| 07-HH3C-DOMAIN-MIB | 54.44 KB |
HH3C-DOMAIN-MIB
About this MIB
Use this MIB to manage domains.
MIB file name
hh3c-domain.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDomain(46)
Scalar objects
hh3cDomainControl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDomainDefault (1.3.6.1.4.1.25506.2.46.1.1) |
read-write |
OCTET STRING |
SIZE (1..255) |
Name of the default domain. |
Default: system. (Comware 5) Default: 24. |
hh3cDomainGlobalStat
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
Tabular objects
hh3cDomainInfoTable
About this table
Use this table to configure or obtain ISP domain settings.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cDomainName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDomainName (1.3.6.1.4.1.25506.2.46.2.1.1.1) |
read-only |
OCTET STRING |
SIZE (0..255) |
Name of a domain. |
String of 1 to 114 characters. |
hh3cDomainState (1.3.6.1.4.1.25506.2.46.2.1.1.2) |
read-create |
INTEGER |
active(1) block(2) |
Status of the domain. |
As per the MIB. |
hh3cDomainRowStatus (1.3.6.1.4.1.25506.2.46.2.1.1.14) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
hh3cDomainSchemeTable
About this table
This table contains AAA schemes for a domain. By default, a domain has only a local scheme.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cDomainName and hh3cDomainSchemeIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDomainSchemeIndex (1.3.6.1.4.1.25506.2.46.2.2.1.1) |
not-accessible |
Integer32 |
Standard MIB values. |
Index of an AAA scheme. |
As per the MIB. |
hh3cDomainSchemeMode (1.3.6.1.4.1.25506.2.46.2.2.1.2) |
read-create |
H3cModeOfDomainScheme |
INTEGER{ none(1) local(2) radius(3) tacacs(4) ldap(5) } |
Mode of the AAA scheme. |
As per the MIB. |
hh3cDomainAuthSchemeName (1.3.6.1.4.1.25506.2.46.2.2.1.3) |
read-create |
OCTET STRING |
OCTET STRING (SIZE (0..32)) |
Name of the authentication scheme. |
This object has been replaced by hh3cDomainSchemeAAAName. Its value will be ignored. |
hh3cDomainAcctSchemeName (1.3.6.1.4.1.25506.2.46.2.2.1.4) |
read-create |
OCTET STRING |
Name of the accounting scheme. |
hh3cDomainSchemeRowStatus (1.3.6.1.4.1.25506.2.46.2.2.1.5) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDomainSchemeAAAType (1.3.6.1.4.1.25506.2.46.2.2.1.6) |
read-create |
Hh3cAAATypeDomainScheme |
INTEGER{ accounting(1) authentication(2) authorization(3) none(4) } |
Service type of the server, accounting, authentication, or authorization. |
As per the MIB. |
hh3cDomainSchemeAAAName (1.3.6.1.4.1.25506.2.46.2.2.1.7) |
read-create |
OCTET STRING |
Scheme name of the domain. |
If the hh3cDomainSchemeMode is RADIUS, TACACS, or LDAP scheme mode, you must specify a valid scheme name. If the hh3cDomainSchemeMode is none or local, the object will be ignored. When read, this object returns a zero-length string. |
hh3cDomainSchemeAccessMode (1.3.6.1.4.1.25506.2.46.2.2.1.8) |
read-create |
Hh3cAccessModeofDomainScheme |
INTEGER{ default(1) login(2) lanAccess(3) portal(4) ppp(5) gcm(6) dvpn(7) dhcp(8) voice(9) superauthen(10) command(11) reserved(12) } |
Access mode of the scheme for the domain. |
Supports only the value default. |
hh3cDomainStatTable
About this table
This table contains statistics for a domain.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDomainOnlineIPoEUser (1.3.6.1.4.1.25506.2.46.2.4.1.4) |
read-only |
Unsigned32 |
Number of online IPoE users in the domain. |
As per the MIB. |
hh3cDomainOnlinePPPoEUser (1.3.6.1.4.1.25506.2.46.2.4.1.5) |
read-only |
Unsigned32 |
Number of online PPPoE users in the domain. |
As per the MIB. |
hh3cDomainOnlinePPPoAUser (1.3.6.1.4.1.25506.2.46.2.4.1.6) |
read-only |
Unsigned32 |
Number of online PPPoA users in the domain. |
As per the MIB. |
hh3cDomainOnlineLacUser (1.3.6.1.4.1.25506.2.46.2.4.1.8) |
read-only |
Unsigned32 |
Number of online LAC users in the domain. |
As per the MIB. |
hh3cDomainIPPoolStatTable
About this table
This table contains IP pool statistics for a domain.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
