- 11-NMM Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-PoE commands
- 05-SNMP commands
- 06-RMON commands
- 07-NETCONF commands
- 08-CWMP commands
- 09-EAA commands
- 10-Process monitoring and maintenance commands
- 11-Mirroring commands
- 12-sFlow commands
- 13-Information center commands
- 14-PTP commands
- 15-Network synchronization commands
| 00-Preface | 102.05 KB |
Preface
This command reference describes the network management and monitoring configuration commands. It covers the commands for viewing system information, collecting traffic statistics, assessing the network performance, synchronizing time for all devices with clocks in your network, and checking and debugging the current network connectivity with the ping, tracert, and debug commands.
· Audience
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
