06-Layer 2 - LAN Switching
HomeSupportResource CenterSwitchesS5590 SeriesS5590-EI SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S5590-EI Switch Series MIB Reference-6W10006-Layer 2 - LAN Switching
10-HH3C-VMAP-MIB
10-HH3C-VMAP-MIB 66.45 KB
HH3C-VMAP-MIB
About this MIB
Use this MIB to configure VLAN mapping features, for example, one-to-one VLAN mapping, many-to-one VLAN mapping, one-to-two VLAN mapping, two-to-two VLAN mapping, and two-to-one VLAN mapping. VLAN mapping re-marks VLAN traffic with new VLAN IDs. Implementation varies by product.
MIB file name
hh3c-vmap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cVmap(138)
Tabular objects
hh3cVMAPNNITable
About this table
Use this table to configure many-to-one VLAN mapping on the network side.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cVMAPNNIState (1.3.6.1.4.1.25506.2.138.1.1.1)
read-write
TruthValue
true(1),
false(2)
Configure VLAN mapping.
hh3cVMAP1to1Table
About this table
Use this table to configure one-to-one VLAN mapping.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ifIndex and hh3cVMAP1to1Vlan.
Object (OID)
Access
Value range
Implementation
hh3cVMAP1to1Vlan (1.3.6.1.4.1.25506.2.138.2.1.1)
not-accessible
Integer32
Integer32 (1..65535)
Configure one-to-one VLAN mapping.
As per the MIB.
hh3cVMAP1to1TranslatedVlan (1.3.6.1.4.1.25506.2.138.2.1.2)
read-create
Integer32
Translated VLAN for one-to-one VLAN mapping.
hh3cVMAP1to1RowStatus
(1.3.6.1.4.1.25506.2.138.2.1.3)
read-create
RowStatus
Standard MIB values.
One-to-one VLAN mapping row state.
Available values are active(1), createAndGo(4), and destroy(6).
hh3cVMAPNto1RangeTable
About this table
Use this table to configure many-to-one VLAN mapping on the user side. The original VLANs are specified in a list, for example, VLANs 20 through 30.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ifIndex and hh3cVMAPNto1StartVlan.
Object (OID)
Access
Value range
Implementation
hh3cVMAPNto1StartVlan (1.3.6.1.4.1.25506.2.138.3.1.1)
not-accessible
Integer32
Start VLAN of the original VLAN list for many-to-one VLAN mapping.
As per the MIB.
hh3cVMAPNto1EndVlan (1.3.6.1.4.1.25506.2.138.3.1.2)
read-create
Integer32
End VLAN of the original VLAN list for many-to-one VLAN mapping.
hh3cVMAPNto1RangeTranslatedVlan (1.3.6.1.4.1.25506.2.138.3.1.3)
read-create
Integer32
Translated VLAN for many-to-one VLAN mapping.
hh3cVMAPNto1RangeRowStatus
(1.3.6.1.4.1.25506.2.138.3.1.4)
read-create
RowStatus
Many-to-one VLAN mapping row state.
hh3cVMAPNto1SingleTable
About this table
Use this table to configure many-to-one VLAN mapping on the user side. The original VLANs are single VLANs, for example, VLAN 20 and VLAN 30.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ifIndex and hh3cVMAPNto1Vlan.
Object (OID)
Access
Value range
Implementation
hh3cVMAPNto1Vlan (1.3.6.1.4.1.25506.2.138.4.1.1)
not-accessible
Integer32
Many-to-one VLAN mapping.
As per the MIB.
hh3cVMAPNto1SingleTranslatedVlan (1.3.6.1.4.1.25506.2.138.4.1.2)
read-create
Integer32
hh3cVMAPNto1SingleRowStatus
(1.3.6.1.4.1.25506.2.138.4.1.3)
read-create
RowStatus
hh3cVMAP1to2RangeTable
About this table
Use this table to configure two-to-one VLAN mapping. The original VLANs are specified in a list, for example, VLANs 20 through 30.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ifIndex and hh3cVMAP1to2StartVlan.
Object (OID)
Access
Value range
Implementation
hh3cVMAP1to2StartVlan (1.3.6.1.4.1.25506.2.138.5.1.1)
not-accessible
Integer32
Start VLAN of the original VLAN list for one-to-two VLAN mapping.
As per the MIB.
hh3cVMAP1to2EndVlan (1.3.6.1.4.1.25506.2.138.5.1.2)
read-create
Integer32
End VLAN of the original VLAN list for one-to-two VLAN mapping.
hh3cVMAP1to2RangeNestedVlan (1.3.6.1.4.1.25506.2.138.5.1.3)
read-create
Integer32
Outer VLAN for one-to-two VLAN mapping.
hh3cVMAP1to2RangeRowStatus
(1.3.6.1.4.1.25506.2.138.5.1.4)
read-create
RowStatus
One-to-two VLAN mapping row state.
hh3cVMAP1to2RangeNestedPrio
(1.3.6.1.4.1.25506.2.138.5.1.5)
read-create
Integer32
Outer VLAN priority for one-to-two VLAN mapping.
The value range is 0 to 7. If no priority is configured, the default is 65535.
hh3cVMAP1to2SingleTable
About this table
Use this table to configure one-to-two VLAN mapping. The original VLANs are single VLANs, for example, VLAN 20 and VLAN 30.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cVMAP1to2Vlan (1.3.6.1.4.1.25506.2.138.6.1.1)
not-accessible
Integer32
Configure one-to-two VLAN mapping.
As per the MIB.
hh3cVMAP1to2SingleNestedVlan (1.3.6.1.4.1.25506.2.138.6.1.2)
read-create
Integer32
Single outer VLAN for one-to-two VLAN mapping.
hh3cVMAP1to2SingleRowStatus
(1.3.6.1.4.1.25506.2.138.6.1.3)
read-create
RowStatus
hh3cVMAP1to2SingleNestedPrio
(1.3.6.1.4.1.25506.2.138.6.1.4)
read-create
Integer32
Single outer VLAN priority for one-to-two VLAN mapping.
hh3cVMAP2to2Table
About this table
Use this table to configure two-to-two VLAN mapping.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ifIndex, hh3cVMAP2to2OuterVlan, and hh3cVMAP2to2InnerVlan.
Object (OID)
Access
Value range
Implementation
hh3cVMAP2to2OuterVlan (1.3.6.1.4.1.25506.2.138.7.1.1)
not-accessible
Integer32
Original outer VLAN for two-to-two VLAN mapping.
As per the MIB.
hh3cVMAP2to2InnerVlan  (1.3.6.1.4.1.25506.2.138.7.1.2)
not-accessible
Integer32
Original inner VLAN for two-to-two VLAN mapping.
As per the MIB.
hh3cVMAP2to2TranslatedOuterVlan (1.3.6.1.4.1.25506.2.138.7.1.3)
read-create
Integer32
Translated outer VLAN for two-to-two VLAN mapping.
hh3cVMAP2to2TranslatedInnerVlan  (1.3.6.1.4.1.25506.2.138.7.1.4)
read-create
Integer32
Translated inner VLAN for two-to-two VLAN mapping.
hh3cVMAP2to2RowStatus
(1.3.6.1.4.1.25506.2.138.7.1.5)
read-create
RowStatus
Two-to-two VLAN mapping row state.
hh3cVMAP2to1Table
About this table
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ifIndex, hh3cVMAP2to1OuterVlan, and hh3cVMAP2to1InnerVlan.
Object (OID)
Access
Value range
Implementation
hh3cVMAP2to1OuterVlan (1.3.6.1.4.1.25506.2.138.8.1.1)
not-accessible
Integer32
Original outer VLAN for two-to-one VLAN mapping.
As per the MIB.
hh3cVMAP2to1InnerVlan  (1.3.6.1.4.1.25506.2.138.8.1.2)
not-accessible
Integer32
Original inner VLAN for two-to-one VLAN mapping.
As per the MIB.
hh3cVMAP2to1TranslatedOuterVlan (1.3.6.1.4.1.25506.2.138.8.1.3)
read-create
Integer32
Translated outer VLAN for two-to-one VLAN mapping.
hh3cVMAP2to1RowStatus
(1.3.6.1.4.1.25506.2.138.8.1.4)
read-create
RowStatus
Two-to-one VLAN mapping row state.
  • Become a Partner
  • Partner Resources
