07-HH3C-SMLK-MIB | 73.70 KB |
HH3C-SMLK-MIB
About this MIB
HH3C-SMLK-MIB is a private MIB defined to implement network management on the Smart Link feature. You can use this MIB to create, modify, and delete smart link groups. Smart link group settings include preemption mode, control VLAN, and protected VLAN. You can also configure primary and secondary ports for a smart link group, configure the flush message receiving function, and obtain configuration information.
MIB file name
hh3c-smlk.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cSmlk(147)
Tabular objects
hh3cSmlkGroupTable
About this table
Use this table to obtain and set basic smart link group information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
If a valid value is set for hh3cSmlkSpeedThreshold, hh3cSmlkPreemptionMode must be set to speed. hh3cSmlkInstanceListLow and hh3cSmlkInstanceListHigh are optional. If configuration is required, they must be both configured.
If a valid value is set for hh3cSmlkSpeedThreshold, hh3cSmlkPreemptionMode must be set to speed. hh3cSmlkInstanceListLow and hh3cSmlkInstanceListHigh must be both configured. If member ports are configured for a smart link group, hh3cSmlkInstanceListLow and hh3cSmlkInstanceListHigh cannot be both set to 0. |
To delete a smart link group with member ports configured, delete the member ports from the group first. |
Supported |
Columns
The table index is hh3cSmlkGroupID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSmlkGroupID (1.3.6.1.4.1.25506.2.147.1.1.1.1) |
accessible-for-notify |
Integer32 |
Integer32(1..256) |
Table index. |
Smart link group ID. The valid value range is 1 to 256. Supported value varies by device model. |
hh3cSmlkDeviceID (1.3.6.1.4.1.25506.2.147.1.1.1.2) |
read-only |
MacAddress |
OCTET STRING (6) |
Device ID. |
As per the MIB. |
hh3cSmlkPreemptionMode (1.3.6.1.4.1.25506.2.147.1.1.1.3) |
read-create |
INTEGER |
none(1), role(2), speed(3) |
Preemption mode. |
As per the MIB. |
hh3cSmlkSpeedThreshold (1.3.6.1.4.1.25506.2.147.1.1.1.4) |
read-create |
Integer32 |
Integer32(0..10000) |
Speed preemption threshold that applies only to speed preemption mode. |
Default: 0. The value takes effect when hh3cSmlkPreemptionMode is set to speed. |
hh3cSmlkPreemptionDelay (1.3.6.1.4.1.25506.2.147.1.1.1.5) |
read-create |
Integer32 |
Integer32(0..300) |
Preemption delay. |
As per the MIB. |
hh3cSmlkControlVlanID (1.3.6.1.4.1.25506.2.147.1.1.1.6) |
read-create |
Integer32 |
Integer32(1..4094|65535) |
Control VLAN. |
Default: 1. The value 65535 is invalid, indicating not configured. |
hh3cSmlkInstanceListLow (1.3.6.1.4.1.25506.2.147.1.1.1.7) |
read-create |
OCTET STRING |
OCTET STRING (256) |
Low bits of MSTIs mapped to protected VLANs. |
As per the MIB. |
hh3cSmlkInstanceListHigh (1.3.6.1.4.1.25506.2.147.1.1.1.8) |
read-create |
OCTET STRING |
High bits of MSTIs mapped to protected VLANs. |
As per the MIB. |
hh3cSmlkGroupRowStatus (1.3.6.1.4.1.25506.2.147.1.1.1.9) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
hh3cSmlkPortTable
About this table
Use this table to obtain and set Smart Link port information.
Create |
Edit/Modify |
Delete |
Read |
Before creating hh3cSmlkPortTable, you must create protected VLANs. Do not enable STP, RRPP, or ERPS for the port. When assigning a port to multiple smart link groups, configure each group with a different protected VLAN. Port roles must be specified for the smart link group. |
Once set, the port roles of the smart link group cannot be modified. |
Supported |
Supported |
Columns
The table indexes are hh3cSmlkGroupID and hh3cSmlkPortIfIndx.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSmlkPortIfIndex (1.3.6.1.4.1.25506.2.147.1.2.1.1) |
InterfaceIndex |
Integer32 (1..2147483647) |
Interface index of the smart link group. |
As per the MIB. |
hh3cSmlkPortRole (1.3.6.1.4.1.25506.2.147.1.2.1.2) |
read-create |
INTEGER |
primary(1), secondary(2) |
Port role. |
As per the MIB. |
hh3cSmlkPortStatus (1.3.6.1.4.1.25506.2.147.1.2.1.3) |
read-only |
INTEGER |
down(1), active(2), standby(3) |
Port state. |
As per the MIB. |
hh3cSmlkFlushCount (1.3.6.1.4.1.25506.2.147.1.2.1.4) |
read-only |
Counter64 |
Standard MIB values. |
Number of flush messages sent by the port. |
As per the MIB. |
hh3cSmlkLastFlushTime (1.3.6.1.4.1.25506.2.147.1.2.1.5) |
read-only |
TimeStamp |
Most recent time when flush messages were sent. |
As per the MIB. |
hh3cSmlkPortRowStatus (1.3.6.1.4.1.25506.2.147.1.2.1.6) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cSmlkFlushEnableTable
About this table
Use this table to enable flush message receiving on a port and obtain flush message configuration information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
hh3cSmlkControlVlanListLow and hh3cSmlkControlVlanListHigh must be both specified. |
Not supported |
Supported |
Columns
The table index is hh3cSmlkIfIndx.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSmlkIfIndex (1.3.6.1.4.1.25506.2.147.1.3.1.1) |
not-accessible |
InterfaceIndex |
Interface index. |
As per the MIB. |
hh3cSmlkControlVlanListLow (1.3.6.1.4.1.25506.2.147.1.3.1.2) |
read-write |
OCTET STRING |
Low bits of control VLANs for receiving flush messages. |
As per the MIB. |
hh3cSmlkControlVlanListHigh (1.3.6.1.4.1.25506.2.147.1.3.1.3) |
read-write |
OCTET STRING |
High bits of control VLANs for receiving flush messages. |
As per the MIB. |
Notifications
This section contains trap notifications.
hh3cSmlkGroupLinkActive
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.147.2.0.1 |
A member port transitions to forwarding state. |
Informational |
N/A |
N/A |
ON |
A notification sent when a member port becomes active.
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.147.1.1.1.1 (hh3cSmlkGroupID) |
Smart link group ID. |
No |
Integer32 |
1..256 |
1.3.6.1.4.1.25506.2.147.1.2.1.1 (hh3cSmlkPortIfIndex) |
Index of the member port. |
Yes |
InterfaceIndex |
1..2147483647 |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
Detect the link of the blocked port.
hh3cSmlkGroupStatusSwitch
Basic information
OID |
Event |
Type |
Severity |
Default status |
(1.3.6.1.4.1.25506.2.147.2.0.2 |
The state of the smart link group changes. |
Informational |
N/A |
N/A |
ON |
A notification sent when the state of the smart link group changes.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
Integer32 |
Integer32 (1..256) |
1.3.6.1.4.1.25506.2.147.2.1.1 (hh3cSmlkGroupStatus) |
Smart link group state |
No |
INTEGER |
unknown(0), alldown(1), oneup(2), twoup(3), delay(4) |
Recommended action
To resolve the issue:
1. Check the state of the link attached to the smart link group member port and the smart link group configuration.
2. If the issue persists, contact H3C Support.
hh3cSmlkInactiveLinkDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.147.2.0.3 |
The backup link of the smart link group fails. |
Informational |
Warning |
1.3.6.1.4.1.25506.2.147.2.0.3 (hh3cSmlkInactiveLinkUp) |
ON |
A notification sent when the backup link of the smart link group fails.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
Integer32 |
No |
InterfaceIndex |
1..2147483647 |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Interface name. |
Yes |
OCTET STRING |
OCTET STRING (0..255) |
Recommended action
1. Check the state of the link attached to the smart link group member port.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.147.2.0.4 |
The backup link of the smart link group recovers. |
Informational |
Warning |
N/A |
ON |
A notification sent when the backup link of the smart link group recovers.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
Integer32 |
No |
InterfaceIndex |
1..2147483647 |
Interface name |
Yes |
OCTET STRING |
Recommended action
No action is required.
