05-HH3C-ETHOAM-MIB | 64.42 KB |
HH3C-ETHOAM-MIB
About this MIB
This MIB is a private MIB to implement Ethernet OAM functions.
MIB file name
hh3c-ethoam.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cEthoam(226)
Notifications
hh3cEthoamNonThresholdRecovery
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.226.1.0.1 |
The alarm for a non-threshold-crossing event is cleared. |
Informational |
ON |
A notification sent when the alarm for a non-threshold-crossing event is cleared on the local or remote end.
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Interface index |
No |
Integer32 |
Integer32 (1..2147483647) |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Interface name |
No |
OCTET STRING |
OCTET STRING (0..255) |
1.3.6.1.2.1.158.1.6.1.2 (dot3OamEventLogTimestamp) |
Timestamp of the event. |
No |
TimeStamp |
TimeTicks |
1.3.6.1.2.1.158.1.6.1.3 (dot3OamEventLogOui) |
OUI of the event packet. |
No |
EightOTwoOui |
OCTET STRING (SIZE (1..255)) |
1.3.6.1.2.1.158.1.6.1.4 (dot3OamEventLogType) |
Event type. |
No |
Unsigned32 |
linkFault(256) dyingGaspEvent(257) criticalLinkEvent(258) |
1.3.6.1.2.1.158.1.6.1.5 (dot3OamEventLogLocation) |
Whether the event is a local event or a peer event. |
No |
INTEGER |
local(1) remote(2) |
1.3.6.1.2.1.158.1.6.1.12 (dot3OamEventLogTimestamp) |
Total number of times the event has occurred. |
No |
Unsigned32 |
Standard MIB values. |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cEthoamLoopbackFailed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.226.1.0.2 |
Loopback detection fails to be enabled on an interface. |
Informational |
Warning |
ON |
This notification is generated when loopback detection fails to be enabled on an interface.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index |
No |
Integer32 |
Interface name |
No |
OCTET STRING |
Recommended action
Verify that the OAM connection is established correctly. If the problem persists, contact H3C Support.
