- 03-Device Management
- 01-HH3C-INFOCENTER-MIB
- 02-HH3C-LSW-DEV-ADM-MIB
- 03-HH3C-LswDEVM-MIB
- 04-HH3C-LswTRAP-MIB
- 05-HH3C-POWER-ETH-EXT-MIB
- 06-HH3C-RES-MON-MIB
- 07-HH3C-TRANSCEIVER-INFO-MIB
- 08-HH3C-TRAP-MIB
- 09-POWER-ETHERNET-MIB
- 10-SYSLOG-MSG-MIB
- 11-ENTITY-MIB
- 12-HH3C-COMMON-SYSTEM-MIB
- 13-HH3C-ENTITY-EXT-MIB
- 14-HH3C-ENTRELATION-MIB
| 05-HH3C-POWER-ETH-EXT-MIB | 58.80 KB |
About this MIB
This MIB is an extension of POWER-ETHERNET-MIB. To implement this MIB, you must first implement relevant parts of POWER-ETHERNET-MIB, such as pethMainPseTable.
This MIB adds some objects which POWER-ETHERNET-MIB does not contain to monitor some specific aspects of entities for better and comprehensive management on devices.
MIB file name
hh3c-power-eth-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPowerEthernetExt(14)
Scalar objects
hh3cPsePolicyMode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPsePolicyMode (1.3.6.1.4.1.25506.2.14.9) |
read-write |
INTEGER |
disabled(1), priority(2) |
PSE power management policy mode. |
As per the MIB. |
hh3cPDPolicyMode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPDPolicyMode (1.3.6.1.4.1.25506.2.14.10) |
read-write |
INTEGER |
PD power management policy mode. |
As per the MIB. |
Tabular objects
hh3cPsePortTable
About this table
Use this table to manage PSE ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are pethPsePortGroupIndex and pethPsePortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPsePortFaultDescription (1.3.6.1.4.1.25506.2.14.1.1.2) |
read-write |
DisplayString |
OCTET STRING (0..255) |
Description about the precise PoE hardware state causing the pethPsePortDetectionStatus object to be in the fault state. |
Not supported |
hh3cPsePortPeakPower (1.3.6.1.4.1.25506.2.14.1.1.3) |
read-write |
Integer32 |
Standard MIB values. |
Peak power of the PSE port, in milliwatts. |
As per the MIB. You can set the value to 0. Other values are not effective. |
hh3cPsePortAveragePower (1.3.6.1.4.1.25506.2.14.1.1.4) |
read-write |
Integer32 |
Average power of the PSE port, in milliwatts. |
As per the MIB. |
hh3cPsePortCurrentPower (1.3.6.1.4.1.25506.2.14.1.1.5) |
read-only |
Integer32 |
Current power of the PSE port, in milliwatts. |
As per the MIB. |
hh3cPsePortPowerLimit (1.3.6.1.4.1.25506.2.14.1.1.6) |
read-write |
Integer32 |
Power limit for the PSE port, in milliwatts. |
As per the MIB. |
hh3cPsePortProfileIndex (1.3.6.1.4.1.25506.2.14.1.1.7) |
read-write |
Integer32 |
Integer32 (0..100) |
Index of the power profile currently associated with this port. |
As per the MIB. |
hh3cMainPseTable
About this table
Use this table to manage PSEs.
This table is not supported on non-default MDCs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is pethPsePortGroupIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMainPsePowerLimit (1.3.6.1.4.1.25506.2.14.2.1.1 |
read-write |
Integer32 |
Power limit for the PSE, in watts. |
As per the MIB. |
hh3cMainPseAveragePower (1.3.6.1.4.1.25506.2.14.2.1.2) |
read-write |
Integer32 |
Average power of the PSE, in watts. |
As per the MIB. |
hh3cMainPsePeakPower (1.3.6.1.4.1.25506.2.14.2.1.3) |
read-write |
Integer32 |
Peak power of the PSE, in watts. |
As per the MIB. |
hh3cMainGuaranteedPowerRemaining (1.3.6.1.4.1.25506.2.14.2.1.4) |
read-only |
Integer32 |
Remaining guaranteed power of the PSE, in watts. |
As per the MIB. |
hh3cMainPsePriorityMode (1.3.6.1.4.1.25506.2.14.2.1.5) |
read-write |
INTEGER |
disconnection(0), non-disconnection(1) |
Describes or controls the priority mode on slot which must be enabled firstly. When a new card is inserted, and the power is overloaded, a value of disconnection(0) means that power will not be supplied to the low priority slot. A value of non-disconnection(1) means that power is supplied to the slot when a new card is inserted, and the power is overloaded. |
Not supported. |
hh3cMainPseLegacy (1.3.6.1.4.1.25506.2.14.2.1.6) |
read-write |
INTEGER |
enable(0), disable(1) |
Standard or nonstandard PD detection mode. |
As per the MIB. |
hh3cMainPsePowerPriority (1.3.6.1.4.1.25506.2.14.2.1.7) |
read-write |
INTEGER |
critical(1), high(2), low(3) |
Priority of the PSE. |
As per the MIB. |
hh3cPseProfilesTable
About this table
Use this table to manage power profiles.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cPseProfileIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPseProfileIndex (1.3.6.1.4.1.25506.2.14.7.1.1) |
not-accessible |
Integer32 |
Integer32 (1..100) |
Profile index. |
As per the MIB. |
hh3cPseProfileName (1.3.6.1.4.1.25506.2.14.7.1.2) |
read-create |
DisplayString |
OCTET STRING (1..15) |
Profile name. |
As per the MIB. |
hh3cPseProfilePowerMode (1.3.6.1.4.1.25506.2.14.7.1.3) |
read-create |
INTEGER |
powerDisabled(1), powerEnabled(2) |
Power mode. |
As per the MIB. |
hh3cPseProfilePowerLimit (1.3.6.1.4.1.25506.2.14.7.1.4) |
read-create |
Integer32 |
Power limit, in milliwatts. |
As per the MIB. |
hh3cPseProfilePriority (1.3.6.1.4.1.25506.2.14.7.1.5) |
read-create |
INTEGER |
Port priority. |
As per the MIB. |
hh3cPseProfilePairs (1.3.6.1.4.1.25506.2.14.7.1.6) |
read-create |
INTEGER |
signal(1), spare(2) |
Pairs in use. |
As per the MIB. |
hh3cPseProfileApplyNum (1.3.6.1.4.1.25506.2.14.7.1.7) |
read-only |
Integer32 |
Number of this profile being applied. |
As per the MIB. |
hh3cPseProfileRowStatus (1.3.6.1.4.1.25506.2.14.7.1.8) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only active, createAndGo, and destory. This row cannot be deleted when the value of the hh3cPseProfileApplyNum is 0. |
Notifications
This section contains the HH3C-POWER-ETH-EXT-MIB notifications.
hh3cpsePDChangeNotification
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.14.6.1 |
PD connected or disconnected |
Informational |
N/A |
N/A |
ON |
This notification is generated when a PD is connected or disconnected.
Status control
ON
MIB: Set pethNotificationControlEnable to true(1).
OFF
MIB: Set pethNotificationControlEnable to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.105.1.1.1.6 (pethPsePortDetectionStatus) |
PD detection status of the PSE port. |
N |
INTEGER |
disabled(1), searching(2), deliveringPower(3), fault(4), test(5), otherFault(6) |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
Check the connection to the PD. No action is required if the alarm is triggered by a human operation.
