- 11-NMM Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-PoE commands
- 05-SNMP commands
- 06-RMON commands
- 07-NETCONF commands
- 08-CWMP commands
- 09-EAA commands
- 10-Process monitoring and maintenance commands
- 11-Mirroring commands
- 12-sFlow commands
- 13-Information center commands
- 14-PTP commands
- 15-Network synchronization commands
| 14-PTP commands | 167.05 KB |
PTP commands
PTP time synchronization is not supported between IRF member devices.
display ptp clock
Use display ptp clock to display PTP clock information.
display ptp clock
This command does not display any information if you have not specified a PTP profile (PTP standard) or a PTP mode.
# Display PTP clock information.
<Sysname> display ptp clock
PTP profile : IEEE 1588 Version 2
PTP mode : BC
Slave only : No
Clock ID : 000FE2-FFFE-FF0000
Clock type : Local
Clock domain : 0
Number of PTP ports : 2
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Offset (log variance) : 65535
Offset from master : 50 (ns)
Mean path delay : 2791 (ns)
Steps removed : 2
Local clock time : Sun Jan 15 20:57:29 2011
PTP profile |
PTP standard: IEEE 1588 version 2. SMPTE ST 2059-2. |
PTP mode |
Clock node type: · BC. · E2ETC. · E2ETC-OC. · OC. · P2PTC. · P2PTC-OC. |
Slave only |
Whether the OC operates in Slave only mode: · Yes. · No. |
Clock ID |
Clock ID for the device, which uniquely identifies a PTP device. |
Clock type |
Clock type of the device: Local (local clock). |
Clock domain |
PTP domain where the device resides. |
Priority1 |
Priority 1 value for the device. |
Priority2 |
Priority 2 value for the device. |
Class |
Time class of the device. |
Accuracy |
Time accuracy of the device. |
Offset (log variance) |
Offset of the grandmaster clock. |
Offset from master |
Offset from the master clock node (parent clock node), in nanoseconds. N/A indicates that information for this field is not obtained. |
Mean path delay |
Mean path delay, in nanoseconds. N/A indicates that information for this field is not obtained. |
Steps removed |
Hops from the grandmaster to the local clock node. N/A indicates that information for this field is not obtained. |
display ptp corrections
Use display ptp corrections to display PTP corrections that have occurred on a subordinate port.
The PTP corrections are displayed only when the following conditions are met:
· You have specified a PTP profile and PTP mode for the device.
· The device has a subordinate port and has performed time or frequency synchronization through the port.
If the subordinate port is changed, the recorded information will be cleared.
# Display PTP corrections that have occurred on a subordinate port.
<Sysname> display ptp corrections
Slave port Correction time Corrections(s,ns) Rate ratio
GE1/0/1 Mar 11 03:14:54 2012 0,74 0.999999973
GE1/0/1 Mar 11 03:14:55 2012 -1,17 0.999999980
Slave port |
Name of the subordinate port. |
Correction time |
Time when the correction occurred. |
Corrections(s,ns) |
Time corrections in seconds or nanoseconds. N/A indicates that no correction occurred this time. |
Rate ratio |
Ratio of the subordinate port rate to the master port rate. N/A indicates that no correction occurred this time. |
display ptp foreign-masters-record
Use display ptp foreign-masters-record to display information about foreign master nodes.
display ptp foreign-masters-record [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about foreign master nodes for all interfaces.
Foreign master node information is displayed only when the following conditions are met:
· The PTP profile is IEEE 1588 version 2 or SMPTE ST 2059-2.
· You have specified a PTP mode for the device.
· The device has a subordinate port or a port in uncalibrated state.
# Display information about foreign master nodes for all interfaces.
<Sysname> display ptp foreign-masters-record
P1=Priority1, P2=Priority2, C=Class, A=Accuracy,
OSLV=Offset-scaled-log-variance, SR=Steps-removed
GM=Grandmaster
Interface Clock ID P1 P2 C A OSLV SR GM
GE1/0/1 000FE2-FFFE-FF0000 0 128 248 254 65535 0 Yes
GE1/0/2 000FE2-FFFE-FF0001 0 128 248 254 65535 1 No
Name of a PTP interface. |
Clock ID |
Clock ID of the foreign master node. |
C |
Time class. |
A |
Time accuracy. |
OSLV |
SR |
Hops from the grandmaster to the local clock node. |
GM |
Whether the node represents the grandmaster clock: · Yes. · No. |
display ptp interface
Use display ptp interface to display PTP running information for an interface.
display ptp interface [ interface-type interface-number | brief ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays PTP running information for all interfaces.
brief: Displays brief PTP running information for all interfaces. If you do not specify this keyword, this command displays detailed PTP running information for the specified interface or all interfaces.
The detailed PTP running information can be displayed only if you enable PTP on the interface. The brief PTP running information can be displayed only when PTP is operating on the interface.
# Display brief PTP running information for all interfaces.
<Sysname> display ptp interface brief
Name State Delay mechanism Clock step Asymmetry correction
GE1/0/1 Slave E2E Two 0
GE1/0/2 Passive E2E Two 0
# Display detailed PTP running information for GigabitEthernet 1/0/1.
<Sysname> display ptp interface gigabitethernet 1/0/1
Port number : 15
PTP version : 2
PTP enable : Enabled
Transport of PTP : User Datagram Protocol (IPv4)
Unicast destination address : 10.10.10.2
DSCP priority : 56
Port state : Disabled
Force state : No
Clock step : Two
Asymmetry correction : 0
Delay mechanism : End to End
Announce interval (log mean) : 1
Announce receipt time out : 3
Sync interval (log mean) : 2
Delay request interval (log mean) : 2
Peer delay request interval (log mean) : 0
Mean path delay : 0 (ns)
Name |
Name of the PTP interface. |
State |
States of the PTP interface: · Slave—Receives synchronization messages. · Uncalibrated—Temporary state before the interface enters Slave state. · Passive—Neither receives nor sends synchronization messages. A PTP interface is in passive state after it receives an announce messages. · Master—Sends synchronization messages. · Premaster—Temporary state before the interface enters Master state. · Listening—Neither receives nor sends synchronization messages. A PTP interface is in listening state after being initialized. · Faulty—PTP is running incorrectly. A PTP interface in faulty state does not process PTP messages. · Disabled—PTP is not running on the interface. A PTP interface in disabled state does not process PTP messages. · Initializing—The interface is initializing. A PTP interface in initializing state does not process PTP messages. · N/A—No PTP interface state is obtained. |
Delay mechanism |
Delay measurement mechanism: · End to End—Request-response mechanism. · Peer to Peer—Peer delay mechanism. |
Clock step |
Mode for carrying timestamps: · One—Single-step mode. · Two—Two-step mode. |
Asymmetry correction |
Asymmetric delay correction value (in nanoseconds). |
Clock ID |
Clock ID of the device where the interface resides. |
PTP version |
PTP version number. The version number is always 2. |
PTP enable |
Whether PTP is enabled or disabled: · Enabled. · Disabled. |
Transport of PTP |
PTP messages are transported by: · User Datagram Protocol (IPv4). · IEEE 802.3/Ethernet. |
DSCP priority |
DSCP value for PTP messages that are transmitted over UDP (IPv4). This field is not displayed if the ptp dscp command is not executed. |
VLAN |
VLAN ID for PTP messages. This field is not displayed if the ptp vlan command is not executed. |
Dot1p priority |
802.1p precedence for PTP messages. This field is not displayed if the ptp vlan command is not executed. |
Force state |
Whether the force state is configured: · Yes. · No. |
Announce interval (log mean) |
Announce message sending interval (in seconds) = 2internal (this field displays the value for the interval exponent). |
Announce receipt time out |
Number of announcement intervals before the receiving node stops receiving announce messages. If a member node does not receive any announce message from the master node within the specified value, it considers the master node invalid. |
Sync interval (log mean) |
Sync message sending interval (in seconds) = 2internal (this field displays the value for the interval exponent). |
Delay request interval (log mean) |
Minimum delay request message sending interval (in seconds) = 2internal (this field displays the value for the interval exponent). |
Peer delay request interval (log mean) |
Peer delay request message sending interval (in seconds) = 2internal (this field displays the value for the interval exponent). |
Mean path delay |
Mean path delay, in nanoseconds. |
display ptp parent
Use display ptp parent to display parent node (master node) information for the PTP device.
display ptp parent
The command does not display any information in any of the following circumstances:
· You have not specified a PTP profile or a PTP mode for the device.
· You have specified the clock node type as TC.
· You have executed the ptp active force-state command.
# Display parent node information for the PTP device.
<Sysname> display ptp parent
Parent clock:
Parent clock ID : 000FE2-FFFE-FF0005
Parent port number : 15
Observed parent offset (log variance) : N/A
Observed parent clock phase change rate : N/A
Grandmaster clock:
Grandmaster clock ID: 000FE2-FFFE-FF0000
Grandmaster clock quality:
Class : 248
Accuracy : 254
Priority1 : 128
Priority2 : 128
Table 5 Command output
Parent port number |
Outgoing interface number of the parent clock. |
Observed parent offset (log variance) |
Offset from the parent clock node. N/A indicates that information for this field is not obtained. |
Class |
Time class of the grandmaster clock. |
Accuracy |
Time accuracy of the grandmaster clock. |
Priority1 |
Priority 1 value of the grandmaster clock. |
Priority2 |
Priority 2 value of the grandmaster clock. |
display ptp statistics
Use display ptp statistics to display PTP statistics.
display ptp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays PTP statistics for all interfaces.
The command does not display any PTP statistics if you have not specified a PTP profile or a PTP mode.
# Display PTP statistics on GigabitEthernet 1/0/1.
<Sysname> display ptp statistics interface gigabitethernet 1/0/1
Received packets
Announce :0 Sync :0 Signaling :0
DelayReq :0 DelayResp :0 FollowUp :0
PdelayReq:0 PdelayResp:0 PdelayRespFollowUp :0
Sent packets
Announce :476 Sync :2543 Signaling :0
DelayReq :0 DelayResp :0 FollowUp :2542
PdelayReq:238 PdelayResp:0 PdelayRespFollowUp :0
Discarded packets
Table 6 Command output
Received packets |
Statistics about received PTP messages. |
Sent packets |
Statistics about sent PTP messages. |
Discarded packets |
Statistics about discarded PTP messages. |
display ptp time-property
Use display ptp time-property to display PTP clock properties.
This command does not display any information in any of the following circumstances:
· You have not specified a PTP standard or a clock node type.
· You have specified the clock node type as e2etc or p2ptc.
# Display PTP clock properties.
<Sysname> display ptp time-property
PTP clock time property:
Current UTC offset valid : True
Current UTC offset : 33
Leap59 : Yes
Leap61 : No
Time traceable : True
Frequency traceable : True
PTP timescale : True
Time source : 0xA0 (Internal oscillator)
Table 7 Command output
Current UTC offset valid |
Whether the UTC offset is valid: · True—Yes. · False—No. |
Current UTC offset |
Cumulative offset (in seconds) between the Coordinated Universal Time (UTC) of the grandmaster clock and the International Atomic Time (TAI). |
Leap59 |
Whether cumulative offset is minus 1: · Yes. · No. |
Leap61 |
Whether cumulative offset is plus 1: · Yes. · No. |
Time traceable |
Whether the PTP time is traceable: · True—Yes. · False—No. |
Frequency traceable |
Whether the PTP frequency is traceable: · True—Yes. · False—No. |
PTP timescale |
The possible timescales available for use by the grandmaster clock: · True—PTP timescale. · False—Non-PTP timescale. |
Time source |
Attributes of the grandmaster clock: · Atomic clock. · GPS. · Handset. · Internal oscillator. · NTP. · Other. · PTP. · Terrestrial radio. · Unknown. |
Use ptp active force-state to activate the port role configuration.
Use undo ptp active force-state to restore the default.
The port role configuration is not activated.
This command is available only after you specify a PTP profile and a PTP mode.
# Activate the port role configuration.
[Sysname] ptp profile 1588v2
[Sysname] ptp mode oc
[Sysname] ptp active force-state
ptp force-state
ptp mode
ptp profile
ptp announce-interval
Use ptp announce-interval to set the interval for sending announce messages.
Use undo ptp announce-interval to restore the default.
ptp announce-interval interval
For the IEEE 1588 version 2 profile, the interval argument value is 1 and the announce message sending interval is 2 (21) seconds.
For the SMPTE ST 2059-2 PTP profile, the interval argument value is –2 and the announce message sending interval is 1/4 (2-2) second.
interval: Specifies an exponent, to the power of which base 2 is raised to get the interval in seconds for sending announce messages. The value range for the interval argument is 0 to 6; When the PTP profile is SMPTE ST 2059-2, the value range for the interval argument is –3 to 1.
The master node uses the value configured on its interface as the interval for sending announce messages.
# Set the announce message sending interval to 4 (22) seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ptp announce-interval 2
ptp mode
ptp profile
ptp announce-timeout
Use ptp announce-timeout to set the timeout multiplier for the announce message receiving interval.
Use undo ptp announce-timeout to restore the default.
ptp announce-timeout multiple-value
The timeout multiplier for the announce message receiving interval is 3.
multiple-value: Sets the timeout multiplier for the announce message receiving interval, in the range of 2 to 10.
A master node periodically sends announce messages to the member nodes.
· IEEE 1588 version 2, SMPTE ST 2059-2—If a member node does not receive any announce message from the master node within multiple-value times the announce message sending interval, it determines that the master node is invalid.
You can configure this command only after you have specified a PTP profile, PTP mode, and PTP domain for the device.
To ensure a stable PTP network, set the timeout multiplier for receiving announce messages to a value in the range of 5 to 7..
# Set the timeout multiplier for the announce message sending interval to 5 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ptp announce-timeout 5
ptp mode
ptp profile
ptp asymmetry-correction
Use ptp asymmetry-correction to set the asymmetric delay correction time.
Use undo ptp asymmetry-correction to restore the default.
ptp asymmetry-correction { minus | plus } value
The asymmetric delay correction time is 0 nanoseconds, which means that delay correction is not performed.
minus: Subtracts the specified asymmetric delay correction value.
plus: Adds the specified asymmetric delay correction value.
value: Specifies the asymmetric delay correction value in the range of 0 to 2000000 nanoseconds.
# Set the asymmetric delay correction time to 100 nanoseconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ptp asymmetry-correction plus 100
ptp mode
ptp profile
ptp clock-step
Use ptp clock-step to configure the mode for carrying timestamps.
Use undo ptp clock-step to restore the default.
ptp clock-step { one-step | two-step }
undo ptp clock-step
The two-step mode is used for carrying timestamps.
one-step: Specifies the single-step mode.
two-step: Specifies the two-step mode.
You can configure this command only after you have specified a PTP profile and PTP mode.
GigabitEthernet 1/0/1 to GigabitEthernet 1/0/16 on the IE4320-28P switch support only the two-step timestamp-carrying mode. GigabitEthernet 1/0/17 to GigabitEthernet 1/0/24 on the IE4320-28P switch support both the single-step and two-step timestamp-carrying modes.
All interfaces on the IE4300-28P-M switch support both the single-step and two-step timestamp-carrying modes.
# Configure the two-step timestamp-carrying mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ptp clock-step two-step
ptp mode
ptp profile
ptp delay-mechanism
Use ptp delay-mechanism to specify a delay measurement mechanism for a BC or an OC.
Use undo ptp delay-mechanism to restore the default.
ptp delay-mechanism { e2e | p2p }
The request-response delay mechanism applies.
e2e: Specifies the request-response mechanism used by E2ETC.
p2p: Specifies the peer delay mechanism used by P2PTC.
This command is applicable only to BCs and OCs.
GigabitEthernet1/0/1 to GigabitEthernet1/0/16 on the IE4320-28P switch do not support the peer delay measurement mechanism.
# Specify the OC clock node type. Specify the request-response delay mechanism (e2e) on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ptp delay-mechanism e2e
ptp mode
ptp profile
ptp destination-mac
Use ptp destination-mac to configure the destination MAC address for non-peer delay messages.
Use undo ptp destination-mac to restore the default.
ptp destination-mac mac-address
The destination MAC address for non-peer delay messages is 011B-1900-0000.
mac-address: Specifies the destination MAC address for non-peer delay messages as 0180-C200-000E or 011B-1900-0000.
This command is available only after you specify a PTP profile and a PTP mode. The SMPTE ST 2059-2 profile does not support this command.
Peer delay messages include Pdelay_Req, Pdelay_Resp, and Pdelay_Resp_Follow_Up messages. The destination MAC address for peer delay messages is 0180-C200-000E, which cannot be modified.
This command takes effect only if PTP messages are encapsulated in IEEE 802.3/Ethernet packets.
# Configure the destination MAC address for non-peer delay messages as 0180-C200-000E on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ptp destination-mac 0180-c200-000e
ptp mode
ptp profile
ptp domain
Use ptp domain to specify a PTP domain.
Use undo ptp domain to restore the default.
ptp domain domain-number
undo ptp domain
The PTP domain depends on the PTP profile.
· When the PTP profile is IEEE 1588 version 2, the device belongs to PTP domain 0.
· When the PTP profile is SMPTE ST 2059-2, the device belongs to PTP domain 127.
domain-number: Specifies a PTP domain by its domain number. The value range for the domain-number argument is 0 to 255; When the PTP profile is SMPTE ST 2059-2, the value range for the domain-number argument is 0 to 127.
# Configure the PTP domain number to use for the device as 2.
[Sysname] ptp domain 2
ptp mode
ptp profile
ptp source
ptp dscp
Use ptp dscp to set a DSCP value for PTP messages that are transmitted over UDP (IPv4).
Use undo ptp dscp to restore the default.
ptp dscp dscp
undo ptp dscp
The DSCP value is 56 for PTP messages that are transmitted over UDP (IPv4).
dscp: Sets a DSCP value in the range of 0 to 63 for PTP messages.
This command takes effect only if PTP messages are transmitted over UDP (IPv4).
# Set the DSCP value to 63 for PTP messages transmitted over UDP (IPv4) on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ptp transport-protocol udp
[Sysname-GigabitEthernet1/0/1] ptp dscp 63
ptp mode
ptp profile
ptp enable
Use ptp enable to enable PTP.
Use undo ptp enable to disable PTP.
ptp enable
undo ptp enable
PTP is disabled.
An OC can have only one PTP port.
As a best practice, enable PTP on an interface after you configure PTP parameters.
For PTP to take effect on a Layer 2 Ethernet interface, enable PTP on that interface and make sure the VLAN to which that interface belongs is not bound to any VPN instance (the ip binding command is not configured on that interface).
After PTP is enabled on an interface, the system takes the EtherType field value of 0x88b5 as the PTP timestamp flag. Ethernet frames with the EtherType field value of 0x88b5 will be sent to CPU directly for processing and might fail to be forwarded.
# Configure the OC clock node type, and enable PTP on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ptp enable
# Configure the E2ETC clock node type, and enable PTP on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
[Sysname] ptp mode e2etc
[Sysname-GigabitEthernet1/0/1] interface gigabitethernet 1/0/2
[Sysname-GigabitEthernet1/0/2] ptp enable
ptp mode
ptp profile
ptp force-state
Use ptp force-state to configure a role for a PTP port.
Use undo ptp force-state to restore the default.
ptp force-state { master | passive | slave }
The PTP port role is automatically calculated by BMC.
master: Specifies the PTP port as a master port.
passive: Specifies the PTP port as a passive port.
slave: Specifies the PTP port as a subordinate port.
You can configure only one subordinate port for a device.
By default, the PTP port roles are automatically negotiated based on the BMC algorithm. If you use this command to change the role of one PTP port, all the other PTP ports in the PTP domain stop working. For these PTP ports to function, you must specify a role for each of them by using this command. As a best practice, enable automatic negotiation of PTP port roles based on the BMC algorithm.
# Configure the OC clock node type. Specify the PTP port GigabitEthernet 1/0/1 as a subordinate port.
[Sysname-GigabitEthernet1/0/1] ptp force-state slave
ptp mode
ptp profile
ptp slave-only
ptp min-delayreq-interval
Use ptp min-delayreq-interval to set the minimum interval for sending delay request messages.
Use undo ptp min-delayreq-interval to restore the default.
ptp min-delayreq-interval interval
The minimum interval for sending delay request messages is 1 (20) second.
interval: Specifies an exponent, to the power of which base 2 is raised to get the interval in seconds for sending delay request messages. When the PTP profile is IEEE 1588 version 2, the value range for the interval argument is –4 to 6. When the PTP profile is SMPTE ST 2059-2, the value range for the interval argument is –5 to 4.
When a member clock receives a Sync message, it responds by sending a Delay_Req message and starts a timer defined by this command. The member clock will not send another Delay_Req message until it receives a Sync message after the timer expires.
In PTP multicast transport mode, this command takes effect only when configured on the master clock. The master clock sends the value to a member clock through PTP messages to control the interval for the member clock to send Delay_Req messages. To view the interval, execute the display ptp interface command on the member clock.
In PTP unicast transport mode, this command takes effect when configured on member clocks. It does not take effect when configured on the master clock.
When the PTP profile is SMPTE ST 2059-2, set the interval argument to a value in the range of ptp syn-interval interval to ptp syn-interval interval plus 5 as a best practice.
# Set the minimum interval to 4 (22) seconds for sending delay request messages on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ptp min-delayreq-interval 2
ptp mode
ptp profile
ptp syn-interval
ptp mode
Use ptp mode to specify a clock node type for the device.
Use undo ptp mode to restore the default.
ptp mode { bc | e2etc | e2etc-oc | oc | p2ptc | p2ptc-oc }
undo ptp mode
No clock node type is specified.
bc: Specifies the clock node type as boundary clock (BC).
e2etc: Specifies the clock node type as end-to-end transparent clock (E2ETC).
e2etc-oc: Specifies the clock node type as E2ETC+OC.
oc: Specifies the clock node type as ordinary clock (OC).
p2ptc: Specifies the clock node type as peer-to-peer transparent clock (P2PTC).
p2ptc-oc: Specifies the clock node type as P2PTC+OC.
CAUTION: If you change the clock node type for the device, all settings except for the PTP profile will be removed. |
This command is available only after you specify a PTP profile.
When the PTP profile is SMPTE ST 2059-2, you cannot specify the E2ETC+OC or P2PTC+OC clock node type.
GigabitEthernet 1/0/1 to GigabitEthernet 1/0/16 on the IE4320-28P switch do not support the P2PTC or P2PTC+OC clock node type.
# Specify the OC clock node type for the device.
ptp profile
ptp pdelay-req-interval
Use ptp pdelay-req-interval to set the interval for sending peer delay request messages.
Use undo ptp pdelay-req-interval to restore the default.
ptp pdelay-req-interval interval
The interval for sending peer delay request messages is 1 (20) second.
interval: Specifies an exponent, to the power of which base 2 is raised to get the interval in seconds for sending peer delay request messages. When the PTP profile is IEEE 1588 version 2, the value range for the interval argument is 0 to 5. When the PTP profile is SMPTE ST 2059-2, the value range for the interval argument is –5 to 4.
# Set the interval to 4 (22) seconds for sending peer delay request messages on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ptp pdelay-req-interval 2
ptp mode
ptp profile
ptp syn-interval
ptp port-mode
Use ptp port-mode to configure the port type as OC for a TC+OC (including E2ETC+OC and P2PTC+OC) clock.
Use undo ptp port-mode to restore the default.
ptp port-mode oc
undo ptp port-mode
The type of all ports on an E2ETC+OC or a P2PTC+OC clock is TC.
oc: Specifies the port type for a TC+OC clock as OC.
This command is applicable only to E2ETC+OC and P2PTC+OC clocks and is available only after you specify a PTP profile and a PTP mode.
The SMPTE ST 2059-2 PTP profiles does not support this command.
# Specify the clock node type as P2PTC+OC for the device. Configure the port type for GigabitEthernet 1/0/1 as OC.
[Sysname] ptp mode p2ptc-oc
[Sysname-GigabitEthernet1/0/1] ptp port-mode oc
ptp mode
ptp profile
ptp priority
Use ptp priority clock-source to configure the priority for the specified clock for GM election through BMC.
Use undo ptp priority clock-source to restore the specified priority to its default value.
ptp priority clock-source local { priority1 priority1 | priority2 priority2 }
undo ptp priority clock-source local { priority1 | priority2 }
The values of priority 1 and priority 2 are both 128.
local: Specifies the local clock.
priority1 priority1: Specifies priority 1 for the clock, in the range of 0 to 255. A numerically smaller value has higher priority.
priority2 priority2: Specifies priority 2 for the clock, in the range of 0 to 255. A numerically smaller value has higher priority.
# Configure priority 1 as 10 for the local clock.
[Sysname] ptp priority clock-source local priority1 10
ptp mode
ptp profile
ptp profile
Use ptp profile to specify the IEEE 1588 version 2 PTP profile for the device.
Use undo ptp profile to restore the default.
ptp profile { 1588v2 | st2059-2 }
undo ptp profile
No PTP profile is configured and PTP is not running on the device.
1588v2: Specifies the IEEE 1588 version 2 PTP profile.
st2059-2: Specifies the SMPTE ST 2059-2 PTP profile.
Configure a PTP profile for the device before any other PTP configurations.
If you change or remove a PTP profile, PTP functions do not operate and all the configurations for that PTP profile will be removed.
# Configure the PTP profile as IEEE 1588 version 2.
ptp slave-only
Use ptp slave-only to configure the OC to operate only as a member clock.
Use undo ptp slave-only to restore the default.
ptp slave-only
undo ptp slave-only
An OC can operate either as a master clock or a member clock.
This command is applicable only to OCs and is available only after you specify a PTP profile and a PTP mode.
You can execute the ptp force-state command to specify a subordinate port as a master port or passive port even if the OC operates as a member clock.
# Specify the clock node type as OC for the device. Configure the OC to operate only as a member clock.
[Sysname] ptp slave-only
ptp force-state
ptp mode
ptp profile
ptp source
Use ptp source to configure the source IP address for multicast PTP message transmission over UDP (IPv4).
Use undo ptp source to remove the specified source IP address for multicast PTP message transmission over UDP (IPv4).
ptp source ip-address [ vpn-instance vpn-instance-name ]
undo ptp source ip-address [ vpn-instance vpn-instance-name ]
No source IP address is configured for multicast PTP message transmission over UDP (IPv4).
ip-address: Specifies the source IP address for multicast PTP message transmission over UDP (IPv4).
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance used for communication between the local device and the peer device. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the peer device belongs to the public network, do not specify this option.
This command takes effect only when PTP messages are transmitted over IPv4 UDP in multicast mode.
# Configure the source IP address as 3.5.1.5 for multicast PTP messages.
[Sysname] ptp source 3.5.1.5
ptp mode
ptp profile
ptp syn-interval
Use ptp syn-interval to set the interval for sending Sync messages.
Use undo ptp syn-interval to restore the default.
When the PTP profile is IEEE 1588 version 2, the interval argument value is 0 and the interval for sending Sync messages is 1 (20) second.
When the PTP profile is SMPTE ST 2059-2, the interval argument value is –3 and the interval for sending Sync messages is 1/8 (2-3) seconds.
interval: Specifies an exponent, to the power of which base 2 is raised to get the interval in seconds for sending Sync messages. When the PTP profile is IEEE 1588 version 2, the value range for the interval argument is -1 to 1. When the PTP profile is SMPTE ST 2059-2, the value range for the interval argument is –5 to –1.
# Set the Sync message sending interval to 2 (21) seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ptp syn-interval 1
ptp mode
ptp profile
Use ptp transport-protocol to configure UDP transport protocol over IPv4 for PTP messages.
Use undo ptp transport-protocol to restore the default.
PTP messages are transported through IEEE 802.3 and Ethernet.
udp: Specifies the UDP over IPv4 transmit protocol for PTP messages.
This command is available only after you specify a PTP profile and a PTP mode. This command is not available for the SMPTE ST 2059-2 PTP profile.
# Configure UDP transport protocol over IPv4 for PTP messages on GigabitEthernet 1/0/1.
ptp mode
ptp profile
ptp utc
Use ptp utc to set the correction date for the UTC.
Use undo ptp utc to remove the correction date configured for the UTC.
ptp utc { leap59-date | leap61-date } date
undo ptp utc { leap59-date | leap61-date }
No correction date is configured for the UTC.
leap59-date: Adjusts the UTC at the last minute (23:59) of the specified date so that the UTC is one second slower than the TAI.
leap61-date: Adjusts the UTC at the last minute (23:59) of the specified date so that the UTC is one second faster than the TAI.
date: Sets the date to adjust the UTC, in the format of YYYY/MM/DD. The value range for YYYY and MM is 2000 to 2035 and 1 to 12, respectively. The value range for DD depends on the specified month. For the configuration to take effect, do not specify a date earlier than the current date.
This command takes effect only when it is configured on the master clock node and the local clock of the master clock node is the GM.
Specify either the leap59-date or leap61-date keyword in this command. If you execute this command multiple times, the most recent configuration takes effect.
# Assume the current date is August 8, 2010. Specify the clock node type as BC for the device. Adjust the UTC at the last minute of December 31, 2010 so that the UTC is one second slower than the TAI.
[Sysname] ptp mode bc
[Sysname] ptp utc leap59-date 2010/12/31
ptp mode
ptp profile
ptp utc offset
Use ptp utc offset to set the cumulative offset between the UTC and TAI.
Use undo ptp utc offset to restore the default.
ptp utc offset utc-offset
undo ptp utc offset
The cumulative offset between the UTC and TAI is 0 seconds.
utc-offset: Sets the cumulative offset between the UTC and TAI, in seconds. The utc-offset argument is in the range of 0 to 999.
A time difference exists between UTC and TAI. Internet devices typically use the UTC time. To provide more accurate time, PTP also uses TAI. If the device acts as a subordinate clock node, it uses the UTC time and TAI time of the clock reference. If the device acts as the clock reference, it will calculate the TAI time based on the UTC time, and synchronize the UTC and TAI time to the subordinate clocks. TAI provided by the device = Current UTC + cumulative offset.
BIPM periodically publishes the cumulative offset of UTC relative to TAI. Use the value published by BIPM to configure this command.
You can configure this command only after you have specified a PTP profile and PTP mode for the device.
# Set the cumulative offset to 37 seconds between the UTC and TAI.
[Sysname] ptp utc offset 37
ptp mode
ptp profile
ptp vlan
Use ptp vlan to specify a VLAN tag for PTP messages.
Use undo ptp vlan to restore the default.
ptp vlan vlan-id [ dot1p dot1p-value ]
undo ptp vlan [ dot1p ]
PTP messages do not have a VLAN tag.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094..
dot1p dot1p-value: Specifies an 802.1p precedence for PTP messages, in the range of 0 to 7. The default 802.1p precedence is 7 (the highest).
# Specify VLAN 2 and set the 802.1p precedence to 6 for PTP messages.
[Sysname-GigabitEthernet1/0/1] ptp vlan 2 dot1p 6
ptp mode
ptp profile
reset ptp statistics
Use reset ptp statistics to clear PTP statistics.
reset ptp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears PTP statistics on all interfaces.
# Clear PTP statistics on GigabitEthernet 1/0/1.
<Sysname> reset ptp statistics interface gigabitethernet 1/0/1
