- 03-Device Management
- 01-HH3C-INFOCENTER-MIB
- 02-HH3C-LSW-DEV-ADM-MIB
- 03-HH3C-LswDEVM-MIB
- 04-HH3C-LswTRAP-MIB
- 05-HH3C-POWER-ETH-EXT-MIB
- 06-HH3C-RES-MON-MIB
- 07-HH3C-TRANSCEIVER-INFO-MIB
- 08-HH3C-TRAP-MIB
- 09-POWER-ETHERNET-MIB
- 10-SYSLOG-MSG-MIB
- 11-ENTITY-MIB
- 12-HH3C-COMMON-SYSTEM-MIB
- 13-HH3C-ENTITY-EXT-MIB
- 14-HH3C-ENTRELATION-MIB
| 14-HH3C-ENTRELATION-MIB | 36.40 KB |
About this MIB
Use this MIB to obtain information about the relationship between two entities on combo interfaces or stack ports and describes the relationship between combo interfaces and stack ports.
MIB file name
hh3c-entrelation.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cEntityRelation(15)
Tabular objects
hh3cEntRelationTable
About this table
This table contains information about the relationship between combo interfaces and stack ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cEntRelationType, hh3cEntityIndex, and hh3cRelatedEntityIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cEntRelationType (1.3.6.1.4.1.25506.2.15.1.1.1.1.1) |
not-accessible |
INTEGER |
stackport(1), comboport(2) |
Association type. |
Supports only combo interfaces. |
hh3cEntityIndex (1.3.6.1.4.1.25506.2.15.1.1.1.1.2) |
not-accessible |
PhysicalIndex |
Integer32 (1..2147483647) |
Entity index. |
By default, the entity is a combo interface. |
hh3cRelatedEntityIndex (1.3.6.1.4.1.25506.2.15.1.1.1.1.3) |
read-only |
PhysicalIndex |
Index of the associated entity. |
Implementation varies by product. |
