12-High Availability
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10012-High Availability
03-HH3C-DLDP2-MIB
03-HH3C-DLDP2-MIB 78.79 KB
HH3C-DLDP2-MIB
About this MIB
HH3C-DLDP2-MIB is a private MIB used to implement network management on the DLDP feature. Use this MIB to enable DLDP globally or on a port, and obtain port running state information, link state information, and DLDP neighbor information.
MIB file name
hh3c-dldp2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cDldp2(117)
Scalar objects
hh3cDldp2GlobalEnable
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.117.1.1)
read-write
TruthValue
true(1),
false(2)
Whether DLDP is enabled globally.
As per the MIB.
hh3cDldp2Interval
Object (OID)
Access
Value range
Implementation
hh3cDldp2Interval
(1.3.6.1.4.1.25506.2.117.1.2)
read-write
Integer32
Integer32(1..100)
Advertisement packet sending interval.
As per the MIB.
hh3cDldp2AuthMode
Object (OID)
Access
Value range
Implementation
hh3cDldp2AuthMode
(1.3.6.1.4.1.25506.2.117.1.3)
read-write
INTEGER
unknown(1),
none(2),
simple(3),
md5(4)
Authentication mode.
As per the MIB.
hh3cDldp2AuthPassword
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.117.1.4)
read-write
OCTET STRING
OCTET STRING (0..16)
Authentication password.
As per the MIB.
hh3cDldp2UniShutdown
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.117.1.5)
read-write
INTEGER
unknown(1),             auto(2),                    manual(3)
Port shutdown mode on detecting a unidirectional link.
As per the MIB.
Tabular objects
hh3cDldp2PortConfigTable
About this table
Use this table to enable DLDP on a port and obtain DLDP port configuration information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cDldp2PortEnable
(1.3.6.1.4.1.25506.2.117.2.1.1.1)
read-write
TruthValue
true(1),
false(2)
Whether DLDP is enabled on the port.
As per the MIB.
hh3cDldp2PortStatusTable
About this table
Use this table to obtain DLDP port state and link state information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDldp2PortOperStatus
(1.3.6.1.4.1.25506.2.117.2.2.1.1)
read-only
INTEGER
unknown(1),                   initial(2),             inactive(3),               unidirectional(4),                  bidirectional(5)
Port state.
As per the MIB.
hh3cDldp2PortLinkStatus
(1.3.6.1.4.1.25506.2.117.2.2.1.2)
read-only
INTEGER
unknown(1),
down(2),
up(3)
Link state.
As per the MIB.
hh3cDldp2NeighborTable
About this table
Use this table to obtain neighbor information about a port.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ifIndex, hh3cDldp2NeighborBridgeMac, and hh3cDldp2NeighborPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cDldp2NeighborBridgeMac (1.3.6.1.4.1.25506.2.117.2.3.1.1)
not-accessible
MacAddress
OCTET STRING (6)
Bridge MAC address of the neighbor.
As per the MIB.
hh3cDldp2NeighborPortIndex(1.3.6.1.4.1.25506.2.117.2.3.1.2)
not-accessible
Integer32
Integer32(1..2147483647)
Port index of the neighbor.
As per the MIB.
hh3cDldp2NeighborStatus (1.3.6.1.4.1.25506.2.117.2.3.1.3)
read-only
INTEGER
unknown(1),            unconfirmed(2),                  confirmed(3)
State of the neighbor.
As per the MIB.
hh3cDldp2NeighborAgingTime (1.3.6.1.4.1.25506.2.117.2.3.1.4)
read-only
Integer32
Standard MIB values.
Aging time of the neighbor.
As per the MIB.
Notifications
This section contains trap notifications.
hh3cDldp2TrapUniLink
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.117.4.0.1
This notification is generated when DLDP detects unidirectional links.
Failure
Major
ON
A notification sent when DLDP detects unidirectional links.
Status control
The notification cannot be disabled.
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Interface index.
Y
InterfaceIndex
1..2147483647
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Interface description.
N
DisplayString
OCTET STRING (SIZE (0..255))
Recommended action
Disable the interface, and restore the unidirectional links. If the issue cannot be resolved, contact H3C Support.
hh3cDldp2TrapBidLink
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.117.4.0.2
This notification is generated when DLDP detects bidirectional links.
Failure recovery
ON
A notification sent when DLDP detects bidirectional links.
Status control
Objects
OID (object name)
Index
Value range
Interface index.
Y
InterfaceIndex
1..2147483647
N
DisplayString
Recommended action
No action is required.
