12-High Availability
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10012-High Availability
04-HH3C-ERPS-MIB
04-HH3C-ERPS-MIB 60.64 KB
HH3C-ERPS-MIB
About this MIB
HH3C-ERPS-MIB is a private MIB used to implement network management for ERPS. Use this MIB to bind a ring port to an ERPS ring or obtain port state information.
MIB file name
hh3c-erps.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cErps(225)
Notifications
hh3cErpsPortStateForwarding
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.223.1.0.1
The ERPS ring port transitions to forwarding state.
Informational
Warning
N/A
ON
A notification sent when the ERPS ring port state becomes forwarding.
Status control
The notification cannot be disabled.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.223.1.1.1 (hh3cErpsRingID)
ID of the ERPS ring.
N
Integer32
Integer32 (1..255)
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Index of the interface
N
Integer32
Integer32 (1..2147483647)
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Name of the interface.
N
OCTET STRING
OCTET STRING (0..255)
Recommended action
1.     Examine the link attached to the blocked port.
2.     If the issue persists, contact H3C Support.
hh3cErpsPortStateDiscarding
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.223.1.0.2
The ERPS ring port transitions to blocked state.
Informational
N/A
1.3.6.1.4.1.25506.2.223.1.0.1 (hh3cErpsPortStateForwarding)
ON
A notification sent when the ERPS ring port state becomes blocked.
Status control
Objects
OID (object name)
Index
Value range
N
Integer32
Integer32 (1..255)
N
Integer32
N
OCTET STRING
Recommended action
