06-Layer 2 - LAN Switching
HomeSupportResource CenterSwitchesS5590 SeriesS5590-EI SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S5590-EI Switch Series MIB Reference-6W10006-Layer 2 - LAN Switching
23-HH3C-LPBKDT-MIB
23-HH3C-LPBKDT-MIB 50.69 KB
HH3C-LPBKDT-MIB
About this MIB
The loop detection mechanism performs periodic checking for Layer 2 loops and processes the interfaces with loops as configured.
Use this MIB to perform the following tasks:
·     Generate traps when the loop state of an interface changes.
·     Configure and view the loop detection state, loop protection action, and loop detection interval for VLANs globally.
·     Configure and view the loop detection state, loop protection action, and loop detection interval for VLANs on an interface.
MIB file name
hh3c-lpbkdt.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cDldp2Lpbkdt(95)
Scalar objects
OID of this table is: 1.3.6.1.4.1.25506.2.95.2
hh3cLpbkdtVlanID
Object (OID)
Access
Value range
Implementation
hh3cLpbkdtVlanID (1.3.6.1.4.1.25506.2.95.2.1)
accessible-for-notify
INTEGER
1..4094
VLAN ID in reported trap messages when a loop is detected or eliminated on an interface.
As per the MIB.
hh3cLpbkdtVlanEnable
Object (OID)
Access
Value range
Implementation
hh3cLpbkdtVlanEnable (1.3.6.1.4.1.25506.2.95.2.2)
read-write
OCTETSTRING
SIZE(1..512)
Enable or disable loop detection for VLANs globally.
As per the MIB.
hh3cLpbkdtAction
Object (OID)
Access
Value range
Implementation
hh3cLpbkdtAction (1.3.6.1.4.1.25506.2.95.2.3)
read-write
INTEGER
none (1),
block(2),
nolearning(3),
shutdown(4)
Configure the global loop protection action, which is to take on all ports where loops are detected.
In the current software version, only the log and shutdown operations are supported, and the block and nolearning actions are not supported.
hh3cLpbkdtAction
Object (OID)
Access
Value range
Implementation
hh3cLpbkdtIntervalTime (1.3.6.1.4.1.25506.2.95.2.4)
read-write
Integer32
1..300
Loop detection interval.
As per the MIB.
Tabular objects
hh3cLpbkdtPortTable
OID of this table is: 1.3.6.1.4.1.25506.2.95.2.5
About this table
Use this table to configure loop detection on a port.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cLpbkdtPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cLpbkdtPortIfIndex (1.3.6.1.4.1.25506.2.95.2.5.1.1)
not-accessible
INTEGER
1..2147483647
Interface index.
As per the MIB.
hh3cLpbkdtPortVlanEnable (1.3.6.1.4.1.25506.2.95.2.5.1.2)
read-write
OCTET STRING
SIZE(1..512)
Enable or disable loop detection for VLANs on a port.
As per the MIB.
Not related. Please archive it.
hh3cLpbkdtPortAction (1.3.6.1.4.1.25506.2.95.2.5.1.3)
read-write
INTEGER
none (1),
block(2),
nolearning(3),
shutdown(4)
Configure the loop protection action for a port, which is to take on the port when a loop is detected.
An aggregate interface supports only the log and shutdown actions. The other interfaces support all actions.
hh3cLpbkdtPortLoopbacked (1.3.6.1.4.1.25506.2.95.2.5.1.4)
read-only
TruthValue
true(1),
false(2)
Check for a loop on a port.
As per the MIB.
  • Become a Partner
  • Partner Resources
