement packets with a priority of 0.
As per the MIB.
vrrpStatsInvalidTypePktsRcvd (1.3.6.1.2.1.68.2.4.1.8)
read-only
Counter32
Total number of received VRRP advertisement packets with an invalid value in the type field.
As per the MIB.
vrrpStatsAddressListErrors (1.3.6.1.2.1.68.2.4.1.9)
read-only
Counter32
Total number of received VRRP advertisement packets with an address list that does not match the local configuration.
As per the MIB.
vrrpStatsInvalidAuthType (1.3.6.1.2.1.68.2.4.1.10)
read-only
Counter32
Total number of received VRRP advertisement packets with an unknown authentication type.
As per the MIB.
vrrpStatsAuthTypeMismatch (1.3.6.1.2.1.68.2.4.1.11)
read-only
Counter32
Total number of received VRRP advertisement packets with an authentication type that does not match the local configuration.
As per the MIB.
vrrpStatsPacketLengthErrors (1.3.6.1.2.1.68.2.4.1.12)
read-only
Counter32
Total number of received VRRP advertisement packets with a packet length smaller than that in the VRRP header.
As per the MIB.
Notifications
vrrpTrapNewMaster
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.68.0.1
Indicates that the sending device has transitioned to master state.
Informational
Warning
N/A
ON
A notification sent when the sending device (agent) has transitioned to master state.
Status control
ON
CLI: Use the snmp-agent trap enable vrrp new-master command.
OFF
CLI: Use the undo snmp-agent trap enable vrrp new-master command.
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.68.1.3.1.7 (vrrpOperMasterIpAddr)
Real (primary) IP address of the master router that is used as the source address of VRRP advertisement packets.
No
IpAddress
OCTET STRING (4)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
vrrpTrapAuthFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.68.0.2
Indicates the received VRRP packet contains an authentication type or authentication key that conflicts with the local configuration.
Informational
Warning
N/A
ON
A notification sent upon receiving a VRRP packet from a router with an authentication type or authentication key setting that conflicts with the local router. Implementation of this notification is optional.
Status control
ON
CLI: Use the snmp-agent trap enable vrrp auth-failure command.
OFF
CLI: Use the undo snmp-agent trap enable vrrp auth-failure command.
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.68.1.5 (vrrpTrapPacketSrc)
No
IpAddress
OCTET STRING (4)
1.3.6.1.2.1.68.1.6 (vrrpTrapAuthErrorType)
No
INTEGER
invalidAuthType(1)
authTypeMismatch(2)
authFailure(3)
Recommended action
Check for configuration errors or configuration conflicts.
