14-User Access and Authentication
HomeSupportResource CenterSwitchesS5590 SeriesS5590-EI SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S5590-EI Switch Series MIB Reference-6W10014-User Access and Authentication
02-HH3C-USER-MIB
02-HH3C-USER-MIB 105.04 KB
HH3C-USER-MIB
About this MIB
Use this MIB to manage local users.
MIB file name
hh3c-user.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cUser(12)
Scalar objects
hh3cUser
Object (OID)
Access
Value range
Implementation
hh3cUserMaxNum (1.3.6.1.4.1.25506.2.12.1.3)
read-only
Integer32
Standard MIB values.
Maximum number of local users can be created.
Implementation varies by product.
hh3cUserCurrNum (1.3.6.1.4.1.25506.2.12.1.4)
read-only
Integer32
Number of existing local users.
As per the MIB.
hh3cUserIndexIndicator (1.3.6.1.4.1.25506.2.12.1.5)
read-only
Integer32
Index to be used for the next local user.
As per the MIB.
Tabular objects
hh3cUserInfoTable
About this table
Use this table to configure or obtain basic information of a local user.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
You must specify hh3cUserPassword and hh3cAuthMode in pairs in an SNMP request.
Columns
The table index is hh3cUserIndex.
Object (OID)
Access
Value range
Implementation
hh3cUserName (1.3.6.1.4.1.25506.2.12.1.1.1.1)
read-create
DisplayString
OCTET STRING (1..255)
Name of a local user.
The username cannot contain any of the following characters: backslash (\), forward slash (/), colon (:), asterisk (*), question mark (?), quotation mark ("), left angle bracket (<), right angle bracket (>), or vertical bar (|). It cannot be a, al, or all and cannot begin with or end with at sign (@).
A username that contains a domain name is in the format of localusername@domain. The localusername part in the username cannot contain any of the following characters: backslash (\), forward slash (/), colon (:), asterisk (*), question mark (?), quotation mark ("), left angle bracket (<), right angle bracket (>), or vertical bar (|).. The maximum length of this part varies by device model.
The username of each local user is unique. You cannot edit an existing username.
hh3cUserPassword (1.3.6.1.4.1.25506.2.12.1.1.1.2)
read-create
DisplayString
OCTET STRING (0..255)
Password of the local user.
When read, this object returns a zero-length string.
hh3cAuthMode (1.3.6.1.4.1.25506.2.12.1.1.1.3)
read-create
Integer32
Encryption type of the user password.
Value range: 0 or 7.
hh3cUserState (1.3.6.1.4.1.25506.2.12.1.1.1.5)
read-create
INTEGER
active(0),
block(1)
Status of the local user.
As per the MIB.
hh3cUserInfoRowStatus (1.3.6.1.4.1.25506.2.12.1.1.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
hh3cUserIndex (1.3.6.1.4.1.25506.2.12.1.1.1.7)
not-accessible
Integer32
Integer32 (1..2147483646)
Index of the local user.
Value range: 1 to 1024.
hh3cUserAttributeTable
About this table
This table contains attributes of a local user.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cAccessLimit (1.3.6.1.4.1.25506.2.12.1.2.1.1)
read-write
Integer32
Maximum number of concurrent users that can use a username to access the device.
Default: No limit is placed on the maximum number of concurrent users that can use a username to access the device.
Value range: 0 to 1024.
hh3cIdleCut (1.3.6.1.4.1.25506.2.12.1.2.1.2)
read-write
Integer32
Idle timeout period, in seconds.
This object will round the specified value to the nearest multiple of 60.
hh3cIPAddress (1.3.6.1.4.1.25506.2.12.1.2.1.3)
read-write
IpAddress
IP address of a user.
Default: 0.0.0.0.
hh3cNasIPAddress (1.3.6.1.4.1.25506.2.12.1.2.1.4)
read-write
IpAddress
IP address of the NAS for the user.
Not supported.
hh3cSlotNum (1.3.6.1.4.1.25506.2.12.1.2.1.5)
read-write
Integer32
Slot number of the user.
Not supported.
hh3cSubSlotNum (1.3.6.1.4.1.25506.2.12.1.2.1.6)
read-write
Integer32
Subslot number of the user.
Not supported.
hh3cPortNum (1.3.6.1.4.1.25506.2.12.1.2.1.7)
read-write
Integer32
Port number of the user.
Not supported.
hh3cMacAddress (1.3.6.1.4.1.25506.2.12.1.2.1.8)
read-write
MacAddress
OCTET STRING (6)
MAC address of the user.
As per the MIB.
hh3cVlan (1.3.6.1.4.1.25506.2.12.1.2.1.9)
read-write
Integer32
Integer32 (0..4094)
ID of the VLAN to which the user belongs.
As per the MIB.
hh3cFtpService (1.3.6.1.4.1.25506.2.12.1.2.1.10)
read-write
ServiceType
enable(1),
disable(2)
FTP service.
Not supported.
hh3cFtpDirectory (1.3.6.1.4.1.25506.2.12.1.2.1.11)
read-write
OCTET STRING
FTP directory.
Not supported.
hh3cLanAccessService (1.3.6.1.4.1.25506.2.12.1.2.1.12)
read-write
ServiceType
enable(1),
disable(2)
LAN access service.
As per the MIB.
hh3cSshService (1.3.6.1.4.1.25506.2.12.1.2.1.13)
read-write
ServiceType
enable(1),
disable(2)
SSH service.
Not supported.
hh3cTelnetService (1.3.6.1.4.1.25506.2.12.1.2.1.14)
read-write
ServiceType
enable(1),
disable(2)
Telnet service.
Not supported.
hh3cTerminalService (1.3.6.1.4.1.25506.2.12.1.2.1.15)
read-write
ServiceType
enable(1),
disable(2)
Terminal service.
Not supported.
hh3cExpirationDate (1.3.6.1.4.1.25506.2.12.1.2.1.16)
read-write
DateAndTime
OCTET STRING (8)
Expired date of the user.
Not supported.
hh3cUserGroup (1.3.6.1.4.1.25506.2.12.1.2.1.17)
read-write
DisplayString
User group of the user.
A user group name cannot exceed 32 characters.
hh3cPortalService (1.3.6.1.4.1.25506.2.12.1.2.1.18)
read-write
ServiceType
enable(1),
disable(2)
Portal service.
As per the MIB.
hh3cPPPService (1.3.6.1.4.1.25506.2.12.1.2.1.19)
read-write
ServiceType
enable(1),
disable(2)
PPP service.
As per the MIB.
hh3cHttpService (1.3.6.1.4.1.25506.2.12.1.2.1.20)
read-write
ServiceType
enable(1),
disable(2)
HTTP service.
Not supported
hh3cHttpsService (1.3.6.1.4.1.25506.2.12.1.2.1.21)
read-write
ServiceType
enable(1),
disable(2)
HTTPS service.
Not supported
hh3cUserIfIndex (1.3.6.1.4.1.25506.2.12.1.2.1.22)
read-write
Integer32
Index of the user's access interface.
As per the MIB.
hh3cUserRoleTable
About this table
Use this table to configure or obtain basis information of a local user.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cUserIndex and hh3cUserRole.
Object (OID)
Access
Value range
Implementation
hh3cUserRole (1.3.6.1.4.1.25506.2.12.1.6.1.1)
not-accessable
DisplayString
OCTET STRING  (1..63))
User role.
In MDCs, the default user role is mdc-operator.
In non-MDCs, the default user role is network-operator.
hh3cUserRoleStatus (1.3.6.1.4.1.25506.2.12.1.6.1.2)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
You must specify hh3cUserIndex when you create a local user.
hh3cUserGroupInfoTable
About this table
Use this table to configure or obtain basic information of a user group.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cUserGroupName.
Object (OID)
Access
Value range
Implementation
hh3cUserGroupName (1.3.6.1.4.1.25506.2.12.2.1.1.1)
not-accessible
DisplayString
Name of a user group.
As per the MIB.
hh3cUserGroupInfoRowStatus (1.3.6.1.4.1.25506.2.12.2.1.1.2)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
  • Become a Partner
  • Partner Resources
